root/radiance/ray/src/gen/mkillum2.c
Revision: 2.29
Committed: Wed Mar 4 00:12:25 2009 UTC (16 years, 3 months ago) by greg
Changes since 2.28: +68 -16 lines
2 static const char RCSid[] = "$Id: mkillum2.c,v 2.28 2007/12/13 07:03:37 greg Exp $";
5 * Routines to do the actual calculation for mkillum
6 */
7
8 #include <string.h>
9
10 #include "mkillum.h"
11 #include "face.h"
12 #include "cone.h"
13 #include "source.h"
14
15
16 COLORV * distarr = NULL; /* distribution array */
17 int distsiz = 0;
18 COLORV * direct_discount = NULL; /* amount to take off direct */
19
20 void
21 newdist( /* allocate & clear distribution array */
22 int siz
23 )
24 {
25 if (siz <= 0) {
26 if (distsiz > 0)
27 free((void *)distarr);
28 distarr = NULL;
29 distsiz = 0;
30 return;
31 }
32 if (distsiz < siz) {
33 if (distsiz > 0)
34 free((void *)distarr);
35 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
36 if (distarr == NULL)
37 error(SYSTEM, "out of memory in newdist");
38 distsiz = siz;
39 }
40 memset(distarr, '\0', sizeof(COLOR)*siz);
41 }
42
43
44 static void
45 new_discount() /* allocate space for direct contrib. record */
46 {
47 if (distsiz <= 0)
48 return;
49 direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR));
50 if (direct_discount == NULL)
51 error(SYSTEM, "out of memory in new_discount");
52 }
53
54
55 static void
56 done_discount() /* clear off direct contrib. record */
57 {
58 if (direct_discount == NULL)
59 return;
60 free((void *)direct_discount);
61 direct_discount = NULL;
62 }
63
64
65 int
66 process_ray( /* process a ray result or report error */
67 RAY *r,
68 int rv
69 )
70 {
71 COLORV *colp;
72
73 if (rv == 0) /* no result ready */
74 return(0);
75 if (rv < 0)
76 error(USER, "ray tracing process died");
77 if (r->rno >= distsiz)
78 error(INTERNAL, "bad returned index in process_ray");
79 multcolor(r->rcol, r->rcoef); /* in case it's a source ray */
80 colp = &distarr[r->rno * 3];
81 addcolor(colp, r->rcol);
82 if (r->rsrc >= 0 && /* remember source contrib. */
83 direct_discount != NULL) {
84 colp = &direct_discount[r->rno * 3];
85 addcolor(colp, r->rcol);
86 }
87 return(1);
88 }
89
90
91 void
92 raysamp( /* queue a ray sample */
93 int ndx,
94 FVECT org,
95 FVECT dir
96 )
97 {
98 RAY myRay;
99 int rv;
100
101 if ((ndx < 0) | (ndx >= distsiz))
102 error(INTERNAL, "bad index in raysamp");
103 VCOPY(myRay.rorg, org);
104 VCOPY(myRay.rdir, dir);
105 myRay.rmax = .0;
106 rayorigin(&myRay, PRIMARY, NULL, NULL);
107 myRay.rno = ndx;
108 /* queue ray, check result */
109 process_ray(&myRay, ray_pqueue(&myRay));
110 }
111
112
113 void
114 srcsamps( /* sample sources from this surface position */
115 struct illum_args *il,
116 FVECT org,
117 FVECT nrm,
118 MAT4 ixfm
119 )
120 {
121 int nalt, nazi;
122 SRCINDEX si;
123 RAY sr;
124 FVECT v;
125 double d;
126 int i, j;
127 /* get sampling density */
128 if (il->sampdens <= 0) {
129 nalt = nazi = 1;
130 } else {
131 i = PI * il->sampdens;
132 nalt = sqrt(i/PI) + .5;
133 nazi = PI*nalt + .5;
134 }
135 initsrcindex(&si); /* loop over (sub)sources */
136 for ( ; ; ) {
137 VCOPY(sr.rorg, org); /* pick side to shoot from */
138 if (il->sd != NULL) {
139 int sn = si.sn;
140 if (si.sp+1 >= si.np) ++sn;
141 if (sn >= nsources) break;
142 if (source[sn].sflags & SDISTANT)
