root/Development/ray/src/gen/mkillum2.c
Fri Jun 20 03:43:17 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.43 , to selected 2.36
fix(rvu): Issue with live reset of -u boolean and consistency improvements
Fri Nov 17 20:02:07 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 2.42: +4 -4 lines
Diff to previous 2.42 , to selected 2.36
Fri Sep 16 15:08:38 2016 UTC (9 years, 2 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.41: +12 -9 lines
Diff to previous 2.41 , to selected 2.36
Additional checks and fixes for ring illums
Thu Sep 15 22:34:41 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.40: +9 -10 lines
Diff to previous 2.40 , to selected 2.36
Made mkillum more forgiving of non-planar polygons
Thu May 21 05:54:54 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.39 , to selected 2.36
Thu Dec 4 05:26:28 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.38: +5 -13 lines
Diff to previous 2.38 , to selected 2.36
Sat Oct 13 20:15:43 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.37: +51 -327 lines
Diff to previous 2.37 , to selected 2.36
Tue Aug 16 18:09:53 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.36: +4 -7 lines
Diff to previous 2.36
Minor fixes
Revision 2.36 - (view) (download) (annotate) - [selected]
Mon Aug 15 19:48:06 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.35: +7 -7 lines
Diff to previous 2.35
Fri Sep 3 23:53:50 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.34: +60 -3 lines
Diff to previous 2.34 , to selected 2.36
Wed Sep 9 15:32:20 2009 UTC (16 years, 2 months ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33 , to selected 2.36
Fixed bug introduced in last bug-fix.
Tue Sep 8 23:05:47 2009 UTC (16 years, 2 months ago) by greg
Changes since 2.32: +7 -3 lines
Diff to previous 2.32 , to selected 2.36
Attempt to fix bug in l- setting with BSDF
Thu Jul 2 04:26:41 2009 UTC (16 years, 4 months ago) by greg
Diff to previous 2.31 , to selected 2.36
Increased BSDF sampling to improve smoothness in pathological cases (zenith)
Fri Jun 12 17:37:37 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.30: +107 -1 lines
Diff to previous 2.30 , to selected 2.36
Broke BSDF-handling routines into their own module
Thu May 28 18:38:52 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29 , to selected 2.36
Bug fix in source sampling
Wed Mar 4 00:12:25 2009 UTC (16 years, 8 months ago) by greg
Changes since 2.28: +68 -16 lines
Diff to previous 2.28 , to selected 2.36
Thu Dec 13 07:03:37 2007 UTC (17 years, 11 months ago) by greg
Diff to previous 2.27 , to selected 2.36
Wed Dec 12 05:09:58 2007 UTC (17 years, 11 months ago) by greg
Changes since 2.26: +4 -2 lines
Diff to previous 2.26 , to selected 2.36
Initial implementation of BSDF complete (untested)
Sat Dec 8 01:43:09 2007 UTC (17 years, 11 months ago) by greg
Changes since 2.25: +2 -3 lines
Diff to previous 2.25 , to selected 2.36
Thu Dec 6 19:40:43 2007 UTC (17 years, 11 months ago) by greg
Changes since 2.24: +167 -18 lines
Diff to previous 2.24 , to selected 2.36
Added light source sampling when l+ and -dv- are set
Wed Dec 5 20:07:34 2007 UTC (17 years, 11 months ago) by greg
Changes since 2.23: +6 -6 lines
Diff to previous 2.23 , to selected 2.36
Improved BSDF resampling
Mon Nov 5 23:40:26 2007 UTC (18 years ago) by greg
Diff to previous 2.22 , to selected 2.36
Sun Sep 30 19:05:26 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.21: +27 -19 lines
Diff to previous 2.21 , to selected 2.36
Fixed BTDF sampling density to match output angles
Fri Sep 21 05:53:21 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.20: +146 -107 lines
Diff to previous 2.20 , to selected 2.36
Tue Sep 18 19:51:07 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.19: +8 -9 lines
Diff to previous 2.19 , to selected 2.36
Tue Sep 18 03:35:09 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.18: +5 -5 lines
Diff to previous 2.18 , to selected 2.36
Corrected calls from o_default() to my_default()
Thu Sep 13 06:31:21 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.17: +86 -138 lines
Diff to previous 2.17 , to selected 2.36
