1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: mksource.c,v 2.2 2005/07/30 17:01:30 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Generate distant sources corresponding to the given environment map |
6 |
7 |
8 |
#include "ray.h" |
9 |
#include "random.h" |
10 |
#include "resolu.h" |
11 |
12 |
#define NTRUNKBR 4 /* number of branches at trunk */ |
13 |
#define NTRUNKVERT 4 /* number of vertices at trunk */ |
14 |
#define DEF_NSAMPS 262144L /* default # sphere samples */ |
15 |
#define DEF_MAXANG 15. /* maximum source angle (deg.) */ |
16 |
17 |
/* Data structure for geodesic samples */ |
18 |
19 |
typedef struct tritree { |
20 |
FVECT gdv[3]; /* spherical triangle vertex direc. */ |
21 |
FVECT sd; /* sample direction if leaf */ |
22 |
struct tritree *kid; /* 4 children if branch node */ |
23 |
COLR val; /* sampled color value */ |
24 |
} TRITREE; |
25 |
26 |
typedef struct lostlight { |
27 |
struct lostlight *next; /* next in list */ |
28 |
FVECT sd; /* lost source direction */ |
29 |
COLOR intens; /* output times solid angle */ |
30 |
} LOSTLIGHT; |
31 |
32 |
char *progname; |
33 |
34 |
FVECT scene_cent; /* center of octree cube */ |
35 |
RREAL scene_rad; /* radius to get outside cube from center */ |
36 |
37 |
const COLR blkclr = BLKCOLR; |
38 |
39 |
#define isleaf(node) ((node)->kid == NULL) |
40 |
41 |
/* Compute signum of signed volume for three vectors */ |
42 |
int |
43 |
vol_sign(const FVECT v1, const FVECT v2, const FVECT v3) |
44 |
45 |
double vol; |
46 |
47 |
vol = v1[0]*(v2[1]*v3[2] - v2[2]*v3[1]); |
48 |
vol += v1[1]*(v2[2]*v3[0] - v2[0]*v3[2]); |
49 |
vol += v1[2]*(v2[0]*v3[1] - v2[1]*v3[0]); |
50 |
if (vol > .0) |
51 |
return(1); |
52 |
if (vol < .0) |
53 |
return(-1); |
54 |
return(0); |
55 |
56 |
57 |
/* Is the given direction contained within the specified spherical triangle? */ |
58 |
int |
59 |
intriv(FVECT tri[3], const FVECT sdir) |
60 |
61 |
int sv[3]; |
62 |
63 |
sv[0] = vol_sign(sdir, tri[0], tri[1]); |
64 |
sv[1] = vol_sign(sdir, tri[1], tri[2]); |
65 |
sv[2] = vol_sign(sdir, tri[2], tri[0]); |
66 |
if ((sv[0] == sv[1]) & (sv[1] == sv[2])) |
67 |
return(1); |
68 |
return(!sv[0] | !sv[1] | !sv[2]); |
69 |
70 |
71 |
/* Find leaf containing the given sample direction */ |
72 |
TRITREE * |
73 |
findleaf(TRITREE *node, const FVECT sdir) |
74 |
75 |
int i; |
76 |
77 |
if (isleaf(node)) |
78 |
return(intriv(node->gdv,sdir) ? node : (TRITREE *)NULL); |
79 |
for (i = 0; i < 4; i++) { |
80 |
TRITREE *chknode = &node->kid[i]; |
81 |
if (intriv(chknode->gdv, sdir)) |
82 |
return(isleaf(chknode) ? chknode : |
83 |
findleaf(chknode, sdir)); |
84 |
85 |
return(NULL); |
86 |
87 |
88 |
/* Initialize leaf with random sample inside the given spherical triangle */ |
89 |
void |
90 |
leafsample(TRITREE *leaf) |
91 |
92 |
RAY myray; |
93 |
RREAL wt[3]; |
94 |
int i, j; |
95 |
/* random point on triangle */ |
96 |
i = random() % 3; |
