root/radiance/ray/src/gen/mkillum4.c
Revision: 2.11
Committed: Fri Apr 11 20:07:12 2008 UTC (17 years, 1 month ago) by greg
Changes since 2.10: +10 -9 lines
Fixed angle orientation
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.11 static const char RCSid[] = "$Id: mkillum4.c,v 2.10 2008/03/27 01:40:30 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines for handling BSDF data within mkillum
6     */
7
8     #include "mkillum.h"
9     #include "paths.h"
10 greg 2.2 #include "ezxml.h"
11 greg 2.1
12 greg 2.6 #define MAXLATS 46 /* maximum number of latitudes */
13
14 greg 2.11 /* BSDF angle specification */
15 greg 2.6 typedef struct {
16 greg 2.7 char name[64]; /* basis name */
17 greg 2.6 int nangles; /* total number of directions */
18     struct {
19     float tmin; /* starting theta */
20     short nphis; /* number of phis (0 term) */
21     } lat[MAXLATS+1]; /* latitudes */
22     } ANGLE_BASIS;
23
24 greg 2.7 #define MAXABASES 3 /* limit on defined bases */
25 greg 2.6
26 greg 2.7 ANGLE_BASIS abase_list[MAXABASES] = {
27 greg 2.6 {
28     "LBNL/Klems Full", 145,
29     { {-5., 1},
30     {5., 8},
31     {15., 16},
32     {25., 20},
33     {35., 24},
34     {45., 24},
35     {55., 24},
36     {65., 16},
37     {75., 12},
38     {90., 0} }
39     }, {
40     "LBNL/Klems Half", 73,
41     { {-6.5, 1},
42     {6.5, 8},
43     {19.5, 12},
44     {32.5, 16},
45     {46.5, 20},
46     {61.5, 12},
47     {76.5, 4},
48     {90., 0} }
49     }, {
50     "LBNL/Klems Quarter", 41,
51     { {-9., 1},
52     {9., 8},
53     {27., 12},
54     {46., 12},
55     {66., 8},
56     {90., 0} }
57     }
58     };
59
60 greg 2.7 static int nabases = 3; /* current number of defined bases */
61
62 greg 2.6
63     static int
64     ab_getvec( /* get vector for this angle basis index */
65     FVECT v,
66     int ndx,
67     void *p
68     )
69     {
70     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
71     int li;
72     double alt, azi, d;
73
74     if ((ndx < 0) | (ndx >= ab->nangles))
75     return(0);
76     for (li = 0; ndx >= ab->lat[li].nphis; li++)
77     ndx -= ab->lat[li].nphis;
78     alt = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin);
79     azi = 2.*PI*ndx/ab->lat[li].nphis;
80 greg 2.11 v[2] = d = cos(alt);
81     d = sqrt(1. - d*d); /* sin(alt) */
82 greg 2.6 v[0] = cos(azi)*d;
83     v[1] = sin(azi)*d;
84     return(1);
85     }
86
87
88     static int
89     ab_getndx( /* get index corresponding to the given vector */
90     FVECT v,
91     void *p
92     )
93     {
94     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
95     int li, ndx;
96     double alt, azi, d;
97
98 greg 2.7 if ((v[2] < -1.0) | (v[2] > 1.0))
99 greg 2.6 return(-1);
100     alt = 180.0/PI*acos(v[2]);
101     azi = 180.0/PI*atan2(v[1], v[0]);
102     if (azi < 0.0) azi += 360.0;
103     for (li = 1; ab->lat[li].tmin <= alt; li++)
104     if (!ab->lat[li].nphis)
105     return(-1);
106     --li;
107     ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
108     if (ndx >= ab->lat[li].nphis) ndx = 0;
109     while (li--)
110     ndx += ab->lat[li].nphis;
111     return(ndx);
112     }
113
114
115     static double
116     ab_getohm( /* get solid angle for this angle basis index */
117     int ndx,
118     void *p
119     )
120     {
121     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
122     int li;
123     double tdia, pdia;
124
125     if ((ndx < 0) | (ndx >= ab->nangles))
126     return(0);
127     for (li = 0; ndx >= ab->lat[li].nphis; li++)
128     ndx -= ab->lat[li].nphis;
129 greg 2.7 if (ab->lat[li].nphis == 1) { /* special case */
130     if (ab->lat[li].tmin > FTINY)
131     error(USER, "unsupported BSDF coordinate system");
132     tdia = PI/180. * ab->lat[li+1].tmin;
133     return(PI*tdia*tdia);
134     }
135 greg 2.6 tdia = PI/180.*(ab->lat[li+1].tmin - ab->lat[li].tmin);
136 greg 2.7 tdia *= sin(PI/180.*(ab->lat[li].tmin + ab->lat[li+1].tmin));
