| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mkillum2.c,v 2.33 2009/09/08 23:05:47 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to do the actual calculation for mkillum
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "mkillum.h"
| 11 |
#include "face.h"
| 12 |
#include "cone.h"
| 13 |
#include "source.h"
| 14 |
| 15 |
#ifndef NBSDFSAMPS
| 16 |
#define NBSDFSAMPS 256 /* BSDF resampling count */
| 17 |
#endif
| 18 |
| 19 |
COLORV * distarr = NULL; /* distribution array */
| 20 |
int distsiz = 0;
| 21 |
COLORV * direct_discount = NULL; /* amount to take off direct */
| 22 |
| 23 |
| 24 |
void
| 25 |
newdist( /* allocate & clear distribution array */
| 26 |
int siz
| 27 |
| 28 |
| 29 |
if (siz <= 0) {
| 30 |
if (distsiz > 0)
| 31 |
free((void *)distarr);
| 32 |
distarr = NULL;
| 33 |
distsiz = 0;
| 34 |
return;
| 35 |
| 36 |
if (distsiz < siz) {
| 37 |
if (distsiz > 0)
| 38 |
| 39 |
distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
| 40 |
if (distarr == NULL)
| 41 |
error(SYSTEM, "out of memory in newdist");
| 42 |
distsiz = siz;
| 43 |
| 44 |
memset(distarr, '\0', sizeof(COLOR)*siz);
| 45 |
| 46 |
| 47 |
| 48 |
static void
| 49 |
new_discount() /* allocate space for direct contrib. record */
| 50 |
| 51 |
if (distsiz <= 0)
| 52 |
return;
| 53 |
direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR));
| 54 |
if (direct_discount == NULL)
| 55 |
error(SYSTEM, "out of memory in new_discount");
| 56 |
| 57 |
| 58 |
| 59 |
static void
| 60 |
done_discount() /* clear off direct contrib. record */
| 61 |
| 62 |
| 63 |
return;
| 64 |
free((void *)direct_discount);
| 65 |
| 66 |
| 67 |
| 68 |
| 69 |
int
| 70 |
process_ray( /* process a ray result or report error */
| 71 |
RAY *r,
| 72 |
int rv
| 73 |
| 74 |
| 75 |
COLORV *colp;
| 76 |
| 77 |
if (rv == 0) /* no result ready */
| 78 |
return(0);
| 79 |
if (rv < 0)
| 80 |
error(USER, "ray tracing process died");
| 81 |
if (r->rno >= distsiz)
| 82 |
error(INTERNAL, "bad returned index in process_ray");
| 83 |
multcolor(r->rcol, r->rcoef); /* in case it's a source ray */
| 84 |
colp = &distarr[r->rno * 3];
| 85 |
addcolor(colp, r->rcol);
| 86 |
if (r->rsrc >= 0 && /* remember source contrib. */
| 87 |
direct_discount != NULL) {
| 88 |
colp = &direct_discount[r->rno * 3];
| 89 |
| 90 |
| 91 |
return(1);
| 92 |
| 93 |
| 94 |
| 95 |
void
| 96 |
raysamp( /* queue a ray sample */
| 97 |
int ndx,
| 98 |
FVECT org,
| 99 |
FVECT dir
| 100 |
| 101 |
| 102 |
RAY myRay;
| 103 |
int rv;
| 104 |
| 105 |
if ((ndx < 0) | (ndx >= distsiz))
| 106 |
error(INTERNAL, "bad index in raysamp");
| 107 |
VCOPY(myRay.rorg, org);
| 108 |
VCOPY(myRay.rdir, dir);
| 109 |
myRay.rmax = .0;
| 110 |
rayorigin(&myRay, PRIMARY, NULL, NULL);
| 111 |
myRay.rno = ndx;
| 112 |
/* queue ray, check result */
| 113 |
