--- ray/src/gen/mksource.c 2005/04/12 03:30:43 2.1 +++ ray/src/gen/mksource.c 2007/08/24 04:41:36 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mksource.c,v 2.1 2005/04/12 03:30:43 greg Exp $"; +static const char RCSid[] = "$Id: mksource.c,v 2.5 2007/08/24 04:41:36 greg Exp $"; #endif /* * Generate distant sources corresponding to the given environment map @@ -7,6 +7,7 @@ static const char RCSid[] = "$Id: mksource.c,v 2.1 200 #include "ray.h" #include "random.h" +#include "resolu.h" #define NTRUNKBR 4 /* number of branches at trunk */ #define NTRUNKVERT 4 /* number of vertices at trunk */ @@ -16,19 +17,19 @@ static const char RCSid[] = "$Id: mksource.c,v 2.1 200 /* Data structure for geodesic samples */ typedef struct tritree { - FVECT gdv[3]; /* spherical triangle vertex direc. */ - FVECT sd; /* sample direction if leaf */ + int32 gdv[3]; /* spherical triangle vertex direc. */ + int32 sd; /* sample direction if leaf */ struct tritree *kid; /* 4 children if branch node */ COLR val; /* sampled color value */ } TRITREE; typedef struct lostlight { struct lostlight *next; /* next in list */ - FVECT sd; /* lost source direction */ + int32 sd; /* lost source direction */ COLOR intens; /* output times solid angle */ } LOSTLIGHT; -char *progname; +extern char *progname; FVECT scene_cent; /* center of octree cube */ RREAL scene_rad; /* radius to get outside cube from center */ @@ -55,10 +56,14 @@ vol_sign(const FVECT v1, const FVECT v2, const FVECT v /* Is the given direction contained within the specified spherical triangle? */ int -intriv(FVECT tri[3], const FVECT sdir) +intriv(const int32 trid[3], const FVECT sdir) { int sv[3]; + FVECT tri[3]; + decodedir(tri[0], trid[0]); + decodedir(tri[1], trid[1]); + decodedir(tri[2], trid[2]); sv[0] = vol_sign(sdir, tri[0], tri[1]); sv[1] = vol_sign(sdir, tri[1], tri[2]); sv[2] = vol_sign(sdir, tri[2], tri[0]); @@ -90,6 +95,7 @@ leafsample(TRITREE *leaf) { RAY myray; RREAL wt[3]; + FVECT sdir; int i, j; /* random point on triangle */ i = random() % 3; @@ -97,13 +103,17 @@ leafsample(TRITREE *leaf) j = random() & 1; wt[(i+2-j)%3] = 1. - wt[i] - (wt[(i+1+j)%3] = (1.-wt[i])*frandom()); - leaf->sd[0] = leaf->sd[1] = leaf->sd[2] = .0; - for (i = 0; i < 3; i++) - VSUM(leaf->sd, leaf->sd, leaf->gdv[i], wt[i]); - normalize(leaf->sd); /* record sample direction */ + sdir[0] = sdir[1] = sdir[2] = .0; + for (i = 0; i < 3; i++) { + FVECT vt; + decodedir(vt, leaf->gdv[i]); + VSUM(sdir, sdir, vt, wt[i]); + } + normalize(sdir); /* record sample direction */ + leaf->sd = encodedir(sdir); /* evaluate at inf. */ - VSUM(myray.rorg, scene_cent, leaf->sd, scene_rad); - VCOPY(myray.rdir, leaf->sd); + VSUM(myray.rorg, scene_cent, sdir, scene_rad); + VCOPY(myray.rdir, sdir); myray.rmax = 0.; ray_trace(&myray); setcolr(leaf->val, colval(myray.rcol,RED), @@ -113,35 +123,39 @@ leafsample(TRITREE *leaf) /* Initialize a branch node contained in the given spherical triangle */ void -subdivide(TRITREE *branch, FVECT