--- ray/src/gen/mkillum2.c 2009/06/12 17:37:37 2.31 +++ ray/src/gen/mkillum2.c 2016/09/15 22:34:41 2.41 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.31 2009/06/12 17:37:37 greg Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.41 2016/09/15 22:34:41 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -11,14 +11,14 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.31 20 #include "face.h" #include "cone.h" #include "source.h" +#include "paths.h" #ifndef NBSDFSAMPS -#define NBSDFSAMPS 32 /* BSDF resampling count */ +#define NBSDFSAMPS 256 /* BSDF resampling count */ #endif COLORV * distarr = NULL; /* distribution array */ int distsiz = 0; -COLORV * direct_discount = NULL; /* amount to take off direct */ void @@ -28,14 +28,14 @@ newdist( /* allocate & clear distribution array */ { if (siz <= 0) { if (distsiz > 0) - free((void *)distarr); + free(distarr); distarr = NULL; distsiz = 0; return; } if (distsiz < siz) { if (distsiz > 0) - free((void *)distarr); + free(distarr); distarr = (COLORV *)malloc(sizeof(COLOR)*siz); if (distarr == NULL) error(SYSTEM, "out of memory in newdist"); @@ -45,27 +45,6 @@ newdist( /* allocate & clear distribution array */ } -static void -new_discount() /* allocate space for direct contrib. record */ -{ - if (distsiz <= 0) - return; - direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR)); - if (direct_discount == NULL) - error(SYSTEM, "out of memory in new_discount"); -} - - -static void -done_discount() /* clear off direct contrib. record */ -{ - if (direct_discount == NULL) - return; - free((void *)direct_discount); - direct_discount = NULL; -} - - int process_ray( /* process a ray result or report error */ RAY *r, @@ -83,11 +62,6 @@ process_ray( /* process a ray result or report error multcolor(r->rcol, r->rcoef); /* in case it's a source ray */ colp = &distarr[r->rno * 3]; addcolor(colp, r->rcol); - if (r->rsrc >= 0 && /* remember source contrib. */ - direct_discount != NULL) { - colp = &direct_discount[r->rno * 3]; - addcolor(colp, r->rcol); - } return(1); } @@ -107,7 +81,7 @@ raysamp( /* queue a ray sample */ VCOPY(myRay.rorg, org); VCOPY(myRay.rdir, dir); myRay.rmax = .0; - rayorigin(&myRay, PRIMARY, NULL, NULL); + rayorigin(&myRay, PRIMARY|SPECULAR, NULL, NULL); myRay.rno = ndx; /* queue ray, check result */ process_ray(&myRay, ray_pqueue(&myRay)); @@ -118,20 +92,18 @@ void srcsamps( /* sample sources from this surface position */ struct illum_args *il, FVECT org, - FVECT nrm, + double eps, MAT4 ixfm ) { - int nalt, nazi; + int nalt=1, nazi=1; SRCINDEX si; RAY sr; FVECT v; double d; int i, j; /* get sampling density */ - if (il->sampdens <= 0) { - nalt = nazi = 1; - } else { + if (il->sampdens > 0) { i = PI * il->sampdens; nalt = sqrt(i/PI) + .5; nazi = PI*nalt + .5; @@ -139,24 +111,6 @@ srcsamps( /* sample sources from this surface positi initsrcindex(&si); /* loop over (sub)sources */ for ( ; ; ) { VCOPY(sr.rorg, org); /* pick side to shoot from */ - if (il->sd != NULL) { - int sn = si.sn; - if (si.sp+1 >= si.np) ++sn; - if (sn >= nsources) break; - if (source[sn].sflags & SDISTANT) - d = DOT(source[sn].sloc, nrm); - else { - VSUB(v, source[sn].sloc, org); - d = DOT(v, nrm); - } - } else - d = 1.0; /* only transmission */ - if (d < 0.0) - d = -1.0001*il->thick - 5.*FTINY; - else - d = 5.