process_ray(&myRay, ray_pqueue(&myRay));
| 114 |
| 115 |
| 116 |
| 117 |
void
| 118 |
srcsamps( /* sample sources from this surface position */
| 119 |
struct illum_args *il,
| 120 |
FVECT org,
| 121 |
FVECT nrm,
| 122 |
MAT4 ixfm
| 123 |
| 124 |
| 125 |
int nalt, nazi;
| 126 |
SRCINDEX si;
| 127 |
RAY sr;
| 128 |
FVECT v;
| 129 |
double d;
| 130 |
int i, j;
| 131 |
/* get sampling density */
| 132 |
if (il->sampdens <= 0) {
| 133 |
nalt = nazi = 1;
| 134 |
} else {
| 135 |
i = PI * il->sampdens;
| 136 |
nalt = sqrt(i/PI) + .5;
| 137 |
nazi = PI*nalt + .5;
| 138 |
| 139 |
initsrcindex(&si); /* loop over (sub)sources */
| 140 |
for ( ; ; ) {
| 141 |
VCOPY(sr.rorg, org); /* pick side to shoot from */
| 142 |
if (il->sd != NULL) {
| 143 |
int sn = si.sn;
| 144 |
if (si.sp+1 >= si.np) ++sn;
| 145 |
if (sn >= nsources) break;
| 146 |
if (source[sn].sflags & SDISTANT)
| 147 |
d = DOT(source[sn].sloc, nrm);
| 148 |
else {
| 149 |
VSUB(v, source[sn].sloc, org);
| 150 |
d = DOT(v, nrm);
| 151 |
| 152 |
} else
| 153 |
d = 1.0; /* only transmission */
| 154 |
if (d < 0.0)
| 155 |
d = -1.0001*il->thick - 5.*FTINY;
| 156 |
else
| 157 |
d = 5.*FTINY;
| 158 |
for (i = 3; i--; )
| 159 |
sr.rorg[i] += d*nrm[i];
| 160 |
samplendx++; /* increment sample counter */
| 161 |
if (!srcray(&sr, NULL, &si))
| 162 |
break; /* end of sources */
| 163 |
/* index direction */
| 164 |
if (ixfm != NULL)
| 165 |
multv3(v, sr.rdir, ixfm);
| 166 |
else
| 167 |
VCOPY(v, sr.rdir);
| 168 |
| 169 |
i = getBSDF_incndx(il->sd, v);
| 170 |
if (i < 0)
| 171 |
continue; /* must not be important */
| 172 |
sr.rno = i;
| 173 |
d = 1.0/getBSDF_incohm(il->sd, i);
| 174 |
} else {
| 175 |
if (v[2] >= -FTINY)
| 176 |
continue; /* only sample transmission */
| 177 |
v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
| 178 |
sr.rno = flatindex(v, nalt, nazi);
| 179 |
d = nalt*nazi*(1./PI) * v[2];
| 180 |
| 181 |
d *= si.dom; /* solid angle correction */
| 182 |
scalecolor(sr.rcoef, d);
| 183 |
process_ray(&sr, ray_pqueue(&sr));
| 184 |
| 185 |
| 186 |
| 187 |
| 188 |
void
| 189 |
rayclean() /* finish all pending rays */
| 190 |
| 191 |
RAY myRay;
| 192 |
| 193 |
while (process_ray(&myRay, ray_presult(&myRay, 0)))
| 194 |
| 195 |
| 196 |
| 197 |
| 198 |
static void
| 199 |
mkaxes( /* compute u and v to go with n */
| 200 |
FVECT u,
| 201 |
FVECT v,
| 202 |
FVECT n
| 203 |
| 204 |
| 205 |
register int i;
| 206 |
| 207 |
v[0] = v[1] = v[2] = 0.0;
| 208 |
for (i = 0; i < 3; i++)
| 209 |
if (n[i] < 0.6 && n[i] > -0.6)
| 210 |
break;
| 211 |
v[i] = 1.0;
| 212 |
fcross(u, v, n);
| 213 |
normalize(u);
| 214 |
fcross(v, n, u);
| 215 |
| 216 |
| 217 |
| 218 |
static void
| 219 |
rounddir( /* compute uniform spherical direction */
| 220 |
register FVECT dv,
| 221 |
double alt,
| 222 |
double azi
| 223 |
