Minor fixes
Fixed bug introduced in last bug-fix.
Attempt to fix bug in l- setting with BSDF
Increased BSDF sampling to improve smoothness in pathological cases (zenith)
Broke BSDF-handling routines into their own module
Bug fix in source sampling
Initial implementation of BSDF complete (untested)
Added light source sampling when l+ and -dv- are set
Improved BSDF resampling
Fixed BTDF sampling density to match output angles
Corrected calls from o_default() to my_default()
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed aspect on spherical divisions
fixed bug in calculation of ring sample positions
minor optimization in long-enough edge determination
minor improvement to check ALL edges for possible u vector in face
made off-axis polygons sample better
changed so light below threshold is printed as ordinary object
reset errno at appropriate points
fixed distribution pattern discontinuity
interpret d=0 to mean diffuse source changed peano() calls to multisamp()
changed from urind() to peano() for n-dimensional sampling
added zeroing of position set as tag to rtrace
*** empty log message ***
test debugging
visual debugging pass
first version of mkillum
