root/Development/ray/src/gen/mkillum3.c
Sat Dec 16 18:35:27 2023 UTC (22 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.14: +10 -12 lines
Diff to previous 2.14
perf(mkillum): Replaced brt() macro with proper one from color.h
Thu Sep 15 22:34:41 2016 UTC (9 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.13: +35 -35 lines
Diff to previous 2.13
Made mkillum more forgiving of non-planar polygons
Mon Aug 15 19:48:06 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.12
Thu Sep 13 17:52:35 2007 UTC (18 years, 1 month ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.11: +24 -26 lines
Made use of COLORV in place of float more consistent
Thu Sep 13 06:31:21 2007 UTC (18 years, 1 month ago) by greg
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Tue Sep 28 17:54:18 2004 UTC (21 years, 1 month ago) by greg
Sun Nov 16 10:29:38 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.8: +88 -48 lines
Mon Mar 10 17:26:26 2003 UTC (22 years, 8 months ago) by greg
Compile fixes for Linux
Sat Feb 22 02:07:24 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.6: +4 -7 lines
Wed Aug 12 14:24:08 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.5: +5 -3 lines
fixed a couple of minor oversights (bugs!)
Wed Aug 12 14:18:04 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.4: +57 -28 lines
simplified interpolation of polar regions
Mon Aug 10 15:55:10 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.3: +35 -14 lines
eliminated star patterns at poles by adding pole interpolation
Thu Mar 12 11:44:01 1992 UTC (33 years, 8 months ago) by greg
fixed handling of surfaces
Wed Mar 11 12:25:49 1992 UTC (33 years, 8 months ago) by greg
changed so light below threshold is printed as ordinary object
Tue Nov 12 17:05:08 1991 UTC (34 years ago) by greg
Diff to previous 1.8
Tue Nov 12 10:52:37 1991 UTC (34 years ago) by greg
Diff to previous 1.7
changed noop function to noneg in brightfunc
Wed Oct 30 12:30:32 1991 UTC (34 years ago) by greg
Diff to previous 1.6
slight adjustment to brightness function (NTSC -> standard monitor)
Mon Aug 26 10:16:59 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.5: +54 -26 lines
Diff to previous 1.5
fixed distribution pattern discontinuity
Fri Aug 23 12:30:35 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.4
Thu Aug 22 12:12:25 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +5 -4 lines
Diff to previous 1.3
interpret d=0 to mean diffuse source
changed peano() calls to multisamp()
Thu Jul 25 12:52:21 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +1 -4 lines
Diff to previous 1.2
test debugging
Thu Jul 25 10:59:09 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.1: +29 -29 lines
Diff to previous 1.1
visual debugging pass
Wed Jul 24 16:48:45 1991 UTC (34 years, 3 months ago) by greg