| 224 |
| 225 |
double d1, d2;
| 226 |
| 227 |
dv[2] = 1. - 2.*alt;
| 228 |
d1 = sqrt(1. - dv[2]*dv[2]);
| 229 |
d2 = 2.*PI * azi;
| 230 |
dv[0] = d1*cos(d2);
| 231 |
dv[1] = d1*sin(d2);
| 232 |
| 233 |
| 234 |
| 235 |
void
| 236 |
flatdir( /* compute uniform hemispherical direction */
| 237 |
FVECT dv,
| 238 |
double alt,
| 239 |
double azi
| 240 |
| 241 |
| 242 |
double d1, d2;
| 243 |
| 244 |
d1 = sqrt(alt);
| 245 |
d2 = 2.*PI * azi;
| 246 |
dv[0] = d1*cos(d2);
| 247 |
dv[1] = d1*sin(d2);
| 248 |
dv[2] = sqrt(1. - alt);
| 249 |
| 250 |
| 251 |
int
| 252 |
flatindex( /* compute index for hemispherical direction */
| 253 |
FVECT dv,
| 254 |
int nalt,
| 255 |
int nazi
| 256 |
| 257 |
| 258 |
double d;
| 259 |
int i, j;
| 260 |
| 261 |
d = 1.0 - dv[2]*dv[2];
| 262 |
i = d*nalt;
| 263 |
d = atan2(dv[1], dv[0]) * (0.5/PI);
| 264 |
if (d < 0.0) d += 1.0;
| 265 |
j = d*nazi + 0.5;
| 266 |
if (j >= nazi) j = 0;
| 267 |
return(i*nazi + j);
| 268 |
| 269 |
| 270 |
| 271 |
int
| 272 |
my_default( /* default illum action */
| 273 |
OBJREC *ob,
| 274 |
| 275 |
char *nm
| 276 |
| 277 |
| 278 |
sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
| 279 |
nm, ofun[ob->otype].funame, ob->oname);
| 280 |
error(WARNING, errmsg);
| 281 |
printobj(il->altmat, ob);
| 282 |
return(1);
| 283 |
| 284 |
| 285 |
| 286 |
int
| 287 |
my_face( /* make an illum face */
| 288 |
OBJREC *ob,
| 289 |
| 290 |
char *nm
| 291 |
| 292 |
| 293 |
int dim[2];
| 294 |
int n, nalt, nazi, alti;
| 295 |
double sp[2], r1, r2;
| 296 |
int h;
| 297 |
FVECT dn, org, dir;
| 298 |
FVECT u, v;
| 299 |
double ur[2], vr[2];
| 300 |
MAT4 xfm;
| 301 |
int nallow;
| 302 |
FACE *fa;
| 303 |
int i, j;
| 304 |
/* get/check arguments */
| 305 |
fa = getface(ob);
| 306 |
if (fa->area == 0.0) {
| 307 |
freeface(ob);
| 308 |
return(my_default(ob, il, nm));
| 309 |
| 310 |
/* set up sampling */
| 311 |
| 312 |
if (!getBSDF_xfm(xfm, fa->norm, il->udir)) {
| 313 |
objerror(ob, WARNING, "illegal up direction");
| 314 |
freeface(ob);
| 315 |
| 316 |
| 317 |
n = il->sd->ninc;
| 318 |
} else {
| 319 |
| 320 |
nalt = nazi = 1; /* diffuse assumption */
| 321 |
} else {
| 322 |
n = PI * il->sampdens;
| 323 |
nalt = sqrt(n/PI) + .5;
| 324 |
| 325 |
| 326 |
n = nazi*nalt;
| 327 |
| 328 |
newdist(n);
| 329 |
/* take first edge >= sqrt(area) */
| 330 |
for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
| 331 |
u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
| 332 |
u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
| 333 |
u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
| 334 |
if ((r1 = DOT(u,u)) >= fa->area-FTINY)
| 335 |
break;
| 336 |
| 337 |
if (i < fa->nv) { /* got one! -- let's align our axes */
| 338 |
r2 = 1.0/sqrt(r1);
| 339 |
u[0] *= r2; u[1] *= r2; u[2] *= r2;
| 340 |
fcross(v, fa->norm, u);