dv[3]) +subdivide(TRITREE *branch, const int32 dv[3]) { - FVECT sdv[3]; + FVECT dvv[3], sdv[3]; + int32 sd[3]; int i; - for (i = 0; i < 3; i++) /* copy spherical triangle */ - VCOPY(branch->gdv[i], dv[i]); + for (i = 0; i < 3; i++) { /* copy spherical triangle */ + branch->gdv[i] = dv[i]; + decodedir(dvv[i], dv[i]); + } for (i = 0; i < 3; i++) { /* create new vertices */ int j = (i+1)%3; - VADD(sdv[i], dv[i], dv[j]); + VADD(sdv[i], dvv[i], dvv[j]); normalize(sdv[i]); + sd[i] = encodedir(sdv[i]); } /* allocate leaves */ branch->kid = (TRITREE *)calloc(4, sizeof(TRITREE)); if (branch->kid == NULL) error(SYSTEM, "out of memory in subdivide()"); /* assign subtriangle directions */ - VCOPY(branch->kid[0].gdv[0], dv[0]); - VCOPY(branch->kid[0].gdv[1], sdv[0]); - VCOPY(branch->kid[0].gdv[2], sdv[2]); - VCOPY(branch->kid[1].gdv[0], sdv[0]); - VCOPY(branch->kid[1].gdv[1], dv[1]); - VCOPY(branch->kid[1].gdv[2], sdv[1]); - VCOPY(branch->kid[2].gdv[0], sdv[1]); - VCOPY(branch->kid[2].gdv[1], dv[2]); - VCOPY(branch->kid[2].gdv[2], sdv[2]); - VCOPY(branch->kid[3].gdv[0], sdv[0]); - VCOPY(branch->kid[3].gdv[1], sdv[1]); - VCOPY(branch->kid[3].gdv[2], sdv[2]); + branch->kid[0].gdv[0] = dv[0]; + branch->kid[0].gdv[1] = sd[0]; + branch->kid[0].gdv[2] = sd[2]; + branch->kid[1].gdv[0] = sd[0]; + branch->kid[1].gdv[1] = dv[1]; + branch->kid[1].gdv[2] = sd[1]; + branch->kid[2].gdv[0] = sd[1]; + branch->kid[2].gdv[1] = dv[2]; + branch->kid[2].gdv[2] = sd[2]; + branch->kid[3].gdv[0] = sd[0]; + branch->kid[3].gdv[1] = sd[1]; + branch->kid[3].gdv[2] = sd[2]; } /* Recursively subdivide the given node to the specified quadtree depth */ @@ -154,10 +168,12 @@ branchsample(TRITREE *node, int depth) return; if (isleaf(node)) { /* subdivide leaf node */ TRITREE branch, *moved_leaf; + FVECT sdir; subdivide(&branch, node->gdv); - moved_leaf = findleaf(&branch, node->sd); + decodedir(sdir, node->sd); + moved_leaf = findleaf(&branch, sdir); if (moved_leaf != NULL) { /* bequeath old sample */ - VCOPY(moved_leaf->sd, node->sd); + moved_leaf->sd = node->sd; copycolr(moved_leaf->val, node->val); } for (i = 0; i < 4; i++) /* compute new samples */ @@ -192,21 +208,20 @@ geosample(int nsamps) trunk[1][1] = sqrt(1. - trunk[1][2]*trunk[1][2]); spinvector(trunk[2], trunk[1], trunk[0], 2.*PI/3.); spinvector(trunk[3], trunk[1], trunk[0], 4.*PI/3.); - VCOPY(tree->gdv[0], trunk[0]); - VCOPY(tree->gdv[1], trunk[0]); - VCOPY(tree->gdv[2], trunk[0]); + tree->gdv[0] = tree->gdv[1] = tree->gdv[2] = encodedir(trunk[0]); tree->kid = (TRITREE *)calloc(NTRUNKBR, sizeof(TRITREE)); if (tree->kid == NULL) goto memerr; /* grow our tree from trunk */ for (i = 0; i < NTRUNKBR; i++) { for (j = 0; j < 3; j++) /* XXX works for tetra only */ - VCOPY(tree->kid[i].gdv[j], trunk[(i+j)%NTRUNKVERT]); + tree->kid[i].gdv[j] = encodedir(trunk[(i+j)%NTRUNKVERT]); leafsample(&tree->kid[i]); branchsample(&tree->kid[i], depth); } return(tree); memerr: error(SYSTEM, "out of memory in geosample()"); + return NULL; /* dummy