--- ray/src/gen/mkillum3.c 2004/09/28 17:54:18 2.10 +++ ray/src/gen/mkillum3.c 2007/09/13 17:52:35 2.12 @@ -1,11 +1,12 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum3.c,v 2.10 2004/09/28 17:54:18 greg Exp $"; +static const char RCSid[] = "$Id: mkillum3.c,v 2.12 2007/09/13 17:52:35 greg Exp $"; #endif /* * Routines to print mkillum objects */ #include "mkillum.h" +#include "paths.h" #define brt(col) (.263*(col)[0]+.655*(col)[1]+.082*(col)[2]) @@ -14,12 +15,12 @@ char DATSUF[] = ".dat"; /* data file suffix */ char DSTSUF[] = ".dist"; /* distribution suffix */ char FNCFNM[] = "illum.cal"; /* function file name */ -void compinv(float *rinv, float *rp, int m); -void colorout(int p, float *da, int n, int m, double mult, FILE *fp); +void compinv(COLORV *rinv, COLORV *rp, int m); +void colorout(int p, COLORV *da, int n, int m, double mult, FILE *fp); void fputnum(double d, FILE *fp); -void brightout(float *da, int n, int m, double mult, FILE *fp); +void brightout(COLORV *da, int n, int m, double mult, FILE *fp); void fputeol(FILE *fp); -void compavg(float col[3], float *da, int n); +void compavg(COLOR col, COLORV *da, int n); char * dfname(struct illum_args *il, int c); FILE * dfopen(struct illum_args *il, int c); @@ -101,7 +102,7 @@ dfopen( /* open data file */ extern void flatout( /* write hemispherical distribution */ struct illum_args *il, - float *da, + COLORV *da, int n, int m, FVECT u, @@ -109,11 +110,11 @@ flatout( /* write hemispherical distribution */ FVECT w ) { - float *Ninv; + COLORV *Ninv; FILE *dfp; int i; - if ((Ninv = (float *)malloc(3*m*sizeof(float))) == NULL) + if ((Ninv = (COLORV *)malloc(3*m*sizeof(COLORV))) == NULL) error(SYSTEM, "out of memory in flatout"); compinv(Ninv, da, m); if (il->flags & IL_COLDST) { @@ -158,17 +159,17 @@ flatout( /* write hemispherical distribution */ extern void roundout( /* write spherical distribution */ struct illum_args *il, - float *da, + COLORV *da, int n, int m ) { - float *Ninv, *Sinv; + COLORV *Ninv, *Sinv; FILE *dfp; int i; - if ((Ninv = (float *)malloc(3*m*sizeof(float))) == NULL || - (Sinv = (float *)malloc(3*m*sizeof(float))) == NULL) + if ((Ninv = (COLORV *)malloc(3*m*sizeof(COLORV))) == NULL || + (Sinv = (COLORV *)malloc(3*m*sizeof(COLORV))) == NULL) error(SYSTEM, "out of memory in roundout"); compinv(Ninv, da, m); compinv(Sinv, da+3*m*(n-1), m); @@ -244,33 +245,31 @@ illumout( /* print illum object */ void compavg( /* compute average for set of data values */ - float col[3], - register float *da, + COLOR col, + register COLORV *da, int n ) { register int i; - col[0] = col[1] = col[2] = 0.; + setcolor(col, 0.0, 0.0, 0.0); i = n; while (i-- > 0) { - col[0] += *da++; - col[1] += *da++; - col[2] += *da++; + addcolor(col, da); + da += 3; } - for (i = 0; i < 3; i++) - col[i] /= (double)n; + scalecolor(col, 1./(double)n); } void compinv( /* compute other side of row average */ - register float *rinv, - register float *rp, + register COLORV *rinv, + register COLORV *rp, int m ) { - float avg[3]; + COLOR avg; compavg(avg, rp, m); /* row average */ while (m-- > 0) { @@ -284,7 +283,7 @@ compinv( /* compute other side of row average */ extern int average( /* evaluate average value for distribution */ register struct illum_args *il, - float *da, + COLORV *da, int n ) { @@ -326,7 +325,7 @@ fputeol( /* write end of line to fp */ void colorout( /* put out color distribution data */ int p, - register float *da, + register COLORV *da, int n, int m, double mult, @@ -347,7 +346,7 @@ colorout( /* put out color distribution data */ void brightout( /* put out brightness distribution data */ - register float *da, + register COLORV *da, int n, int m, double mult,
