root/radiance/ray/src/gen/mkillum4.c
Revision: 2.19
Committed: Fri Jun 12 17:37:37 2009 UTC (15 years, 11 months ago) by greg
State: FILE REMOVED
Broke BSDF-handling routines into their own module
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.19 static const char RCSid[] = "$Id: mkillum4.c,v 2.18 2009/06/06 05:03:47 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines for handling BSDF data within mkillum
6     */
7
8     #include "mkillum.h"
9     #include "paths.h"
10 greg 2.2 #include "ezxml.h"
11 greg 2.12 #include <ctype.h>
12 greg 2.1
13 greg 2.18 #ifndef NBSDFSAMPS
14     #define NBSDFSAMPS 32 /* BSDF resampling count */
15     #endif
16 greg 2.6 #define MAXLATS 46 /* maximum number of latitudes */
17
18 greg 2.11 /* BSDF angle specification */
19 greg 2.6 typedef struct {
20 greg 2.7 char name[64]; /* basis name */
21 greg 2.6 int nangles; /* total number of directions */
22     struct {
23     float tmin; /* starting theta */
24     short nphis; /* number of phis (0 term) */
25     } lat[MAXLATS+1]; /* latitudes */
26     } ANGLE_BASIS;
27
28 greg 2.7 #define MAXABASES 3 /* limit on defined bases */
29 greg 2.6
30 greg 2.13 static ANGLE_BASIS abase_list[MAXABASES] = {
31 greg 2.6 {
32     "LBNL/Klems Full", 145,
33     { {-5., 1},
34     {5., 8},
35     {15., 16},
36     {25., 20},
37     {35., 24},
38     {45., 24},
39     {55., 24},
40     {65., 16},
41     {75., 12},
42     {90., 0} }
43     }, {
44     "LBNL/Klems Half", 73,
45     { {-6.5, 1},
46     {6.5, 8},
47     {19.5, 12},
48     {32.5, 16},
49     {46.5, 20},
50     {61.5, 12},
51     {76.5, 4},
52     {90., 0} }
53     }, {
54     "LBNL/Klems Quarter", 41,
55     { {-9., 1},
56     {9., 8},
57     {27., 12},
58     {46., 12},
59     {66., 8},
60     {90., 0} }
61     }
62     };
63
64 greg 2.7 static int nabases = 3; /* current number of defined bases */
65
66 greg 2.6
67     static int
68     ab_getvec( /* get vector for this angle basis index */
69     FVECT v,
70     int ndx,
71     void *p
72     )
73     {
74     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
75     int li;
76     double alt, azi, d;
77
78     if ((ndx < 0) | (ndx >= ab->nangles))
79     return(0);
80     for (li = 0; ndx >= ab->lat[li].nphis; li++)
81     ndx -= ab->lat[li].nphis;
82     alt = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin);
83     azi = 2.*PI*ndx/ab->lat[li].nphis;
84 greg 2.11 v[2] = d = cos(alt);
85     d = sqrt(1. - d*d); /* sin(alt) */
86 greg 2.6 v[0] = cos(azi)*d;
87     v[1] = sin(azi)*d;
88     return(1);
89     }
90
91
92     static int
93     ab_getndx( /* get index corresponding to the given vector */
94     FVECT v,
95     void *p
96     )
97     {
98     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
99     int li, ndx;
100     double alt, azi, d;
101
102 greg 2.7 if ((v[2] < -1.0) | (v[2] > 1.0))
103 greg 2.6 return(-1);
104     alt = 180.0/PI*acos(v[2]);
105     azi = 180.0/PI*atan2(v[1], v[0]);
106     if (azi < 0.0) azi += 360.0;
107     for (li = 1; ab->lat[li].tmin <= alt; li++)
108     if (!ab->lat[li].nphis)
109     return(-1);
110     --li;
111     ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
112     if (ndx >= ab->lat[li].nphis) ndx = 0;
113     while (li--)
114     ndx += ab->lat[li].nphis;
115     return(ndx);
116     }
117
118
119     static double
120     ab_getohm( /* get solid angle for this angle basis index */
121     int ndx,
122     void *p
123     )
124     {
125     ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
126     int li;
127 greg 2.17 double theta, theta1;
128 greg 2.6
129     if ((ndx < 0) | (ndx >= ab->nangles))
130     return(0);
131     for (li = 0; ndx >= ab->lat[li].nphis; li++)