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Sun Sep 19 08:42:22 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.16: +11 -20 lines
Diff to previous 2.16 , to selected 2.36
Fri Sep 17 21:43:50 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.15: +120 -50 lines
Diff to previous 2.15 , to selected 2.36
Tue Mar 30 20:40:04 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 2.14 , to selected 2.36
Sun Mar 28 20:33:12 2004 UTC (21 years, 7 months ago) by schorsch
Diff to previous 2.13 , to selected 2.36
Fri Nov 21 07:15:30 2003 UTC (22 years ago) by greg
Changes since 2.12: +14 -12 lines
Diff to previous 2.12 , to selected 2.36
Sun Nov 16 10:29:38 2003 UTC (22 years ago) by schorsch
Changes since 2.11: +69 -36 lines
Diff to previous 2.11 , to selected 2.36
Mon Jun 30 14:59:11 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 2.10 , to selected 2.36
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.9: +2 -5 lines
Diff to previous 2.9 , to selected 2.36
Sat Feb 22 02:07:24 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.8: +5 -8 lines
Diff to previous 2.8 , to selected 2.36
Wed Jul 9 11:24:52 1997 UTC (28 years, 4 months ago) by gregl
Diff to previous 2.7 , to selected 2.36
Tue Nov 7 17:50:44 1995 UTC (30 years ago) by greg
Diff to previous 2.6 , to selected 2.36
fixed aspect on spherical divisions
Fri Jan 7 14:51:46 1994 UTC (31 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.36
fixed bug in calculation of ring sample positions
Thu Aug 13 11:23:46 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.4: +3 -2 lines
Diff to previous 2.4 , to selected 2.36
minor optimization in long-enough edge determination
Thu Aug 13 10:03:19 1992 UTC (33 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 2.36
minor improvement to check ALL edges for possible u vector in face
Wed Aug 12 14:44:15 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.2: +13 -1 lines
Diff to previous 2.2 , to selected 2.36
made off-axis polygons sample better
Wed Mar 11 12:25:47 1992 UTC (33 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.36
changed so light below threshold is printed as ordinary object
Tue Nov 12 17:05:11 1991 UTC (34 years ago) by greg
Diff to previous 1.14 , to selected 2.36
Fri Nov 8 13:17:47 1991 UTC (34 years ago) by greg
Diff to previous 1.13 , to selected 2.36
reset errno at appropriate points
Mon Aug 26 10:16:56 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.12 , to selected 2.36
fixed distribution pattern discontinuity
Fri Aug 23 12:30:33 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.11: +20 -14 lines
Diff to previous 1.11 , to selected 2.36
Thu Aug 22 12:12:23 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.10: +39 -19 lines
Diff to previous 1.10 , to selected 2.36
interpret d=0 to mean diffuse source
changed peano() calls to multisamp()
Tue Aug 13 13:45:18 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.9: +26 -34 lines
Diff to previous 1.9 , to selected 2.36
changed from urind() to peano() for n-dimensional sampling
Tue Jul 30 13:00:26 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.8: +1 -2 lines
Diff to previous 1.8 , to selected 2.36
added zeroing of position set as tag to rtrace
Thu Jul 25 14:43:15 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.7: +2 -8 lines
Diff to previous 1.7 , to selected 2.36
*** empty log message ***
Thu Jul 25 14:12:22 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.6 , to selected 2.36
Thu Jul 25 12:52:18 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 2.36
test debugging
Thu Jul 25 10:59:07 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +28 -18 lines
Diff to previous 1.4 , to selected 2.36
visual debugging pass
Wed Jul 24 16:48:26 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.3: +63 -43 lines
Diff to previous 1.3 , to selected 2.36
first version of mkillum
Wed Jul 24 13:32:05 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +138 -2 lines
Diff to previous 1.2 , to selected 2.36
Wed Jul 24 12:22:05 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.1: +124 -1 lines
Diff to previous 1.1 , to selected 2.36
Tue Jul 23 15:42:42 1991 UTC (34 years, 4 months ago) by greg
Diff to selected 2.36
