--- ray/src/gen/mkillum2.c 2004/03/28 20:33:12 2.14 +++ ray/src/gen/mkillum2.c 2004/09/19 08:42:22 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.14 2004/03/28 20:33:12 schorsch Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.17 2004/09/19 08:42:22 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -11,24 +11,30 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.14 20 #include "face.h" #include "cone.h" #include "random.h" +#include "selcall.h" -int o_default(FUN_ARGLIST); -int o_face(FUN_ARGLIST); -int o_sphere(FUN_ARGLIST); -int o_ring(FUN_ARGLIST); -void raysamp(float res[3], FVECT org, FVECT dir, struct rtproc *rt); -void rayflush(struct rtproc *rt); -void mkaxes(FVECT u, FVECT v, FVECT n); -void rounddir(FVECT dv, double alt, double azi); -void flatdir(FVECT dv, double alt, double azi); +static void mkaxes(FVECT u, FVECT v, FVECT n); +static void rounddir(FVECT dv, double alt, double azi); +static void flatdir(FVECT dv, double alt, double azi); +static void +rayclean( /* finish all pending rays */ + struct rtproc *rt0 +) +{ + rayflush(rt0, 1); + while (raywait(rt0) != NULL) + ; +} + + int /* XXX type conflict with otypes.h */ o_default( /* default illum action */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt, + struct rtproc *rt0, char *nm ) { @@ -44,7 +50,7 @@ int o_face( /* make an illum face */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt, + struct rtproc *rt0, char *nm ) { @@ -63,7 +69,7 @@ o_face( /* make an illum face */ fa = getface(ob); if (fa->area == 0.0) { freeface(ob); - return(o_default(ob, il, rt, nm)); + return(o_default(ob, il, rt0, nm)); } /* set up sampling */ if (il->sampdens <= 0) @@ -127,17 +133,17 @@ o_face( /* make an illum face */ } while (!inface(org, fa) && nmisses++ < MAXMISS); if (nmisses > MAXMISS) { objerror(ob, WARNING, "bad aspect"); - rt->nrays = 0; + rayclean(rt0); freeface(ob); free((void *)distarr); - return(o_default(ob, il, rt, nm)); + return(o_default(ob, il, rt0, nm)); } for (j = 0; j < 3; j++) org[j] += .001*fa->norm[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the face and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -148,8 +154,8 @@ o_face( /* make an illum face */ /* clean up */ freeface(ob); free((void *)distarr); + return(0); #undef MAXMISS - /* XXX we need to return something here. what is it? */ } @@ -157,7 +163,7 @@ int o_sphere( /* make an illum sphere */ register OBJREC *ob, struct illum_args *il, - struct rtproc *rt, + struct rtproc *rt0, char *nm ) { @@ -207,9 +213,9 @@ o_sphere( /* make an illum sphere */ dir[j] = -dir[j]; } /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the sphere and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -229,7 +235,7 @@ int o_ring( /* make an illum ring */ OBJREC *ob, struct illum_args *il, - struct rtproc *rt, + struct rtproc *rt0, char *nm ) { @@ -280,9 +286,9 @@ o_ring( /* make an illum ring */ .001*co->ad[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the ring and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -298,51 +304,106 @@ o_ring( /* make an illum ring */ void -raysamp( /* compute a ray sample */ +raysamp( /* queue a ray sample */ float res[3], FVECT org, FVECT dir, - register struct rtproc *rt + struct rtproc *rt0 ) { + register struct rtproc *rt; register float *fp; - if (rt->nrays == rt->bsiz) - rayflush(rt); - rt->dest[rt->nrays] = res; - fp = rt->buf + 6*rt->nrays++; + for (rt = rt0; rt != NULL; rt = rt->next) + if (rt->nrays < rt->bsiz && rt->dest[rt->nrays] == NULL) + break; + if (rt == NULL) /* need to free up buffer? */ + rt = raywait(rt0); + if (rt == NULL) + error(SYSTEM, "raywait() returned NULL in raysamp()"); + fp = rt->buf + 6*rt->nrays; *fp++ = org[0]; *fp++ = org[1]; *fp++ = org[2]; *fp++ = dir[0]; *fp++ = dir[1]; *fp = dir[2]; + rt->dest[rt->nrays++] = res; + if (rt->nrays == rt->bsiz) + rayflush(rt, 0); } void -rayflush( /* flush buffered rays */ - register struct rtproc *rt +rayflush( /* flush queued rays to rtrace */ + register struct rtproc *rt, + int doall ) { - register int i; + int nw; - if (rt->nrays <= 0) - return; - memset(rt->buf+6*rt->nrays, '\0', 6*sizeof(float)); - errno = 0; - if ( process(&(rt->pd), (char *)rt->buf, (char *)rt->buf, - 3*sizeof(float)*(rt->nrays+1), - 6*sizeof(float)*(rt->nrays+1)) < - 3*sizeof(float)*(rt->nrays+1) ) - error(SYSTEM, "error reading from rtrace process"); - i = rt->nrays; - while (i--) { - rt->dest[i][0] += rt->buf[3*i]; - rt->dest[i][1] += rt->buf[3*i+1]; - rt->dest[i][2] += rt->buf[3*i+2]; + do { + if (rt->nrays <= 0) + continue; + memset(rt->buf+6*rt->nrays, 0, 6*sizeof(float)); + nw = 6*sizeof(float)*(rt->nrays+1); + errno = 0; + if (writebuf(rt->pd.w, (char *)rt->buf, nw) < nw) + error(SYSTEM, "error writing to rtrace process"); + rt->nrays = 0; /* flag buffer as flushed */ + } while (doall && (rt = rt->next) != NULL); +} + + +struct rtproc * +raywait( /* retrieve rtrace results */ + struct rtproc *rt0 +) +{ + fd_set readset, errset; + int nr; + struct rtproc *rtfree; + register struct rtproc *rt; + register int n; + /* prepare select call */ + FD_ZERO(&readset); FD_ZERO(&errset); n = 0; + nr = 0; + for (rt = rt0; rt != NULL; rt = rt->next) { + if (rt->nrays == 0 && rt->dest[0] != NULL) { + FD_SET(rt->pd.r, &readset); + ++nr; + } + FD_SET(rt->pd.r, &errset); + if (rt->pd.r >= n) + n = rt->pd.r + 1; } - rt->nrays = 0; + if (!nr) /* no rays pending */ + return(NULL); + if (nr > 1) { /* call select for multiple processes */ + errno = 0; + if (select(n, &readset, NULL, &errset, NULL) < 0) + error(SYSTEM, "select call error in raywait()"); + } else + FD_ZERO(&errset); + rtfree = NULL; /* read from ready process(es) */ + for (rt = rt0; rt != NULL; rt = rt->next) { + if (!FD_ISSET(rt->pd.r, &readset) && + !FD_ISSET(rt->pd.r, &errset)) + continue; + for (n = 0; n < rt->bsiz && rt->dest[n] != NULL; n++) + ; + nr = 3*sizeof(float)*(n+1); + if (readbuf(rt->pd.r, (char *)rt->buf, nr) < nr) + error(USER, "rtrace process died"); + while (n-- > 0) { + rt->dest[n][0] += rt->buf[3*n]; + rt->dest[n][1] += rt->buf[3*n+1]; + rt->dest[n][2] += rt->buf[3*n+2]; + rt->dest[n] = NULL; + } + rtfree = rt; + } + return(rtfree); } -void +static void mkaxes( /* compute u and v to go with n */ FVECT u, FVECT v, @@ -362,7 +423,7 @@ mkaxes( /* compute u and v to go with n */ } -void +static void rounddir( /* compute uniform spherical direction */ register FVECT dv, double alt, @@ -379,7 +440,7 @@ rounddir( /* compute uniform spherical direction */ } -void +static void flatdir( /* compute uniform hemispherical direction */ register FVECT dv, double alt,