137 greg 2.6 pdia = 2.*PI/ab->lat[li].nphis;
138     return(tdia*pdia);
139     }
140
141
142     static int
143     ab_getvecR( /* get reverse vector for this angle basis index */
144     FVECT v,
145     int ndx,
146     void *p
147     )
148     {
149     if (!ab_getvec(v, ndx, p))
150     return(0);
151
152     v[0] = -v[0];
153     v[1] = -v[1];
154 greg 2.11 v[2] = -v[2];
155 greg 2.6
156     return(1);
157     }
158
159
160     static int
161     ab_getndxR( /* get index corresponding to the reverse vector */
162     FVECT v,
163     void *p
164     )
165     {
166     FVECT v2;
167
168     v2[0] = -v[0];
169     v2[1] = -v[1];
170 greg 2.11 v2[2] = -v[2];
171 greg 2.6
172     return ab_getndx(v2, p);
173     }
174
175 greg 2.7
176 greg 2.6 static void
177     load_bsdf_data( /* load BSDF distribution for this wavelength */
178     struct BSDF_data *dp,
179     ezxml_t wdb
180     )
181     {
182 greg 2.7 char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
183     char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
184     char *sdata;
185 greg 2.6 int i;
186
187 greg 2.7 if ((cbasis == NULL) | (rbasis == NULL)) {
188     error(WARNING, "missing column/row basis for BSDF");
189     return;
190     }
191     /* XXX need to add routines for loading in foreign bases */
192     for (i = nabases; i--; )
193 greg 2.6 if (!strcmp(cbasis, abase_list[i].name)) {
194     dp->ninc = abase_list[i].nangles;
195     dp->ib_priv = (void *)&abase_list[i];
196 greg 2.11 dp->ib_vec = ab_getvecR;
197     dp->ib_ndx = ab_getndxR;
198 greg 2.6 dp->ib_ohm = ab_getohm;
199     break;
200     }
201     if (i < 0) {
202 greg 2.7 sprintf(errmsg, "unsupported ColumnAngleBasis '%s'", cbasis);
203     error(WARNING, errmsg);
204     return;
205 greg 2.6 }
206 greg 2.7 for (i = nabases; i--; )
207 greg 2.6 if (!strcmp(rbasis, abase_list[i].name)) {
208     dp->nout = abase_list[i].nangles;
209     dp->ob_priv = (void *)&abase_list[i];
210 greg 2.11 dp->ob_vec = ab_getvec;
211     dp->ob_ndx = ab_getndx;
212 greg 2.6 dp->ob_ohm = ab_getohm;
213     break;
214     }
215     if (i < 0) {
216 greg 2.7 sprintf(errmsg, "unsupported RowAngleBasis '%s'", cbasis);
217     error(WARNING, errmsg);
218     return;
219     }
220     /* read BSDF data */
221     sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData"));
222     if (sdata == NULL) {
223     error(WARNING, "missing BSDF ScatteringData");
224     return;
225     }
226     dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout);
227     if (dp->bsdf == NULL)
228     error(SYSTEM, "out of memory in load_bsdf_data");
229     for (i = 0; i < dp->ninc*dp->nout; i++) {
230     char *sdnext = fskip(sdata);
231     if (sdnext == NULL) {
232     error(WARNING, "bad/missing BSDF ScatteringData");
233     free(dp->bsdf); dp->bsdf = NULL;
234     return;
235     }
236     while (*sdnext && isspace(*sdnext))
237     sdnext++;
238     if (*sdnext == ',') sdnext++;
239     dp->bsdf[i] = atof(sdata);
240     sdata = sdnext;
241     }
242     while (isspace(*sdata))
243     sdata++;
244     if (*sdata) {
245     sprintf(errmsg, "%d extra characters after BSDF ScatteringData",
246     strlen(sdata));
247     error(WARNING, errmsg);
248 greg 2.6 }
249     }
250
251 greg 2.1
252     struct BSDF_data *
253     load_BSDF( /* load BSDF data from file */
254     char *fname
255     )
256     {
257     char *path;
258 greg 2.10 ezxml_t fl, wtl, wld, wdb;
259 greg 2.1 struct BSDF_data *dp;
260
261     path = getpath(fname, getrlibpath(), R_OK);
262     if (path == NULL) {
263     sprintf(errmsg, "cannot find BSDF file \"%s\"", fname);
264     error(WARNING, errmsg);
265     return(NULL);
266     }
267 greg 2.2 fl = ezxml_parse_file(path);
268     if (fl == NULL) {
269 greg 2.1 sprintf(errmsg, "cannot open BSDF \"%s\"", path);
270     error(WARNING, errmsg);
271     return(NULL);
272     }
273 greg 2.6 if (ezxml_error(fl)[0]) {
