--- ray/src/gen/mkillum2.c 2007/12/13 07:03:37 2.28 +++ ray/src/gen/mkillum2.c 2009/07/02 04:26:41 2.32 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.28 2007/12/13 07:03:37 greg Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.32 2009/07/02 04:26:41 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -12,9 +12,13 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.28 20 #include "cone.h" #include "source.h" +#ifndef NBSDFSAMPS +#define NBSDFSAMPS 256 /* BSDF resampling count */ +#endif COLORV * distarr = NULL; /* distribution array */ int distsiz = 0; +COLORV * direct_discount = NULL; /* amount to take off direct */ void @@ -41,6 +45,27 @@ newdist( /* allocate & clear distribution array */ } +static void +new_discount() /* allocate space for direct contrib. record */ +{ + if (distsiz <= 0) + return; + direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR)); + if (direct_discount == NULL) + error(SYSTEM, "out of memory in new_discount"); +} + + +static void +done_discount() /* clear off direct contrib. record */ +{ + if (direct_discount == NULL) + return; + free((void *)direct_discount); + direct_discount = NULL; +} + + int process_ray( /* process a ray result or report error */ RAY *r, @@ -58,6 +83,11 @@ process_ray( /* process a ray result or report error multcolor(r->rcol, r->rcoef); /* in case it's a source ray */ colp = &distarr[r->rno * 3]; addcolor(colp, r->rcol); + if (r->rsrc >= 0 && /* remember source contrib. */ + direct_discount != NULL) { + colp = &direct_discount[r->rno * 3]; + addcolor(colp, r->rcol); + } return(1); } @@ -127,6 +157,7 @@ srcsamps( /* sample sources from this surface positi d = 5.*FTINY; for (i = 3; i--; ) sr.rorg[i] += d*nrm[i]; + samplendx++; /* increment sample counter */ if (!srcray(&sr, NULL, &si)) break; /* end of sources */ /* index direction */ @@ -143,14 +174,9 @@ srcsamps( /* sample sources from this surface positi } else { if (v[2] >= -FTINY) continue; /* only sample transmission */ - d = 1.0 - v[2]*v[2]; - i = d*nalt; - d = atan2(-v[1], -v[0])/(2.*PI); - if (d < 0.0) d += 1.0; - j = d*nazi + 0.5; - if (j >= nazi) j = 0; - sr.rno = i*nazi + j; - d = nalt*nazi/PI * -v[2]; + v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; + sr.rno = flatindex(v, nalt, nazi); + d = nalt*nazi*(1./PI) * v[2]; } d *= si.dom; /* solid angle correction */ scalecolor(sr.rcoef, d); @@ -222,7 +248,26 @@ flatdir( /* compute uniform hemispherical direction * dv[2] = sqrt(1. - alt); } +int +flatindex( /* compute index for hemispherical direction */ + FVECT dv, + int nalt, + int nazi +) +{ + double d; + int i, j; + + d = 1.0 - dv[2]*dv[2]; + i = d*nalt; + d = atan2(dv[1], dv[0]) * (0.5/PI); + if (d < 0.0) d += 1.0; + j = d*nazi + 0.5; + if (j >= nazi) j = 0; + return(i*nazi + j); +} + int my_default( /* default illum action */ OBJREC *ob, @@ -350,7 +395,7 @@ my_face( /* make an illum face */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (!directvis && il->flags & IL_LIGHT) { + if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) { MAT4 ixfm; if (il->sd == NULL) { for (i = 3; i--; ) { @@ -361,8 +406,13 @@ my_face( /* make an illum face */ } ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; ixfm[3][3] = 1.; - } else if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, "cannot invert BSDF transform"); + } else { + if (!invmat4(ixfm, xfm)) + objerror(ob, INTERNAL, + "cannot invert BSDF transform"); + if (!