--- ray/src/gen/mkillum2.c 2003/06/26 00:58:09 2.10 +++ ray/src/gen/mkillum2.c 2004/09/19 08:42:22 2.17 @@ -1,34 +1,58 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.10 2003/06/26 00:58:09 schorsch Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.17 2004/09/19 08:42:22 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum */ +#include + #include "mkillum.h" #include "face.h" #include "cone.h" #include "random.h" +#include "selcall.h" -o_default(ob, il, rt, nm) /* default illum action */ -OBJREC *ob; -struct illum_args *il; -struct rtproc *rt; -char *nm; +static void mkaxes(FVECT u, FVECT v, FVECT n); +static void rounddir(FVECT dv, double alt, double azi); +static void flatdir(FVECT dv, double alt, double azi); + + +static void +rayclean( /* finish all pending rays */ + struct rtproc *rt0 +) { + rayflush(rt0, 1); + while (raywait(rt0) != NULL) + ; +} + + +int /* XXX type conflict with otypes.h */ +o_default( /* default illum action */ + OBJREC *ob, + struct illum_args *il, + struct rtproc *rt0, + char *nm +) +{ sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"", nm, ofun[ob->otype].funame, ob->oname); error(WARNING, errmsg); printobj(il->altmat, ob); + return(1); } -o_face(ob, il, rt, nm) /* make an illum face */ -OBJREC *ob; -struct illum_args *il; -struct rtproc *rt; -char *nm; +int +o_face( /* make an illum face */ + OBJREC *ob, + struct illum_args *il, + struct rtproc *rt0, + char *nm +) { #define MAXMISS (5*n*il->nsamps) int dim[3]; @@ -45,8 +69,7 @@ char *nm; fa = getface(ob); if (fa->area == 0.0) { freeface(ob); - o_default(ob, il, rt, nm); - return; + return(o_default(ob, il, rt0, nm)); } /* set up sampling */ if (il->sampdens <= 0) @@ -110,18 +133,17 @@ char *nm; } while (!inface(org, fa) && nmisses++ < MAXMISS); if (nmisses > MAXMISS) { objerror(ob, WARNING, "bad aspect"); - rt->nrays = 0; + rayclean(rt0); freeface(ob); free((void *)distarr); - o_default(ob, il, rt, nm); - return; + return(o_default(ob, il, rt0, nm)); } for (j = 0; j < 3; j++) org[j] += .001*fa->norm[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the face and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -132,15 +154,18 @@ char *nm; /* clean up */ freeface(ob); free((void *)distarr); + return(0); #undef MAXMISS } -o_sphere(ob, il, rt, nm) /* make an illum sphere */ -register OBJREC *ob; -struct illum_args *il; -struct rtproc *rt; -char *nm; +int +o_sphere( /* make an illum sphere */ + register OBJREC *ob, + struct illum_args *il, + struct rtproc *rt0, + char *nm +) { int dim[3]; int n, nalt, nazi; @@ -188,9 +213,9 @@ char *nm; dir[j] = -dir[j]; } /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the sphere and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -202,14 +227,17 @@ char *nm; printobj(il->altmat, ob); /* clean up */ free((void *)distarr); + return(1); } -o_ring(ob, il, rt, nm) /* make an illum ring */ -OBJREC *ob; -struct illum_args *il; -struct rtproc *rt; -char *nm; +int +o_ring( /* make an illum ring */ + OBJREC *ob, + struct illum_args *il, + struct rtproc *rt0, + char *nm +) { int dim[3]; int n, nalt, nazi; @@ -258,9 +286,9 @@ char *nm; .001*co->ad[j]; /* send sample */ - raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt); + raysamp(distarr+3*(dim[1]*nazi+dim[2]), org, dir, rt0); } - rayflush(rt); + rayclean(rt0); /* write out the ring and its distribution */ if (average(il, distarr, nalt*nazi)) { if (il->sampdens > 0) @@ -271,51 +299,116 @@ char *nm; /* clean up */ freecone(ob); free((void *)distarr); + return(1); } -raysamp(res, org, dir, rt) /* compute a ray sample */ -float res[3]; -FVECT org, dir; -register struct rtproc *rt; +void +raysamp( /* queue a ray sample */ + float res[3], + FVECT