| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Generate distant sources corresponding to the given environment map
| 6 |
| 7 |
| 8 |
#include "ray.h"
| 9 |
#include "random.h"
| 10 |
| 11 |
#define NTRUNKBR 4 /* number of branches at trunk */
| 12 |
#define NTRUNKVERT 4 /* number of vertices at trunk */
| 13 |
#define DEF_NSAMPS 262144L /* default # sphere samples */
| 14 |
#define DEF_MAXANG 15. /* maximum source angle (deg.) */
| 15 |
| 16 |
/* Data structure for geodesic samples */
| 17 |
| 18 |
typedef struct tritree {
| 19 |
FVECT gdv[3]; /* spherical triangle vertex direc. */
| 20 |
FVECT sd; /* sample direction if leaf */
| 21 |
struct tritree *kid; /* 4 children if branch node */
| 22 |
COLR val; /* sampled color value */
| 23 |
} TRITREE;
| 24 |
| 25 |
typedef struct lostlight {
| 26 |
struct lostlight *next; /* next in list */
| 27 |
FVECT sd; /* lost source direction */
| 28 |
COLOR intens; /* output times solid angle */
| 29 |
} LOSTLIGHT;
| 30 |
| 31 |
char *progname;
| 32 |
| 33 |
FVECT scene_cent; /* center of octree cube */
| 34 |
RREAL scene_rad; /* radius to get outside cube from center */
| 35 |
| 36 |
const COLR blkclr = BLKCOLR;
| 37 |
| 38 |
#define isleaf(node) ((node)->kid == NULL)
| 39 |
| 40 |
/* Compute signum of signed volume for three vectors */
| 41 |
int
| 42 |
vol_sign(const FVECT v1, const FVECT v2, const FVECT v3)
| 43 |
| 44 |
double vol;
| 45 |
| 46 |
vol = v1[0]*(v2[1]*v3[2] - v2[2]*v3[1]);
| 47 |
vol += v1[1]*(v2[2]*v3[0] - v2[0]*v3[2]);
| 48 |
vol += v1[2]*(v2[0]*v3[1] - v2[1]*v3[0]);
| 49 |
if (vol > .0)
| 50 |
return(1);
| 51 |
if (vol < .0)
| 52 |
return(-1);
| 53 |
return(0);
| 54 |
| 55 |
| 56 |
/* Is the given direction contained within the specified spherical triangle? */
| 57 |
int
| 58 |
intriv(FVECT tri[3], const FVECT sdir)
| 59 |
| 60 |
int sv[3];
| 61 |
| 62 |
sv[0] = vol_sign(sdir, tri[0], tri[1]);
| 63 |
sv[1] = vol_sign(sdir, tri[1], tri[2]);
| 64 |
sv[2] = vol_sign(sdir, tri[2], tri[0]);
| 65 |
if ((sv[0] == sv[1]) & (sv[1] == sv[2]))
| 66 |
return(1);
| 67 |
return(!sv[0] | !sv[1] | !sv[2]);
| 68 |
| 69 |
| 70 |
/* Find leaf containing the given sample direction */
| 71 |
TRITREE *
| 72 |
findleaf(TRITREE *node, const FVECT sdir)
| 73 |
| 74 |
int i;
| 75 |
| 76 |
if (isleaf(node))
| 77 |
return(intriv(node->gdv,sdir) ? node : (TRITREE *)NULL);
| 78 |
for (i = 0; i < 4; i++) {
| 79 |
TRITREE *chknode = &node->kid[i];
| 80 |
if (intriv(chknode->gdv, sdir))
| 81 |
return(isleaf(chknode) ? chknode :
| 82 |
findleaf(chknode, sdir));
| 83 |
| 84 |
return(NULL);
| 85 |
| 86 |
| 87 |
/* Initialize leaf with random sample inside the given spherical triangle */
| 88 |
void
| 89 |
leafsample(TRITREE *leaf)
| 90 |
| 91 |
RAY myray;
| 92 |
RREAL wt[3];
| 93 |
int i, j;
| 94 |
/* random point on triangle */
| 95 |
i = random() % 3;
| 96 |
wt[i] = frandom();
| 97 |
j = random() & 1;
| 98 |
wt[(i+2-j)%3] = 1. - wt[i] -
