--- ray/src/gen/mkillum2.c 2011/08/16 18:09:53 2.37 +++ ray/src/gen/mkillum2.c 2016/09/16 15:08:38 2.42 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkillum2.c,v 2.37 2011/08/16 18:09:53 greg Exp $"; +static const char RCSid[] = "$Id: mkillum2.c,v 2.42 2016/09/16 15:08:38 greg Exp $"; #endif /* * Routines to do the actual calculation for mkillum @@ -13,13 +13,12 @@ static const char RCSid[] = "$Id: mkillum2.c,v 2.37 20 #include "source.h" #include "paths.h" -#ifndef NBSDFSAMPS -#define NBSDFSAMPS 256 /* BSDF resampling count */ +#ifndef R_EPS +#define R_EPS 0.005 /* relative epsilon for ray origin */ #endif COLORV * distarr = NULL; /* distribution array */ int distsiz = 0; -COLORV * direct_discount = NULL; /* amount to take off direct */ void @@ -46,27 +45,6 @@ newdist( /* allocate & clear distribution array */ } -static void -new_discount() /* allocate space for direct contrib. record */ -{ - if (distsiz <= 0) - return; - direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR)); - if (direct_discount == NULL) - error(SYSTEM, "out of memory in new_discount"); -} - - -static void -done_discount() /* clear off direct contrib. record */ -{ - if (direct_discount == NULL) - return; - free(direct_discount); - direct_discount = NULL; -} - - int process_ray( /* process a ray result or report error */ RAY *r, @@ -84,11 +62,6 @@ process_ray( /* process a ray result or report error multcolor(r->rcol, r->rcoef); /* in case it's a source ray */ colp = &distarr[r->rno * 3]; addcolor(colp, r->rcol); - if (r->rsrc >= 0 && /* remember source contrib. */ - direct_discount != NULL) { - colp = &direct_discount[r->rno * 3]; - addcolor(colp, r->rcol); - } return(1); } @@ -119,7 +92,7 @@ void srcsamps( /* sample sources from this surface position */ struct illum_args *il, FVECT org, - FVECT nrm, + double eps, MAT4 ixfm ) { @@ -130,7 +103,7 @@ srcsamps( /* sample sources from this surface positi double d; int i, j; /* get sampling density */ - if (il->sd == NULL && il->sampdens > 0) { + if (il->sampdens > 0) { i = PI * il->sampdens; nalt = sqrt(i/PI) + .5; nazi = PI*nalt + .5; @@ -138,23 +111,6 @@ srcsamps( /* sample sources from this surface positi initsrcindex(&si); /* loop over (sub)sources */ for ( ; ; ) { VCOPY(sr.rorg, org); /* pick side to shoot from */ - if (il->sd != NULL) { - int sn = si.sn; - if (si.sp+1 >= si.np) ++sn; - if (sn >= nsources) break; - if (source[sn].sflags & SDISTANT) - d = DOT(source[sn].sloc, nrm); - else { - VSUB(v, source[sn].sloc, org); - d = DOT(v, nrm); - } - } else - d = 1.0; /* only transmission */ - if (d < 0.0) - d = -1.0001*il->thick - 5.*FTINY; - else - d = 5.*FTINY; - VSUM(sr.rorg, sr.rorg, nrm, d); samplendx++; /* increment sample counter */ if (!srcray(&sr, NULL, &si)) break; /* end of sources */ @@ -163,21 +119,14 @@ srcsamps( /* sample sources from this surface positi multv3(v, sr.rdir, ixfm); else VCOPY(v, sr.rdir); - if (il->sd != NULL) { - i = getBSDF_incndx(il->sd, v); - if (i < 0) - continue; /* must not be important */ - sr.rno = i; - d = 1.0/getBSDF_incohm(il->sd, i); - } else { - if (v[2] >= -FTINY) - continue; /* only sample transmission */ - v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; - sr.rno = flatindex(v, nalt, nazi); - d = nalt*nazi*(1./PI) * v[2]; - } + if (v[2] >= -FTINY) + continue; /* only sample transmission */ + v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2]; + sr.rno = flatindex(v, nalt, nazi); + d = nalt*nazi*(1./PI) * v[2]; d *= si.dom; /* solid angle correction */ scalecolor(sr.rcoef, d); + VSUM(sr.rorg, sr.rorg, sr.rdir, -eps); process_ray(&sr, ray_pqueue(&sr)); } } @@ -200,22 +149,14 @@ mkaxes( /* compute u and v to go with n */ FVECT n ) { - register int i; - - v[0] = v[1] = v[2] = 0.0; - for (i = 0; i < 3; i++) - if (n[i] < 0.6 && n[i] > -0.6) - break; - v[i] = 1.0; - fcross(u, v, n); - normalize(u); + getperpendicular(u, n, 1); fcross(v, n, u); } static void rounddir( /* compute uniform spherical direction */ - register FVECT dv, + FVECT dv, double alt, double azi ) @@ -268,51 +209,6 @@ flatindex( /* compute index for hemispherical directi int -printgeom( /* print out detailed geometry for BSDF */ - struct BSDF_data *sd, - char *xfrot, - FVECT ctr, - double s1, - double s2 -) -{ - static char mgftemp[] = TEMPLATE; - char cmdbuf[64]; - FILE *fp; - double sca; - - if (sd == NULL || sd->mgf == NULL) - return(0); - if (sd->dim[0] <= FTINY || sd->dim[1] <= FTINY) - return(0); - if ((s1 > s2) ^ (sd->dim[0] > sd->dim[1])) { - sca = s1; s1 = s2; s2 = sca; - } - s1 /= sd->dim[0]; - s2 /= sd->dim[1]; - sca = s1 > s2 ? s1 : s2; - strcpy(mgftemp, TEMPLATE); - if ((fp = fopen(mktemp(mgftemp), "w")) == NULL) - error(SYSTEM, "cannot create temporary file for MGF"); - /* prepend our transform */ - fprintf(fp, "xf%s -s %.5f -t %.5g %.5g %.5g\n", - xfrot, sca, ctr[0], ctr[1], ctr[2]); - /* output given MGF description */ - fputs(sd->mgf, fp); - fputs("\nxf\n", fp); - if (fclose(fp) == EOF) - error(SYSTEM, "error writing MGF temporary file"); - /* execute mgf2rad to convert MGF */ - strcpy(cmdbuf, "mgf2rad "); - strcpy(cmdbuf+8, mgftemp); - fflush(stdout); - system(cmdbuf); - unlink(mgftemp); /* clean up */ - return(1); -} - - -int my_default( /* default illum action */ OBJREC *ob, struct illum_args *il, @@ -341,6 +237,7 @@ my_face( /* make an illum face */ FVECT dn, org, dir; FVECT u, v; double ur[2], vr[2]; + double epsilon; MAT4 xfm; char xfrot[64]; int nallow; @@ -353,23 +250,14 @@ my_face( /* make an illum face */ return(my_default(ob, il, nm)); } /* set up sampling */ - if (il->sd != NULL) { - if (!getBSDF_xfm(xfm, fa->norm, il->udir, xfrot)) { - objerror(ob, WARNING, "illegal up direction"); - freeface(ob); - return(my_default(ob, il, nm)); - } - n = il->sd->ninc; + if (il->sampdens <= 0) { + nalt = nazi = 1; /* diffuse assumption */ } else { - if (il->sampdens <= 0) { - nalt = nazi = 1; /* diffuse assumption */ - } else { - n = PI * il->sampdens; - nalt = sqrt(n/PI) + .5; - nazi = PI*nalt + .5; - } - n = nazi*nalt; + n = PI * il->sampdens; + nalt = sqrt(n/PI) + .5; + nazi = PI*nalt + .5; } + n = nazi*nalt; newdist(n); /* take first edge >= sqrt(area) */ for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) { @@ -396,34 +284,22 @@ my_face( /* make an illum face */ if (r2 < vr[0]) vr[0] = r2; if (r2 > vr[1]) vr[1] = r2; } - /* output detailed geometry? */ - if (!