--- ray/src/gen/mkillum3.c 2003/03/10 17:26:26 2.8 +++ ray/src/gen/mkillum3.c 2004/09/28 17:54:18 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id"; +static const char RCSid[] = "$Id: mkillum3.c,v 2.10 2004/09/28 17:54:18 greg Exp $"; #endif /* * Routines to print mkillum objects @@ -14,10 +14,21 @@ char DATSUF[] = ".dat"; /* data file suffix */ char DSTSUF[] = ".dist"; /* distribution suffix */ char FNCFNM[] = "illum.cal"; /* function file name */ +void compinv(float *rinv, float *rp, int m); +void colorout(int p, float *da, int n, int m, double mult, FILE *fp); +void fputnum(double d, FILE *fp); +void brightout(float *da, int n, int m, double mult, FILE *fp); +void fputeol(FILE *fp); +void compavg(float col[3], float *da, int n); +char * dfname(struct illum_args *il, int c); +FILE * dfopen(struct illum_args *il, int c); -printobj(mod, obj) /* print out an object */ -char *mod; -register OBJREC *obj; + +void +printobj( /* print out an object */ + char *mod, + register OBJREC *obj +) { register int i; @@ -45,9 +56,10 @@ register OBJREC *obj; char * -dfname(il, c) /* return data file name */ -struct illum_args *il; -int c; +dfname( /* return data file name */ + struct illum_args *il, + int c +) { char fname[MAXSTR]; register char *s; @@ -65,9 +77,10 @@ int c; FILE * -dfopen(il, c) /* open data file */ -register struct illum_args *il; -int c; +dfopen( /* open data file */ + register struct illum_args *il, + int c +) { char *fn; FILE *fp; @@ -85,11 +98,16 @@ int c; } -flatout(il, da, n, m, u, v, w) /* write hemispherical distribution */ -struct illum_args *il; -float *da; -int n, m; -FVECT u, v, w; +extern void +flatout( /* write hemispherical distribution */ + struct illum_args *il, + float *da, + int n, + int m, + FVECT u, + FVECT v, + FVECT w +) { float *Ninv; FILE *dfp; @@ -137,10 +155,13 @@ FVECT u, v, w; } -roundout(il, da, n, m) /* write spherical distribution */ -struct illum_args *il; -float *da; -int n, m; +extern void +roundout( /* write spherical distribution */ + struct illum_args *il, + float *da, + int n, + int m +) { float *Ninv, *Sinv; FILE *dfp; @@ -190,9 +211,11 @@ int n, m; } -illumout(il, ob) /* print illum object */ -register struct illum_args *il; -OBJREC *ob; +extern void +illumout( /* print illum object */ + register struct illum_args *il, + OBJREC *ob +) { double cout[3]; @@ -219,10 +242,12 @@ OBJREC *ob; } -compavg(col, da, n) /* compute average for set of data values */ -float col[3]; -register float *da; -int n; +void +compavg( /* compute average for set of data values */ + float col[3], + register float *da, + int n +) { register int i; @@ -238,9 +263,12 @@ int n; } -compinv(rinv, rp, m) /* compute other side of row average */ -register float *rinv, *rp; -int m; +void +compinv( /* compute other side of row average */ + register float *rinv, + register float *rp, + int m +) { float avg[3]; @@ -253,10 +281,12 @@ int m; } -average(il, da, n) /* evaluate average value for distribution */ -register struct illum_args *il; -float *da; -int n; +extern int +average( /* evaluate average value for distribution */ + register struct illum_args *il, + float *da, + int n +) { compavg(il->col, da, n); /* average */ if (il->nsamps > 1) { @@ -271,9 +301,11 @@ int n; static int colmcnt = 0; /* count of columns written */ -fputnum(d, fp) /* put out a number to fp */ -double d; -FILE *fp; +void +fputnum( /* put out a number to fp */ + double d, + FILE *fp +) { if (colmcnt++ % 5 == 0) putc('\n', fp); @@ -281,20 +313,25 @@ FILE *fp; } -fputeol(fp) /* write end of line to fp */ -register FILE *fp; +void +fputeol( /* write end of line to fp */ + register FILE *fp +) { putc('\n', fp); colmcnt = 0; } -colorout(p, da, n, m, mult, fp) /* put out color distribution data */ -int p; -register float *da; -int n, m; -double mult; -FILE *fp; +void +colorout( /* put out color distribution data */ + int p, + register float *da, + int n, + int m, + double mult, + FILE *fp +) { register int i, j; @@ -308,11 +345,14 @@ FILE *fp; } -brightout(da, n, m, mult, fp) /* put out brightness distribution data */ -register float *da; -int n, m; -double mult; -FILE *fp; +void +brightout( /* put out brightness distribution data */ + register float *da, + int n, + int m, + double mult, + FILE *fp +) { register int i, j;