| 99 |
(wt[(i+1+j)%3] = (1.-wt[i])*frandom());
| 100 |
leaf->sd[0] = leaf->sd[1] = leaf->sd[2] = .0;
| 101 |
for (i = 0; i < 3; i++)
| 102 |
VSUM(leaf->sd, leaf->sd, leaf->gdv[i], wt[i]);
| 103 |
normalize(leaf->sd); /* record sample direction */
| 104 |
/* evaluate at inf. */
| 105 |
VSUM(myray.rorg, scene_cent, leaf->sd, scene_rad);
| 106 |
VCOPY(myray.rdir, leaf->sd);
| 107 |
myray.rmax = 0.;
| 108 |
ray_trace(&myray);
| 109 |
setcolr(leaf->val, colval(myray.rcol,RED),
| 110 |
colval(myray.rcol,GRN),
| 111 |
colval(myray.rcol,BLU));
| 112 |
| 113 |
| 114 |
/* Initialize a branch node contained in the given spherical triangle */
| 115 |
void
| 116 |
subdivide(TRITREE *branch, FVECT dv[3])
| 117 |
| 118 |
FVECT sdv[3];
| 119 |
int i;
| 120 |
| 121 |
for (i = 0; i < 3; i++) /* copy spherical triangle */
| 122 |
VCOPY(branch->gdv[i], dv[i]);
| 123 |
for (i = 0; i < 3; i++) { /* create new vertices */
| 124 |
int j = (i+1)%3;
| 125 |
VADD(sdv[i], dv[i], dv[j]);
| 126 |
normalize(sdv[i]);
| 127 |
| 128 |
/* allocate leaves */
| 129 |
branch->kid = (TRITREE *)calloc(4, sizeof(TRITREE));
| 130 |
if (branch->kid == NULL)
| 131 |
error(SYSTEM, "out of memory in subdivide()");
| 132 |
/* assign subtriangle directions */
| 133 |
VCOPY(branch->kid[0].gdv[0], dv[0]);
| 134 |
VCOPY(branch->kid[0].gdv[1], sdv[0]);
| 135 |
VCOPY(branch->kid[0].gdv[2], sdv[2]);
| 136 |
VCOPY(branch->kid[1].gdv[0], sdv[0]);
| 137 |
VCOPY(branch->kid[1].gdv[1], dv[1]);
| 138 |
VCOPY(branch->kid[1].gdv[2], sdv[1]);
| 139 |
VCOPY(branch->kid[2].gdv[0], sdv[1]);
| 140 |
VCOPY(branch->kid[2].gdv[1], dv[2]);
| 141 |
VCOPY(branch->kid[2].gdv[2], sdv[2]);
| 142 |
VCOPY(branch->kid[3].gdv[0], sdv[0]);
| 143 |
VCOPY(branch->kid[3].gdv[1], sdv[1]);
| 144 |
VCOPY(branch->kid[3].gdv[2], sdv[2]);
| 145 |
| 146 |
| 147 |
/* Recursively subdivide the given node to the specified quadtree depth */
| 148 |
void
| 149 |
branchsample(TRITREE *node, int depth)
| 150 |
| 151 |
int i;
| 152 |
| 153 |
if (depth <= 0)
| 154 |
return;
| 155 |
if (isleaf(node)) { /* subdivide leaf node */
| 156 |
TRITREE branch, *moved_leaf;
| 157 |
subdivide(&branch, node->gdv);
| 158 |
moved_leaf = findleaf(&branch, node->sd);
| 159 |
if (moved_leaf != NULL) { /* bequeath old sample */
| 160 |
VCOPY(moved_leaf->sd, node->sd);
| 161 |
copycolr(moved_leaf->val, node->val);
| 162 |
| 163 |
for (i = 0; i < 4; i++) /* compute new samples */
| 164 |
if (&branch.kid[i] != moved_leaf)
| 165 |
leafsample(&branch.kid[i]);
| 166 |
*node = branch; /* replace leaf with branch */
| 167 |
| 168 |
for (i = 0; i < 4; i++) /* subdivide children */
| 169 |
branchsample(&node->kid[i], depth-1);
| 170 |
| 171 |
| 172 |
/* Sample sphere using triangular geodesic mesh */
| 173 |
TRITREE *
| 174 |
geosample(int nsamps)
| 175 |
| 176 |
int depth;
| 177 |
TRITREE *tree;
| 178 |
FVECT trunk[NTRUNKVERT];
| 179 |
int i, j;
| 180 |
/* figure out depth */
