--- ray/src/gen/mkillum4.c 2007/09/18 19:51:07 2.1 +++ ray/src/gen/mkillum4.c 2007/09/21 05:53:21 2.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum4.c,v 2.1 2007/09/18 19:51:07 greg Exp $"; +static const char RCSid[] = "$Id: mkillum4.c,v 2.2 2007/09/21 05:53:21 greg Exp $"; #endif /* * Routines for handling BSDF data within mkillum @@ -7,6 +7,7 @@ static const char RCSid[] = "$Id: mkillum4.c,v 2.1 200 #include "mkillum.h" #include "paths.h" +#include "ezxml.h" struct BSDF_data * @@ -15,7 +16,7 @@ load_BSDF( /* load BSDF data from file */ ) { char *path; - FILE *fp; + ezxml_t fl, wld, wdb; struct BSDF_data *dp; path = getpath(fname, getrlibpath(), R_OK); @@ -24,7 +25,8 @@ load_BSDF( /* load BSDF data from file */ error(WARNING, errmsg); return(NULL); } - if ((fp = fopen(path, "r")) == NULL) { + fl = ezxml_parse_file(path); + if (fl == NULL) { sprintf(errmsg, "cannot open BSDF \"%s\"", path); error(WARNING, errmsg); return(NULL); @@ -32,8 +34,18 @@ load_BSDF( /* load BSDF data from file */ dp = (struct BSDF_data *)malloc(sizeof(struct BSDF_data)); if (dp == NULL) goto memerr; + for (wld = ezxml_child(fl, "WavelengthData"); + fl != NULL; fl = fl->next) { + if (strcmp(ezxml_child(wld, "Wavelength")->txt, "Visible")) + continue; + wdb = ezxml_child(wld, "WavelengthDataBlock"); + if (wdb == NULL) continue; + if (strcmp(ezxml_child(wdb, "WavelengthDataDirection")->txt, + "Transmission Front")) + continue; + } /* etc... */ - fclose(fp); + ezxml_free(fl); return(dp); memerr: error(SYSTEM, "out of memory in load_BSDF"); @@ -102,4 +114,211 @@ r_BSDF_outvec( /* compute random output vector at giv if (xm != NULL) multv3(v, v, xm); normalize(v); +} + + +#define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7) + +static int +addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */ + char *xfarg[], + FVECT xp, + FVECT yp, + FVECT zp +) +{ + static char bufs[3][16]; + int bn = 0; + char **xfp = xfarg; + double theta; + + theta = atan2(yp[2], zp[2]); + if (!FEQ(theta,0.0)) { + *xfp++ = "-rx"; + sprintf(bufs[bn], "%f", theta*(180./PI)); + *xfp++ = bufs[bn++]; + } + theta = asin(-xp[2]); + if (!FEQ(theta,0.0)) { + *xfp++ = "-ry"; + sprintf(bufs[bn], " %f", theta*(180./PI)); + *xfp++ = bufs[bn++]; + } + theta = atan2(xp[1], xp[0]); + if (!FEQ(theta,0.0)) { + *xfp++ = "-rz"; + sprintf(bufs[bn], "%f", theta*(180./PI)); + *xfp++ = bufs[bn++]; + } + *xfp = NULL; + return(xfp - xfarg); +} + + +int +getBSDF_xfm( /* compute transform for the given surface */ + MAT4 xm, + FVECT nrm, + UpDir ud +) +{ + char *xfargs[7]; + XF myxf; + FVECT updir, xdest, ydest; + + updir[0] = updir[1] = updir[2] = 0.; + switch (ud) { + case UDzneg: + updir[2] = -1.; + break; + case UDyneg: + updir[1] = -1.; + break; + case UDxneg: + updir[0] = -1.; + break; + case UDxpos: + updir[0] = 1.; + break; + case UDypos: + updir[1] = 1.; + break; + case UDzpos: + updir[2] = 1.; + break; + case UDunknown: + error(WARNING, "unspecified up direction"); + return(0); + } + fcross(xdest, updir, nrm); + if (normalize(xdest) == 