274 greg 2.10 sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl));
275 greg 2.6 error(WARNING, errmsg);
276     ezxml_free(fl);
277     return(NULL);
278     }
279 greg 2.10 if (strcmp(ezxml_name(fl), "WindowElement")) {
280     sprintf(errmsg,
281     "BSDF \"%s\": top level node not 'WindowElement'",
282     path);
283     error(WARNING, errmsg);
284     ezxml_free(fl);
285     return(NULL);
286     }
287     wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
288 greg 2.5 dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data));
289 greg 2.10 for (wld = ezxml_child(wtl, "WavelengthData");
290 greg 2.8 wld != NULL; wld = wld->next) {
291 greg 2.6 if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible"))
292 greg 2.2 continue;
293     wdb = ezxml_child(wld, "WavelengthDataBlock");
294     if (wdb == NULL) continue;
295 greg 2.6 if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")),
296 greg 2.2 "Transmission Front"))
297     continue;
298 greg 2.6 load_bsdf_data(dp, wdb); /* load front BTDF */
299     break; /* ignore the rest */
300     }
301     ezxml_free(fl); /* done with XML file */
302     if (dp->bsdf == NULL) {
303     sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path);
304     error(WARNING, errmsg);
305     free_BSDF(dp);
306     dp = NULL;
307 greg 2.2 }
308 greg 2.1 return(dp);
309     }
310
311
312     void
313     free_BSDF( /* free BSDF data structure */
314     struct BSDF_data *b
315     )
316     {
317     if (b == NULL)
318     return;
319 greg 2.6 if (b->bsdf != NULL)
320     free(b->bsdf);
321 greg 2.1 free(b);
322     }
323
324
325 greg 2.6 int
326 greg 2.1 r_BSDF_incvec( /* compute random input vector at given location */
327     FVECT v,
328     struct BSDF_data *b,
329     int i,
330     double rv,
331     MAT4 xm
332     )
333     {
334     FVECT pert;
335     double rad;
336     int j;
337
338 greg 2.6 if (!getBSDF_incvec(v, b, i))
339     return(0);
340     rad = sqrt(getBSDF_incohm(b, i) / PI);
341 greg 2.1 multisamp(pert, 3, rv);
342     for (j = 0; j < 3; j++)
343     v[j] += rad*(2.*pert[j] - 1.);
344     if (xm != NULL)
345     multv3(v, v, xm);
346 greg 2.7 return(normalize(v) != 0.0);
347 greg 2.1 }
348
349
350 greg 2.6 int
351 greg 2.1 r_BSDF_outvec( /* compute random output vector at given location */
352     FVECT v,
353     struct BSDF_data *b,
354     int o,
355     double rv,
356     MAT4 xm
357     )
358     {
359     FVECT pert;
360     double rad;
361     int j;
362
363 greg 2.6 if (!getBSDF_outvec(v, b, o))
364     return(0);
365     rad = sqrt(getBSDF_outohm(b, o) / PI);
366 greg 2.1 multisamp(pert, 3, rv);
367     for (j = 0; j < 3; j++)
368     v[j] += rad*(2.*pert[j] - 1.);
369     if (xm != NULL)
370     multv3(v, v, xm);
371 greg 2.7 return(normalize(v) != 0.0);
372 greg 2.1 }
373 greg 2.2
374
375     #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
376
377     static int
378     addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
379     char *xfarg[],
380     FVECT xp,
381     FVECT yp,
382     FVECT zp
383     )
384     {
385     static char bufs[3][16];
386     int bn = 0;
387     char **xfp = xfarg;
388     double theta;
389
390 greg 2.9 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
391     /* Special case for X' along Z-axis */
392     theta = -atan2(yp[0], yp[1]);
393     *xfp++ = "-ry";
394     *xfp++ = xp[2] < 0.0 ? "90" : "-90";
395     *xfp++ = "-rz";
396     sprintf(bufs[bn], "%f", theta*(180./PI));
397     *xfp++ = bufs[bn++];
398     return(xfp - xfarg);
399     }
400 greg 2.2 theta = atan2(yp[2], zp[2]);
401     if (!FEQ(theta,0.0)) {
402     *xfp++ = "-rx";
403     sprintf(bufs[bn], "%f", theta*(180./PI));
404     *xfp++ = bufs[bn++];
405     }
406     theta = asin(-xp[2]);
407     if (!FEQ(theta,0.0)) {
408     *xfp++ = "-ry";
409     sprintf(bufs[bn], " %f", theta*(180./PI));
410     *xfp++ = bufs[bn++];
411     }
