root/Development/ray/src/gen/mkillum2.c
Revision: 2.37
Committed: Tue Aug 16 18:09:53 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.36: +4 -7 lines
Minor fixes
2 static const char RCSid[] = "$Id: mkillum2.c,v 2.36 2011/08/15 19:48:06 greg Exp $";
5 * Routines to do the actual calculation for mkillum
6 */
7
8 #include <string.h>
9
10 #include "mkillum.h"
11 #include "face.h"
12 #include "cone.h"
13 #include "source.h"
14 #include "paths.h"
15
16 #ifndef NBSDFSAMPS
17 #define NBSDFSAMPS 256 /* BSDF resampling count */
18 #endif
19
20 COLORV * distarr = NULL; /* distribution array */
21 int distsiz = 0;
22 COLORV * direct_discount = NULL; /* amount to take off direct */
23
24
25 void
26 newdist( /* allocate & clear distribution array */
27 int siz
28 )
29 {
30 if (siz <= 0) {
31 if (distsiz > 0)
32 free(distarr);
33 distarr = NULL;
34 distsiz = 0;
35 return;
36 }
37 if (distsiz < siz) {
38 if (distsiz > 0)
39 free(distarr);
40 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
41 if (distarr == NULL)
42 error(SYSTEM, "out of memory in newdist");
43 distsiz = siz;
44 }
45 memset(distarr, '\0', sizeof(COLOR)*siz);
46 }
47
48
49 static void
50 new_discount() /* allocate space for direct contrib. record */
51 {
52 if (distsiz <= 0)
53 return;
54 direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR));
55 if (direct_discount == NULL)
56 error(SYSTEM, "out of memory in new_discount");
57 }
58
59
60 static void
61 done_discount() /* clear off direct contrib. record */
62 {
63 if (direct_discount == NULL)
64 return;
65 free(direct_discount);
66 direct_discount = NULL;
67 }
68
69
70 int
71 process_ray( /* process a ray result or report error */
72 RAY *r,
73 int rv
74 )
75 {
76 COLORV *colp;
77
78 if (rv == 0) /* no result ready */
79 return(0);
80 if (rv < 0)
81 error(USER, "ray tracing process died");
82 if (r->rno >= distsiz)
83 error(INTERNAL, "bad returned index in process_ray");
84 multcolor(r->rcol, r->rcoef); /* in case it's a source ray */
85 colp = &distarr[r->rno * 3];
86 addcolor(colp, r->rcol);
87 if (r->rsrc >= 0 && /* remember source contrib. */
88 direct_discount != NULL) {
89 colp = &direct_discount[r->rno * 3];
90 addcolor(colp, r->rcol);
91 }
92 return(1);
93 }
94
95
96 void
97 raysamp( /* queue a ray sample */
98 int ndx,
99 FVECT org,
100 FVECT dir
101 )
102 {
103 RAY myRay;
104 int rv;
105
106 if ((ndx < 0) | (ndx >= distsiz))
107 error(INTERNAL, "bad index in raysamp");
108 VCOPY(myRay.rorg, org);
109 VCOPY(myRay.rdir, dir);
110 myRay.rmax = .0;
111 rayorigin(&myRay, PRIMARY|SPECULAR, NULL, NULL);
112 myRay.rno = ndx;
113 /* queue ray, check result */
114 process_ray(&myRay, ray_pqueue(&myRay));
115 }
116
117
118 void
119 srcsamps( /* sample sources from this surface position */
120 struct illum_args *il,
121 FVECT org,
122 FVECT nrm,
123 MAT4 ixfm
124 )
125 {
126 int nalt=1, nazi=1;
127 SRCINDEX si;
128 RAY sr;
129 FVECT v;
130 double d;
131 int i, j;
132 /* get sampling density */
133 if (il->sd == NULL && il->sampdens > 0) {
134 i = PI * il->sampdens;
135 nalt = sqrt(i/PI) + .5;
136 nazi = PI*nalt + .5;
137 }
138 initsrcindex(&si); /* loop over (sub)sources */
139 for ( ; ; ) {
140 VCOPY(sr.rorg, org); /* pick side to shoot from */
141 if (il->sd != NULL) {
142 int sn = si.sn;
143 if (si.sp+1 >= si.np) ++sn;
144 if (sn >= nsources) break;
145 if (source[sn].sflags & SDISTANT)
146 d = DOT(source[sn].sloc, nrm);
147 else {
148 VSUB(v, source[sn].sloc, org);
149 d = DOT(v, nrm);
150 }
151 } else
152 d = 1.0; /* only transmission */
153 if (d < 0.0)
154 d = -1.0001*il->thick - 5.*FTINY;
155 else
156 d = 5.*FTINY;
157 VSUM(sr.rorg, sr.rorg, nrm, d);