return */ } /* Compute leaf exponent histogram */ @@ -234,10 +249,10 @@ get_threshold(const TRITREE *tree) memset((void *)exphisto, 0, sizeof(exphisto)); for (i = 0; i < NTRUNKBR; i++) get_ehisto(&tree->kid[i], exphisto); - /* use 99th percentile */ + /* use 98th percentile */ for (i = 0; i < 256; i++) samptotal += exphisto[i]; - samptotal /= 100; + samptotal /= 50; for (i = 256; (--i > 0) & (samptotal > 0); ) samptotal -= exphisto[i]; return(ldexp(.75, i-COLXS)); @@ -267,68 +282,73 @@ findemax(TRITREE *node, int *expp) /* Compute solid angle of spherical triangle (approx.) */ double -tri_omegav(FVECT v[3]) +tri_omegav(const int32 vd[3]) { - FVECT e1, e2, vcross; - + FVECT v[3], e1, e2, vcross; + + decodedir(v[0], vd[0]); + decodedir(v[1], vd[1]); + decodedir(v[2], vd[2]); VSUB(e1, v[1], v[0]); VSUB(e2, v[2], v[1]); fcross(vcross, e1, e2); return(.5*VLEN(vcross)); } -/* Sum intensity times direction for non-zero leaves */ +/* Sum intensity times direction for above-threshold perimiter within radius */ void vector_sum(FVECT vsum, TRITREE *node, - const FVECT cent, double mincos, int ethresh) + FVECT cent, double maxr2, int ethresh) { if (isleaf(node)) { double intens; + FVECT sdir; if (node->val[EXP] < ethresh) - return; - if (DOT(node->sd,cent) < mincos) - return; + return; /* below threshold */ + if (fdir2diff(node->sd,cent) > maxr2) + return; /* too far away */ intens = colrval(node->val,GRN) * tri_omegav(node->gdv); - VSUM(vsum, vsum, node->sd, intens); + decodedir(sdir, node->sd); + VSUM(vsum, vsum, sdir, intens); return; } - if (DOT(node->gdv[0],node->gdv[1]) < mincos && - DOT(node->gdv[0],cent) > mincos && - DOT(node->gdv[1],cent) > mincos && - DOT(node->gdv[2],cent) > mincos) - return; - vector_sum(vsum, &node->kid[0], cent, mincos, ethresh); - vector_sum(vsum, &node->kid[1], cent, mincos, ethresh); - vector_sum(vsum, &node->kid[2], cent, mincos, ethresh); - vector_sum(vsum, &node->kid[3], cent, mincos, ethresh); + if (dir2diff(node->gdv[0],node->gdv[1]) > maxr2 && + fdir2diff(node->gdv[0],cent) < maxr2 && + fdir2diff(node->gdv[1],cent) < maxr2 && + fdir2diff(node->gdv[2],cent) < maxr2) + return; /* containing node */ + vector_sum(vsum, &node->kid[0], cent, maxr2, ethresh); + vector_sum(vsum, &node->kid[1], cent, maxr2, ethresh); + vector_sum(vsum, &node->kid[2], cent, maxr2, ethresh); + vector_sum(vsum, &node->kid[3], cent, maxr2, ethresh); } /* Claim source contributions within the given solid angle */ void -claimlight(COLOR intens, TRITREE *node, const FVECT cent, double mincos) +claimlight(COLOR intens, TRITREE *node, FVECT cent, double maxr2) { int remaining; int i; if (isleaf(node)) { /* claim contribution */ COLOR contrib; if (node->val[EXP] <= 0) - return; - if (DOT(node->sd,cent) < mincos) - return; + return; /* already claimed */ + if (fdir2diff(node->sd,cent) > maxr2) + return; /* too far away */ colr_color(contrib, node->val); scalecolor(contrib, tri_omegav(node->gdv)); addcolor(intens, contrib); copycolr(node->val, blkclr); return; } - if (DOT(node->gdv[0],node->gdv[1]) < mincos && - DOT(node->gdv[0],cent) > mincos && - DOT(node->gdv[1],cent) > mincos && - DOT(node->gdv[2],cent) > mincos) - return; + if (dir2diff(node->gdv[0],node->gdv[1]) > maxr2 && + fdir2diff(node->gdv[0],cent) < maxr2 && + fdir2diff(node->gdv[1],cent) < maxr2 && + fdir2diff(node->gdv[2],cent) < maxr2) + return; /* previously claimed node */ remaining = 0; /* recurse on children */ for (i = 0; i < 4; i++) { - claimlight(intens, &node->kid[i], cent, mincos); + claimlight(intens, &node->kid[i], cent, maxr2); if (!isleaf(&node->kid[i]) || node->kid[i].val[EXP] != 0) ++remaining; } @@ -337,34 +357,34 @@ claimlight(COLOR intens, TRITREE *node, const FVECT ce /* consolidate empties */ free((void *)node->kid); node->kid = NULL; copycolr(node->val, blkclr); - VCOPY(node->sd, node->gdv[0]); /* doesn't really matter */ + node->sd = node->gdv[0]; /* doesn't really matter */ } /* Add lost light contribution to the given list */ void -add2lost(LOSTLIGHT **llp, COLOR intens, const FVECT cent) +add2lost(LOSTLIGHT **llp, COLOR intens, FVECT cent) { LOSTLIGHT *newll = (LOSTLIGHT *)malloc(sizeof(LOSTLIGHT)); if (newll == NULL) return; copycolor(newll->intens, intens); - VCOPY(newll->sd, cent); + newll->sd = encodedir(cent); newll->next = *llp; *llp = newll; } /* Check lost light list for contributions */ void -getlost(LOSTLIGHT **llp, COLOR intens, const FVECT cent, double omega) +getlost(LOSTLIGHT **llp, COLOR intens, FVECT cent, double omega) { - const double mincos = 1. - omega/(2.*PI); + const double maxr2 = omega/PI; LOSTLIGHT lhead, *lastp, *thisp; lhead.next = *llp; lastp = &lhead; while ((thisp = lastp->next) != NULL) - if (DOT(thisp->sd,cent) >= mincos) { + if (fdir2diff(thisp->sd,cent) <= maxr2) { LOSTLIGHT *mynext = thisp->next; addcolor(intens, thisp->intens); free((void *)thisp); @@ -385,7 +405,6 @@ mksources(TRITREE *samptree, double thresh, double max LOSTLIGHT *lostlightlist = NULL; int emax; TRITREE *startleaf; - COLOR cval; double growstep; FVECT curcent; double currad; @@ -418,7 +437,7 @@ mksources(TRITREE *samptree, double thresh, double max if (startleaf == NULL) break; /* claim it */ - VCOPY(curcent, startleaf->sd); + decodedir(curcent, startleaf->sd); curomega = tri_omegav(startleaf->gdv); currad = sqrt(curomega/PI); growstep = 3.*currad; @@ -434,7 +453,7 @@ mksources(TRITREE *samptree, double thresh, double max vsum[0] = vsum[1] = vsum[2] = .0; for (i = 0; i < NTRUNKBR; i++) vector_sum(vsum, &samptree->kid[i], - curcent, cos(currad+growstep), + curcent, 2.-2.*cos(currad+growstep), thisethresh); if (normalize(vsum) == .0) break; @@ -450,7 +469,7 @@ mksources(TRITREE *samptree, double thresh, double max curomega = 2.*PI*(1. - cos(currad)); for (i = 0; i < NTRUNKBR; i++) claimlight(curintens, &samptree->kid[i], - curcent, cos(currad)); + curcent, 2.-2.*cos(currad)); } while (curomega < maxomega && bright(curintens)/curomega > thisthresh); if (bright(curintens) < minintens) {