| 341 |
} else /* oh well, we'll just have to wing it */
| 342 |
mkaxes(u, v, fa->norm);
| 343 |
/* now, find limits in (u,v) coordinates */
| 344 |
ur[0] = vr[0] = FHUGE;
| 345 |
ur[1] = vr[1] = -FHUGE;
| 346 |
for (i = 0; i < fa->nv; i++) {
| 347 |
r1 = DOT(VERTEX(fa,i),u);
| 348 |
if (r1 < ur[0]) ur[0] = r1;
| 349 |
if (r1 > ur[1]) ur[1] = r1;
| 350 |
r2 = DOT(VERTEX(fa,i),v);
| 351 |
if (r2 < vr[0]) vr[0] = r2;
| 352 |
if (r2 > vr[1]) vr[1] = r2;
| 353 |
| 354 |
dim[0] = random();
| 355 |
/* sample polygon */
| 356 |
nallow = 5*n*il->nsamps;
| 357 |
for (dim[1] = 0; dim[1] < n; dim[1]++)
| 358 |
for (i = 0; i < il->nsamps; i++) {
| 359 |
/* randomize direction */
| 360 |
h = ilhash(dim, 2) + i;
| 361 |
| 362 |
r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
| 363 |
} else {
| 364 |
multisamp(sp, 2, urand(h));
| 365 |
alti = dim[1]/nazi;
| 366 |
r1 = (alti + sp[0])/nalt;
| 367 |
r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
| 368 |
flatdir(dn, r1, r2);
| 369 |
for (j = 0; j < 3; j++)
| 370 |
dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
| 371 |
dn[2]*fa->norm[j];
| 372 |
| 373 |
/* randomize location */
| 374 |
do {
| 375 |
multisamp(sp, 2, urand(h+4862+nallow));
| 376 |
r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
| 377 |
r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
| 378 |
| 379 |
org[j] = r1*u[j] + r2*v[j]
| 380 |
+ fa->offset*fa->norm[j];
| 381 |
} while (!inface(org, fa) && nallow-- > 0);
| 382 |
if (nallow < 0) {
| 383 |
objerror(ob, WARNING, "bad aspect");
| 384 |
rayclean();
| 385 |
freeface(ob);
| 386 |
| 387 |
| 388 |
if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY)
| 389 |
r1 = -1.0001*il->thick - 5.*FTINY;
| 390 |
else
| 391 |
r1 = 5.*FTINY;
| 392 |
| 393 |
org[j] += r1*fa->norm[j];
| 394 |
/* send sample */
| 395 |
raysamp(dim[1], org, dir);
| 396 |
| 397 |
/* add in direct component? */
| 398 |
if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) {
| 399 |
MAT4 ixfm;
| 400 |
if (il->sd == NULL) {
| 401 |
for (i = 3; i--; ) {
| 402 |
ixfm[i][0] = u[i];
| 403 |
ixfm[i][1] = v[i];
| 404 |
ixfm[i][2] = fa->norm[i];
| 405 |
ixfm[i][3] = 0.;
| 406 |
| 407 |
ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
| 408 |
ixfm[3][3] = 1.;
| 409 |
} else {
| 410 |
if (!invmat4(ixfm, xfm))
| 411 |
objerror(ob, INTERNAL,
| 412 |
"cannot invert BSDF transform");
| 413 |
if (!(il->flags & IL_LIGHT))
| 414 |
new_discount();
| 415 |
| 416 |
dim[0] = random();
| 417 |
nallow = 10*il->nsamps;
| 418 |
| 419 |
| 420 |
h = dim[0] + samplendx++;
| 421 |
do {
| 422 |
multisamp(sp, 2, urand(h+nallow));
| 423 |
| 424 |
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
if (nallow < 0) {
| 430 |
| 431 |
rayclean();
| 432 |
freeface(ob);
| 433 |
| 434 |
| 435 |
/* sample source rays */