132     ndx -= ab->lat[li].nphis;
133 greg 2.17 theta1 = PI/180. * ab->lat[li+1].tmin;
134 greg 2.7 if (ab->lat[li].nphis == 1) { /* special case */
135     if (ab->lat[li].tmin > FTINY)
136     error(USER, "unsupported BSDF coordinate system");
137 greg 2.17 return(2.*PI*(1. - cos(theta1)));
138 greg 2.7 }
139 greg 2.17 theta = PI/180. * ab->lat[li].tmin;
140     return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis);
141 greg 2.6 }
142
143
144     static int
145     ab_getvecR( /* get reverse vector for this angle basis index */
146     FVECT v,
147     int ndx,
148     void *p
149     )
150     {
151     if (!ab_getvec(v, ndx, p))
152     return(0);
153
154     v[0] = -v[0];
155     v[1] = -v[1];
156 greg 2.11 v[2] = -v[2];
157 greg 2.6
158     return(1);
159     }
160
161
162     static int
163     ab_getndxR( /* get index corresponding to the reverse vector */
164     FVECT v,
165     void *p
166     )
167     {
168     FVECT v2;
169
170     v2[0] = -v[0];
171     v2[1] = -v[1];
172 greg 2.11 v2[2] = -v[2];
173 greg 2.6
174     return ab_getndx(v2, p);
175     }
176
177 greg 2.7
178 greg 2.6 static void
179     load_bsdf_data( /* load BSDF distribution for this wavelength */
180     struct BSDF_data *dp,
181     ezxml_t wdb
182     )
183     {
184 greg 2.7 char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
185     char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
186     char *sdata;
187 greg 2.6 int i;
188
189 greg 2.7 if ((cbasis == NULL) | (rbasis == NULL)) {
190     error(WARNING, "missing column/row basis for BSDF");
191     return;
192     }
193     /* XXX need to add routines for loading in foreign bases */
194     for (i = nabases; i--; )
195 greg 2.6 if (!strcmp(cbasis, abase_list[i].name)) {
196     dp->ninc = abase_list[i].nangles;
197     dp->ib_priv = (void *)&abase_list[i];
198 greg 2.11 dp->ib_vec = ab_getvecR;
199     dp->ib_ndx = ab_getndxR;
200 greg 2.6 dp->ib_ohm = ab_getohm;
201     break;
202     }
203     if (i < 0) {
204 greg 2.7 sprintf(errmsg, "unsupported ColumnAngleBasis '%s'", cbasis);
205     error(WARNING, errmsg);
206     return;
207 greg 2.6 }
208 greg 2.7 for (i = nabases; i--; )
209 greg 2.6 if (!strcmp(rbasis, abase_list[i].name)) {
210     dp->nout = abase_list[i].nangles;
211     dp->ob_priv = (void *)&abase_list[i];
212 greg 2.11 dp->ob_vec = ab_getvec;
213     dp->ob_ndx = ab_getndx;
214 greg 2.6 dp->ob_ohm = ab_getohm;
215     break;
216     }
217     if (i < 0) {
218 greg 2.7 sprintf(errmsg, "unsupported RowAngleBasis '%s'", cbasis);
219     error(WARNING, errmsg);
220     return;
221     }
222     /* read BSDF data */
223     sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData"));
224     if (sdata == NULL) {
225     error(WARNING, "missing BSDF ScatteringData");
226     return;
227     }
228     dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout);
229     if (dp->bsdf == NULL)
230     error(SYSTEM, "out of memory in load_bsdf_data");
231     for (i = 0; i < dp->ninc*dp->nout; i++) {
232     char *sdnext = fskip(sdata);
233     if (sdnext == NULL) {
234     error(WARNING, "bad/missing BSDF ScatteringData");
235     free(dp->bsdf); dp->bsdf = NULL;
236     return;
237     }
238     while (*sdnext && isspace(*sdnext))
239     sdnext++;
240     if (*sdnext == ',') sdnext++;
241     dp->bsdf[i] = atof(sdata);
242     sdata = sdnext;
243     }
244     while (isspace(*sdata))
245     sdata++;
246     if (*sdata) {
247     sprintf(errmsg, "%d extra characters after BSDF ScatteringData",
248     strlen(sdata));
249     error(WARNING, errmsg);
250 greg 2.6 }
251     }
252
253 greg 2.1
254 greg 2.17 static int
255     check_bsdf_data( /* check that BSDF data is sane */
