--- ray/src/gen/mkillum2.c 2012/10/13 20:15:43 2.38 +++ ray/src/gen/mkillum2.c 2023/11/17 20:02:07 2.43 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.38 2012/10/13 20:15:43 greg Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.43 2023/11/17 20:02:07 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -13,8 +13,8 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.38 20 #include "source.h" #include "paths.h" -#ifndef NBSDFSAMPS -#define NBSDFSAMPS 256 /* BSDF resampling count */ +#ifndef R_EPS +#define R_EPS 0.005 /* relative epsilon for ray origin */ #endif COLORV * distarr = NULL; /* distribution array */ @@ -59,9 +59,9 @@ process_ray( /* process a ray result or report error error(USER, "ray tracing process died"); if (r->rno >= distsiz) error(INTERNAL, "bad returned index in process_ray"); - multcolor(r->rcol, r->rcoef); /* in case it's a source ray */ + smultscolor(r->rcol, r->rcoef); /* in case it's a source ray */ colp = &distarr[r->rno * 3]; - addcolor(colp, r->rcol); + addscolor(colp, r->rcol); return(1); } @@ -92,7 +92,7 @@ void srcsamps( /* sample sources from this surface position */ struct illum_args *il, FVECT org, - FVECT nrm, + double eps, MAT4 ixfm ) { @@ -111,8 +111,6 @@ srcsamps( /* sample sources from this surface positi initsrcindex(&si); /* loop over (sub)sources */ for ( ; ; ) { VCOPY(sr.rorg, org); /* pick side to shoot from */ - d = 5.*FTINY; - VSUM(sr.rorg, sr.rorg, nrm, d); samplendx++; /* increment sample counter */ if (!srcray(&sr, NULL, &si)) break; /* end of sources */ @@ -122,12 +120,13 @@ srcsamps( /* sample sources from this surface positi else VCOPY(v, sr.rdir); if (v[2] >= -FTINY) - continue; /* only sample transmission */ + continue; /* only sample transmission */ v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; sr.rno = flatindex(v, nalt, nazi); d = nalt*nazi*(1./PI) * v[2]; d *= si.dom; /* solid angle correction */ - scalecolor(sr.rcoef, d); + scalescolor(sr.rcoef, d); + VSUM(sr.rorg, sr.rorg, sr.rdir, -eps); process_ray(&sr, ray_pqueue(&sr)); } } @@ -150,22 +149,14 @@ mkaxes( /* compute u and v to go with n */ FVECT n ) { - register int i; - - v[0] = v[1] = v[2] = 0.0; - for (i = 0; i < 3; i++) - if (n[i] < 0.6 && n[i] > -0.6) - break; - v[i] = 1.0; - fcross(u, v, n); - normalize(u); + getperpendicular(u, n, 1); fcross(v, n, u); } static void rounddir( /* compute uniform spherical direction */ - register FVECT dv, + FVECT dv, double alt, double azi ) @@ -246,6 +237,7 @@ my_face( /* make an illum face */ FVECT dn, org, dir; FVECT u, v; double ur[2], vr[2]; + double epsilon; MAT4 xfm; char xfrot[64]; int nallow; @@ -295,6 +287,7 @@ my_face( /* make an illum face */ dim[0] = random(); /* sample polygon */ nallow = 5*n*il->nsamps; + epsilon = R_EPS*sqrt(fa->area); for (dim[1] = 0; dim[1] < n; dim[1]++) for (i = 0; i < il->nsamps; i++) { /* randomize direction */ @@ -322,9 +315,7 @@ my_face( /* make an illum face */ freeface(ob); return(my_default(ob, il, nm)); } - r1 = 5.*FTINY; - for (j = 0; j < 3; j++) - org[j] += r1*fa->norm[j]; + VSUM(org, org, dir, -epsilon); /* send sample */ raysamp(dim[1], org, dir); } @@ -359,7 +350,7 @@ my_face( /* make an illum face */ return(my_default(ob, il, nm)); } /* sample source rays */ - srcsamps(il, org, fa->norm, ixfm); + srcsamps(il, org, epsilon, ixfm); } } /* wait for all rays to finish */ @@ -379,7 +370,7 @@ my_face( /* make an illum face */ int my_sphere( /* make an illum sphere */ - register OBJREC *ob, + OBJREC *ob, struct illum_args *il, char *nm ) @@ -389,7 +380,7 @@ my_sphere( /* make an illum sphere */ double sp[4], r1, r2, r3; FVECT org, dir; FVECT u, v; - register int i, j; + int i, j; /* check arguments */ if (ob->oargs.nfargs != 4) objerror(ob, USER, "bad # of arguments"); @@ -455,15 +446,18 @@ my_ring( /* make an illum ring */ int dim[2]; int n, nalt, nazi, alti; double sp[2], r1, r2, r3; + double epsilon; int h; FVECT dn, org, dir; FVECT u, v; MAT4 xfm; CONE *co; int i, j; - /* get/check arguments */ + /* get/check arguments */ co = getcone(ob, 0); - /* set up sampling */ + if (co == NULL) + objerror(ob, USER, "cannot create illum"); + /* set up sampling */ if (il->sampdens <= 0) { nalt = nazi = 1; /* diffuse assumption */ } else { @@ -471,6 +465,7 @@ my_ring( /* make an illum ring */ nalt = sqrt(n/PI) + .5; nazi = PI*nalt + .5; } + epsilon = R_EPS*CO_R1(co); n = nazi*nalt; newdist(n); mkaxes(u, v, co->ad); @@ -495,10 +490,9 @@ my_ring( /* make an illum ring */ r2 = 2.*PI*sp[1]; r1 = r3*cos(r2); r2 = r3*sin(r2); - r3 = 5.*FTINY; for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] + - r3*co->ad[j]; + epsilon*co->ad[j]; /* send sample */ raysamp(dim[1], org, dir); } @@ -526,7 +520,7 @@ my_ring( /* make an illum ring */ for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j]; /* sample source rays */ - srcsamps(il, org, co->ad, ixfm); + srcsamps(il, org, epsilon, ixfm); } } /* wait for all rays to finish */