| 436 |
srcsamps(il, org, fa->norm, ixfm);
| 437 |
| 438 |
| 439 |
/* wait for all rays to finish */
| 440 |
rayclean();
| 441 |
if (il->sd != NULL) { /* run distribution through BSDF */
| 442 |
nalt = sqrt(il->sd->nout/PI) + .5;
| 443 |
| 444 |
redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm);
| 445 |
done_discount();
| 446 |
if (!il->sampdens)
| 447 |
il->sampdens = nalt*nazi/PI + .999;
| 448 |
| 449 |
/* write out the face and its distribution */
| 450 |
if (average(il, distarr, n)) {
| 451 |
if (il->sampdens > 0)
| 452 |
flatout(il, distarr, nalt, nazi, u, v, fa->norm);
| 453 |
illumout(il, ob);
| 454 |
} else
| 455 |
| 456 |
/* clean up */
| 457 |
freeface(ob);
| 458 |
return(0);
| 459 |
| 460 |
| 461 |
| 462 |
int
| 463 |
my_sphere( /* make an illum sphere */
| 464 |
register OBJREC *ob,
| 465 |
| 466 |
char *nm
| 467 |
| 468 |
| 469 |
int dim[3];
| 470 |
int n, nalt, nazi;
| 471 |
double sp[4], r1, r2, r3;
| 472 |
FVECT org, dir;
| 473 |
FVECT u, v;
| 474 |
register int i, j;
| 475 |
/* check arguments */
| 476 |
if (ob->oargs.nfargs != 4)
| 477 |
objerror(ob, USER, "bad # of arguments");
| 478 |
| 479 |
| 480 |
nalt = nazi = 1;
| 481 |
else {
| 482 |
n = 4.*PI * il->sampdens;
| 483 |
nalt = sqrt(2./PI*n) + .5;
| 484 |
nazi = PI/2.*nalt + .5;
| 485 |
| 486 |
if (il->sd != NULL)
| 487 |
objerror(ob, WARNING, "BSDF ignored");
| 488 |
n = nalt*nazi;
| 489 |
newdist(n);
| 490 |
dim[0] = random();
| 491 |
/* sample sphere */
| 492 |
for (dim[1] = 0; dim[1] < nalt; dim[1]++)
| 493 |
for (dim[2] = 0; dim[2] < nazi; dim[2]++)
| 494 |
| 495 |
/* next sample point */
| 496 |
multisamp(sp, 4, urand(ilhash(dim,3)+i));
| 497 |
/* random direction */
| 498 |
r1 = (dim[1] + sp[0])/nalt;
| 499 |
r2 = (dim[2] + sp[1] - .5)/nazi;
| 500 |
rounddir(dir, r1, r2);
| 501 |
/* random location */
| 502 |
mkaxes(u, v, dir); /* yuck! */
| 503 |
r3 = sqrt(sp[2]);
| 504 |
r2 = 2.*PI*sp[3];
| 505 |
r1 = r3*ob->oargs.farg[3]*cos(r2);
| 506 |
r2 = r3*ob->oargs.farg[3]*sin(r2);
| 507 |
r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
| 508 |
for (j = 0; j < 3; j++) {
| 509 |
org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
| 510 |
r3*dir[j];
| 511 |
dir[j] = -dir[j];
| 512 |
| 513 |
/* send sample */
| 514 |
raysamp(dim[1]*nazi+dim[2], org, dir);
| 515 |
| 516 |
| 517 |
rayclean();
| 518 |
/* write out the sphere and its distribution */
| 519 |
| 520 |
| 521 |
roundout(il, distarr, nalt, nazi);
| 522 |
else
| 523 |
objerror(ob, WARNING, "diffuse distribution");
| 524 |
illumout(il, ob);
| 525 |
} else
| 526 |
| 527 |
/* clean up */
| 528 |
return(1);
| 529 |
| 530 |
| 531 |
| 532 |
int
| 533 |
my_ring( /* make an illum ring */
| 534 |
OBJREC *ob,
| 535 |
| 536 |
char *nm
| 537 |
| 538 |
| 539 |
int dim[2];
| 540 |
| 541 |
double sp[2], r1, r2, r3;