256     struct BSDF_data *dp
257     )
258     {
259     double * omega_arr;
260     double dom, hemi_total;
261     int nneg;
262     int i, o;
263
264     if (dp == NULL || dp->bsdf == NULL)
265     return(0);
266     omega_arr = (double *)calloc(dp->nout, sizeof(double));
267     if (omega_arr == NULL)
268     error(SYSTEM, "out of memory in check_bsdf_data");
269     hemi_total = .0;
270     for (o = dp->nout; o--; ) {
271     FVECT v;
272     dom = getBSDF_outohm(dp,o);
273     if (dom <= .0) {
274     error(WARNING, "zero/negative solid angle");
275     continue;
276     }
277     if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) {
278     error(WARNING, "illegal outgoing BSDF direction");
279     free(omega_arr);
280     return(0);
281     }
282     hemi_total += omega_arr[o] = dom*v[2];
283     }
284     if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
285     sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%",
286     100.*(hemi_total/PI - 1.));
287     error(WARNING, errmsg);
288     }
289     dom = PI / hemi_total; /* normalize solid angles */
290     for (o = dp->nout; o--; )
291     omega_arr[o] *= dom;
292     nneg = 0;
293     for (i = dp->ninc; i--; ) {
294     hemi_total = .0;
295     for (o = dp->nout; o--; ) {
296     double f = BSDF_value(dp,i,o);
297     if (f > .0)
298     hemi_total += f*omega_arr[o];
299     else if (f < -FTINY)
300     ++nneg;
301     }
302     if (hemi_total > 1.02) {
303     sprintf(errmsg, "BSDF direction passes %.1f%% of light",
304     100.*hemi_total);
305     error(WARNING, errmsg);
306     }
307     }
308     free(omega_arr);
309     if (nneg > 0) {
310     sprintf(errmsg, "%d negative BSDF values", nneg);
311     error(WARNING, errmsg);
312     return(0);
313     }
314     return(1);
315     }
316
317 greg 2.1 struct BSDF_data *
318     load_BSDF( /* load BSDF data from file */
319     char *fname
320     )
321     {
322     char *path;
323 greg 2.10 ezxml_t fl, wtl, wld, wdb;
324 greg 2.1 struct BSDF_data *dp;
325
326     path = getpath(fname, getrlibpath(), R_OK);
327     if (path == NULL) {
328     sprintf(errmsg, "cannot find BSDF file \"%s\"", fname);
329     error(WARNING, errmsg);
330     return(NULL);
331     }
332 greg 2.2 fl = ezxml_parse_file(path);
333     if (fl == NULL) {
334 greg 2.1 sprintf(errmsg, "cannot open BSDF \"%s\"", path);
335     error(WARNING, errmsg);
336     return(NULL);
337     }
338 greg 2.6 if (ezxml_error(fl)[0]) {
339 greg 2.10 sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl));
340 greg 2.6 error(WARNING, errmsg);
341     ezxml_free(fl);
342     return(NULL);
343     }
344 greg 2.10 if (strcmp(ezxml_name(fl), "WindowElement")) {
345     sprintf(errmsg,
346     "BSDF \"%s\": top level node not 'WindowElement'",
347     path);
348     error(WARNING, errmsg);
349     ezxml_free(fl);
350     return(NULL);
351     }
352     wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
353 greg 2.5 dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data));
354 greg 2.10 for (wld = ezxml_child(wtl, "WavelengthData");
355 greg 2.8 wld != NULL; wld = wld->next) {
356 greg 2.6 if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible"))
357 greg 2.2 continue;
358     wdb = ezxml_child(wld, "WavelengthDataBlock");
359     if (wdb == NULL) continue;
360 greg 2.6 if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")),
361 greg 2.2 "Transmission Front"))
362     continue;
363 greg 2.6 load_bsdf_data(dp, wdb); /* load front BTDF */
364     break; /* ignore the rest */
365     }
366     ezxml_free(fl); /* done with XML file */
367 greg 2.17 if (!check_bsdf_data(dp)) {
368 greg 2.6 sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path);
