--- ray/src/gen/mkillum2.c 2004/09/19 08:42:22 2.17 +++ ray/src/gen/mkillum2.c 2007/09/13 06:31:21 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.17 2004/09/19 08:42:22 greg Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.18 2007/09/13 06:31:21 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -11,7 +11,6 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.17 20 #include "face.h" #include "cone.h" #include "random.h" -#include "selcall.h" static void mkaxes(FVECT u, FVECT v, FVECT n); @@ -19,22 +18,86 @@ static void rounddir(FVECT dv, double alt, double azi) static void flatdir(FVECT dv, double alt, double azi); +static COLORV * distarr = NULL; /* distribution array */ +static int distsiz = 0; + + static void -rayclean( /* finish all pending rays */ - struct rtproc *rt0 +newdist( /* allocate & clear distribution array */ + int siz ) { - rayflush(rt0, 1); - while (raywait(rt0) != NULL) + if (siz == 0) { + if (distsiz > 0) + free((void *)distarr); + distarr = NULL; + distsiz = 0; + return; + } + if (distsiz < siz) { + free((void *)distarr); + distarr = (COLORV *)malloc(sizeof(COLORV)*3*siz); + if (distarr == NULL) + error(SYSTEM, "Out of memory in distalloc"); + distsiz = siz; + } + memset(distarr, '\0', sizeof(COLORV)*3*siz); +} + + +static int +process_ray(RAY *r, int rv) +{ + COLORV *colp; + + if (rv == 0) + return(0); + if (rv < 0) + error(USER, "Ray tracing process died"); + if (r->rno >= distsiz) + error(INTERNAL, "Bad returned index in process_ray"); + colp = &distarr[r->rno * 3]; + addcolor(colp, r->rcol); + return(1); +} + + +static void +raysamp( /* queue a ray sample */ + int ndx, + FVECT org, + FVECT dir +) +{ + RAY myRay; + int rv; + + if ((ndx < 0) | (ndx >= distsiz)) + error(INTERNAL, "Bad index in raysamp"); + VCOPY(myRay.rorg, org); + VCOPY(myRay.rdir, dir); + myRay.rmax = .0; + rayorigin(&myRay, PRIMARY, NULL, NULL); + myRay.rno = ndx; + /* queue ray, check result */ + process_ray(&myRay, ray_pqueue(&myRay)); +} + + +static void +rayclean() /* finish all pending rays */ +{ + RAY myRay; + + while (process_ray(&myRay, ray_presult(&myRay, 0))) ; } int /* XXX type conflict with otypes.h */ -o_default( /* default illum action */ +my_default( /* default illum action */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt0, char *nm ) { @@ -47,17 +110,15 @@ o_default( /* default illum action */ int -o_face( /* make an illum face */ +my_face( /* make an illum face */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt0, char *nm ) { #define MAXMISS (5*n*il->nsamps) int dim[3]; int n, nalt, nazi, h; - float *distarr; double sp[2], r1, r2; FVECT dn, org, dir; FVECT u, v; @@ -69,7 +130,7 @@ o_face( /* make an illum face */ fa = getface(ob); if (fa->area == 0.0) { freeface(ob); - return(o_default(ob, il, rt0, nm)); + return(o_default(ob, il, nm)); } /* set up sampling */ if (il->sampdens <= 0) @@ -80,9 +141,7 @@ o_face( /* make an illum face */ nazi = PI*nalt + .5; } n = nalt*nazi; - distarr = (float *)calloc(n, 3*sizeof(float)); - if (distarr == NULL) - error(SYSTEM, "out of memory in o_face"); + newdist(n); /* take first edge longer than sqrt(area) */ for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) { u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0]; @@ -133,17 +192,17 @@ o_face( /* make an illum face */ } while (!inface(org, fa) && nmisses++ < MAXMISS); if (nmisses > MAXMISS) { objerror(ob, WARNING, "bad aspect"); - rayclean(rt0); + rayclean(); freeface(ob); free((void *)distarr); - return(o_default(ob, il, rt0, nm)); + return(o_default(ob, il, nm)); } for (j = 0; j < 3; j++) org[j] += .001*fa->norm[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); + raysamp(dim[1]*nazi+dim[2], org, dir); } - rayclean(rt0); + rayclean(); /* write out the face and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -153,23 +212,20 @@ o_face( /* make an illum face */ printobj(il->altmat, ob); /* clean up */ freeface(ob); - free((void *)distarr); return(0); #undef MAXMISS } int -o_sphere( /* make an illum sphere */ +my_sphere( /* make an illum sphere */ register OBJREC *ob, struct illum_args *il, - struct rtproc *rt0, char *nm ) { int dim[3]; int n, nalt, nazi; - float *distarr; double sp[4], r1, r2, r3; FVECT org, dir; FVECT u, v; @@ -186,9 +242,7 @@ o_sphere( /* make an illum sphere */ nazi = PI/2.