143 d = DOT(source[sn].sloc, nrm);
144 else {
145 VSUB(v, source[sn].sloc, org);
146 d = DOT(v, nrm);
147 }
148 } else
149 d = 1.0; /* only transmission */
150 if (d < 0.0)
151 d = -1.0001*il->thick - 5.*FTINY;
152 else
153 d = 5.*FTINY;
154 for (i = 3; i--; )
155 sr.rorg[i] += d*nrm[i];
156 if (!srcray(&sr, NULL, &si))
157 break; /* end of sources */
158 /* index direction */
159 if (ixfm != NULL)
160 multv3(v, sr.rdir, ixfm);
161 else
162 VCOPY(v, sr.rdir);
163 if (il->sd != NULL) {
164 i = getBSDF_incndx(il->sd, v);
165 if (i < 0)
166 continue; /* must not be important */
167 sr.rno = i;
168 d = 1.0/getBSDF_incohm(il->sd, i);
169 } else {
170 if (v[2] >= -FTINY)
171 continue; /* only sample transmission */
172 v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
173 sr.rno = flatindex(v, nalt, nazi);
174 d = nalt*nazi*(1./PI) * v[2];
175 }
176 d *= si.dom; /* solid angle correction */
177 scalecolor(sr.rcoef, d);
178 process_ray(&sr, ray_pqueue(&sr));
179 }
180 }
181
182
183 void
184 rayclean() /* finish all pending rays */
185 {
186 RAY myRay;
187
188 while (process_ray(&myRay, ray_presult(&myRay, 0)))
189 ;
190 }
191
192
193 static void
194 mkaxes( /* compute u and v to go with n */
195 FVECT u,
196 FVECT v,
197 FVECT n
198 )
199 {
200 register int i;
201
202 v[0] = v[1] = v[2] = 0.0;
203 for (i = 0; i < 3; i++)
204 if (n[i] < 0.6 && n[i] > -0.6)
205 break;
206 v[i] = 1.0;
207 fcross(u, v, n);
208 normalize(u);
209 fcross(v, n, u);
210 }
211
212
213 static void
214 rounddir( /* compute uniform spherical direction */
215 register FVECT dv,
216 double alt,
217 double azi
218 )
219 {
220 double d1, d2;
221
222 dv[2] = 1. - 2.*alt;
223 d1 = sqrt(1. - dv[2]*dv[2]);
224 d2 = 2.*PI * azi;
225 dv[0] = d1*cos(d2);
226 dv[1] = d1*sin(d2);
227 }
228
229
230 void
231 flatdir( /* compute uniform hemispherical direction */
232 FVECT dv,
233 double alt,
234 double azi
235 )
236 {
237 double d1, d2;
238
239 d1 = sqrt(alt);
240 d2 = 2.*PI * azi;
241 dv[0] = d1*cos(d2);
242 dv[1] = d1*sin(d2);
243 dv[2] = sqrt(1. - alt);
244 }
245
246 int
247 flatindex( /* compute index for hemispherical direction */
248 FVECT dv,
249 int nalt,
250 int nazi
251 )
252 {
253 double d;
254 int i, j;
255
256 d = 1.0 - dv[2]*dv[2];
257 i = d*nalt;
258 d = atan2(dv[1], dv[0]) * (0.5/PI);
259 if (d < 0.0) d += 1.0;
260 j = d*nazi + 0.5;
261 if (j >= nazi) j = 0;
262 return(i*nazi + j);
263 }
264
265
266 int
267 my_default( /* default illum action */
268 OBJREC *ob,
269 struct illum_args *il,
270 char *nm
271 )
272 {
273 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
274 nm, ofun[ob->otype].funame, ob->oname);
275 error(WARNING, errmsg);
276 printobj(il->altmat, ob);
277 return(1);
278 }
279
280
281 int
282 my_face( /* make an illum face */
283 OBJREC *ob,
284 struct illum_args *il,
285 char *nm
286 )
287 {
288 int dim[2];
289 int n, nalt, nazi, alti;
290 double sp[2], r1, r2;
291 int h;
292 FVECT dn, org, dir;
293 FVECT u, v;
294 double ur[2], vr[2];
295 MAT4 xfm;
296 int nallow;
297 FACE *fa;
298 int i, j;
299 /* get/check arguments */
300 fa = getface(ob);
301 if (fa->area == 0.0) {
302 freeface(ob);
303 return(my_default(ob, il, nm));
304 }
305 /* set up sampling */
306 if (il->sd != NULL) {
307 if (!getBSDF_xfm(xfm, fa->norm, il->udir)) {