97 |
wt[i] = frandom(); |
98 |
j = random() & 1; |
99 |
wt[(i+2-j)%3] = 1. - wt[i] - |
100 |
(wt[(i+1+j)%3] = (1.-wt[i])*frandom()); |
101 |
leaf->sd[0] = leaf->sd[1] = leaf->sd[2] = .0; |
102 |
for (i = 0; i < 3; i++) |
103 |
VSUM(leaf->sd, leaf->sd, leaf->gdv[i], wt[i]); |
104 |
normalize(leaf->sd); /* record sample direction */ |
105 |
/* evaluate at inf. */ |
106 |
VSUM(myray.rorg, scene_cent, leaf->sd, scene_rad); |
107 |
VCOPY(myray.rdir, leaf->sd); |
108 |
myray.rmax = 0.; |
109 |
ray_trace(&myray); |
110 |
setcolr(leaf->val, colval(myray.rcol,RED), |
111 |
colval(myray.rcol,GRN), |
112 |
colval(myray.rcol,BLU)); |
113 |
114 |
115 |
/* Initialize a branch node contained in the given spherical triangle */ |
116 |
void |
117 |
subdivide(TRITREE *branch, FVECT dv[3]) |
118 |
119 |
FVECT sdv[3]; |
120 |
int i; |
121 |
122 |
for (i = 0; i < 3; i++) /* copy spherical triangle */ |
123 |
VCOPY(branch->gdv[i], dv[i]); |
124 |
for (i = 0; i < 3; i++) { /* create new vertices */ |
125 |
int j = (i+1)%3; |
126 |
VADD(sdv[i], dv[i], dv[j]); |
127 |
normalize(sdv[i]); |
128 |
129 |
/* allocate leaves */ |
130 |
branch->kid = (TRITREE *)calloc(4, sizeof(TRITREE)); |
131 |
if (branch->kid == NULL) |
132 |
error(SYSTEM, "out of memory in subdivide()"); |
133 |
/* assign subtriangle directions */ |
134 |
VCOPY(branch->kid[0].gdv[0], dv[0]); |
135 |
VCOPY(branch->kid[0].gdv[1], sdv[0]); |
136 |
VCOPY(branch->kid[0].gdv[2], sdv[2]); |
137 |
VCOPY(branch->kid[1].gdv[0], sdv[0]); |
138 |
VCOPY(branch->kid[1].gdv[1], dv[1]); |
139 |
VCOPY(branch->kid[1].gdv[2], sdv[1]); |
140 |
VCOPY(branch->kid[2].gdv[0], sdv[1]); |
141 |
VCOPY(branch->kid[2].gdv[1], dv[2]); |
142 |
VCOPY(branch->kid[2].gdv[2], sdv[2]); |
143 |
VCOPY(branch->kid[3].gdv[0], sdv[0]); |
144 |
VCOPY(branch->kid[3].gdv[1], sdv[1]); |
145 |
VCOPY(branch->kid[3].gdv[2], sdv[2]); |
146 |
147 |
148 |
/* Recursively subdivide the given node to the specified quadtree depth */ |
149 |
void |
150 |
branchsample(TRITREE *node, int depth) |
151 |
152 |
int i; |
153 |
154 |
if (depth <= 0) |
155 |
return; |
156 |
if (isleaf(node)) { /* subdivide leaf node */ |
157 |
TRITREE branch, *moved_leaf; |
158 |
subdivide(&branch, node->gdv); |
159 |
moved_leaf = findleaf(&branch, node->sd); |
160 |
if (moved_leaf != NULL) { /* bequeath old sample */ |
161 |
VCOPY(moved_leaf->sd, node->sd); |
162 |
copycolr(moved_leaf->val, node->val); |
163 |
164 |
for (i = 0; i < 4; i++) /* compute new samples */ |
165 |
if (&branch.kid[i] != moved_leaf) |
166 |
leafsample(&branch.kid[i]); |
167 |
*node = branch; /* replace leaf with branch */ |
168 |
169 |
for (i = 0; i < 4; i++) /* subdivide children */ |
170 |
branchsample(&node->kid[i], depth-1); |
171 |
172 |
173 |
/* Sample sphere using triangular geodesic mesh */ |
174 |
TRITREE * |
175 |
geosample(int nsamps) |
176 |
177 |
int depth; |
178 |
TRITREE *tree; |
179 |