*FTINY; - for (i = 3; i--; ) - sr.rorg[i] += d*nrm[i]; samplendx++; /* increment sample counter */ if (!srcray(&sr, NULL, &si)) break; /* end of sources */ @@ -165,21 +119,14 @@ srcsamps( /* sample sources from this surface positi multv3(v, sr.rdir, ixfm); else VCOPY(v, sr.rdir); - if (il->sd != NULL) { - i = getBSDF_incndx(il->sd, v); - if (i < 0) - continue; /* must not be important */ - sr.rno = i; - d = 1.0/getBSDF_incohm(il->sd, i); - } else { - if (v[2] >= -FTINY) - continue; /* only sample transmission */ - v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; - sr.rno = flatindex(v, nalt, nazi); - d = nalt*nazi*(1./PI) * v[2]; - } + if (v[2] >= -FTINY) + continue; /* only sample transmission */ + v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; + sr.rno = flatindex(v, nalt, nazi); + d = nalt*nazi*(1./PI) * v[2]; d *= si.dom; /* solid angle correction */ scalecolor(sr.rcoef, d); + VSUM(sr.rorg, sr.rorg, sr.rdir, -eps); process_ray(&sr, ray_pqueue(&sr)); } } @@ -202,22 +149,14 @@ mkaxes( /* compute u and v to go with n */ FVECT n ) { - register int i; - - v[0] = v[1] = v[2] = 0.0; - for (i = 0; i < 3; i++) - if (n[i] < 0.6 && n[i] > -0.6) - break; - v[i] = 1.0; - fcross(u, v, n); - normalize(u); + getperpendicular(u, n, 1); fcross(v, n, u); } static void rounddir( /* compute uniform spherical direction */ - register FVECT dv, + FVECT dv, double alt, double azi ) @@ -248,6 +187,7 @@ flatdir( /* compute uniform hemispherical direction * dv[2] = sqrt(1. - alt); } + int flatindex( /* compute index for hemispherical direction */ FVECT dv, @@ -297,7 +237,9 @@ my_face( /* make an illum face */ FVECT dn, org, dir; FVECT u, v; double ur[2], vr[2]; + double epsilon; MAT4 xfm; + char xfrot[64]; int nallow; FACE *fa; int i, j; @@ -308,23 +250,14 @@ my_face( /* make an illum face */ return(my_default(ob, il, nm)); } /* set up sampling */ - if (il->sd != NULL) { - if (!getBSDF_xfm(xfm, fa->norm, il->udir)) { - objerror(ob, WARNING, "illegal up direction"); - freeface(ob); - return(my_default(ob, il, nm)); - } - n = il->sd->ninc; + if (il->sampdens <= 0) { + nalt = nazi = 1; /* diffuse assumption */ } else { - if (il->sampdens <= 0) { - nalt = nazi = 1; /* diffuse assumption */ - } else { - n = PI * il->sampdens; - nalt = sqrt(n/PI) + .5; - nazi = PI*nalt + .5; - } - n = nazi*nalt; + n = PI * il->sampdens; + nalt = sqrt(n/PI) + .5; + nazi = PI*nalt + .5; } + n = nazi*nalt; newdist(n); /* take first edge >= sqrt(area) */ for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) { @@ -354,22 +287,19 @@ my_face( /* make an illum face */ dim[0] = random(); /* sample polygon */ nallow = 5*n*il->nsamps; + epsilon = .005*sqrt(fa->area); for (dim[1] = 0; dim[1] < n; dim[1]++) for (i = 0; i < il->nsamps; i++) { /* randomize direction */ h = ilhash(dim, 2) + i; - if (il->sd != NULL) { - r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm); - } else { - multisamp(sp, 2, urand(h)); - alti = dim[1]/nazi; - r1 = (alti + sp[0])/nalt; - r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; - flatdir(dn, r1, r2); - for (j = 0; j < 3; j++) + multisamp(sp, 2, urand(h)); + alti = dim[1]/nazi; + r1 = (alti + sp[0])/nalt; + r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; + flatdir(dn, r1, r2); + for (j = 0; j < 3; j++) dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*fa->norm[j]; - } /* randomize location */ do { multisamp(sp, 2, urand(h+4862+nallow)); @@ -385,34 +315,21 @@ my_face( /* make an illum face */ freeface(ob); return(my_default(ob, il, nm)); } - if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY) - r1 = -1.0001*il->thick - 5.*FTINY; - else - r1 = 5.*FTINY; - for (j = 0; j < 3; j++) - org[j] += r1*fa->norm[j]; + VSUM(org, org, dir, -epsilon); /* send sample */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) { + if (il->flags & IL_LIGHT) { MAT4 ixfm; - if (il->sd == NULL) { - for (i = 3; i--; ) { - ixfm[i][0] = u[i]; - ixfm[i][1] = v[i]; - ixfm[i][2] = fa->norm[i]; - ixfm[i][3] = 0.; - } - ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; - ixfm[3][3] = 1.; - } else { - if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, - "cannot invert BSDF transform"); - if (!