(il->flags & IL_LIGHT) && il->sd != NULL && il->sd->mgf != NULL && - il->thick <= FTINY) { - for (j = 3; j--; ) - org[j] = .5*(ur[0]+ur[1])*u[j] + - .5*(vr[0]+vr[1])*v[j] + - fa->offset*fa->norm[j]; - printgeom(il->sd, xfrot, org, ur[1]-ur[0], vr[1]-vr[0]); - } dim[0] = random(); /* sample polygon */ nallow = 5*n*il->nsamps; + epsilon = R_EPS*sqrt(fa->area); for (dim[1] = 0; dim[1] < n; dim[1]++) for (i = 0; i < il->nsamps; i++) { /* randomize direction */ h = ilhash(dim, 2) + i; - if (il->sd != NULL) { - r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm); - } else { - multisamp(sp, 2, urand(h)); - alti = dim[1]/nazi; - r1 = (alti + sp[0])/nalt; - r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; - flatdir(dn, r1, r2); - for (j = 0; j < 3; j++) + multisamp(sp, 2, urand(h)); + alti = dim[1]/nazi; + r1 = (alti + sp[0])/nalt; + r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; + flatdir(dn, r1, r2); + for (j = 0; j < 3; j++) dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*fa->norm[j]; - } /* randomize location */ do { multisamp(sp, 2, urand(h+4862+nallow)); @@ -439,34 +315,21 @@ my_face( /* make an illum face */ freeface(ob); return(my_default(ob, il, nm)); } - if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY) - r1 = -1.0001*il->thick - 5.*FTINY; - else - r1 = 5.*FTINY; - for (j = 0; j < 3; j++) - org[j] += r1*fa->norm[j]; + VSUM(org, org, dir, -epsilon); /* send sample */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (il->flags & IL_LIGHT || il->sd != NULL) { + if (il->flags & IL_LIGHT) { MAT4 ixfm; - if (il->sd == NULL) { - for (i = 3; i--; ) { - ixfm[i][0] = u[i]; - ixfm[i][1] = v[i]; - ixfm[i][2] = fa->norm[i]; - ixfm[i][3] = 0.; - } - ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; - ixfm[3][3] = 1.; - } else { - if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, - "cannot invert BSDF transform"); - if (!(il->flags & IL_LIGHT)) - new_discount(); + for (i = 3; i--; ) { + ixfm[i][0] = u[i]; + ixfm[i][1] = v[i]; + ixfm[i][2] = fa->norm[i]; + ixfm[i][3] = 0.; } + ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; + ixfm[3][3] = 1.; dim[0] = random(); nallow = 10*il->nsamps; for (i = 0; i < il->nsamps; i++) { @@ -487,19 +350,11 @@ my_face( /* make an illum face */ return(my_default(ob, il, nm)); } /* sample source rays */ - srcsamps(il, org, fa->norm, ixfm); + srcsamps(il, org, epsilon, ixfm); } } /* wait for all rays to finish */ rayclean(); - if (il->sd != NULL) { /* run distribution through BSDF */ - nalt = sqrt(il->sd->nout/PI) + .5; - nazi = PI*nalt + .5; - redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm); - done_discount(); - if (!il->sampdens) - il->sampdens = nalt*nazi/PI + .999; - } /* write out the face and its distribution */ if (average(il, distarr, n)) { if (il->sampdens > 0) @@ -515,7 +370,7 @@ my_face( /* make an illum face */ int my_sphere( /* make an illum sphere */ - register OBJREC *ob, + OBJREC *ob, struct illum_args *il, char *nm ) @@ -525,7 +380,7 @@ my_sphere( /* make an illum sphere */ double sp[4], r1, r2, r3; FVECT org, dir; FVECT u, v; - register int i, j; + int i, j; /* check arguments */ if (ob->oargs.nfargs != 4) objerror(ob, USER, "bad # of arguments"); @@ -537,8 +392,6 @@ my_sphere( /* make an illum sphere */ nalt = sqrt(2./PI*n) + .5; nazi = PI/2.