| 542 |
int h;
| 543 |
FVECT dn, org, dir;
| 544 |
FVECT u, v;
| 545 |
MAT4 xfm;
| 546 |
CONE *co;
| 547 |
int i, j;
| 548 |
| 549 |
co = getcone(ob, 0);
| 550 |
| 551 |
| 552 |
if (!getBSDF_xfm(xfm, co->ad, il->udir)) {
| 553 |
| 554 |
freecone(ob);
| 555 |
| 556 |
| 557 |
n = il->sd->ninc;
| 558 |
} else {
| 559 |
| 560 |
| 561 |
} else {
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
n = nazi*nalt;
| 567 |
| 568 |
newdist(n);
| 569 |
mkaxes(u, v, co->ad);
| 570 |
dim[0] = random();
| 571 |
/* sample disk */
| 572 |
| 573 |
| 574 |
| 575 |
h = ilhash(dim,2) + i;
| 576 |
| 577 |
| 578 |
| 579 |
} else {
| 580 |
| 581 |
alti = dim[1]/nazi;
| 582 |
| 583 |
| 584 |
| 585 |
| 586 |
dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
| 587 |
| 588 |
| 589 |
multisamp(sp, 2, urand(h+8371));
| 590 |
r3 = sqrt(CO_R0(co)*CO_R0(co) +
| 591 |
sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
| 592 |
r2 = 2.*PI*sp[1];
| 593 |
r1 = r3*cos(r2);
| 594 |
r2 = r3*sin(r2);
| 595 |
if (il->sd != NULL && DOT(dir, co->ad) < -FTINY)
| 596 |
r3 = -1.0001*il->thick - 5.*FTINY;
| 597 |
else
| 598 |
r3 = 5.*FTINY;
| 599 |
| 600 |
org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
| 601 |
r3*co->ad[j];
| 602 |
/* send sample */
| 603 |
| 604 |
| 605 |
| 606 |
| 607 |
MAT4 ixfm;
| 608 |
| 609 |
| 610 |
ixfm[i][0] = u[i];
| 611 |
ixfm[i][1] = v[i];
| 612 |
ixfm[i][2] = co->ad[i];
| 613 |
ixfm[i][3] = 0.;
| 614 |
| 615 |
| 616 |
ixfm[3][3] = 1.;
| 617 |
} else {
| 618 |
| 619 |
| 620 |
| 621 |
| 622 |
new_discount();
| 623 |
| 624 |
dim[0] = random();
| 625 |
| 626 |
| 627 |
| 628 |
| 629 |
| 630 |
| 631 |
r2 = 2.*PI*sp[1];
| 632 |
r1 = r3*cos(r2);
| 633 |
r2 = r3*sin(r2);
| 634 |
| 635 |
org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
| 636 |
| 637 |
srcsamps(il, org, co->ad, ixfm);
| 638 |
| 639 |
| 640 |
| 641 |
rayclean();
| 642 |
| 643 |
| 644 |
| 645 |
redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm);
| 646 |
done_discount();
| 647 |
if (!il->sampdens)
| 648 |
| 649 |
| 650 |
/* write out the ring and its distribution */
| 651 |
| 652 |
| 653 |
flatout(il, distarr, nalt, nazi, u, v, co->ad);
| 654 |
illumout(il, ob);
| 655 |
} else
| 656 |
| 657 |
/* clean up */
| 658 |
freecone(ob);
| 659 |
return(1);
| 660 |
| 661 |
| 662 |
| 663 |
void
| 664 |
redistribute( /* pass distarr ray sums through BSDF */
| 665 |
struct BSDF_data *b,
| 666 |
int nalt,
| 667 |
int nazi,
| 668 |
FVECT u,
| 669 |
FVECT v,
| 670 |
FVECT w,
| 671 |
MAT4 xm
| 672 |
| 673 |
| 674 |
int nout = 0;
| 675 |
MAT4 mymat, inmat;
| 676 |
COLORV *idist;
| 677 |
COLORV *cp;
| 678 |
FVECT dv;
| 679 |
double wt;
| 680 |
int i, j, k, c, o;
| 681 |
COLOR col, cinc;
| 682 |
/* copy incoming distribution */
| 683 |
if (b->ninc > distsiz)
| 684 |
error(INTERNAL, "error 1 in redistribute");