FVECT trunk[NTRUNKVERT]; |
180 |
int i, j; |
181 |
/* figure out depth */ |
182 |
if ((nsamps -= 4) < 0) |
183 |
error(USER, "minimum number of samples is 4"); |
184 |
nsamps = nsamps*3/NTRUNKBR; /* round up */ |
185 |
for (depth = 0; nsamps > 1; depth++) |
186 |
nsamps >>= 2; |
187 |
/* make base tetrahedron */ |
188 |
tree = (TRITREE *)malloc(sizeof(TRITREE)); |
189 |
if (tree == NULL) goto memerr; |
190 |
trunk[0][0] = trunk[0][1] = 0; trunk[0][2] = 1; |
191 |
trunk[1][0] = 0; |
192 |
trunk[1][2] = cos(2.*asin(sqrt(2./3.))); |
193 |
trunk[1][1] = sqrt(1. - trunk[1][2]*trunk[1][2]); |
194 |
spinvector(trunk[2], trunk[1], trunk[0], 2.*PI/3.); |
195 |
spinvector(trunk[3], trunk[1], trunk[0], 4.*PI/3.); |
196 |
VCOPY(tree->gdv[0], trunk[0]); |
197 |
VCOPY(tree->gdv[1], trunk[0]); |
198 |
VCOPY(tree->gdv[2], trunk[0]); |
199 |
tree->kid = (TRITREE *)calloc(NTRUNKBR, sizeof(TRITREE)); |
200 |
if (tree->kid == NULL) goto memerr; |
201 |
/* grow our tree from trunk */ |
202 |
for (i = 0; i < NTRUNKBR; i++) { |
203 |
for (j = 0; j < 3; j++) /* XXX works for tetra only */ |
204 |
VCOPY(tree->kid[i].gdv[j], trunk[(i+j)%NTRUNKVERT]); |
205 |
leafsample(&tree->kid[i]); |
206 |
branchsample(&tree->kid[i], depth); |
207 |
208 |
return(tree); |
209 |
memerr: |
210 |
error(SYSTEM, "out of memory in geosample()"); |
211 |
return NULL; /* dummy return */ |
212 |
213 |
214 |
/* Compute leaf exponent histogram */ |
215 |
void |
216 |
get_ehisto(const TRITREE *node, long exphisto[256]) |
217 |
218 |
int i; |
219 |
220 |
if (isleaf(node)) { |
221 |
++exphisto[node->val[EXP]]; |
222 |
return; |
223 |
224 |
for (i = 0; i < 4; i++) |
225 |
get_ehisto(&node->kid[i], exphisto); |
226 |
227 |
228 |
/* Get reasonable source threshold */ |
229 |
double |
230 |
get_threshold(const TRITREE *tree) |
231 |
232 |
long exphisto[256]; |
233 |
long samptotal; |
234 |
int i; |
235 |
/* compute sample histogram */ |
236 |
memset((void *)exphisto, 0, sizeof(exphisto)); |
237 |
for (i = 0; i < NTRUNKBR; i++) |
238 |
get_ehisto(&tree->kid[i], exphisto); |
239 |
/* use 98th percentile */ |
240 |
for (i = 0; i < 256; i++) |
241 |
samptotal += exphisto[i]; |
242 |
samptotal /= 50; |
243 |
for (i = 256; (--i > 0) & (samptotal > 0); ) |
244 |
samptotal -= exphisto[i]; |
245 |
return(ldexp(.75, i-COLXS)); |
246 |
247 |
248 |
/* Find leaf containing the maximum exponent */ |
249 |
TRITREE * |
250 |
findemax(TRITREE *node, int *expp) |
251 |
252 |
if (!isleaf(node)) { |
253 |
TRITREE *maxleaf; |
254 |
TRITREE *rleaf; |
255 |
maxleaf = findemax(&node->kid[0], expp); |
256 |
rleaf = findemax(&node->kid[1], expp); |
257 |
if (rleaf != NULL) maxleaf = rleaf; |
258 |
rleaf = findemax(&node->kid[2], expp); |
259 |
260 |
rleaf = findemax(&node->kid[3], expp); |
261 |
262 |
return(maxleaf); |
263 |
264 |
if (node->val[EXP] <= *expp) |
265 |
return(NULL); |
266 |
*expp = node->val[EXP]; |
267 |
return(node); |
268 |