*nalt + .5; } - if (il->sd != NULL) - objerror(ob, WARNING, "BSDF ignored"); n = nalt*nazi; newdist(n); dim[0] = random(); @@ -593,32 +446,27 @@ my_ring( /* make an illum ring */ int dim[2]; int n, nalt, nazi, alti; double sp[2], r1, r2, r3; + double epsilon; int h; FVECT dn, org, dir; FVECT u, v; MAT4 xfm; CONE *co; int i, j; - /* get/check arguments */ + /* get/check arguments */ co = getcone(ob, 0); - /* set up sampling */ - if (il->sd != NULL) { - if (!getBSDF_xfm(xfm, co->ad, il->udir, NULL)) { - objerror(ob, WARNING, "illegal up direction"); - freecone(ob); - return(my_default(ob, il, nm)); - } - n = il->sd->ninc; + if (co == NULL) + objerror(ob, USER, "cannot create illum"); + /* set up sampling */ + if (il->sampdens <= 0) { + nalt = nazi = 1; /* diffuse assumption */ } else { - if (il->sampdens <= 0) { - nalt = nazi = 1; /* diffuse assumption */ - } else { - n = PI * il->sampdens; - nalt = sqrt(n/PI) + .5; - nazi = PI*nalt + .5; - } - n = nazi*nalt; + n = PI * il->sampdens; + nalt = sqrt(n/PI) + .5; + nazi = PI*nalt + .5; } + epsilon = R_EPS*CO_R1(co); + n = nazi*nalt; newdist(n); mkaxes(u, v, co->ad); dim[0] = random(); @@ -628,17 +476,13 @@ my_ring( /* make an illum ring */ /* next sample point */ h = ilhash(dim,2) + i; /* randomize direction */ - if (il->sd != NULL) { - r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm); - } else { - multisamp(sp, 2, urand(h)); - alti = dim[1]/nazi; - r1 = (alti + sp[0])/nalt; - r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; - flatdir(dn, r1, r2); - for (j = 0; j < 3; j++) - dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j]; - } + multisamp(sp, 2, urand(h)); + alti = dim[1]/nazi; + r1 = (alti + sp[0])/nalt; + r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi; + flatdir(dn, r1, r2); + for (j = 0; j < 3; j++) + dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j]; /* randomize location */ multisamp(sp, 2, urand(h+8371)); r3 = sqrt(CO_R0(co)*CO_R0(co) + @@ -646,35 +490,23 @@ my_ring( /* make an illum ring */ r2 = 2.*PI*sp[1]; r1 = r3*cos(r2); r2 = r3*sin(r2); - if (il->sd != NULL && DOT(dir, co->ad) < -FTINY) - r3 = -1.0001*il->thick - 5.*FTINY; - else - r3 = 5.*FTINY; for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] + - r3*co->ad[j]; + epsilon*co->ad[j]; /* send sample */ raysamp(dim[1], org, dir); } /* add in direct component? */ - if (il->flags & IL_LIGHT || il->sd != NULL) { + if (il->flags & IL_LIGHT) { MAT4 ixfm; - if (il->sd == NULL) { - for (i = 3; i--; ) { - ixfm[i][0] = u[i]; - ixfm[i][1] = v[i]; - ixfm[i][2] = co->ad[i]; - ixfm[i][3] = 0.; - } - ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; - ixfm[3][3] = 1.; - } else { - if (!invmat4(ixfm, xfm)) - objerror(ob, INTERNAL, - "cannot invert BSDF transform"); - if (!(il->flags & IL_LIGHT)) - new_discount(); + for (i = 3; i--; ) { + ixfm[i][0] = u[i]; + ixfm[i][1] = v[i]; + ixfm[i][2] = co->ad[i]; + ixfm[i][3] = 0.; } + ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.; + ixfm[3][3] = 1.; dim[0] = random(); for (i = 0; i < il->nsamps; i++) { /* randomize location */ @@ -688,19 +520,11 @@ my_ring( /* make an illum ring */ for (j = 0; j < 3; j++) org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j]; /* sample source rays */ - srcsamps(il, org, co->ad, ixfm); + srcsamps(il, org, epsilon, ixfm); } } /* wait for all rays to finish */ rayclean(); - if (il->sd != NULL) { /* run distribution through BSDF */ - nalt = sqrt(il->sd->nout/PI) + .5; - nazi = PI*nalt + .5; - redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm); - done_discount(); - if (!il->sampdens) - il->sampdens = nalt*nazi/PI + .999; - } /* write out the ring and its distribution */ if (average(il, distarr, n)) { if (il->sampdens > 0) @@ -711,110 +535,4 @@ my_ring( /* make an illum ring */ /* clean up */ freecone(ob); return(1); -} - - -void -redistribute( /* pass distarr ray sums through BSDF */ - struct BSDF_data *b, - int nalt, - int nazi, - FVECT u, - FVECT v, - FVECT w, - MAT4 xm -) -{ - int nout = 0; - MAT4 mymat, inmat; - COLORV *idist; - COLORV *cp; - FVECT dv; - double wt; - int i, j, k, c, o; - COLOR col, cinc; - /* copy incoming distribution */ - if (b->ninc > distsiz) - error(INTERNAL, "error 1 in redistribute"); - idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc); - if (idist == NULL) - error(SYSTEM, "out of memory in redistribute"); - memcpy(idist, distarr, sizeof(COLOR)*b->ninc); - /* compose direction transform */ - for (i = 3; i--; ) { - mymat[i][0] = u[i]; - mymat[i][1] = v[i]; - mymat[i][2] = w[i]; - mymat[i][3] = 0.; - } - mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.; - mymat[3][3] = 1.; - if (xm != NULL) - multmat4(mymat, xm, mymat); - for (i = 3; i--; ) { /* make sure it's normalized */ - wt = 1./sqrt( mymat[0][i]*mymat[0][i] + - mymat[1][i]*mymat[1][i] + - mymat[2][i]*mymat[2][i] ); - for (j = 3; j--; ) - mymat[j][i] *= wt; - } - if (!invmat4(inmat, mymat)) /* need inverse as well */ - error(INTERNAL, "cannot invert BSDF transform"); - newdist(nalt*nazi); /* resample distribution */ - for (i = b->ninc; i--; ) { - int direct_out = -1; - COLOR cdir; - getBSDF_incvec(dv, b, i); /* compute incident irrad. */ - multv3(dv, dv, mymat); - if (dv[2] < 0.0) { - dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2]; - direct_out += (direct_discount != NULL); - } - wt = getBSDF_incohm(b, i); - wt *= dv[2]; /* solid_angle*cosine(theta) */ - cp = &idist[3*i]; - copycolor(cinc, cp); - scalecolor(cinc, wt); - if (!direct_out) { /* discount direct contr. */ - cp = &direct_discount[3*i]; - copycolor(cdir, cp); - scalecolor(cdir, -wt); - if (b->nout != b->ninc) - direct_out = flatindex(dv, nalt, nazi); - else - direct_out = i; /* assumes dist. mirroring */ - } - for (k = nalt; k--; ) /* loop over distribution */ - for (j = nazi; j--; ) { - int rstart = random(); - for (c = NBSDFSAMPS; c--; ) { - double sp[2]; - multisamp(sp, 2, urand(rstart+c)); - flatdir(dv, (k + sp[0])/nalt, - (j + .5 - sp[1])/nazi); - multv3(dv, dv, inmat); - /* evaluate BSDF @ outgoing */ - o = getBSDF_outndx(b, dv); - if (o < 0) { - nout++; - continue; - } - wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS); - copycolor(col, cinc); - if (b->nout != b->ninc) - o = k*nazi + j; - if (o == direct_out) - addcolor(col, cdir); /* minus direct */ - scalecolor(col, wt); - cp = &distarr[3*(k*nazi + j)]; - addcolor(cp, col); /* sum into distribution */ - } - } - } - free(idist); /* free temp space */ - if (nout) { - sprintf(errmsg, "missing %.1f%% of BSDF directions", - 100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS)); - error(WARNING, errmsg); - } }