(il->flags & IL_LIGHT)) - new_discount(); + for (i = 3; i--; ) { + ixfm[i][0] = u[i]; + ixfm[i][1] = v[i]; + ixfm[i][2] = fa->norm[i]; + ixfm[i][3] = 0.; } + ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; + ixfm[3][3] = 1.; dim[0] = random(); nallow = 10*il->nsamps; for (i = 0; i < il->nsamps; i++) { @@ -433,19 +350,11 @@ my_face( /* make an illum face */ return(my_default(ob, il, nm)); } /* sample source rays */ - srcsamps(il, org, fa->norm, ixfm); + srcsamps(il, org, epsilon, ixfm); } } /* wait for all rays to finish */ rayclean(); - if (il->sd != NULL) { /* run distribution through BSDF */ - nalt = sqrt(il->sd->nout/PI) + .5; - nazi = PI*nalt + .5; - redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm); - done_discount(); - if (!il->sampdens) - il->sampdens = nalt*nazi/PI + .999; - } /* write out the face and its distribution */ if (average(il, distarr, n)) { if (il->sampdens > 0) @@ -461,7 +370,7 @@ my_face( /* make an illum face */ int my_sphere( /* make an illum sphere */ - register OBJREC *ob, + OBJREC *ob, struct illum_args *il, char *nm ) @@ -471,7 +380,7 @@ my_sphere( /* make an illum sphere */ double sp[4], r1, r2, r3; FVECT org, dir; FVECT u, v; - register int i, j; + int i, j; /* check arguments */ if (ob->oargs.nfargs != 4) objerror(ob, USER, "bad # of arguments"); @@ -483,8 +392,6 @@ my_sphere( /* make an illum sphere */ nalt = sqrt(2./PI*n) + .5; nazi = PI/2.*nalt + .5; } - if (il->sd != NULL) - objerror(ob, WARNING, "BSDF ignored"); n = nalt*nazi; newdist(n); dim[0] = random(); @@ -548,23 +455,14 @@ my_ring( /* make an illum ring */ /* get/check arguments */ co = getcone(ob, 0); /* set up sampling */ - if (il->sd != NULL) { - if (!getBSDF_xfm(xfm, co->ad, il->udir)) { - objerror(ob, WARNING, "illegal up direction"); - freecone(ob); - return(my_default(ob, il, nm)); - } - n = il->sd->ninc; + if (il->sampdens <= 0) { + nalt = nazi = 1; /* diffuse assumption */ } else { - if (il->sampdens <= 0) { - nalt = nazi = 1; /* diffuse assumption */ - } else { - n = PI * il->sampdens; - nalt = sqrt(n/PI) + .5; - nazi = PI*nalt + .5; - } - n = nazi*nalt; + n = PI * il->sampdens; + nalt = sqrt(n/PI) + .5; + nazi = PI*nalt + .5; } + n = nazi*nalt; newdist(n); mkaxes(u, v, co->ad); dim[0] = random(); @@ -574,17 +472,13 @@ my_ring( /* make an illum ring */ /* next sample point */ h = ilhash(dim,2) + i; /* randomize direction */ - if (il->sd != NULL) { - r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm); - } else { - multisamp(sp, 2, urand(h)); - alti = dim[1]/nazi; - r1 = (alti + sp[0])/nalt; - r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; - flatdir(dn, r1, r2); - for (j = 0; j < 3; j++) - dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j]; - } + multisamp(sp, 2, urand(h)); + alti = dim[1]/nazi; + r1 = (alti + sp[0])/nalt; + r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; + flatdir(dn, r1, r2); + for (j = 0; j < 3; j++) + dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j]; /* randomize location */ multisamp(sp, 2, urand(h+8371)); r3 = sqrt(CO_R0(co)*CO_R0(co) + @@ -592,10 +486,7 @@ my_ring( /* make an illum ring */ r2 = 2.*PI*sp[1]; r1 = r3*cos(r2); r2 = r3*sin(r2); - if (il->sd != NULL && DOT(dir, co->ad) < -FTINY) - r3 = -1.0001*il->thick - 5.*FTINY; - else - r3 = 5.*FTINY; + r3 = 5.*FTINY; for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] + r3*co->ad[j]; @@ -603,24 +494,16 @@ my_ring( /* make an illum ring */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) { + if (il->flags & IL_LIGHT) { MAT4 ixfm; - if (il->sd == NULL) { - for (i = 3; i--; ) { - ixfm[i][0] = u[i]; - ixfm[i][1] = v[i]; - ixfm[i][2] = co->ad[i]; - ixfm[i][3] = 0.; - } - ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; - ixfm[3][3] = 1.; - } else { - if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, - "cannot invert BSDF transform"); - if (!