0.0) + return(0); + fcross(ydest, nrm, xdest); + xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs); + copymat4(xm, myxf.xfm); + return(1); +} + + +void +redistribute( /* pass distarr ray sums through BSDF */ + struct BSDF_data *b, + int nalt, + int nazi, + FVECT u, + FVECT v, + FVECT w, + MAT4 xm +) +{ + MAT4 mymat; + COLORV *outarr; + float *inpcoef; + COLORV *cp, *csum; + uint16 *distcnt; + FVECT dv; + double oom, wt; + int i, j, o; + int cnt; + COLOR col; + /* allocate temporary memory */ + outarr = (COLORV *)malloc(b->nout * sizeof(COLOR)); + distcnt = (uint16 *)calloc(nalt*nazi, sizeof(uint16)); + inpcoef = (float *)malloc(b->ninc * sizeof(float)); + if ((outarr == NULL) | (distcnt == NULL) | (inpcoef == NULL)) + error(SYSTEM, "out of memory in redistribute"); + /* compose matrix */ + for (i = 3; i--; ) { + mymat[i][0] = u[i]; + mymat[i][1] = v[i]; + mymat[i][2] = w[i]; + mymat[i][3] = 0.; + } + mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.; + mymat[3][3] = 1.; + if (xm != NULL) + multmat4(mymat, xm, mymat); + for (i = 3; i--; ) { /* make sure it's normalized */ + wt = 1./sqrt( mymat[0][i]*mymat[0][i] + + mymat[1][i]*mymat[1][i] + + mymat[2][i]*mymat[2][i] ); + for (j = 3; j--; ) + mymat[j][i] *= wt; + } + /* pass through BSDF */ + for (i = b->ninc; i--; ) { /* get input coefficients */ + getBSDF_incvec(dv, b, i); + multv3(dv, dv, mymat); + wt = getBSDF_incrad(b, i); + inpcoef[i] = PI*wt*wt * dv[2]; /* solid_angle*cosine(theta) */ + } + for (o = b->nout; o--; ) { + csum = &outarr[3*o]; + setcolor(csum, 0., 0., 0.); + oom = getBSDF_outrad(b, o); + oom *= oom * PI; + for (i = b->ninc; i--; ) { + wt = BSDF_data(b,i,o) * inpcoef[i] / oom; + cp = &distarr[3*i]; + copycolor(col, cp); + scalecolor(col, wt); + addcolor(csum, col); + } + wt = 1./b->ninc; + scalecolor(csum, wt); + } + free(inpcoef); + newdist(nalt*nazi); /* resample distribution */ + for (o = b->nout; o--; ) { + getBSDF_outvec(dv, b, o); + multv3(dv, dv, mymat); + j = (.5 + atan2(dv[1],dv[0])*(.5/PI))*nazi + .5; + if (j >= nazi) j = 0; + i = (0.9999 - dv[2]*dv[2])*nalt; + csum = &distarr[3*(i*nazi + j)]; + cp = &outarr[3*o]; + addcolor(csum, cp); + ++distcnt[i*nazi + j]; + } + free(outarr); + /* fill in missing bits */ + for (i = nalt; i--; ) + for (j = nazi; j--; ) { + int ii, jj, alt, azi; + if (distcnt[i*nazi + j]) + continue; + csum = &distarr[3*(i*nazi + j)]; + setcolor(csum, 0., 0., 0.); + cnt = 0; + for (o = 0; !cnt; o++) + for (ii = -o; ii <= o; ii++) { + alt = i + ii; + if (alt < 0) continue; + if (alt >= nalt) break; + for (jj = -o; jj <= o; jj++) { + if (ii*ii + jj*jj != o*o) + continue; + azi = j + jj; + if (azi >= nazi) azi -= nazi; + else if (azi < 0) azi += nazi; + if (!distcnt[alt*nazi + azi]) + continue; + cp = &distarr[3*(alt*nazi + azi)]; + addcolor(csum, cp); + cnt += distcnt[alt*nazi + azi]; + } + } + wt = 1./cnt; + scalecolor(csum, wt); + } + /* finish averages */ + for (i = nalt; i--; ) + for (j = nazi; j--; ) { + if ((cnt = distcnt[i*nazi + j]) <= 1) + continue; + csum = &distarr[3*(i*nazi + j)]; + wt = 1./cnt; + scalecolor(csum, wt); + } + free(distcnt); }