*nalt + .5; } n = nalt*nazi; - distarr = (float *)calloc(n, 3*sizeof(float)); - if (distarr == NULL) - error(SYSTEM, "out of memory in o_sphere"); + newdist(n); dim[0] = random(); /* sample sphere */ for (dim[1] = 0; dim[1] < nalt; dim[1]++) @@ -213,9 +267,9 @@ o_sphere( /* make an illum sphere */ dir[j] = -dir[j]; } /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); + raysamp(dim[1]*nazi+dim[2], org, dir); } - rayclean(rt0); + rayclean(); /* write out the sphere and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -226,22 +280,19 @@ o_sphere( /* make an illum sphere */ } else printobj(il->altmat, ob); /* clean up */ - free((void *)distarr); return(1); } int -o_ring( /* make an illum ring */ +my_ring( /* make an illum ring */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt0, char *nm ) { int dim[3]; int n, nalt, nazi; - float *distarr; double sp[4], r1, r2, r3; FVECT dn, org, dir; FVECT u, v; @@ -258,9 +309,7 @@ o_ring( /* make an illum ring */ nazi = PI*nalt + .5; } n = nalt*nazi; - distarr = (float *)calloc(n, 3*sizeof(float)); - if (distarr == NULL) - error(SYSTEM, "out of memory in o_ring"); + newdist(n); mkaxes(u, v, co->ad); dim[0] = random(); /* sample disk */ @@ -286,9 +335,9 @@ o_ring( /* make an illum ring */ .001*co->ad[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); + raysamp(dim[1]*nazi+dim[2], org, dir); } - rayclean(rt0); + rayclean(); /* write out the ring and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -298,108 +347,7 @@ o_ring( /* make an illum ring */ printobj(il->altmat, ob); /* clean up */ freecone(ob); - free((void *)distarr); return(1); -} - - -void -raysamp( /* queue a ray sample */ - float res[3], - FVECT org, - FVECT dir, - struct rtproc *rt0 -) -{ - register struct rtproc *rt; - register float *fp; - - for (rt = rt0; rt != NULL; rt = rt->next) - if (rt->nrays < rt->bsiz && rt->dest[rt->nrays] == NULL) - break; - if (rt == NULL) /* need to free up buffer? */ - rt = raywait(rt0); - if (rt == NULL) - error(SYSTEM, "raywait() returned NULL in raysamp()"); - fp = rt->buf + 6*rt->nrays; - *fp++ = org[0]; *fp++ = org[1]; *fp++ = org[2]; - *fp++ = dir[0]; *fp++ = dir[1]; *fp = dir[2]; - rt->dest[rt->nrays++] = res; - if (rt->nrays == rt->bsiz) - rayflush(rt, 0); -} - - -void -rayflush( /* flush queued rays to rtrace */ - register struct rtproc *rt, - int doall -) -{ - int nw; - - do { - if (rt->nrays <= 0) - continue; - memset(rt->buf+6*rt->nrays, 0, 6*sizeof(float)); - nw = 6*sizeof(float)*(rt->nrays+1); - errno = 0; - if (writebuf(rt->pd.w, (char *)rt->buf, nw) < nw) - error(SYSTEM, "error writing to rtrace process"); - rt->nrays = 0; /* flag buffer as flushed */ - } while (doall && (rt = rt->next) != NULL); -} - - -struct rtproc * -raywait( /* retrieve rtrace results */ - struct rtproc *rt0 -) -{ - fd_set readset, errset; - int nr; - struct rtproc *rtfree; - register struct rtproc *rt; - register int n; - /* prepare select call */ - FD_ZERO(&readset); FD_ZERO(&errset); n = 0; - nr = 0; - for (rt = rt0; rt != NULL; rt = rt->next) { - if (rt->nrays == 0 && rt->dest[0] != NULL) { - FD_SET(rt->pd.r, &readset); - ++nr; - } - FD_SET(rt->pd.r, &errset); - if (rt->pd.r >= n) - n = rt->pd.r + 1; - } - if (!nr) /* no rays pending */ - return(NULL); - if (nr > 1) { /* call select for multiple processes */ - errno = 0; - if (select(n, &readset, NULL, &errset, NULL) < 0) - error(SYSTEM, "select call error in raywait()"); - } else - FD_ZERO(&errset); - rtfree = NULL; /* read from ready process(es) */ - for (rt = rt0; rt != NULL; rt = rt->next) { - if (!FD_ISSET(rt->pd.r, &readset) && - !FD_ISSET(rt->pd.r, &errset)) - continue; - for (n = 0; n < rt->bsiz && rt->dest[n] != NULL; n++) - ; - nr = 3*sizeof(float)*(n+1); - if (readbuf(rt->pd.r, (char *)rt->buf, nr) < nr) - error(USER, "rtrace process died"); - while (n-- > 0) { - rt->dest[n][0] += rt->buf[3*n]; - rt->dest[n][1] += rt->buf[3*n+1]; - rt->dest[n][2] += rt->buf[3*n+2]; - rt->dest[n] = NULL; - } - rtfree = rt; - } - return(rtfree); }
