--- ray/src/gen/mkillum3.c 1992/08/12 14:18:04 2.5 +++ ray/src/gen/mkillum3.c 2004/09/28 17:54:18 2.10 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mkillum3.c,v 2.10 2004/09/28 17:54:18 greg Exp $"; #endif - /* * Routines to print mkillum objects */ @@ -17,10 +14,21 @@ char DATSUF[] = ".dat"; /* data file suffix */ char DSTSUF[] = ".dist"; /* distribution suffix */ char FNCFNM[] = "illum.cal"; /* function file name */ +void compinv(float *rinv, float *rp, int m); +void colorout(int p, float *da, int n, int m, double mult, FILE *fp); +void fputnum(double d, FILE *fp); +void brightout(float *da, int n, int m, double mult, FILE *fp); +void fputeol(FILE *fp); +void compavg(float col[3], float *da, int n); +char * dfname(struct illum_args *il, int c); +FILE * dfopen(struct illum_args *il, int c); -printobj(mod, obj) /* print out an object */ -char *mod; -register OBJREC *obj; + +void +printobj( /* print out an object */ + char *mod, + register OBJREC *obj +) { register int i; @@ -48,11 +56,11 @@ register OBJREC *obj; char * -dfname(il, c) /* return data file name */ -struct illum_args *il; -int c; +dfname( /* return data file name */ + struct illum_args *il, + int c +) { - extern char *getpath(), *strcpy(); char fname[MAXSTR]; register char *s; @@ -69,9 +77,10 @@ int c; FILE * -dfopen(il, c) /* open data file */ -register struct illum_args *il; -int c; +dfopen( /* open data file */ + register struct illum_args *il, + int c +) { char *fn; FILE *fp; @@ -89,11 +98,16 @@ int c; } -flatout(il, da, n, m, u, v, w) /* write hemispherical distribution */ -struct illum_args *il; -float *da; -int n, m; -FVECT u, v, w; +extern void +flatout( /* write hemispherical distribution */ + struct illum_args *il, + float *da, + int n, + int m, + FVECT u, + FVECT v, + FVECT w +) { float *Ninv; FILE *dfp; @@ -122,7 +136,8 @@ FVECT u, v, w; il->matname, DSTSUF); printf("\n5 noneg"); dfp = dfopen(il, 0); - fprintf(dfp, "2\n%f %f %d\n%f %f %d\n", 1.+.5/n, .5/n, n+1, + fprintf(dfp, "2\n%f %f %d\n%f %f %d\n", + 1.+.5/n, .5/n, n+1, 0., 2.*PI, m+1); brightout(Ninv, 1, m, 1./il->nsamps/brt(il->col), dfp); brightout(da, n, m, 1./il->nsamps/brt(il->col), dfp); @@ -136,14 +151,17 @@ FVECT u, v, w; printf("\t%f\t%f\t%f\n", v[0], v[1], v[2]); printf("\t%f\t%f\t%f\n", w[0], w[1], w[2]); il->dfnum++; - free((char *)Ninv); + free((void *)Ninv); } -roundout(il, da, n, m) /* write spherical distribution */ -struct illum_args *il; -float *da; -int n, m; +extern void +roundout( /* write spherical distribution */ + struct illum_args *il, + float *da, + int n, + int m +) { float *Ninv, *Sinv; FILE *dfp; @@ -151,7 +169,7 @@ int n, m; if ((Ninv = (float *)malloc(3*m*sizeof(float))) == NULL || (Sinv = (float *)malloc(3*m*sizeof(float))) == NULL) - error(SYSTEM, "out of memory in flatout"); + error(SYSTEM, "out of memory in roundout"); compinv(Ninv, da, m); compinv(Sinv, da+3*m*(n-1), m); if (il->flags & IL_COLDST) { @@ -175,7 +193,8 @@ int n, m; il->matname, DSTSUF); printf("\n5 noneg"); dfp = dfopen(il, 0); - fprintf(dfp, "2\n%f %f %d\n%f %f %d\n", 1.-1./n, -1.+1./n, n, + fprintf(dfp, "2\n%f %f %d\n%f %f %d\n", + 1.+1./n, -1.-1./n, n+2, 0., 2.*PI, m+1); brightout(Ninv, 1, m, 1./il->nsamps/brt(il->col), dfp); brightout(da, n, m, 1./il->nsamps/brt(il->col), dfp); @@ -187,14 +206,16 @@ int n, m; printf("\n\t%s il_alt il_azi", FNCFNM); printf("\n0\n0\n"); il->dfnum++; - free((char *)Ninv); - free((char *)Sinv); + free((void *)Ninv); + free((void *)Sinv); } -illumout(il, ob) /* print illum object */ -register struct illum_args *il; -OBJREC *ob; +extern void +illumout( /* print illum object */ + register struct illum_args *il, + OBJREC *ob +) { double cout[3]; @@ -221,10 +242,12 @@ OBJREC *ob; } -compavg(col, da, n) /* compute average for set of data values */ -float col[3]; -register float *da; -int n; +void +compavg( /* compute average for set of data values */ + float col[3], + register float *da, + int n +) { register int i; @@ -240,9 +263,12 @@ int n; } -compinv(rinv, rp, m) /* compute other side of row average */ -register float *rinv, *rp; -int m; +void +compinv( /* compute other side of row average */ + register float *rinv, + register float *rp, + int m +) { float avg[3]; @@ -255,10 +281,12 @@ int m; } -average(il, da, n) /* evaluate average value for distribution */ -register struct illum_args *il; -float *da; -int n; +extern int +average( /* evaluate average value for distribution */ + register struct illum_args *il, + float *da, + int n +) { compavg(il->col, da, n); /* average */ if (il->nsamps > 1) { @@ -273,9 +301,11 @@ int n; static int colmcnt = 0; /* count of columns written */ -fputnum(d, fp) /* put out a number to fp */ -double d; -FILE *fp; +void +fputnum( /* put out a number to fp */ + double d, + FILE *fp +) { if (colmcnt++ % 5 == 0) putc('\n', fp); @@ -283,20 +313,25 @@ FILE *fp; } -fputeol(fp) /* write end of line to fp */ -register FILE *fp; +void +fputeol( /* write end of line to fp */ + register FILE *fp +) { putc('\n', fp); colmcnt = 0; } -colorout(p, da, n, m, mult, fp) /* put out color distribution data */ -int p; -register float *da; -int n, m; -double mult; -FILE *fp; +void +colorout( /* put out color distribution data */ + int p, + register float *da, + int n, + int m, + double mult, + FILE *fp +) { register int i, j; @@ -310,11 +345,14 @@ FILE *fp; } -brightout(da, n, m, mult, fp) /* put out brightness distribution data */ -register float *da; -int n, m; -double mult; -FILE *fp; +void +brightout( /* put out brightness distribution data */ + register float *da, + int n, + int m, + double mult, + FILE *fp +) { register int i, j;
