root/radiance/ray/src/gen/mkillum2.c
Revision: 2.43
Committed: Fri Nov 17 20:02:07 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 2.42: +4 -4 lines
2 static const char RCSid[] = "$Id: mkillum2.c,v 2.42 2016/09/16 15:08:38 greg Exp $";
5 * Routines to do the actual calculation for mkillum
6 */
7
8 #include <string.h>
9
10 #include "mkillum.h"
11 #include "face.h"
12 #include "cone.h"
13 #include "source.h"
14 #include "paths.h"
15
16 #ifndef R_EPS
17 #define R_EPS 0.005 /* relative epsilon for ray origin */
18 #endif
19
20 COLORV * distarr = NULL; /* distribution array */
21 int distsiz = 0;
22
23
24 void
25 newdist( /* allocate & clear distribution array */
26 int siz
27 )
28 {
29 if (siz <= 0) {
30 if (distsiz > 0)
31 free(distarr);
32 distarr = NULL;
33 distsiz = 0;
34 return;
35 }
36 if (distsiz < siz) {
37 if (distsiz > 0)
38 free(distarr);
39 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
40 if (distarr == NULL)
41 error(SYSTEM, "out of memory in newdist");
42 distsiz = siz;
43 }
44 memset(distarr, '\0', sizeof(COLOR)*siz);
45 }
46
47
48 int
49 process_ray( /* process a ray result or report error */
50 RAY *r,
51 int rv
52 )
53 {
54 COLORV *colp;
55
56 if (rv == 0) /* no result ready */
57 return(0);
58 if (rv < 0)
59 error(USER, "ray tracing process died");
60 if (r->rno >= distsiz)
61 error(INTERNAL, "bad returned index in process_ray");
62 smultscolor(r->rcol, r->rcoef); /* in case it's a source ray */
63 colp = &distarr[r->rno * 3];
64 addscolor(colp, r->rcol);
65 return(1);
66 }
67
68
69 void
70 raysamp( /* queue a ray sample */
71 int ndx,
72 FVECT org,
73 FVECT dir
74 )
75 {
76 RAY myRay;
77 int rv;
78
79 if ((ndx < 0) | (ndx >= distsiz))
80 error(INTERNAL, "bad index in raysamp");
81 VCOPY(myRay.rorg, org);
82 VCOPY(myRay.rdir, dir);
83 myRay.rmax = .0;
84 rayorigin(&myRay, PRIMARY|SPECULAR, NULL, NULL);
85 myRay.rno = ndx;
86 /* queue ray, check result */
87 process_ray(&myRay, ray_pqueue(&myRay));
88 }
89
90
91 void
92 srcsamps( /* sample sources from this surface position */
93 struct illum_args *il,
94 FVECT org,
95 double eps,
96 MAT4 ixfm
97 )
98 {
99 int nalt=1, nazi=1;
100 SRCINDEX si;
101 RAY sr;
102 FVECT v;
103 double d;
104 int i, j;
105 /* get sampling density */
106 if (il->sampdens > 0) {
107 i = PI * il->sampdens;
108 nalt = sqrt(i/PI) + .5;
109 nazi = PI*nalt + .5;
110 }
111 initsrcindex(&si); /* loop over (sub)sources */
112 for ( ; ; ) {
113 VCOPY(sr.rorg, org); /* pick side to shoot from */
114 samplendx++; /* increment sample counter */
115 if (!srcray(&sr, NULL, &si))
116 break; /* end of sources */
117 /* index direction */
118 if (ixfm != NULL)
119 multv3(v, sr.rdir, ixfm);
120 else
121 VCOPY(v, sr.rdir);
122 if (v[2] >= -FTINY)
123 continue; /* only sample transmission */
124 v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
125 sr.rno = flatindex(v, nalt, nazi);
126 d = nalt*nazi*(1./PI) * v[2];
127 d *= si.dom; /* solid angle correction */
128 scalescolor(sr.rcoef, d);
129 VSUM(sr.rorg, sr.rorg, sr.rdir, -eps);
130 process_ray(&sr, ray_pqueue(&sr));
131 }
132 }
133
134
135 void
136 rayclean() /* finish all pending rays */
137 {
138 RAY myRay;
139
140 while (process_ray(&myRay, ray_presult(&myRay, 0)))
141 ;
142 }
143
144
145 static void
146 mkaxes( /* compute u and v to go with n */