| 181 |
if ((nsamps -= 4) < 0)
| 182 |
error(USER, "minimum number of samples is 4");
| 183 |
nsamps = nsamps*3/NTRUNKBR; /* round up */
| 184 |
for (depth = 0; nsamps > 1; depth++)
| 185 |
nsamps >>= 2;
| 186 |
/* make base tetrahedron */
| 187 |
tree = (TRITREE *)malloc(sizeof(TRITREE));
| 188 |
if (tree == NULL) goto memerr;
| 189 |
trunk[0][0] = trunk[0][1] = 0; trunk[0][2] = 1;
| 190 |
trunk[1][0] = 0;
| 191 |
trunk[1][2] = cos(2.*asin(sqrt(2./3.)));
| 192 |
trunk[1][1] = sqrt(1. - trunk[1][2]*trunk[1][2]);
| 193 |
spinvector(trunk[2], trunk[1], trunk[0], 2.*PI/3.);
| 194 |
spinvector(trunk[3], trunk[1], trunk[0], 4.*PI/3.);
| 195 |
VCOPY(tree->gdv[0], trunk[0]);
| 196 |
VCOPY(tree->gdv[1], trunk[0]);
| 197 |
VCOPY(tree->gdv[2], trunk[0]);
| 198 |
tree->kid = (TRITREE *)calloc(NTRUNKBR, sizeof(TRITREE));
| 199 |
if (tree->kid == NULL) goto memerr;
| 200 |
/* grow our tree from trunk */
| 201 |
for (i = 0; i < NTRUNKBR; i++) {
| 202 |
for (j = 0; j < 3; j++) /* XXX works for tetra only */
| 203 |
VCOPY(tree->kid[i].gdv[j], trunk[(i+j)%NTRUNKVERT]);
| 204 |
leafsample(&tree->kid[i]);
| 205 |
branchsample(&tree->kid[i], depth);
| 206 |
| 207 |
return(tree);
| 208 |
memerr:
| 209 |
error(SYSTEM, "out of memory in geosample()");
| 210 |
| 211 |
| 212 |
/* Compute leaf exponent histogram */
| 213 |
void
| 214 |
get_ehisto(const TRITREE *node, long exphisto[256])
| 215 |
| 216 |
int i;
| 217 |
| 218 |
if (isleaf(node)) {
| 219 |
++exphisto[node->val[EXP]];
| 220 |
return;
| 221 |
| 222 |
| 223 |
get_ehisto(&node->kid[i], exphisto);
| 224 |
| 225 |
| 226 |
/* Get reasonable source threshold */
| 227 |
double
| 228 |
get_threshold(const TRITREE *tree)
| 229 |
| 230 |
long exphisto[256];
| 231 |
long samptotal;
| 232 |
int i;
| 233 |
/* compute sample histogram */
| 234 |
memset((void *)exphisto, 0, sizeof(exphisto));
| 235 |
| 236 |
get_ehisto(&tree->kid[i], exphisto);
| 237 |
/* use 99th percentile */
| 238 |
for (i = 0; i < 256; i++)
| 239 |
samptotal += exphisto[i];
| 240 |
samptotal /= 100;
| 241 |
for (i = 256; (--i > 0) & (samptotal > 0); )
| 242 |
samptotal -= exphisto[i];
| 243 |
return(ldexp(.75, i-COLXS));
| 244 |
| 245 |
| 246 |
/* Find leaf containing the maximum exponent */
| 247 |
TRITREE *
| 248 |
findemax(TRITREE *node, int *expp)
| 249 |
| 250 |
if (!isleaf(node)) {
| 251 |
TRITREE *maxleaf;
| 252 |
TRITREE *rleaf;
| 253 |
maxleaf = findemax(&node->kid[0], expp);
| 254 |
rleaf = findemax(&node->kid[1], expp);
| 255 |
if (rleaf != NULL) maxleaf = rleaf;
| 256 |
rleaf = findemax(&node->kid[2], expp);
| 257 |
| 258 |
rleaf = findemax(&node->kid[3], expp);
| 259 |
| 260 |
return(maxleaf);
| 261 |
| 262 |
if (node->val[EXP] <= *expp)
| 263 |
return(NULL);
| 264 |
*expp = node->val[EXP];
| 265 |
return(node);
| 266 |
| 267 |
| 268 |
/* Compute solid angle of spherical triangle (approx.) */
| 269 |
double
| 270 |
tri_omegav(FVECT v[3])
| 271 |