308 objerror(ob, WARNING, "illegal up direction");
309 freeface(ob);
310 return(my_default(ob, il, nm));
311 }
312 n = il->sd->ninc;
313 } else {
314 if (il->sampdens <= 0) {
315 nalt = nazi = 1; /* diffuse assumption */
316 } else {
317 n = PI * il->sampdens;
318 nalt = sqrt(n/PI) + .5;
319 nazi = PI*nalt + .5;
320 }
321 n = nazi*nalt;
322 }
323 newdist(n);
324 /* take first edge >= sqrt(area) */
325 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
326 u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
327 u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
328 u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
329 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
330 break;
331 }
332 if (i < fa->nv) { /* got one! -- let's align our axes */
333 r2 = 1.0/sqrt(r1);
334 u[0] *= r2; u[1] *= r2; u[2] *= r2;
335 fcross(v, fa->norm, u);
336 } else /* oh well, we'll just have to wing it */
337 mkaxes(u, v, fa->norm);
338 /* now, find limits in (u,v) coordinates */
339 ur[0] = vr[0] = FHUGE;
340 ur[1] = vr[1] = -FHUGE;
341 for (i = 0; i < fa->nv; i++) {
342 r1 = DOT(VERTEX(fa,i),u);
343 if (r1 < ur[0]) ur[0] = r1;
344 if (r1 > ur[1]) ur[1] = r1;
345 r2 = DOT(VERTEX(fa,i),v);
346 if (r2 < vr[0]) vr[0] = r2;
347 if (r2 > vr[1]) vr[1] = r2;
348 }
349 dim[0] = random();
350 /* sample polygon */
351 nallow = 5*n*il->nsamps;
352 for (dim[1] = 0; dim[1] < n; dim[1]++)
353 for (i = 0; i < il->nsamps; i++) {
354 /* randomize direction */
355 h = ilhash(dim, 2) + i;
356 if (il->sd != NULL) {
357 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
358 } else {
359 multisamp(sp, 2, urand(h));
360 alti = dim[1]/nazi;
361 r1 = (alti + sp[0])/nalt;
362 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
363 flatdir(dn, r1, r2);
364 for (j = 0; j < 3; j++)
365 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
366 dn[2]*fa->norm[j];
367 }
368 /* randomize location */
369 do {
370 multisamp(sp, 2, urand(h+4862+nallow));
371 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
372 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
373 for (j = 0; j < 3; j++)
374 org[j] = r1*u[j] + r2*v[j]
375 + fa->offset*fa->norm[j];
376 } while (!inface(org, fa) && nallow-- > 0);
377 if (nallow < 0) {
378 objerror(ob, WARNING, "bad aspect");
379 rayclean();
380 freeface(ob);
381 return(my_default(ob, il, nm));
382 }
383 if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY)
384 r1 = -1.0001*il->thick - 5.*FTINY;
385 else
386 r1 = 5.*FTINY;
387 for (j = 0; j < 3; j++)
388 org[j] += r1*fa->norm[j];
389 /* send sample */
390 raysamp(dim[1], org, dir);
391 }
392 /* add in direct component? */
393 if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) {
394 MAT4 ixfm;
395 if (il->sd == NULL) {
396 for (i = 3; i--; ) {
397 ixfm[i][0] = u[i];
398 ixfm[i][1] = v[i];
399 ixfm[i][2] = fa->norm[i];
400 ixfm[i][3] = 0.;
401 }
402 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
403 ixfm[3][3] = 1.;
404 } else {
405 if (!invmat4(ixfm, xfm))
406 objerror(ob, INTERNAL,
407 "cannot invert BSDF transform");
408 if (!(il->flags & IL_LIGHT))
409 new_discount();
410 }
411 dim[0] = random();
412 nallow = 10*il->nsamps;
413 for (i = 0; i < il->nsamps; i++) {
414 /* randomize location */
