root/radiance/ray/src/gen/mkillum2.c
Sun Sep 19 08:42:22 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.16: +11 -20 lines
Diff to previous 2.16 , to selected 2.6
Fri Sep 17 21:43:50 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.15: +120 -50 lines
Tue Mar 30 20:40:04 2004 UTC (20 years, 1 month ago) by greg
Fri Nov 21 07:15:30 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.12: +14 -12 lines
Sun Nov 16 10:29:38 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.11: +69 -36 lines
Changes since 2.9: +2 -5 lines
Changes since 2.8: +5 -8 lines
Wed Jul 9 11:24:52 1997 UTC (26 years, 9 months ago) by gregl
Tue Nov 7 17:50:44 1995 UTC (28 years, 5 months ago) by greg
fixed aspect on spherical divisions
Fri Jan 7 14:51:46 1994 UTC (30 years, 3 months ago) by greg
fixed bug in calculation of ring sample positions
Thu Aug 13 11:23:46 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.4: +3 -2 lines
minor optimization in long-enough edge determination
Thu Aug 13 10:03:19 1992 UTC (31 years, 8 months ago) by greg
minor improvement to check ALL edges for possible u vector in face
Wed Aug 12 14:44:15 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +13 -1 lines
made off-axis polygons sample better
Wed Mar 11 12:25:47 1992 UTC (32 years, 1 month ago) by greg
changed so light below threshold is printed as ordinary object
Tue Nov 12 17:05:11 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.14 , to selected 2.6
Fri Nov 8 13:17:47 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.13 , to selected 2.6
reset errno at appropriate points
Mon Aug 26 10:16:56 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.12 , to selected 2.6
fixed distribution pattern discontinuity
Fri Aug 23 12:30:33 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.11: +20 -14 lines
Diff to previous 1.11 , to selected 2.6
Thu Aug 22 12:12:23 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.10: +39 -19 lines
Diff to previous 1.10 , to selected 2.6
interpret d=0 to mean diffuse source
changed peano() calls to multisamp()
Tue Aug 13 13:45:18 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.9: +26 -34 lines
Diff to previous 1.9 , to selected 2.6
changed from urind() to peano() for n-dimensional sampling
Tue Jul 30 13:00:26 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.8: +1 -2 lines
Diff to previous 1.8 , to selected 2.6
added zeroing of position set as tag to rtrace
Thu Jul 25 14:43:15 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.7: +2 -8 lines
Diff to previous 1.7 , to selected 2.6
*** empty log message ***
Thu Jul 25 14:12:22 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 2.6
Thu Jul 25 12:52:18 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 2.6
test debugging
Thu Jul 25 10:59:07 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.4: +28 -18 lines
Diff to previous 1.4 , to selected 2.6
visual debugging pass
Wed Jul 24 16:48:26 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.3: +63 -43 lines
Diff to previous 1.3 , to selected 2.6
first version of mkillum
Wed Jul 24 13:32:05 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.2: +138 -2 lines
Diff to previous 1.2 , to selected 2.6
Wed Jul 24 12:22:05 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.1: +124 -1 lines
Diff to previous 1.1 , to selected 2.6
Tue Jul 23 15:42:42 1991 UTC (32 years, 9 months ago) by greg
Diff to selected 2.6