(il->flags & IL_LIGHT)) + new_discount(); + } dim[0] = random(); nallow = 10*il->nsamps; for (i = 0; i < il->nsamps; i++) { @@ -392,6 +442,7 @@ my_face( /* make an illum face */ nalt = sqrt(il->sd->nout/PI) + .5; nazi = PI*nalt + .5; redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm); + done_discount(); if (!il->sampdens) il->sampdens = nalt*nazi/PI + .999; } @@ -552,7 +603,7 @@ my_ring( /* make an illum ring */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (!directvis && il->flags & IL_LIGHT) { + if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) { MAT4 ixfm; if (il->sd == NULL) { for (i = 3; i--; ) { @@ -563,8 +614,13 @@ my_ring( /* make an illum ring */ } ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; ixfm[3][3] = 1.; - } else if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, "cannot invert BSDF transform"); + } else { + if (!invmat4(ixfm, xfm)) + objerror(ob, INTERNAL, + "cannot invert BSDF transform"); + if (!(il->flags & IL_LIGHT)) + new_discount(); + } dim[0] = random(); for (i = 0; i < il->nsamps; i++) { /* randomize location */ @@ -587,6 +643,7 @@ my_ring( /* make an illum ring */ nalt = sqrt(il->sd->nout/PI) + .5; nazi = PI*nalt + .5; redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm); + done_discount(); if (!il->sampdens) il->sampdens = nalt*nazi/PI + .999; } @@ -600,4 +657,106 @@ my_ring( /* make an illum ring */ /* clean up */ freecone(ob); return(1); +} + + +void +redistribute( /* pass distarr ray sums through BSDF */ + struct BSDF_data *b, + int nalt, + int nazi, + FVECT u, + FVECT v, + FVECT w, + MAT4 xm +) +{ + int nout = 0; + MAT4 mymat, inmat; + COLORV *idist; + COLORV *cp; + FVECT dv; + double wt; + int i, j, k, c, o; + COLOR col, cinc; + /* copy incoming distribution */ + if (b->ninc > distsiz) + error(INTERNAL, "error 1 in redistribute"); + idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc); + if (idist == NULL) + error(SYSTEM, "out of memory in redistribute"); + memcpy(idist, distarr, sizeof(COLOR)*b->ninc); + /* compose direction transform */ + for (i = 3; i--; ) { + mymat[i][0] = u[i]; + mymat[i][1] = v[i]; + mymat[i][2] = w[i]; + mymat[i][3] = 0.; + } + mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.; + mymat[3][3] = 1.; + if (xm != NULL) + multmat4(mymat, xm, mymat); + for (i = 3; i--; ) { /* make sure it's normalized */ + wt = 1./sqrt( mymat[0][i]*mymat[0][i] + + mymat[1][i]*mymat[1][i] + + mymat[2][i]*mymat[2][i] ); + for (j = 3; j--; ) + mymat[j][i] *= wt; + } + if (!invmat4(inmat, mymat)) /* need inverse as well */ + error(INTERNAL, "cannot invert BSDF transform"); + newdist(nalt*nazi); /* resample distribution */ + for (i = b->ninc; i--; ) { + int direct_out = -1; + COLOR cdir; + getBSDF_incvec(dv, b, i); /* compute incident irrad. */ + multv3(dv, dv, mymat); + if (dv[2] < 0.0) { + dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2]; + direct_out += (direct_discount != NULL); + } + wt = getBSDF_incohm(b, i); + wt *= dv[2]; /* solid_angle*cosine(theta) */ + cp = &idist[3*i]; + copycolor(cinc, cp); + scalecolor(cinc, wt); + if (!direct_out) { /* discount direct contr. */ + cp = &direct_discount[3*i]; + copycolor(cdir, cp); + scalecolor(cdir, -wt); + direct_out = flatindex(dv, nalt, nazi); + } + for (k = nalt; k--; ) /* loop over distribution */ + for (j = nazi; j--; ) { + int rstart = random(); + for (c = NBSDFSAMPS; c--; ) { + double sp[2]; + multisamp(sp, 2, urand(rstart+c)); + flatdir(dv, (k + sp[0])/nalt, + (j + .5 - sp[1])/nazi); + multv3(dv, dv, inmat); + /* evaluate BSDF @ outgoing */ + o = getBSDF_outndx(b, dv); + if (o < 0) { + nout++; + continue; + } + wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS); + copycolor(col, cinc); + o = k*nazi + j; + if (o == direct_out) + addcolor(col, cdir); /* minus direct */ + scalecolor(col, wt); + cp = &distarr[3*o]; + addcolor(cp, col); /* sum into distribution */ + } + } + } + free(idist); /* free temp space */ + if (nout) { + sprintf(errmsg, "missing %.1f%% of BSDF directions", + 100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS)); + error(WARNING, errmsg); + } }