147 FVECT u,
148 FVECT v,
149 FVECT n
150 )
151 {
152 getperpendicular(u, n, 1);
153 fcross(v, n, u);
154 }
155
156
157 static void
158 rounddir( /* compute uniform spherical direction */
159 FVECT dv,
160 double alt,
161 double azi
162 )
163 {
164 double d1, d2;
165
166 dv[2] = 1. - 2.*alt;
167 d1 = sqrt(1. - dv[2]*dv[2]);
168 d2 = 2.*PI * azi;
169 dv[0] = d1*cos(d2);
170 dv[1] = d1*sin(d2);
171 }
172
173
174 void
175 flatdir( /* compute uniform hemispherical direction */
176 FVECT dv,
177 double alt,
178 double azi
179 )
180 {
181 double d1, d2;
182
183 d1 = sqrt(alt);
184 d2 = 2.*PI * azi;
185 dv[0] = d1*cos(d2);
186 dv[1] = d1*sin(d2);
187 dv[2] = sqrt(1. - alt);
188 }
189
190
191 int
192 flatindex( /* compute index for hemispherical direction */
193 FVECT dv,
194 int nalt,
195 int nazi
196 )
197 {
198 double d;
199 int i, j;
200
201 d = 1.0 - dv[2]*dv[2];
202 i = d*nalt;
203 d = atan2(dv[1], dv[0]) * (0.5/PI);
204 if (d < 0.0) d += 1.0;
205 j = d*nazi + 0.5;
206 if (j >= nazi) j = 0;
207 return(i*nazi + j);
208 }
209
210
211 int
212 my_default( /* default illum action */
213 OBJREC *ob,
214 struct illum_args *il,
215 char *nm
216 )
217 {
218 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
219 nm, ofun[ob->otype].funame, ob->oname);
220 error(WARNING, errmsg);
221 printobj(il->altmat, ob);
222 return(1);
223 }
224
225
226 int
227 my_face( /* make an illum face */
228 OBJREC *ob,
229 struct illum_args *il,
230 char *nm
231 )
232 {
233 int dim[2];
234 int n, nalt, nazi, alti;
235 double sp[2], r1, r2;
236 int h;
237 FVECT dn, org, dir;
238 FVECT u, v;
239 double ur[2], vr[2];
240 double epsilon;
241 MAT4 xfm;
242 char xfrot[64];
243 int nallow;
244 FACE *fa;
245 int i, j;
246 /* get/check arguments */
247 fa = getface(ob);
248 if (fa->area == 0.0) {
249 freeface(ob);
250 return(my_default(ob, il, nm));
251 }
252 /* set up sampling */
253 if (il->sampdens <= 0) {
254 nalt = nazi = 1; /* diffuse assumption */
255 } else {
256 n = PI * il->sampdens;
257 nalt = sqrt(n/PI) + .5;
258 nazi = PI*nalt + .5;
259 }
260 n = nazi*nalt;
261 newdist(n);
262 /* take first edge >= sqrt(area) */
263 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
264 u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
265 u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
266 u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
267 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
268 break;
269 }
270 if (i < fa->nv) { /* got one! -- let's align our axes */
271 r2 = 1.0/sqrt(r1);
272 u[0] *= r2; u[1] *= r2; u[2] *= r2;
273 fcross(v, fa->norm, u);
274 } else /* oh well, we'll just have to wing it */
275 mkaxes(u, v, fa->norm);
276 /* now, find limits in (u,v) coordinates */
277 ur[0] = vr[0] = FHUGE;
278 ur[1] = vr[1] = -FHUGE;
279 for (i = 0; i < fa->nv; i++) {
280 r1 = DOT(VERTEX(fa,i),u);
281 if (r1 < ur[0]) ur[0] = r1;
282 if (r1 > ur[1]) ur[1] = r1;
283 r2 = DOT(VERTEX(fa,i),v);
284 if (r2 < vr[0]) vr[0] = r2;
285 if (r2 > vr[1]) vr[1] = r2;
286 }
287 dim[0] = random();
288 /* sample polygon */
289 nallow = 5*n*il->nsamps;
290 epsilon = R_EPS*sqrt(fa->area);
291 for (dim[1] = 0; dim[1] < n; dim[1]++)
292 for (i = 0; i < il->nsamps; i++) {
293 /* randomize direction */
294 h = ilhash(dim, 2) + i;
295 multisamp(sp, 2, urand(h));