269 |
270 |
/* Compute solid angle of spherical triangle (approx.) */ |
271 |
double |
272 |
tri_omegav(FVECT v[3]) |
273 |
274 |
FVECT e1, e2, vcross; |
275 |
276 |
VSUB(e1, v[1], v[0]); |
277 |
VSUB(e2, v[2], v[1]); |
278 |
fcross(vcross, e1, e2); |
279 |
return(.5*VLEN(vcross)); |
280 |
281 |
282 |
/* Sum intensity times direction for non-zero leaves */ |
283 |
void |
284 |
vector_sum(FVECT vsum, TRITREE *node, |
285 |
const FVECT cent, double mincos, int ethresh) |
286 |
287 |
288 |
double intens; |
289 |
if (node->val[EXP] < ethresh) |
290 |
return; |
291 |
if (DOT(node->sd,cent) < mincos) |
292 |
return; |
293 |
intens = colrval(node->val,GRN) * tri_omegav(node->gdv); |
294 |
VSUM(vsum, vsum, node->sd, intens); |
295 |
return; |
296 |
297 |
if (DOT(node->gdv[0],node->gdv[1]) < mincos && |
298 |
DOT(node->gdv[0],cent) > mincos && |
299 |
DOT(node->gdv[1],cent) > mincos && |
300 |
DOT(node->gdv[2],cent) > mincos) |
301 |
return; |
302 |
vector_sum(vsum, &node->kid[0], cent, mincos, ethresh); |
303 |
vector_sum(vsum, &node->kid[1], cent, mincos, ethresh); |
304 |
vector_sum(vsum, &node->kid[2], cent, mincos, ethresh); |
305 |
vector_sum(vsum, &node->kid[3], cent, mincos, ethresh); |
306 |
307 |
308 |
/* Claim source contributions within the given solid angle */ |
309 |
void |
310 |
claimlight(COLOR intens, TRITREE *node, const FVECT cent, double mincos) |
311 |
312 |
int remaining; |
313 |
int i; |
314 |
if (isleaf(node)) { /* claim contribution */ |
315 |
COLOR contrib; |
316 |
if (node->val[EXP] <= 0) |
317 |
return; |
318 |
319 |
return; |
320 |
colr_color(contrib, node->val); |
321 |
scalecolor(contrib, tri_omegav(node->gdv)); |
322 |
addcolor(intens, contrib); |
323 |
copycolr(node->val, blkclr); |
324 |
return; |
325 |
326 |
327 |
328 |
329 |
330 |
return; |
331 |
remaining = 0; /* recurse on children */ |
332 |
333 |
claimlight(intens, &node->kid[i], cent, mincos); |
334 |
if (!isleaf(&node->kid[i]) || node->kid[i].val[EXP] != 0) |
335 |
++remaining; |
336 |
337 |
if (remaining) |
338 |
return; |
339 |
/* consolidate empties */ |
340 |
free((void *)node->kid); node->kid = NULL; |
341 |
342 |
VCOPY(node->sd, node->gdv[0]); /* doesn't really matter */ |
343 |
344 |
345 |
/* Add lost light contribution to the given list */ |
346 |
void |
347 |
add2lost(LOSTLIGHT **llp, COLOR intens, const FVECT cent) |
348 |
349 |
LOSTLIGHT *newll = (LOSTLIGHT *)malloc(sizeof(LOSTLIGHT)); |
350 |
351 |
if (newll == NULL) |
352 |
return; |
353 |
copycolor(newll->intens, intens); |
354 |
VCOPY(newll->sd, cent); |
355 |
newll->next = *llp; |
356 |
*llp = newll; |
357 |
358 |
359 |
/* Check lost light list for contributions */ |
360 |
void |
361 |
getlost(LOSTLIGHT **llp, COLOR intens, const FVECT cent, double omega) |
362 |
363 |
const double mincos = 1. - omega/(2.*PI); |
364 |
LOSTLIGHT lhead, *lastp, *thisp; |
365 |
366 |
lhead.next = *llp; |
367 |
lastp = &lhead; |