369     error(WARNING, errmsg);
370     free_BSDF(dp);
371     dp = NULL;
372 greg 2.2 }
373 greg 2.1 return(dp);
374     }
375
376
377     void
378     free_BSDF( /* free BSDF data structure */
379     struct BSDF_data *b
380     )
381     {
382     if (b == NULL)
383     return;
384 greg 2.6 if (b->bsdf != NULL)
385     free(b->bsdf);
386 greg 2.1 free(b);
387     }
388
389
390 greg 2.6 int
391 greg 2.1 r_BSDF_incvec( /* compute random input vector at given location */
392     FVECT v,
393     struct BSDF_data *b,
394     int i,
395     double rv,
396     MAT4 xm
397     )
398     {
399     FVECT pert;
400     double rad;
401     int j;
402
403 greg 2.6 if (!getBSDF_incvec(v, b, i))
404     return(0);
405     rad = sqrt(getBSDF_incohm(b, i) / PI);
406 greg 2.1 multisamp(pert, 3, rv);
407     for (j = 0; j < 3; j++)
408     v[j] += rad*(2.*pert[j] - 1.);
409     if (xm != NULL)
410     multv3(v, v, xm);
411 greg 2.7 return(normalize(v) != 0.0);
412 greg 2.1 }
413
414
415 greg 2.6 int
416 greg 2.1 r_BSDF_outvec( /* compute random output vector at given location */
417     FVECT v,
418     struct BSDF_data *b,
419     int o,
420     double rv,
421     MAT4 xm
422     )
423     {
424     FVECT pert;
425     double rad;
426     int j;
427
428 greg 2.6 if (!getBSDF_outvec(v, b, o))
429     return(0);
430     rad = sqrt(getBSDF_outohm(b, o) / PI);
431 greg 2.1 multisamp(pert, 3, rv);
432     for (j = 0; j < 3; j++)
433     v[j] += rad*(2.*pert[j] - 1.);
434     if (xm != NULL)
435     multv3(v, v, xm);
436 greg 2.7 return(normalize(v) != 0.0);
437 greg 2.1 }
438 greg 2.2
439
440     #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
441
442     static int
443     addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
444     char *xfarg[],
445     FVECT xp,
446     FVECT yp,
447     FVECT zp
448     )
449     {
450     static char bufs[3][16];
451     int bn = 0;
452     char **xfp = xfarg;
453     double theta;
454
455 greg 2.9 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
456     /* Special case for X' along Z-axis */
457     theta = -atan2(yp[0], yp[1]);
458     *xfp++ = "-ry";
459     *xfp++ = xp[2] < 0.0 ? "90" : "-90";
460     *xfp++ = "-rz";
461     sprintf(bufs[bn], "%f", theta*(180./PI));
462     *xfp++ = bufs[bn++];
463     return(xfp - xfarg);
464     }
465 greg 2.2 theta = atan2(yp[2], zp[2]);
466     if (!FEQ(theta,0.0)) {
467     *xfp++ = "-rx";
468     sprintf(bufs[bn], "%f", theta*(180./PI));
469     *xfp++ = bufs[bn++];
470     }
471     theta = asin(-xp[2]);
472     if (!FEQ(theta,0.0)) {
473     *xfp++ = "-ry";
474     sprintf(bufs[bn], " %f", theta*(180./PI));
475     *xfp++ = bufs[bn++];
476     }
477     theta = atan2(xp[1], xp[0]);
478     if (!FEQ(theta,0.0)) {
479     *xfp++ = "-rz";
480     sprintf(bufs[bn], "%f", theta*(180./PI));
481     *xfp++ = bufs[bn++];
482     }
483     *xfp = NULL;
484     return(xfp - xfarg);
485     }
486
487
488     int
489 greg 2.6 getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */
490 greg 2.2 MAT4 xm,
491     FVECT nrm,
492     UpDir ud
493     )
494     {
495     char *xfargs[7];
496     XF myxf;
497     FVECT updir, xdest, ydest;
498
499     updir[0] = updir[1] = updir[2] = 0.;
500     switch (ud) {
501     case UDzneg:
502     updir[2] = -1.;
503     break;
504     case UDyneg:
505     updir[1] = -1.;
506     break;
507     case UDxneg:
508     updir[0] = -1.;
509     break;
510     case UDxpos:
511     updir[0] = 1.;
512     break;
513     case UDypos:
514     updir[1] = 1.;
515     break;
516     case UDzpos:
517     updir[2] = 1.;
518     break;
519     case UDunknown:
520     return(0);
521     }
522     fcross(xdest, updir, nrm);
523     if (normalize(xdest) == 0.0)