org, + FVECT dir, + struct rtproc *rt0 +) { + register struct rtproc *rt; register float *fp; - if (rt->nrays == rt->bsiz) - rayflush(rt); - rt->dest[rt->nrays] = res; - fp = rt->buf + 6*rt->nrays++; + for (rt = rt0; rt != NULL; rt = rt->next) + if (rt->nrays < rt->bsiz && rt->dest[rt->nrays] == NULL) + break; + if (rt == NULL) /* need to free up buffer? */ + rt = raywait(rt0); + if (rt == NULL) + error(SYSTEM, "raywait() returned NULL in raysamp()"); + fp = rt->buf + 6*rt->nrays; *fp++ = org[0]; *fp++ = org[1]; *fp++ = org[2]; *fp++ = dir[0]; *fp++ = dir[1]; *fp = dir[2]; + rt->dest[rt->nrays++] = res; + if (rt->nrays == rt->bsiz) + rayflush(rt, 0); } -rayflush(rt) /* flush buffered rays */ -register struct rtproc *rt; +void +rayflush( /* flush queued rays to rtrace */ + register struct rtproc *rt, + int doall +) { - register int i; + int nw; - if (rt->nrays <= 0) - return; - bzero(rt->buf+6*rt->nrays, 6*sizeof(float)); - errno = 0; - if ( process(&(rt->pd), (char *)rt->buf, (char *)rt->buf, - 3*sizeof(float)*(rt->nrays+1), - 6*sizeof(float)*(rt->nrays+1)) < - 3*sizeof(float)*(rt->nrays+1) ) - error(SYSTEM, "error reading from rtrace process"); - i = rt->nrays; - while (i--) { - rt->dest[i][0] += rt->buf[3*i]; - rt->dest[i][1] += rt->buf[3*i+1]; - rt->dest[i][2] += rt->buf[3*i+2]; + do { + if (rt->nrays <= 0) + continue; + memset(rt->buf+6*rt->nrays, 0, 6*sizeof(float)); + nw = 6*sizeof(float)*(rt->nrays+1); + errno = 0; + if (writebuf(rt->pd.w, (char *)rt->buf, nw) < nw) + error(SYSTEM, "error writing to rtrace process"); + rt->nrays = 0; /* flag buffer as flushed */ + } while (doall && (rt = rt->next) != NULL); +} + + +struct rtproc * +raywait( /* retrieve rtrace results */ + struct rtproc *rt0 +) +{ + fd_set readset, errset; + int nr; + struct rtproc *rtfree; + register struct rtproc *rt; + register int n; + /* prepare select call */ + FD_ZERO(&readset); FD_ZERO(&errset); n = 0; + nr = 0; + for (rt = rt0; rt != NULL; rt = rt->next) { + if (rt->nrays == 0 && rt->dest[0] != NULL) { + FD_SET(rt->pd.r, &readset); + ++nr; + } + FD_SET(rt->pd.r, &errset); + if (rt->pd.r >= n) + n = rt->pd.r + 1; } - rt->nrays = 0; + if (!nr) /* no rays pending */ + return(NULL); + if (nr > 1) { /* call select for multiple processes */ + errno = 0; + if (select(n, &readset, NULL, &errset, NULL) < 0) + error(SYSTEM, "select call error in raywait()"); + } else + FD_ZERO(&errset); + rtfree = NULL; /* read from ready process(es) */ + for (rt = rt0; rt != NULL; rt = rt->next) { + if (!FD_ISSET(rt->pd.r, &readset) && + !FD_ISSET(rt->pd.r, &errset)) + continue; + for (n = 0; n < rt->bsiz && rt->dest[n] != NULL; n++) + ; + nr = 3*sizeof(float)*(n+1); + if (readbuf(rt->pd.r, (char *)rt->buf, nr) < nr) + error(USER, "rtrace process died"); + while (n-- > 0) { + rt->dest[n][0] += rt->buf[3*n]; + rt->dest[n][1] += rt->buf[3*n+1]; + rt->dest[n][2] += rt->buf[3*n+2]; + rt->dest[n] = NULL; + } + rtfree = rt; + } + return(rtfree); } -mkaxes(u, v, n) /* compute u and v to go with n */ -FVECT u, v, n; +static void +mkaxes( /* compute u and v to go with n */ + FVECT u, + FVECT v, + FVECT n +) { register int i; @@ -330,9 +423,12 @@ FVECT u, v, n; } -rounddir(dv, alt, azi) /* compute uniform spherical direction */ -register FVECT dv; -double alt, azi; +static void +rounddir( /* compute uniform spherical direction */ + register FVECT dv, + double alt, + double azi +) { double d1, d2; @@ -344,9 +440,12 @@ double alt, azi; } -flatdir(dv, alt, azi) /* compute uniform hemispherical direction */ -register FVECT dv; -double alt, azi; +static void +flatdir( /* compute uniform hemispherical direction */ + register FVECT dv, + double alt, + double azi +) { double d1, d2;