| 272 |
FVECT e1, e2, vcross;
| 273 |
| 274 |
VSUB(e1, v[1], v[0]);
| 275 |
VSUB(e2, v[2], v[1]);
| 276 |
fcross(vcross, e1, e2);
| 277 |
return(.5*VLEN(vcross));
| 278 |
| 279 |
| 280 |
/* Sum intensity times direction for non-zero leaves */
| 281 |
void
| 282 |
vector_sum(FVECT vsum, TRITREE *node,
| 283 |
const FVECT cent, double mincos, int ethresh)
| 284 |
| 285 |
if (isleaf(node)) {
| 286 |
double intens;
| 287 |
if (node->val[EXP] < ethresh)
| 288 |
return;
| 289 |
if (DOT(node->sd,cent) < mincos)
| 290 |
return;
| 291 |
intens = colrval(node->val,GRN) * tri_omegav(node->gdv);
| 292 |
VSUM(vsum, vsum, node->sd, intens);
| 293 |
return;
| 294 |
| 295 |
if (DOT(node->gdv[0],node->gdv[1]) < mincos &&
| 296 |
DOT(node->gdv[0],cent) > mincos &&
| 297 |
DOT(node->gdv[1],cent) > mincos &&
| 298 |
DOT(node->gdv[2],cent) > mincos)
| 299 |
return;
| 300 |
vector_sum(vsum, &node->kid[0], cent, mincos, ethresh);
| 301 |
vector_sum(vsum, &node->kid[1], cent, mincos, ethresh);
| 302 |
vector_sum(vsum, &node->kid[2], cent, mincos, ethresh);
| 303 |
vector_sum(vsum, &node->kid[3], cent, mincos, ethresh);
| 304 |
| 305 |
| 306 |
/* Claim source contributions within the given solid angle */
| 307 |
void
| 308 |
claimlight(COLOR intens, TRITREE *node, const FVECT cent, double mincos)
| 309 |
| 310 |
int remaining;
| 311 |
int i;
| 312 |
if (isleaf(node)) { /* claim contribution */
| 313 |
COLOR contrib;
| 314 |
if (node->val[EXP] <= 0)
| 315 |
return;
| 316 |
| 317 |
return;
| 318 |
colr_color(contrib, node->val);
| 319 |
scalecolor(contrib, tri_omegav(node->gdv));
| 320 |
addcolor(intens, contrib);
| 321 |
copycolr(node->val, blkclr);
| 322 |
return;
| 323 |
| 324 |
| 325 |
| 326 |
| 327 |
| 328 |
return;
| 329 |
remaining = 0; /* recurse on children */
| 330 |
| 331 |
claimlight(intens, &node->kid[i], cent, mincos);
| 332 |
if (!isleaf(&node->kid[i]) || node->kid[i].val[EXP] != 0)
| 333 |
++remaining;
| 334 |
| 335 |
if (remaining)
| 336 |
return;
| 337 |
/* consolidate empties */
| 338 |
free((void *)node->kid); node->kid = NULL;
| 339 |
| 340 |
VCOPY(node->sd, node->gdv[0]); /* doesn't really matter */
| 341 |
| 342 |
| 343 |
/* Add lost light contribution to the given list */
| 344 |
void
| 345 |
add2lost(LOSTLIGHT **llp, COLOR intens, const FVECT cent)
| 346 |
| 347 |
LOSTLIGHT *newll = (LOSTLIGHT *)malloc(sizeof(LOSTLIGHT));
| 348 |
| 349 |
if (newll == NULL)
| 350 |
return;
| 351 |
copycolor(newll->intens, intens);
| 352 |
VCOPY(newll->sd, cent);
| 353 |
newll->next = *llp;
| 354 |
*llp = newll;
| 355 |
| 356 |
| 357 |
/* Check lost light list for contributions */
| 358 |
void
| 359 |
getlost(LOSTLIGHT **llp, COLOR intens, const FVECT cent, double omega)
| 360 |
| 361 |
const double mincos = 1. - omega/(2.*PI);
| 362 |
LOSTLIGHT lhead, *lastp, *thisp;
| 363 |
| 364 |
lhead.next = *llp;
| 365 |
lastp = &lhead;
| 366 |
while ((thisp = lastp->next) != NULL)
| 367 |
