root/radiance/ray/src/gen/mkillum2.c
Revision: 2.43
Committed: Fri Nov 17 20:02:07 2023 UTC (18 months ago) by greg
Changes since 2.42: +4 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.43 static const char RCSid[] = "$Id: mkillum2.c,v 2.42 2016/09/16 15:08:38 greg Exp $";
3 greg 1.1 #endif
4     /*
5 greg 1.4 * Routines to do the actual calculation for mkillum
6 greg 1.1 */
7
8 schorsch 2.11 #include <string.h>
9
10 greg 1.1 #include "mkillum.h"
11     #include "face.h"
12     #include "cone.h"
13 greg 2.25 #include "source.h"
14 greg 2.35 #include "paths.h"
15 greg 1.1
16 greg 2.42 #ifndef R_EPS
17     #define R_EPS 0.005 /* relative epsilon for ray origin */
18 greg 2.31 #endif
19 greg 2.13
20 greg 2.21 COLORV * distarr = NULL; /* distribution array */
21     int distsiz = 0;
22 greg 2.16
23 greg 2.31
24 greg 2.21 void
25 greg 2.18 newdist( /* allocate & clear distribution array */
26     int siz
27     )
28     {
29 greg 2.24 if (siz <= 0) {
30 greg 2.18 if (distsiz > 0)
31 greg 2.36 free(distarr);
32 greg 2.18 distarr = NULL;
33     distsiz = 0;
34     return;
35     }
36     if (distsiz < siz) {
37 greg 2.21 if (distsiz > 0)
38 greg 2.36 free(distarr);
39 greg 2.21 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
40 greg 2.18 if (distarr == NULL)
41 greg 2.20 error(SYSTEM, "out of memory in newdist");
42 greg 2.18 distsiz = siz;
43     }
44 greg 2.21 memset(distarr, '\0', sizeof(COLOR)*siz);
45 greg 2.18 }
46
47
48 greg 2.21 int
49 greg 2.25 process_ray( /* process a ray result or report error */
50     RAY *r,
51     int rv
52     )
53 greg 2.18 {
54     COLORV *colp;
55
56 greg 2.24 if (rv == 0) /* no result ready */
57 greg 2.18 return(0);
58     if (rv < 0)
59 greg 2.20 error(USER, "ray tracing process died");
60 greg 2.18 if (r->rno >= distsiz)
61 greg 2.20 error(INTERNAL, "bad returned index in process_ray");
62 greg 2.43 smultscolor(r->rcol, r->rcoef); /* in case it's a source ray */
63 greg 2.18 colp = &distarr[r->rno * 3];
64 greg 2.43 addscolor(colp, r->rcol);
65 greg 2.18 return(1);
66     }
67
68
69 greg 2.21 void
70 greg 2.25 raysamp( /* queue a ray sample */
71 greg 2.18 int ndx,
72     FVECT org,
73     FVECT dir
74 greg 2.16 )
75     {
76 greg 2.18 RAY myRay;
77     int rv;
78
79     if ((ndx < 0) | (ndx >= distsiz))
80 greg 2.20 error(INTERNAL, "bad index in raysamp");
81 greg 2.18 VCOPY(myRay.rorg, org);
82     VCOPY(myRay.rdir, dir);
83     myRay.rmax = .0;
84 greg 2.36 rayorigin(&myRay, PRIMARY|SPECULAR, NULL, NULL);
85 greg 2.18 myRay.rno = ndx;
86     /* queue ray, check result */
87     process_ray(&myRay, ray_pqueue(&myRay));
88     }
89
90
91 greg 2.21 void
92 greg 2.25 srcsamps( /* sample sources from this surface position */
93     struct illum_args *il,
94     FVECT org,
95 greg 2.41 double eps,
96 greg 2.25 MAT4 ixfm
97     )
98     {
99 greg 2.37 int nalt=1, nazi=1;
100 greg 2.25 SRCINDEX si;
101     RAY sr;
102     FVECT v;
103     double d;
104     int i, j;
105     /* get sampling density */
106 greg 2.38 if (il->sampdens > 0) {
107 greg 2.25 i = PI * il->sampdens;
108     nalt = sqrt(i/PI) + .5;
109     nazi = PI*nalt + .5;
110     }
111     initsrcindex(&si); /* loop over (sub)sources */
112     for ( ; ; ) {
113     VCOPY(sr.rorg, org); /* pick side to shoot from */
114 greg 2.30 samplendx++; /* increment sample counter */
