root/radiance/ray/src/gen/mksource.c
Sat Jan 18 20:23:15 2025 UTC (4 months, 1 week ago) by greg
fix(mksource): Problem for large -d settings on 32-bit architectures
Fri Nov 17 20:02:07 2023 UTC (18 months, 2 weeks ago) by greg
Changes since 2.10: +2 -4 lines
Mon Feb 6 22:40:21 2023 UTC (2 years, 3 months ago) by greg
Changes since 2.9: +3 -3 lines
Fri Jan 15 20:56:50 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.8: +6 -2 lines
fix: avoid infinite loop in problematic environments
Thu Mar 6 00:42:21 2014 UTC (11 years, 3 months ago) by greg
Switched to calling Acos() for safety
Mon Aug 15 19:48:06 2011 UTC (13 years, 9 months ago) by greg
Wed Aug 10 22:28:45 2011 UTC (13 years, 9 months ago) by greg
Minor bug fixes
Fri Aug 24 04:41:36 2007 UTC (17 years, 9 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.4: +89 -71 lines
Made ray direction storage more efficient (1/4 the original memory)
Fri Sep 23 19:22:37 2005 UTC (19 years, 8 months ago) by greg
Removed some redundant globals
Mon Sep 19 12:32:12 2005 UTC (19 years, 8 months ago) by schorsch
Added mksource to SCons build, fixed some compile warnings.
Sat Jul 30 17:01:30 2005 UTC (19 years, 10 months ago) by greg
Changed to 98th percentile for default threshold
Tue Apr 12 03:30:43 2005 UTC (20 years, 1 month ago) by greg
Diff to selected 2.8
Created mksource program