412     theta = atan2(xp[1], xp[0]);
413     if (!FEQ(theta,0.0)) {
414     *xfp++ = "-rz";
415     sprintf(bufs[bn], "%f", theta*(180./PI));
416     *xfp++ = bufs[bn++];
417     }
418     *xfp = NULL;
419     return(xfp - xfarg);
420     }
421
422
423     int
424 greg 2.6 getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */
425 greg 2.2 MAT4 xm,
426     FVECT nrm,
427     UpDir ud
428     )
429     {
430     char *xfargs[7];
431     XF myxf;
432     FVECT updir, xdest, ydest;
433
434     updir[0] = updir[1] = updir[2] = 0.;
435     switch (ud) {
436     case UDzneg:
437     updir[2] = -1.;
438     break;
439     case UDyneg:
440     updir[1] = -1.;
441     break;
442     case UDxneg:
443     updir[0] = -1.;
444     break;
445     case UDxpos:
446     updir[0] = 1.;
447     break;
448     case UDypos:
449     updir[1] = 1.;
450     break;
451     case UDzpos:
452     updir[2] = 1.;
453     break;
454     case UDunknown:
455     return(0);
456     }
457     fcross(xdest, updir, nrm);
458     if (normalize(xdest) == 0.0)
459     return(0);
460     fcross(ydest, nrm, xdest);
461     xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs);
462     copymat4(xm, myxf.xfm);
463     return(1);
464     }
465
466
467     void
468     redistribute( /* pass distarr ray sums through BSDF */
469     struct BSDF_data *b,
470     int nalt,
471     int nazi,
472     FVECT u,
473     FVECT v,
474     FVECT w,
475     MAT4 xm
476     )
477     {
478 greg 2.6 int nout = 0;
479 greg 2.5 MAT4 mymat, inmat;
480     COLORV *idist;
481 greg 2.2 COLORV *cp, *csum;
482     FVECT dv;
483 greg 2.5 double wt;
484 greg 2.6 int i, j, k, o;
485 greg 2.5 COLOR col, cinc;
486     /* copy incoming distribution */
487     if (b->ninc != distsiz)
488     error(INTERNAL, "error 1 in redistribute");
489     idist = (COLORV *)malloc(sizeof(COLOR)*distsiz);
490     if (idist == NULL)
491 greg 2.2 error(SYSTEM, "out of memory in redistribute");
492 greg 2.5 memcpy(idist, distarr, sizeof(COLOR)*distsiz);
493     /* compose direction transform */
494 greg 2.2 for (i = 3; i--; ) {
495     mymat[i][0] = u[i];
496     mymat[i][1] = v[i];
497     mymat[i][2] = w[i];
498     mymat[i][3] = 0.;
499     }
500     mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.;
501     mymat[3][3] = 1.;
502     if (xm != NULL)
503     multmat4(mymat, xm, mymat);
504     for (i = 3; i--; ) { /* make sure it's normalized */
505 greg 2.5 wt = 1./sqrt( mymat[0][i]*mymat[0][i] +
506 greg 2.2 mymat[1][i]*mymat[1][i] +
507     mymat[2][i]*mymat[2][i] );
508     for (j = 3; j--; )
509 greg 2.5 mymat[j][i] *= wt;
510 greg 2.2 }
511 greg 2.5 if (!invmat4(inmat, mymat)) /* need inverse as well */
512     error(INTERNAL, "cannot invert BSDF transform");
513     newdist(nalt*nazi); /* resample distribution */
514 greg 2.4 for (i = b->ninc; i--; ) {
515 greg 2.5 getBSDF_incvec(dv, b, i); /* compute incident irrad. */
516 greg 2.2 multv3(dv, dv, mymat);
517 greg 2.5 if (dv[2] < 0.0) dv[2] = -dv[2];
518 greg 2.6 wt = getBSDF_incohm(b, i);
519     wt *= dv[2]; /* solid_angle*cosine(theta) */
520 greg 2.5 cp = &idist[3*i];
521     copycolor(cinc, cp);
522     scalecolor(cinc, wt);
523     for (k = nalt; k--; ) /* loop over distribution */
524     for (j = nazi; j--; ) {
525     flatdir(dv, (k + .5)/nalt, (double)j/nazi);
526     multv3(dv, dv, inmat);
527     /* evaluate BSDF @ outgoing */
528 greg 2.6 o = getBSDF_outndx(b, dv);
529     if (o < 0) {
530     nout++;
531     continue;
532     }
533 greg 2.7 wt = BSDF_value(b, i, o);
534 greg 2.5 copycolor(col, cinc);
535     scalecolor(col, wt);
536     csum = &distarr[3*(k*nazi + j)];
537     addcolor(csum, col); /* sum into distribution */
538     }
539 greg 2.2 }
540 greg 2.5 free(idist); /* free temp space */
541 greg 2.6 if (nout) {
542     sprintf(errmsg, "missing %.1f%% of BSDF directions",
543     100.*nout/(b->ninc*nalt*nazi));
544     error(WARNING, errmsg);
545     }
546 greg 2.2 }