296 alti = dim[1]/nazi;
297 r1 = (alti + sp[0])/nalt;
298 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
299 flatdir(dn, r1, r2);
300 for (j = 0; j < 3; j++)
301 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
302 dn[2]*fa->norm[j];
303 /* randomize location */
304 do {
305 multisamp(sp, 2, urand(h+4862+nallow));
306 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
307 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
308 for (j = 0; j < 3; j++)
309 org[j] = r1*u[j] + r2*v[j]
310 + fa->offset*fa->norm[j];
311 } while (!inface(org, fa) && nallow-- > 0);
312 if (nallow < 0) {
313 objerror(ob, WARNING, "bad aspect");
314 rayclean();
315 freeface(ob);
316 return(my_default(ob, il, nm));
317 }
318 VSUM(org, org, dir, -epsilon);
319 /* send sample */
320 raysamp(dim[1], org, dir);
321 }
322 /* add in direct component? */
323 if (il->flags & IL_LIGHT) {
324 MAT4 ixfm;
325 for (i = 3; i--; ) {
326 ixfm[i][0] = u[i];
327 ixfm[i][1] = v[i];
328 ixfm[i][2] = fa->norm[i];
329 ixfm[i][3] = 0.;
330 }
331 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
332 ixfm[3][3] = 1.;
333 dim[0] = random();
334 nallow = 10*il->nsamps;
335 for (i = 0; i < il->nsamps; i++) {
336 /* randomize location */
337 h = dim[0] + samplendx++;
338 do {
339 multisamp(sp, 2, urand(h+nallow));
340 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
341 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
342 for (j = 0; j < 3; j++)
343 org[j] = r1*u[j] + r2*v[j]
344 + fa->offset*fa->norm[j];
345 } while (!inface(org, fa) && nallow-- > 0);
346 if (nallow < 0) {
347 objerror(ob, WARNING, "bad aspect");
348 rayclean();
349 freeface(ob);
350 return(my_default(ob, il, nm));
351 }
352 /* sample source rays */
353 srcsamps(il, org, epsilon, ixfm);
354 }
355 }
356 /* wait for all rays to finish */
357 rayclean();
358 /* write out the face and its distribution */
359 if (average(il, distarr, n)) {
360 if (il->sampdens > 0)
361 flatout(il, distarr, nalt, nazi, u, v, fa->norm);
362 illumout(il, ob);
363 } else
364 printobj(il->altmat, ob);
365 /* clean up */
366 freeface(ob);
367 return(0);
368 }
369
370
371 int
372 my_sphere( /* make an illum sphere */
373 OBJREC *ob,
374 struct illum_args *il,
375 char *nm
376 )
377 {
378 int dim[3];
379 int n, nalt, nazi;
380 double sp[4], r1, r2, r3;
381 FVECT org, dir;
382 FVECT u, v;
383 int i, j;
384 /* check arguments */
385 if (ob->oargs.nfargs != 4)
386 objerror(ob, USER, "bad # of arguments");
387 /* set up sampling */
388 if (il->sampdens <= 0)
389 nalt = nazi = 1;
390 else {
391 n = 4.*PI * il->sampdens;
392 nalt = sqrt(2./PI*n) + .5;
393 nazi = PI/2.*nalt + .5;
394 }
395 n = nalt*nazi;
396 newdist(n);
397 dim[0] = random();
398 /* sample sphere */
399 for (dim[1] = 0; dim[1] < nalt; dim[1]++)
400 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
401 for (i = 0; i < il->nsamps; i++) {
402 /* next sample point */
403 multisamp(sp, 4, urand(ilhash(dim,3)+i));
404 /* random direction */
405 r1 = (dim[1] + sp[0])/nalt;
406 r2 = (dim[2] + sp[1] - .5)/nazi;
407 rounddir(dir, r1, r2);
408 /* random location */
409 mkaxes(u, v, dir); /* yuck! */
410 r3 = sqrt(sp[2]);
411 r2 = 2.*PI*sp[3];
412 r1 = r3*ob->oargs.farg[3]*cos(r2);
413 r2 = r3*ob->oargs.farg[3]*sin(r2);
414 r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