(il->flags & IL_LIGHT)) - new_discount(); + for (i = 3; i--; ) { + ixfm[i][0] = u[i]; + ixfm[i][1] = v[i]; + ixfm[i][2] = co->ad[i]; + ixfm[i][3] = 0.; } + ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; + ixfm[3][3] = 1.; dim[0] = random(); for (i = 0; i < il->nsamps; i++) { /* randomize location */ @@ -634,19 +517,11 @@ my_ring( /* make an illum ring */ for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j]; /* sample source rays */ - srcsamps(il, org, co->ad, ixfm); + srcsamps(il, org, 5.*FTINY, ixfm); } } /* wait for all rays to finish */ rayclean(); - if (il->sd != NULL) { /* run distribution through BSDF */ - nalt = sqrt(il->sd->nout/PI) + .5; - nazi = PI*nalt + .5; - redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm); - done_discount(); - if (!il->sampdens) - il->sampdens = nalt*nazi/PI + .999; - } /* write out the ring and its distribution */ if (average(il, distarr, n)) { if (il->sampdens > 0) @@ -657,106 +532,4 @@ my_ring( /* make an illum ring */ /* clean up */ freecone(ob); return(1); -} - - -void -redistribute( /* pass distarr ray sums through BSDF */ - struct BSDF_data *b, - int nalt, - int nazi, - FVECT u, - FVECT v, - FVECT w, - MAT4 xm -) -{ - int nout = 0; - MAT4 mymat, inmat; - COLORV *idist; - COLORV *cp; - FVECT dv; - double wt; - int i, j, k, c, o; - COLOR col, cinc; - /* copy incoming distribution */ - if (b->ninc > distsiz) - error(INTERNAL, "error 1 in redistribute"); - idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc); - if (idist == NULL) - error(SYSTEM, "out of memory in redistribute"); - memcpy(idist, distarr, sizeof(COLOR)*b->ninc); - /* compose direction transform */ - for (i = 3; i--; ) { - mymat[i][0] = u[i]; - mymat[i][1] = v[i]; - mymat[i][2] = w[i]; - mymat[i][3] = 0.; - } - mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.; - mymat[3][3] = 1.; - if (xm != NULL) - multmat4(mymat, xm, mymat); - for (i = 3; i--; ) { /* make sure it's normalized */ - wt = 1./sqrt( mymat[0][i]*mymat[0][i] + - mymat[1][i]*mymat[1][i] + - mymat[2][i]*mymat[2][i] ); - for (j = 3; j--; ) - mymat[j][i] *= wt; - } - if (!invmat4(inmat, mymat)) /* need inverse as well */ - error(INTERNAL, "cannot invert BSDF transform"); - newdist(nalt*nazi); /* resample distribution */ - for (i = b->ninc; i--; ) { - int direct_out = -1; - COLOR cdir; - getBSDF_incvec(dv, b, i); /* compute incident irrad. */ - multv3(dv, dv, mymat); - if (dv[2] < 0.0) { - dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2]; - direct_out += (direct_discount != NULL); - } - wt = getBSDF_incohm(b, i); - wt *= dv[2]; /* solid_angle*cosine(theta) */ - cp = &idist[3*i]; - copycolor(cinc, cp); - scalecolor(cinc, wt); - if (!direct_out) { /* discount direct contr. */ - cp = &direct_discount[3*i]; - copycolor(cdir, cp); - scalecolor(cdir, -wt); - direct_out = flatindex(dv, nalt, nazi); - } - for (k = nalt; k--; ) /* loop over distribution */ - for (j = nazi; j--; ) { - int rstart = random(); - for (c = NBSDFSAMPS; c--; ) { - double sp[2]; - multisamp(sp, 2, urand(rstart+c)); - flatdir(dv, (k + sp[0])/nalt, - (j + .5 - sp[1])/nazi); - multv3(dv, dv, inmat); - /* evaluate BSDF @ outgoing */ - o = getBSDF_outndx(b, dv); - if (o < 0) { - nout++; - continue; - } - wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS); - copycolor(col, cinc); - o = k*nazi + j; - if (o == direct_out) - addcolor(col, cdir); /* minus direct */ - scalecolor(col, wt); - cp = &distarr[3*o]; - addcolor(cp, col); /* sum into distribution */ - } - } - } - free(idist); /* free temp space */ - if (nout) { - sprintf(errmsg, "missing %.1f%% of BSDF directions", - 100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS)); - error(WARNING, errmsg); - } }