115 greg 2.25 if (!srcray(&sr, NULL, &si))
116     break; /* end of sources */
117     /* index direction */
118     if (ixfm != NULL)
119     multv3(v, sr.rdir, ixfm);
120     else
121     VCOPY(v, sr.rdir);
122 greg 2.38 if (v[2] >= -FTINY)
123 greg 2.41 continue; /* only sample transmission */
124 greg 2.38 v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
125     sr.rno = flatindex(v, nalt, nazi);
126     d = nalt*nazi*(1./PI) * v[2];
127 greg 2.25 d *= si.dom; /* solid angle correction */
128 greg 2.43 scalescolor(sr.rcoef, d);
129 greg 2.41 VSUM(sr.rorg, sr.rorg, sr.rdir, -eps);
130 greg 2.25 process_ray(&sr, ray_pqueue(&sr));
131     }
132     }
133
134
135     void
136 greg 2.18 rayclean() /* finish all pending rays */
137     {
138     RAY myRay;
139
140     while (process_ray(&myRay, ray_presult(&myRay, 0)))
141 greg 2.16 ;
142     }
143 schorsch 2.12
144
145 greg 2.21 static void
146     mkaxes( /* compute u and v to go with n */
147     FVECT u,
148     FVECT v,
149     FVECT n
150     )
151     {
152 greg 2.40 getperpendicular(u, n, 1);
153 greg 2.21 fcross(v, n, u);
154     }
155
156
157     static void
158     rounddir( /* compute uniform spherical direction */
159 greg 2.39 FVECT dv,
160 greg 2.21 double alt,
161     double azi
162     )
163     {
164     double d1, d2;
165
166     dv[2] = 1. - 2.*alt;
167     d1 = sqrt(1. - dv[2]*dv[2]);
168     d2 = 2.*PI * azi;
169     dv[0] = d1*cos(d2);
170     dv[1] = d1*sin(d2);
171     }
172
173
174 greg 2.24 void
175 greg 2.21 flatdir( /* compute uniform hemispherical direction */
176 greg 2.24 FVECT dv,
177 greg 2.21 double alt,
178     double azi
179     )
180     {
181     double d1, d2;
182
183     d1 = sqrt(alt);
184     d2 = 2.*PI * azi;
185     dv[0] = d1*cos(d2);
186     dv[1] = d1*sin(d2);
187     dv[2] = sqrt(1. - alt);
188     }
189
190 greg 2.35
191 greg 2.29 int
192     flatindex( /* compute index for hemispherical direction */
193     FVECT dv,
194     int nalt,
195     int nazi
196     )
197     {
198     double d;
199     int i, j;
200
201     d = 1.0 - dv[2]*dv[2];
202     i = d*nalt;
203     d = atan2(dv[1], dv[0]) * (0.5/PI);
204     if (d < 0.0) d += 1.0;
205     j = d*nazi + 0.5;
206     if (j >= nazi) j = 0;
207     return(i*nazi + j);
208     }
209
210 greg 2.21
211 greg 2.19 int
212 greg 2.18 my_default( /* default illum action */
213 schorsch 2.12 OBJREC *ob,
214     struct illum_args *il,
215     char *nm
216     )
217 greg 1.1 {
218 greg 1.2 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
219     nm, ofun[ob->otype].funame, ob->oname);
220     error(WARNING, errmsg);
221 greg 2.2 printobj(il->altmat, ob);
222 greg 2.13 return(1);
223 greg 1.2 }
224
225
226 greg 2.13 int
227 greg 2.18 my_face( /* make an illum face */
228 schorsch 2.12 OBJREC *ob,
229     struct illum_args *il,
230     char *nm
231     )
232 greg 1.2 {
233 greg 2.21 int dim[2];
234 greg 2.25 int n, nalt, nazi, alti;
235 greg 1.10 double sp[2], r1, r2;
236 greg 2.25 int h;
237 greg 1.4 FVECT dn, org, dir;
238 greg 1.3 FVECT u, v;
239     double ur[2], vr[2];
240 greg 2.41 double epsilon;
241 greg 2.21 MAT4 xfm;
242 greg 2.35 char xfrot[64];
243 greg 2.25 int nallow;
244 greg 2.21 FACE *fa;
245 greg 2.25 int i, j;
246 greg 1.3 /* get/check arguments */
247     fa = getface(ob);
248     if (fa->area == 0.0) {
249     freeface(ob);