368 |
while ((thisp = lastp->next) != NULL) |
369 |
if (DOT(thisp->sd,cent) >= mincos) { |
370 |
LOSTLIGHT *mynext = thisp->next; |
371 |
addcolor(intens, thisp->intens); |
372 |
free((void *)thisp); |
373 |
lastp->next = mynext; |
374 |
} else |
375 |
lastp = thisp; |
376 |
*llp = lhead.next; |
377 |
378 |
379 |
/* Create & print distant sources */ |
380 |
void |
381 |
mksources(TRITREE *samptree, double thresh, double maxang) |
382 |
383 |
const int ethresh = (int)(log(thresh)/log(2.) + (COLXS+.5)); |
384 |
const double maxomega = 2.*PI*(1. - cos(PI/180./2.*maxang)); |
385 |
const double minintens = .05*thresh*maxomega; |
386 |
int nsrcs = 0; |
387 |
LOSTLIGHT *lostlightlist = NULL; |
388 |
int emax; |
389 |
TRITREE *startleaf; |
390 |
double growstep; |
391 |
FVECT curcent; |
392 |
double currad; |
393 |
double curomega; |
394 |
COLOR curintens; |
395 |
double thisthresh; |
396 |
int thisethresh; |
397 |
int i; |
398 |
399 |
* General algorithm: |
400 |
* 1) Start with brightest unclaimed pixel |
401 |
* 2) Grow source toward brightest unclaimed perimeter until: |
402 |
* a) Source exceeds maximum size, or |
403 |
* b) Perimeter values all below threshold, or |
404 |
* c) Source average drops below threshold |
405 |
* 3) Loop until nothing over threshold |
406 |
407 |
* Complexity added to absorb insignificant sources in larger ones. |
408 |
409 |
if (thresh <= FTINY) |
410 |
return; |
411 |
for ( ; ; ) { |
412 |
emax = ethresh; /* find brightest unclaimed */ |
413 |
startleaf = NULL; |
414 |
415 |
TRITREE *bigger = findemax(&samptree->kid[i], &emax); |
416 |
if (bigger != NULL) |
417 |
startleaf = bigger; |
418 |
419 |
if (startleaf == NULL) |
420 |
break; |
421 |
/* claim it */ |
422 |
VCOPY(curcent, startleaf->sd); |
423 |
curomega = tri_omegav(startleaf->gdv); |
424 |
currad = sqrt(curomega/PI); |
425 |
growstep = 3.*currad; |
426 |
colr_color(curintens, startleaf->val); |
427 |
thisthresh = .15*bright(curintens); |
428 |
if (thisthresh < thresh) thisthresh = thresh; |
429 |
thisethresh = (int)(log(thisthresh)/log(2.) + (COLXS+.5)); |
430 |
scalecolor(curintens, curomega); |
431 |
copycolr(startleaf->val, blkclr); |
432 |
do { /* grow source */ |
433 |
FVECT vsum; |
434 |
double movedist; |
435 |
vsum[0] = vsum[1] = vsum[2] = .0; |
436 |
437 |
vector_sum(vsum, &samptree->kid[i], |
438 |
curcent, cos(currad+growstep), |
439 |
thisethresh); |
440 |
if (normalize(vsum) == .0) |
441 |
break; |
442 |
movedist = acos(DOT(vsum,curcent)); |
443 |
if (movedist > growstep) { |
444 |
VSUB(vsum, vsum, curcent); |
445 |
movedist = growstep/VLEN(vsum); |
446 |
VSUM(curcent, curcent, vsum, movedist); |
447 |
normalize(curcent); |
448 |
} else |
449 |
VCOPY(curcent, vsum); |
450 |
currad += growstep; |
451 |
curomega = 2.*PI*(1. - cos(currad)); |
452 |
453 |
claimlight(curintens, &samptree->kid[i], |
454 |
curcent, cos(currad)); |
455 |