| 685 |
idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc);
| 686 |
if (idist == NULL)
| 687 |
error(SYSTEM, "out of memory in redistribute");
| 688 |
memcpy(idist, distarr, sizeof(COLOR)*b->ninc);
| 689 |
/* compose direction transform */
| 690 |
| 691 |
mymat[i][0] = u[i];
| 692 |
mymat[i][1] = v[i];
| 693 |
mymat[i][2] = w[i];
| 694 |
mymat[i][3] = 0.;
| 695 |
| 696 |
mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.;
| 697 |
mymat[3][3] = 1.;
| 698 |
if (xm != NULL)
| 699 |
multmat4(mymat, xm, mymat);
| 700 |
for (i = 3; i--; ) { /* make sure it's normalized */
| 701 |
wt = 1./sqrt( mymat[0][i]*mymat[0][i] +
| 702 |
mymat[1][i]*mymat[1][i] +
| 703 |
mymat[2][i]*mymat[2][i] );
| 704 |
for (j = 3; j--; )
| 705 |
mymat[j][i] *= wt;
| 706 |
| 707 |
if (!invmat4(inmat, mymat)) /* need inverse as well */
| 708 |
error(INTERNAL, "cannot invert BSDF transform");
| 709 |
newdist(nalt*nazi); /* resample distribution */
| 710 |
for (i = b->ninc; i--; ) {
| 711 |
int direct_out = -1;
| 712 |
COLOR cdir;
| 713 |
getBSDF_incvec(dv, b, i); /* compute incident irrad. */
| 714 |
multv3(dv, dv, mymat);
| 715 |
if (dv[2] < 0.0) {
| 716 |
dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2];
| 717 |
direct_out += (direct_discount != NULL);
| 718 |
| 719 |
wt = getBSDF_incohm(b, i);
| 720 |
wt *= dv[2]; /* solid_angle*cosine(theta) */
| 721 |
cp = &idist[3*i];
| 722 |
copycolor(cinc, cp);
| 723 |
scalecolor(cinc, wt);
| 724 |
if (!direct_out) { /* discount direct contr. */
| 725 |
cp = &direct_discount[3*i];
| 726 |
copycolor(cdir, cp);
| 727 |
scalecolor(cdir, -wt);
| 728 |
if (b->nout != b->ninc)
| 729 |
direct_out = flatindex(dv, nalt, nazi);
| 730 |
else
| 731 |
direct_out = i; /* assumes dist. mirroring */
| 732 |
| 733 |
for (k = nalt; k--; ) /* loop over distribution */
| 734 |
for (j = nazi; j--; ) {
| 735 |
int rstart = random();
| 736 |
for (c = NBSDFSAMPS; c--; ) {
| 737 |
double sp[2];
| 738 |
multisamp(sp, 2, urand(rstart+c));
| 739 |
flatdir(dv, (k + sp[0])/nalt,
| 740 |
(j + .5 - sp[1])/nazi);
| 741 |
multv3(dv, dv, inmat);
| 742 |
/* evaluate BSDF @ outgoing */
| 743 |
o = getBSDF_outndx(b, dv);
| 744 |
if (o < 0) {
| 745 |
nout++;
| 746 |
continue;
| 747 |
| 748 |
wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS);
| 749 |
copycolor(col, cinc);
| 750 |
| 751 |
o = k*nazi + j;
| 752 |
if (o == direct_out)
| 753 |
addcolor(col, cdir); /* minus direct */
| 754 |
scalecolor(col, wt);
| 755 |
cp = &distarr[3*(k*nazi + j)];
| 756 |
addcolor(cp, col); /* sum into distribution */
| 757 |
| 758 |
| 759 |
| 760 |
free(idist); /* free temp space */
| 761 |
if (nout) {
| 762 |
sprintf(errmsg, "missing %.1f%% of BSDF directions",
| 763 |
100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS));
| 764 |
| 765 |
| 766 |
