root/Development/ray/src/gen/mkillum4.c
Revision 2.19
Fri Jun 12 17:37:37 2009 UTC (16 years, 6 months ago) by greg
FILE REMOVED
Broke BSDF-handling routines into their own module
Sat Jun 6 05:03:47 2009 UTC (16 years, 7 months ago) by greg
Changes since 2.17: +15 -6 lines
Diff to previous 2.17
Improved redistribute() sampling algorithm
Sat May 30 22:19:08 2009 UTC (16 years, 7 months ago) by greg
Changes since 2.16: +70 -10 lines
Diff to previous 2.16
Fixed bug in solid angle calculation and added BSDF checks
Thu May 28 18:38:52 2009 UTC (16 years, 7 months ago) by greg
Changes since 2.15: +2 -1 lines
Diff to previous 2.15
Bug fix in source sampling
Wed Mar 4 00:12:25 2009 UTC (16 years, 10 months ago) by greg
Changes since 2.14: +19 -5 lines
Diff to previous 2.14
Sun Jan 18 17:41:38 2009 UTC (16 years, 11 months ago) by greg
Diff to previous 2.13
Bug fix for "error 1 in redistribute"
Mon Nov 10 19:08:18 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 2.12
Thu May 1 16:42:06 2008 UTC (17 years, 8 months ago) by greg
Fri Apr 11 20:07:12 2008 UTC (17 years, 8 months ago) by greg
Changes since 2.10: +10 -9 lines
Fixed angle orientation
Thu Mar 27 01:40:30 2008 UTC (17 years, 9 months ago) by greg
Changes since 2.9: +13 -4 lines
Updated for newer XML format of BSDF data
Fri Jan 25 02:11:13 2008 UTC (17 years, 11 months ago) by greg
Changes since 2.8: +11 -1 lines
Thu Dec 13 07:03:37 2007 UTC (18 years ago) by greg
Wed Dec 12 05:09:58 2007 UTC (18 years ago) by greg
Changes since 2.6: +63 -18 lines
Initial implementation of BSDF complete (untested)
Sat Dec 8 01:43:09 2007 UTC (18 years ago) by greg
Changes since 2.5: +237 -23 lines
Wed Dec 5 20:07:34 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.4: +38 -85 lines
Improved BSDF resampling
Wed Dec 5 05:02:58 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.3: +17 -27 lines
Fixed resampling coefficients
Wed Nov 21 18:51:05 2007 UTC (18 years, 1 month ago) by greg
Fixed implicit declarations
Fri Sep 21 05:53:21 2007 UTC (18 years, 3 months ago) by greg
Changes since 2.1: +223 -4 lines
Tue Sep 18 19:51:07 2007 UTC (18 years, 3 months ago) by greg