} while (curomega < maxomega && |
456 |
bright(curintens)/curomega > thisthresh); |
457 |
if (bright(curintens) < minintens) { |
458 |
add2lost(&lostlightlist, curintens, curcent); |
459 |
continue; |
460 |
461 |
/* absorb lost contributions */ |
462 |
getlost(&lostlightlist, curintens, curcent, curomega); |
463 |
++nsrcs; /* output source */ |
464 |
scalecolor(curintens, 1./curomega); |
465 |
printf("\nvoid illum IBLout\n"); |
466 |
printf("0\n0\n3 %f %f %f\n", |
467 |
colval(curintens,RED), |
468 |
colval(curintens,GRN), |
469 |
colval(curintens,BLU)); |
470 |
printf("\nIBLout source IBLsrc%d\n", nsrcs); |
471 |
printf("0\n0\n4 %f %f %f %f\n", |
472 |
curcent[0], curcent[1], curcent[2], |
473 |
2.*180./PI*currad); |
474 |
475 |
476 |
477 |
int |
478 |
main(int argc, char *argv[]) |
479 |
480 |
long nsamps = DEF_NSAMPS; |
481 |
double maxang = DEF_MAXANG; |
482 |
TRITREE *samptree; |
483 |
double thresh = 0; |
484 |
int i; |
485 |
486 |
progname = argv[0]; |
487 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
488 |
switch (argv[i][1]) { |
489 |
case 'd': /* number of samples */ |
490 |
if (i >= argc-1) goto userr; |
491 |
nsamps = atol(argv[++i]); |
492 |
break; |
493 |
case 't': /* manual threshold */ |
494 |
495 |
thresh = atof(argv[++i]); |
496 |
break; |
497 |
case 'a': /* maximum source angle */ |
498 |
499 |
maxang = atof(argv[++i]); |
500 |
if (maxang <= FTINY) |
501 |
goto userr; |
502 |
if (maxang > 180.) |
503 |
maxang = 180.; |
504 |
break; |
505 |
default: |
506 |
goto userr; |
507 |
508 |
if (i < argc-1) |
509 |
goto userr; |
510 |
/* start our ray calculation */ |
511 |
directvis = 0; |
512 |
ray_init(i == argc-1 ? argv[i] : (char *)NULL); |
513 |
VCOPY(scene_cent, thescene.cuorg); |
514 |
scene_cent[0] += 0.5*thescene.cusize; |
515 |
scene_cent[1] += 0.5*thescene.cusize; |
516 |
scene_cent[2] += 0.5*thescene.cusize; |
517 |
scene_rad = 0.86603*thescene.cusize; |
518 |
/* sample geodesic mesh */ |
519 |
samptree = geosample(nsamps); |
520 |
/* get source threshold */ |
521 |
522 |
thresh = get_threshold(samptree); |
523 |
/* done with ray samples */ |
524 |
ray_done(1); |
525 |
/* print header */ |
526 |
printf("# "); |
527 |
printargs(argc, argv, stdout); |
528 |
/* create & print sources */ |
529 |
mksources(samptree, thresh, maxang); |
530 |
/* all done, no need to clean up */ |
531 |
return(0); |
532 |
userr: |
533 |
fprintf(stderr, "Usage: %s [-d nsamps][-t thresh][-a maxang] [octree]\n", |
534 |
argv[0]); |
535 |
exit(1); |
536 |
537 |
538 |
void |
539 |
eputs(char *s) |
540 |
541 |
static int midline = 0; |
542 |
543 |
if (!*s) |
544 |
return; |
545 |
if (!midline++) { |
546 |
fputs(progname, stderr); |
547 |
fputs(": ", stderr); |
548 |
549 |
fputs(s, stderr); |
550 |
if (s[strlen(s)-1] == '\n') { |
551 |
fflush(stderr); |
552 |
midline = 0; |
553 |
554 |
555 |
556 |
void |
557 |
wputs(char *s) |
558 |
559 |
/* no warnings */ |
560 |