250 greg 2.19 return(my_default(ob, il, nm));
251 greg 1.3 }
252     /* set up sampling */
253 greg 2.38 if (il->sampdens <= 0) {
254     nalt = nazi = 1; /* diffuse assumption */
255 greg 2.22 } else {
256 greg 2.38 n = PI * il->sampdens;
257     nalt = sqrt(n/PI) + .5;
258     nazi = PI*nalt + .5;
259 greg 2.22 }
260 greg 2.38 n = nazi*nalt;
261 greg 2.18 newdist(n);
262 greg 2.20 /* take first edge >= sqrt(area) */
263 greg 2.4 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
264     u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
265     u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
266     u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
267 greg 2.5 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
268 greg 2.3 break;
269     }
270     if (i < fa->nv) { /* got one! -- let's align our axes */
271 greg 2.5 r2 = 1.0/sqrt(r1);
272     u[0] *= r2; u[1] *= r2; u[2] *= r2;
273 greg 2.3 fcross(v, fa->norm, u);
274     } else /* oh well, we'll just have to wing it */
275     mkaxes(u, v, fa->norm);
276     /* now, find limits in (u,v) coordinates */
277 greg 1.3 ur[0] = vr[0] = FHUGE;
278     ur[1] = vr[1] = -FHUGE;
279     for (i = 0; i < fa->nv; i++) {
280     r1 = DOT(VERTEX(fa,i),u);
281     if (r1 < ur[0]) ur[0] = r1;
282     if (r1 > ur[1]) ur[1] = r1;
283     r2 = DOT(VERTEX(fa,i),v);
284     if (r2 < vr[0]) vr[0] = r2;
285     if (r2 > vr[1]) vr[1] = r2;
286     }
287     dim[0] = random();
288     /* sample polygon */
289 greg 2.25 nallow = 5*n*il->nsamps;
290 greg 2.42 epsilon = R_EPS*sqrt(fa->area);
291 greg 2.21 for (dim[1] = 0; dim[1] < n; dim[1]++)
292 greg 1.3 for (i = 0; i < il->nsamps; i++) {
293 greg 2.23 /* randomize direction */
294 greg 2.21 h = ilhash(dim, 2) + i;
295 greg 2.38 multisamp(sp, 2, urand(h));
296     alti = dim[1]/nazi;
297     r1 = (alti + sp[0])/nalt;
298     r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
299     flatdir(dn, r1, r2);
300     for (j = 0; j < 3; j++)
301 greg 2.21 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
302     dn[2]*fa->norm[j];
303 greg 2.23 /* randomize location */
304 greg 1.3 do {
305 greg 2.25 multisamp(sp, 2, urand(h+4862+nallow));
306 greg 1.10 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
307     r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
308 greg 1.3 for (j = 0; j < 3; j++)
309     org[j] = r1*u[j] + r2*v[j]
310     + fa->offset*fa->norm[j];
311 greg 2.25 } while (!inface(org, fa) && nallow-- > 0);
312     if (nallow < 0) {
313 greg 1.3 objerror(ob, WARNING, "bad aspect");
314 greg 2.18 rayclean();
315 greg 1.3 freeface(ob);
316 greg 2.19 return(my_default(ob, il, nm));
317 greg 1.3 }
318 greg 2.41 VSUM(org, org, dir, -epsilon);
319 greg 1.3 /* send sample */
320 greg 2.21 raysamp(dim[1], org, dir);
321 greg 1.3 }
322 greg 2.25 /* add in direct component? */
323 greg 2.38 if (il->flags & IL_LIGHT) {
324 greg 2.25 MAT4 ixfm;
325 greg 2.38 for (i = 3; i--; ) {
326     ixfm[i][0] = u[i];
327     ixfm[i][1] = v[i];
328     ixfm[i][2] = fa->norm[i];
329     ixfm[i][3] = 0.;
330 greg 2.29 }
331 greg 2.38 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
332     ixfm[3][3] = 1.;
333 greg 2.25 dim[0] = random();
334     nallow = 10*il->nsamps;
335     for (i = 0; i < il->nsamps; i++) {
336     /* randomize location */
337     h = dim[0] + samplendx++;
338     do {