if (DOT(thisp->sd,cent) >= mincos) {
| 368 |
LOSTLIGHT *mynext = thisp->next;
| 369 |
addcolor(intens, thisp->intens);
| 370 |
free((void *)thisp);
| 371 |
lastp->next = mynext;
| 372 |
} else
| 373 |
lastp = thisp;
| 374 |
*llp = lhead.next;
| 375 |
| 376 |
| 377 |
/* Create & print distant sources */
| 378 |
void
| 379 |
mksources(TRITREE *samptree, double thresh, double maxang)
| 380 |
| 381 |
const int ethresh = (int)(log(thresh)/log(2.) + (COLXS+.5));
| 382 |
const double maxomega = 2.*PI*(1. - cos(PI/180./2.*maxang));
| 383 |
const double minintens = .05*thresh*maxomega;
| 384 |
int nsrcs = 0;
| 385 |
LOSTLIGHT *lostlightlist = NULL;
| 386 |
int emax;
| 387 |
TRITREE *startleaf;
| 388 |
COLOR cval;
| 389 |
double growstep;
| 390 |
FVECT curcent;
| 391 |
double currad;
| 392 |
double curomega;
| 393 |
COLOR curintens;
| 394 |
double thisthresh;
| 395 |
int thisethresh;
| 396 |
int i;
| 397 |
| 398 |
* General algorithm:
| 399 |
* 1) Start with brightest unclaimed pixel
| 400 |
* 2) Grow source toward brightest unclaimed perimeter until:
| 401 |
* a) Source exceeds maximum size, or
| 402 |
* b) Perimeter values all below threshold, or
| 403 |
* c) Source average drops below threshold
| 404 |
* 3) Loop until nothing over threshold
| 405 |
| 406 |
* Complexity added to absorb insignificant sources in larger ones.
| 407 |
| 408 |
if (thresh <= FTINY)
| 409 |
return;
| 410 |
for ( ; ; ) {
| 411 |
emax = ethresh; /* find brightest unclaimed */
| 412 |
startleaf = NULL;
| 413 |
| 414 |
TRITREE *bigger = findemax(&samptree->kid[i], &emax);
| 415 |
if (bigger != NULL)
| 416 |
startleaf = bigger;
| 417 |
| 418 |
if (startleaf == NULL)
| 419 |
break;
| 420 |
/* claim it */
| 421 |
VCOPY(curcent, startleaf->sd);
| 422 |
curomega = tri_omegav(startleaf->gdv);
| 423 |
currad = sqrt(curomega/PI);
| 424 |
growstep = 3.*currad;
| 425 |
colr_color(curintens, startleaf->val);
| 426 |
thisthresh = .15*bright(curintens);
| 427 |
if (thisthresh < thresh) thisthresh = thresh;
| 428 |
thisethresh = (int)(log(thisthresh)/log(2.) + (COLXS+.5));
| 429 |
scalecolor(curintens, curomega);
| 430 |
copycolr(startleaf->val, blkclr);
| 431 |
do { /* grow source */
| 432 |
FVECT vsum;
| 433 |
double movedist;
| 434 |
vsum[0] = vsum[1] = vsum[2] = .0;
| 435 |
| 436 |
vector_sum(vsum, &samptree->kid[i],
| 437 |
curcent, cos(currad+growstep),
| 438 |
thisethresh);
| 439 |
if (normalize(vsum) == .0)
| 440 |
break;
| 441 |
movedist = acos(DOT(vsum,curcent));
| 442 |
if (movedist > growstep) {
| 443 |
VSUB(vsum, vsum, curcent);
| 444 |
movedist = growstep/VLEN(vsum);
| 445 |
VSUM(curcent, curcent, vsum, movedist);
| 446 |
normalize(curcent);
| 447 |
} else
| 448 |
VCOPY(curcent, vsum);
| 449 |
currad += growstep;
| 450 |
curomega = 2.*PI*(1. - cos(currad));
| 451 |
| 452 |
claimlight(curintens, &samptree->kid[i],
| 453 |
curcent, cos(currad));
| 454 |
} while (curomega < maxomega &&
| 455 |