415 for (j = 0; j < 3; j++) {
416 org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
417 r3*dir[j];
418 dir[j] = -dir[j];
419 }
420 /* send sample */
421 raysamp(dim[1]*nazi+dim[2], org, dir);
422 }
423 /* wait for all rays to finish */
424 rayclean();
425 /* write out the sphere and its distribution */
426 if (average(il, distarr, n)) {
427 if (il->sampdens > 0)
428 roundout(il, distarr, nalt, nazi);
429 else
430 objerror(ob, WARNING, "diffuse distribution");
431 illumout(il, ob);
432 } else
433 printobj(il->altmat, ob);
434 /* clean up */
435 return(1);
436 }
437
438
439 int
440 my_ring( /* make an illum ring */
441 OBJREC *ob,
442 struct illum_args *il,
443 char *nm
444 )
445 {
446 int dim[2];
447 int n, nalt, nazi, alti;
448 double sp[2], r1, r2, r3;
449 double epsilon;
450 int h;
451 FVECT dn, org, dir;
452 FVECT u, v;
453 MAT4 xfm;
454 CONE *co;
455 int i, j;
456 /* get/check arguments */
457 co = getcone(ob, 0);
458 if (co == NULL)
459 objerror(ob, USER, "cannot create illum");
460 /* set up sampling */
461 if (il->sampdens <= 0) {
462 nalt = nazi = 1; /* diffuse assumption */
463 } else {
464 n = PI * il->sampdens;
465 nalt = sqrt(n/PI) + .5;
466 nazi = PI*nalt + .5;
467 }
468 epsilon = R_EPS*CO_R1(co);
469 n = nazi*nalt;
470 newdist(n);
471 mkaxes(u, v, co->ad);
472 dim[0] = random();
473 /* sample disk */
474 for (dim[1] = 0; dim[1] < n; dim[1]++)
475 for (i = 0; i < il->nsamps; i++) {
476 /* next sample point */
477 h = ilhash(dim,2) + i;
478 /* randomize direction */
479 multisamp(sp, 2, urand(h));
480 alti = dim[1]/nazi;
481 r1 = (alti + sp[0])/nalt;
482 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
483 flatdir(dn, r1, r2);
484 for (j = 0; j < 3; j++)
485 dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
486 /* randomize location */
487 multisamp(sp, 2, urand(h+8371));
488 r3 = sqrt(CO_R0(co)*CO_R0(co) +
489 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
490 r2 = 2.*PI*sp[1];
491 r1 = r3*cos(r2);
492 r2 = r3*sin(r2);
493 for (j = 0; j < 3; j++)
494 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
495 epsilon*co->ad[j];
496 /* send sample */
497 raysamp(dim[1], org, dir);
498 }
499 /* add in direct component? */
500 if (il->flags & IL_LIGHT) {
501 MAT4 ixfm;
502 for (i = 3; i--; ) {
503 ixfm[i][0] = u[i];
504 ixfm[i][1] = v[i];
505 ixfm[i][2] = co->ad[i];
506 ixfm[i][3] = 0.;
507 }
508 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
509 ixfm[3][3] = 1.;
510 dim[0] = random();
511 for (i = 0; i < il->nsamps; i++) {
512 /* randomize location */
513 h = dim[0] + samplendx++;
514 multisamp(sp, 2, urand(h));
515 r3 = sqrt(CO_R0(co)*CO_R0(co) +
516 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
517 r2 = 2.*PI*sp[1];
518 r1 = r3*cos(r2);
519 r2 = r3*sin(r2);
520 for (j = 0; j < 3; j++)
521 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
522 /* sample source rays */
523 srcsamps(il, org, epsilon, ixfm);
524 }
525 }
526 /* wait for all rays to finish */
527 rayclean();
528 /* write out the ring and its distribution */
529 if (average(il, distarr, n)) {
530 if (il->sampdens > 0)
531 flatout(il, distarr, nalt, nazi, u, v, co->ad);
532 illumout(il, ob);
533 } else
534 printobj(il->altmat, ob);
535 /* clean up */
536 freecone(ob);
537 return(1);
538 }