339     multisamp(sp, 2, urand(h+nallow));
340     r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
341     r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
342     for (j = 0; j < 3; j++)
343     org[j] = r1*u[j] + r2*v[j]
344     + fa->offset*fa->norm[j];
345     } while (!inface(org, fa) && nallow-- > 0);
346     if (nallow < 0) {
347     objerror(ob, WARNING, "bad aspect");
348     rayclean();
349     freeface(ob);
350     return(my_default(ob, il, nm));
351     }
352     /* sample source rays */
353 greg 2.41 srcsamps(il, org, epsilon, ixfm);
354 greg 2.25 }
355     }
356     /* wait for all rays to finish */
357 greg 2.18 rayclean();
358 greg 1.11 /* write out the face and its distribution */
359 greg 2.21 if (average(il, distarr, n)) {
360 greg 1.12 if (il->sampdens > 0)
361     flatout(il, distarr, nalt, nazi, u, v, fa->norm);
362     illumout(il, ob);
363 greg 2.2 } else
364 greg 1.12 printobj(il->altmat, ob);
365 greg 1.3 /* clean up */
366     freeface(ob);
367 greg 2.15 return(0);
368 greg 1.2 }
369
370
371 greg 2.13 int
372 greg 2.18 my_sphere( /* make an illum sphere */
373 greg 2.39 OBJREC *ob,
374 schorsch 2.12 struct illum_args *il,
375     char *nm
376     )
377 greg 1.2 {
378 greg 1.10 int dim[3];
379 greg 1.2 int n, nalt, nazi;
380 greg 1.10 double sp[4], r1, r2, r3;
381 greg 1.4 FVECT org, dir;
382 greg 1.2 FVECT u, v;
383 greg 2.39 int i, j;
384 greg 1.2 /* check arguments */
385     if (ob->oargs.nfargs != 4)
386     objerror(ob, USER, "bad # of arguments");
387     /* set up sampling */
388 greg 1.11 if (il->sampdens <= 0)
389     nalt = nazi = 1;
390     else {
391     n = 4.*PI * il->sampdens;
392 greg 2.7 nalt = sqrt(2./PI*n) + .5;
393     nazi = PI/2.*nalt + .5;
394 greg 1.11 }
395 greg 1.2 n = nalt*nazi;
396 greg 2.18 newdist(n);
397 greg 1.2 dim[0] = random();
398     /* sample sphere */
399     for (dim[1] = 0; dim[1] < nalt; dim[1]++)
400 greg 1.8 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
401 greg 1.2 for (i = 0; i < il->nsamps; i++) {
402 greg 1.10 /* next sample point */
403 greg 1.11 multisamp(sp, 4, urand(ilhash(dim,3)+i));
404 greg 1.2 /* random direction */
405 greg 1.10 r1 = (dim[1] + sp[0])/nalt;
406 greg 1.13 r2 = (dim[2] + sp[1] - .5)/nazi;
407 greg 1.2 rounddir(dir, r1, r2);
408     /* random location */
409 greg 1.8 mkaxes(u, v, dir); /* yuck! */
410 greg 1.10 r3 = sqrt(sp[2]);
411     r2 = 2.*PI*sp[3];
412 greg 1.5 r1 = r3*ob->oargs.farg[3]*cos(r2);
413     r2 = r3*ob->oargs.farg[3]*sin(r2);
414     r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
415     for (j = 0; j < 3; j++) {
416     org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
417     r3*dir[j];
418     dir[j] = -dir[j];
419     }
420 greg 1.2 /* send sample */
421 greg 2.18 raysamp(dim[1]*nazi+dim[2], org, dir);
422 greg 1.2 }
423 greg 2.25 /* wait for all rays to finish */
424 greg 2.18 rayclean();
425 greg 1.11 /* write out the sphere and its distribution */
426 greg 2.21 if (average(il, distarr, n)) {
427 greg 1.12 if (il->sampdens > 0)
428     roundout(il, distarr, nalt, nazi);
429     else
430     objerror(ob, WARNING, "diffuse distribution");
431     illumout(il, ob);
432 greg 2.2 } else
433 greg 1.12 printobj(il->altmat, ob);
434 greg 1.2 /* clean up */
435 greg 2.13 return(1);
436 greg 1.2 }
437
438
439 greg 2.13 int
440 greg 2.18 my_ring( /* make an illum ring */