bright(curintens)/curomega > thisthresh);
| 456 |
if (bright(curintens) < minintens) {
| 457 |
add2lost(&lostlightlist, curintens, curcent);
| 458 |
continue;
| 459 |
| 460 |
/* absorb lost contributions */
| 461 |
getlost(&lostlightlist, curintens, curcent, curomega);
| 462 |
++nsrcs; /* output source */
| 463 |
scalecolor(curintens, 1./curomega);
| 464 |
printf("\nvoid illum IBLout\n");
| 465 |
printf("0\n0\n3 %f %f %f\n",
| 466 |
colval(curintens,RED),
| 467 |
colval(curintens,GRN),
| 468 |
colval(curintens,BLU));
| 469 |
printf("\nIBLout source IBLsrc%d\n", nsrcs);
| 470 |
printf("0\n0\n4 %f %f %f %f\n",
| 471 |
curcent[0], curcent[1], curcent[2],
| 472 |
2.*180./PI*currad);
| 473 |
| 474 |
| 475 |
| 476 |
int
| 477 |
main(int argc, char *argv[])
| 478 |
| 479 |
long nsamps = DEF_NSAMPS;
| 480 |
double maxang = DEF_MAXANG;
| 481 |
TRITREE *samptree;
| 482 |
double thresh = 0;
| 483 |
int i;
| 484 |
| 485 |
progname = argv[0];
| 486 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 487 |
switch (argv[i][1]) {
| 488 |
case 'd': /* number of samples */
| 489 |
if (i >= argc-1) goto userr;
| 490 |
nsamps = atol(argv[++i]);
| 491 |
break;
| 492 |
case 't': /* manual threshold */
| 493 |
| 494 |
thresh = atof(argv[++i]);
| 495 |
break;
| 496 |
case 'a': /* maximum source angle */
| 497 |
| 498 |
maxang = atof(argv[++i]);
| 499 |
if (maxang <= FTINY)
| 500 |
goto userr;
| 501 |
if (maxang > 180.)
| 502 |
maxang = 180.;
| 503 |
break;
| 504 |
default:
| 505 |
goto userr;
| 506 |
| 507 |
if (i < argc-1)
| 508 |
goto userr;
| 509 |
/* start our ray calculation */
| 510 |
directvis = 0;
| 511 |
ray_init(i == argc-1 ? argv[i] : (char *)NULL);
| 512 |
VCOPY(scene_cent, thescene.cuorg);
| 513 |
scene_cent[0] += 0.5*thescene.cusize;
| 514 |
scene_cent[1] += 0.5*thescene.cusize;
| 515 |
scene_cent[2] += 0.5*thescene.cusize;
| 516 |
scene_rad = 0.86603*thescene.cusize;
| 517 |
/* sample geodesic mesh */
| 518 |
samptree = geosample(nsamps);
| 519 |
/* get source threshold */
| 520 |
| 521 |
thresh = get_threshold(samptree);
| 522 |
/* done with ray samples */
| 523 |
ray_done(1);
| 524 |
/* print header */
| 525 |
printf("# ");
| 526 |
printargs(argc, argv, stdout);
| 527 |
/* create & print sources */
| 528 |
mksources(samptree, thresh, maxang);
| 529 |
/* all done, no need to clean up */
| 530 |
return(0);
| 531 |
userr:
| 532 |
fprintf(stderr, "Usage: %s [-d nsamps][-t thresh][-a maxang] [octree]\n",
| 533 |
argv[0]);
| 534 |
exit(1);
| 535 |
| 536 |
| 537 |
void
| 538 |
eputs(char *s)
| 539 |
| 540 |
static int midline = 0;
| 541 |
| 542 |
if (!*s)
| 543 |
return;
| 544 |
if (!midline++) {
| 545 |
fputs(progname, stderr);
| 546 |
fputs(": ", stderr);
| 547 |
| 548 |
fputs(s, stderr);
| 549 |
if (s[strlen(s)-1] == '\n') {
| 550 |
fflush(stderr);
| 551 |
midline = 0;
| 552 |
| 553 |
| 554 |
| 555 |
void
| 556 |
wputs(char *s)
| 557 |
| 558 |
/* no warnings */
| 559 |