524     return(0);
525     fcross(ydest, nrm, xdest);
526     xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs);
527     copymat4(xm, myxf.xfm);
528     return(1);
529     }
530
531
532     void
533     redistribute( /* pass distarr ray sums through BSDF */
534     struct BSDF_data *b,
535     int nalt,
536     int nazi,
537     FVECT u,
538     FVECT v,
539     FVECT w,
540     MAT4 xm
541     )
542     {
543 greg 2.6 int nout = 0;
544 greg 2.5 MAT4 mymat, inmat;
545     COLORV *idist;
546 greg 2.15 COLORV *cp;
547 greg 2.2 FVECT dv;
548 greg 2.5 double wt;
549 greg 2.18 int i, j, k, c, o;
550 greg 2.5 COLOR col, cinc;
551     /* copy incoming distribution */
552 greg 2.14 if (b->ninc > distsiz)
553 greg 2.5 error(INTERNAL, "error 1 in redistribute");
554 greg 2.14 idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc);
555 greg 2.5 if (idist == NULL)
556 greg 2.2 error(SYSTEM, "out of memory in redistribute");
557 greg 2.14 memcpy(idist, distarr, sizeof(COLOR)*b->ninc);
558 greg 2.5 /* compose direction transform */
559 greg 2.2 for (i = 3; i--; ) {
560     mymat[i][0] = u[i];
561     mymat[i][1] = v[i];
562     mymat[i][2] = w[i];
563     mymat[i][3] = 0.;
564     }
565     mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.;
566     mymat[3][3] = 1.;
567     if (xm != NULL)
568     multmat4(mymat, xm, mymat);
569     for (i = 3; i--; ) { /* make sure it's normalized */
570 greg 2.5 wt = 1./sqrt( mymat[0][i]*mymat[0][i] +
571 greg 2.2 mymat[1][i]*mymat[1][i] +
572     mymat[2][i]*mymat[2][i] );
573     for (j = 3; j--; )
574 greg 2.5 mymat[j][i] *= wt;
575 greg 2.2 }
576 greg 2.5 if (!invmat4(inmat, mymat)) /* need inverse as well */
577     error(INTERNAL, "cannot invert BSDF transform");
578     newdist(nalt*nazi); /* resample distribution */
579 greg 2.4 for (i = b->ninc; i--; ) {
580 greg 2.15 int direct_out = -1;
581     COLOR cdir;
582 greg 2.5 getBSDF_incvec(dv, b, i); /* compute incident irrad. */
583 greg 2.2 multv3(dv, dv, mymat);
584 greg 2.15 if (dv[2] < 0.0) {
585     dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2];
586     direct_out += (direct_discount != NULL);
587     }
588 greg 2.6 wt = getBSDF_incohm(b, i);
589     wt *= dv[2]; /* solid_angle*cosine(theta) */
590 greg 2.5 cp = &idist[3*i];
591     copycolor(cinc, cp);
592     scalecolor(cinc, wt);
593 greg 2.15 if (!direct_out) { /* discount direct contr. */
594     cp = &direct_discount[3*i];
595     copycolor(cdir, cp);
596     scalecolor(cdir, -wt);
597     direct_out = flatindex(dv, nalt, nazi);
598     }
599 greg 2.5 for (k = nalt; k--; ) /* loop over distribution */
600 greg 2.18 for (j = nazi; j--; ) {
601     int rstart = random();
602     for (c = NBSDFSAMPS; c--; ) {
603     double sp[2];
604     multisamp(sp, 2, urand(rstart+c));
605     flatdir(dv, (k + sp[0])/nalt,
606     (j + .5 - sp[1])/nazi);
607 greg 2.5 multv3(dv, dv, inmat);
608     /* evaluate BSDF @ outgoing */
609 greg 2.6 o = getBSDF_outndx(b, dv);
610     if (o < 0) {
611     nout++;
612     continue;
613     }
614 greg 2.18 wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS);
615 greg 2.5 copycolor(col, cinc);
616 greg 2.15 o = k*nazi + j;
617     if (o == direct_out)
618     addcolor(col, cdir); /* minus direct */
619 greg 2.5 scalecolor(col, wt);
620 greg 2.15 cp = &distarr[3*o];
621     addcolor(cp, col); /* sum into distribution */
622 greg 2.5 }
623 greg 2.18 }
624 greg 2.2 }
625 greg 2.5 free(idist); /* free temp space */
626 greg 2.6 if (nout) {
627     sprintf(errmsg, "missing %.1f%% of BSDF directions",
628 greg 2.18 100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS));
629 greg 2.6 error(WARNING, errmsg);
630     }
631 greg 2.2 }