441 schorsch 2.12 OBJREC *ob,
442     struct illum_args *il,
443     char *nm
444     )
445 greg 1.2 {
446 greg 2.21 int dim[2];
447     int n, nalt, nazi, alti;
448     double sp[2], r1, r2, r3;
449 greg 2.42 double epsilon;
450 greg 2.21 int h;
451 greg 1.4 FVECT dn, org, dir;
452 greg 1.3 FVECT u, v;
453 greg 2.21 MAT4 xfm;
454     CONE *co;
455 greg 2.25 int i, j;
456 greg 2.42 /* get/check arguments */
457 greg 1.3 co = getcone(ob, 0);
458 greg 2.42 if (co == NULL)
459     objerror(ob, USER, "cannot create illum");
460     /* set up sampling */
461 greg 2.38 if (il->sampdens <= 0) {
462     nalt = nazi = 1; /* diffuse assumption */
463 greg 2.22 } else {
464 greg 2.38 n = PI * il->sampdens;
465     nalt = sqrt(n/PI) + .5;
466     nazi = PI*nalt + .5;
467 greg 2.22 }
468 greg 2.42 epsilon = R_EPS*CO_R1(co);
469 greg 2.38 n = nazi*nalt;
470 greg 2.18 newdist(n);
471 greg 1.3 mkaxes(u, v, co->ad);
472     dim[0] = random();
473     /* sample disk */
474 greg 2.21 for (dim[1] = 0; dim[1] < n; dim[1]++)
475 greg 1.3 for (i = 0; i < il->nsamps; i++) {
476 greg 1.10 /* next sample point */
477 greg 2.21 h = ilhash(dim,2) + i;
478 greg 2.23 /* randomize direction */
479 greg 2.38 multisamp(sp, 2, urand(h));
480     alti = dim[1]/nazi;
481     r1 = (alti + sp[0])/nalt;
482     r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
483     flatdir(dn, r1, r2);
484     for (j = 0; j < 3; j++)
485     dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
486 greg 2.23 /* randomize location */
487 greg 2.21 multisamp(sp, 2, urand(h+8371));
488 greg 1.5 r3 = sqrt(CO_R0(co)*CO_R0(co) +
489 greg 2.21 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
490     r2 = 2.*PI*sp[1];
491 greg 1.5 r1 = r3*cos(r2);
492     r2 = r3*sin(r2);
493 greg 1.3 for (j = 0; j < 3; j++)
494 greg 2.6 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
495 greg 2.42 epsilon*co->ad[j];
496 greg 1.3 /* send sample */
497 greg 2.21 raysamp(dim[1], org, dir);
498 greg 1.3 }
499 greg 2.25 /* add in direct component? */
500 greg 2.38 if (il->flags & IL_LIGHT) {
501 greg 2.25 MAT4 ixfm;
502 greg 2.38 for (i = 3; i--; ) {
503     ixfm[i][0] = u[i];
504     ixfm[i][1] = v[i];
505     ixfm[i][2] = co->ad[i];
506     ixfm[i][3] = 0.;
507 greg 2.29 }
508 greg 2.38 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
509     ixfm[3][3] = 1.;
510 greg 2.25 dim[0] = random();
511     for (i = 0; i < il->nsamps; i++) {
512     /* randomize location */
513     h = dim[0] + samplendx++;
514     multisamp(sp, 2, urand(h));
515     r3 = sqrt(CO_R0(co)*CO_R0(co) +
516     sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
517     r2 = 2.*PI*sp[1];
518     r1 = r3*cos(r2);
519     r2 = r3*sin(r2);
520     for (j = 0; j < 3; j++)
521     org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
522     /* sample source rays */
523 greg 2.42 srcsamps(il, org, epsilon, ixfm);
524 greg 2.25 }
525     }
526     /* wait for all rays to finish */
527 greg 2.18 rayclean();
528 greg 1.11 /* write out the ring and its distribution */
529 greg 2.21 if (average(il, distarr, n)) {
530 greg 1.12 if (il->sampdens > 0)
531     flatout(il, distarr, nalt, nazi, u, v, co->ad);
532     illumout(il, ob);
533 greg 2.2 } else
534 greg 1.12 printobj(il->altmat, ob);
535 greg 1.3 /* clean up */
536     freecone(ob);
537 greg 2.13 return(1);
538 greg 1.2 }
