root/Development/ray/src/gen/replmarks.c
Sat Jun 7 05:09:45 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.22: +1 -2 lines
Diff to previous 2.22 , to selected 2.2
Tue Jun 3 21:31:51 2025 UTC (3 months, 4 weeks ago) by greg
Changes since 2.21: +2 -4 lines
Diff to previous 2.21 , to selected 2.2
Wed Apr 23 01:57:04 2025 UTC (5 months, 1 week ago) by greg
Changes since 2.20: +9 -10 lines
Diff to previous 2.20 , to selected 2.2
fix: Functio prototypes and other fixes to reduce compiler warnings
Tue Apr 22 14:51:29 2025 UTC (5 months, 1 week ago) by greg
Changes since 2.19: +3 -5 lines
Diff to previous 2.19 , to selected 2.2
fix: Changed some errors to warnings for pclose()
Tue Apr 22 04:45:25 2025 UTC (5 months, 1 week ago) by greg
Changes since 2.18: +7 -2 lines
Diff to previous 2.18 , to selected 2.2
fix: Added check to return value of pclose() in several tools
Fri Feb 12 00:53:56 2021 UTC (4 years, 7 months ago) by greg
Changes since 2.17: +4 -6 lines
refactor: Created comparison macros for RREAL and FVECT types
Tue Feb 2 18:02:32 2016 UTC (9 years, 8 months ago) by greg
Thu Mar 6 00:47:37 2014 UTC (11 years, 7 months ago) by greg
Changed to calling asin() for safety
Fri Jan 25 02:11:13 2008 UTC (17 years, 8 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Changes since 2.14: +9 -1 lines
Wed Dec 28 18:35:42 2005 UTC (19 years, 9 months ago) by greg
Changes since 2.13: +9 -5 lines
Thu Mar 17 06:38:45 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.12: +7 -5 lines
Increased maximum number of markers from 32 to 128 and added error check
Tue Sep 28 17:54:18 2004 UTC (21 years ago) by greg
Thu Jan 29 22:20:31 2004 UTC (21 years, 8 months ago) by greg
Changes since 2.10: +17 -7 lines
Fri Jan 2 17:11:40 2004 UTC (21 years, 9 months ago) by greg
Removed outdated -e option sent to xform command
Sun Nov 16 10:29:38 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.8: +57 -30 lines
Mon Oct 27 10:27:25 2003 UTC (21 years, 11 months ago) by schorsch
Various compatibility fixes.
Sun Jun 8 12:03:10 2003 UTC (22 years, 4 months ago) by schorsch
Mon Mar 10 17:26:26 2003 UTC (22 years, 6 months ago) by greg
Compile fixes for Linux
Sat Feb 22 02:07:24 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.4: +13 -17 lines
Fri Jan 16 10:48:23 1998 UTC (27 years, 8 months ago) by gregl
changed M_PI definition to ward off long double problems
Mon Aug 2 14:29:31 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +4 -0 lines
Added conditional declaration of atof()
Tue Mar 3 21:30:03 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +69 -51 lines
added ability to accept multiple mark modifiers
Tue Nov 12 17:04:51 1991 UTC (33 years, 10 months ago) by greg
Mon Feb 18 13:45:12 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.1: +29 -11 lines
added -m option to xform
Sun Feb 17 22:36:30 1991 UTC (34 years, 7 months ago) by greg
Diff to selected 2.2