415 h = dim[0] + samplendx++;
416 do {
417 multisamp(sp, 2, urand(h+nallow));
418 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
419 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
420 for (j = 0; j < 3; j++)
421 org[j] = r1*u[j] + r2*v[j]
422 + fa->offset*fa->norm[j];
423 } while (!inface(org, fa) && nallow-- > 0);
424 if (nallow < 0) {
425 objerror(ob, WARNING, "bad aspect");
426 rayclean();
427 freeface(ob);
428 return(my_default(ob, il, nm));
429 }
430 /* sample source rays */
431 srcsamps(il, org, fa->norm, ixfm);
432 }
433 }
434 /* wait for all rays to finish */
435 rayclean();
436 if (il->sd != NULL) { /* run distribution through BSDF */
437 nalt = sqrt(il->sd->nout/PI) + .5;
438 nazi = PI*nalt + .5;
439 redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm);
440 done_discount();
441 if (!il->sampdens)
442 il->sampdens = nalt*nazi/PI + .999;
443 }
444 /* write out the face and its distribution */
445 if (average(il, distarr, n)) {
446 if (il->sampdens > 0)
447 flatout(il, distarr, nalt, nazi, u, v, fa->norm);
448 illumout(il, ob);
449 } else
450 printobj(il->altmat, ob);
451 /* clean up */
452 freeface(ob);
453 return(0);
454 }
455
456
457 int
458 my_sphere( /* make an illum sphere */
459 register OBJREC *ob,
460 struct illum_args *il,
461 char *nm
462 )
463 {
464 int dim[3];
465 int n, nalt, nazi;
466 double sp[4], r1, r2, r3;
467 FVECT org, dir;
468 FVECT u, v;
469 register int i, j;
470 /* check arguments */
471 if (ob->oargs.nfargs != 4)
472 objerror(ob, USER, "bad # of arguments");
473 /* set up sampling */
474 if (il->sampdens <= 0)
475 nalt = nazi = 1;
476 else {
477 n = 4.*PI * il->sampdens;
478 nalt = sqrt(2./PI*n) + .5;
479 nazi = PI/2.*nalt + .5;
480 }
481 if (il->sd != NULL)
482 objerror(ob, WARNING, "BSDF ignored");
483 n = nalt*nazi;
484 newdist(n);
485 dim[0] = random();
486 /* sample sphere */
487 for (dim[1] = 0; dim[1] < nalt; dim[1]++)
488 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
489 for (i = 0; i < il->nsamps; i++) {
490 /* next sample point */
491 multisamp(sp, 4, urand(ilhash(dim,3)+i));
492 /* random direction */
493 r1 = (dim[1] + sp[0])/nalt;
494 r2 = (dim[2] + sp[1] - .5)/nazi;
495 rounddir(dir, r1, r2);
496 /* random location */
497 mkaxes(u, v, dir); /* yuck! */
498 r3 = sqrt(sp[2]);
499 r2 = 2.*PI*sp[3];
500 r1 = r3*ob->oargs.farg[3]*cos(r2);
501 r2 = r3*ob->oargs.farg[3]*sin(r2);
502 r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
503 for (j = 0; j < 3; j++) {
504 org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
505 r3*dir[j];
506 dir[j] = -dir[j];
507 }
508 /* send sample */
509 raysamp(dim[1]*nazi+dim[2], org, dir);
510 }
511 /* wait for all rays to finish */
512 rayclean();
513 /* write out the sphere and its distribution */
514 if (average(il, distarr, n)) {
515 if (il->sampdens > 0)
516 roundout(il, distarr, nalt, nazi);
517 else
518 objerror(ob, WARNING, "diffuse distribution");
519 illumout(il, ob);
520 } else
521 printobj(il->altmat, ob);
522 /* clean up */
523 return(1);
524 }
525
526
527 int
528 my_ring( /* make an illum ring */
529 OBJREC *ob,
530 struct illum_args *il,
531 char *nm
532 )
533 {
534 int dim[2];
535 int n, nalt, nazi, alti;
536 double sp[2], r1, r2, r3;
537 int h;
538 FVECT dn, org, dir;
539 FVECT u, v;
540 MAT4 xfm;
541 CONE *co;
542 int i, j;
543 /* get/check arguments */
544 co = getcone(ob, 0);
545 /* set up sampling */
546 if (il->sd != NULL) {
547 if (!getBSDF_xfm(xfm, co->ad, il->udir)) {
548 objerror(ob, WARNING, "illegal up direction");
549 freecone(ob);
550 return(my_default(ob, il, nm));
551 }
552 n = il->sd->ninc;
553 } else {
554 if (il->sampdens <= 0) {
555 nalt = nazi = 1; /* diffuse assumption */
556 } else {
557 n = PI * il->sampdens;
558 nalt = sqrt(n/PI) + .5;
559 nazi = PI*nalt + .5;
560 }
561 n = nazi*nalt;
562 }
563 newdist(n);
564 mkaxes(u, v, co->ad);
565 dim[0] = random();
566 /* sample disk */
567 for (dim[1] = 0; dim[1] < n; dim[1]++)
568 for (i = 0; i < il->nsamps; i++) {
569 /* next sample point */
570 h = ilhash(dim,2) + i;
571 /* randomize direction */
572 if (il->sd != NULL) {
573 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
574 } else {
575 multisamp(sp, 2, urand(h));
576 alti = dim[1]/nazi;
577 r1 = (alti + sp[0])/nalt;
578 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
579 flatdir(dn, r1, r2);
580 for (j = 0; j < 3; j++)
581 dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
582 }
583 /* randomize location */
584 multisamp(sp, 2, urand(h+8371));
585 r3 = sqrt(CO_R0(co)*CO_R0(co) +
586 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
587 r2 = 2.*PI*sp[1];
588 r1 = r3*cos(r2);
589 r2 = r3*sin(r2);
590 if (il->sd != NULL && DOT(dir, co->ad) < -FTINY)
591 r3 = -1.0001*il->thick - 5.*FTINY;
592 else
593 r3 = 5.*FTINY;
594 for (j = 0; j < 3; j++)
595 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
596 r3*co->ad[j];
597 /* send sample */
598 raysamp(dim[1], org, dir);
599 }
600 /* add in direct component? */
601 if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) {
602 MAT4 ixfm;
603 if (il->sd == NULL) {
604 for (i = 3; i--; ) {
605 ixfm[i][0] = u[i];
606 ixfm[i][1] = v[i];
607 ixfm[i][2] = co->ad[i];
608 ixfm[i][3] = 0.;
609 }
610 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
611 ixfm[3][3] = 1.;
612 } else {
613 if (!invmat4(ixfm, xfm))
614 objerror(ob, INTERNAL,
615 "cannot invert BSDF transform");
616 if (!(il->flags & IL_LIGHT))
617 new_discount();
618 }
619 dim[0] = random();
620 for (i = 0; i < il->nsamps; i++) {
621 /* randomize location */
622 h = dim[0] + samplendx++;
623 multisamp(sp, 2, urand(h));
624 r3 = sqrt(CO_R0(co)*CO_R0(co) +
625 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
626 r2 = 2.*PI*sp[1];
627 r1 = r3*cos(r2);
628 r2 = r3*sin(r2);
629 for (j = 0; j < 3; j++)
630 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
631 /* sample source rays */
632 srcsamps(il, org, co->ad, ixfm);
633 }
634 }
635 /* wait for all rays to finish */
636 rayclean();
637 if (il->sd != NULL) { /* run distribution through BSDF */
638 nalt = sqrt(il->sd->nout/PI) + .5;
639 nazi = PI*nalt + .5;
640 redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm);
641 done_discount();
642 if (!il->sampdens)
643 il->sampdens = nalt*nazi/PI + .999;
644 }
645 /* write out the ring and its distribution */
646 if (average(il, distarr, n)) {
647 if (il->sampdens > 0)
648 flatout(il, distarr, nalt, nazi, u, v, co->ad);
649 illumout(il, ob);
650 } else
651 printobj(il->altmat, ob);
652 /* clean up */
653 freecone(ob);
654 return(1);
655 }