158 samplendx++; /* increment sample counter */
159 if (!srcray(&sr, NULL, &si))
160 break; /* end of sources */
161 /* index direction */
162 if (ixfm != NULL)
163 multv3(v, sr.rdir, ixfm);
164 else
165 VCOPY(v, sr.rdir);
166 if (il->sd != NULL) {
167 i = getBSDF_incndx(il->sd, v);
168 if (i < 0)
169 continue; /* must not be important */
170 sr.rno = i;
171 d = 1.0/getBSDF_incohm(il->sd, i);
172 } else {
173 if (v[2] >= -FTINY)
174 continue; /* only sample transmission */
175 v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
176 sr.rno = flatindex(v, nalt, nazi);
177 d = nalt*nazi*(1./PI) * v[2];
178 }
179 d *= si.dom; /* solid angle correction */
180 scalecolor(sr.rcoef, d);
181 process_ray(&sr, ray_pqueue(&sr));
182 }
183 }
184
185
186 void
187 rayclean() /* finish all pending rays */
188 {
189 RAY myRay;
190
191 while (process_ray(&myRay, ray_presult(&myRay, 0)))
192 ;
193 }
194
195
196 static void
197 mkaxes( /* compute u and v to go with n */
198 FVECT u,
199 FVECT v,
200 FVECT n
201 )
202 {
203 register int i;
204
205 v[0] = v[1] = v[2] = 0.0;
206 for (i = 0; i < 3; i++)
207 if (n[i] < 0.6 && n[i] > -0.6)
208 break;
209 v[i] = 1.0;
210 fcross(u, v, n);
211 normalize(u);
212 fcross(v, n, u);
213 }
214
215
216 static void
217 rounddir( /* compute uniform spherical direction */
218 register FVECT dv,
219 double alt,
220 double azi
221 )
222 {
223 double d1, d2;
224
225 dv[2] = 1. - 2.*alt;
226 d1 = sqrt(1. - dv[2]*dv[2]);
227 d2 = 2.*PI * azi;
228 dv[0] = d1*cos(d2);
229 dv[1] = d1*sin(d2);
230 }
231
232
233 void
234 flatdir( /* compute uniform hemispherical direction */
235 FVECT dv,
236 double alt,
237 double azi
238 )
239 {
240 double d1, d2;
241
242 d1 = sqrt(alt);
243 d2 = 2.*PI * azi;
244 dv[0] = d1*cos(d2);
245 dv[1] = d1*sin(d2);
246 dv[2] = sqrt(1. - alt);
247 }
248
249
250 int
251 flatindex( /* compute index for hemispherical direction */
252 FVECT dv,
253 int nalt,
254 int nazi
255 )
256 {
257 double d;
258 int i, j;
259
260 d = 1.0 - dv[2]*dv[2];
261 i = d*nalt;
262 d = atan2(dv[1], dv[0]) * (0.5/PI);
263 if (d < 0.0) d += 1.0;
264 j = d*nazi + 0.5;
265 if (j >= nazi) j = 0;
266 return(i*nazi + j);
267 }
268
269
270 int
271 printgeom( /* print out detailed geometry for BSDF */
272 struct BSDF_data *sd,
273 char *xfrot,
274 FVECT ctr,
275 double s1,
276 double s2
277 )
278 {
279 static char mgftemp[] = TEMPLATE;
280 char cmdbuf[64];
281 FILE *fp;
282 double sca;
283
284 if (sd == NULL || sd->mgf == NULL)
285 return(0);
286 if (sd->dim[0] <= FTINY || sd->dim[1] <= FTINY)
287 return(0);
288 if ((s1 > s2) ^ (sd->dim[0] > sd->dim[1])) {
289 sca = s1; s1 = s2; s2 = sca;
290 }
291 s1 /= sd->dim[0];
292 s2 /= sd->dim[1];
293 sca = s1 > s2 ? s1 : s2;
294 strcpy(mgftemp, TEMPLATE);
295 if ((fp = fopen(mktemp(mgftemp), "w")) == NULL)
296 error(SYSTEM, "cannot create temporary file for MGF");
297 /* prepend our transform */
298 fprintf(fp, "xf%s -s %.5f -t %.5g %.5g %.5g\n",
299 xfrot, sca, ctr[0], ctr[1], ctr[2]);
300 /* output given MGF description */
301 fputs(sd->mgf, fp);
302 fputs("\nxf\n", fp);
303 if (fclose(fp) == EOF)
304 error(SYSTEM, "error writing MGF temporary file");
305 /* execute mgf2rad to convert MGF */
306 strcpy(cmdbuf, "mgf2rad ");
307 strcpy(cmdbuf+8, mgftemp);
308 fflush(stdout);
309 system(cmdbuf);
310 unlink(mgftemp); /* clean up */
311 return(1);
312 }
313
314
315 int
316 my_default( /* default illum action */
317 OBJREC *ob,
318 struct illum_args *il,
319 char *nm
320 )
321 {
322 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
323 nm, ofun[ob->otype].funame, ob->oname);
324 error(WARNING, errmsg);
325 printobj(il->altmat, ob);
326 return(1);
327 }
328
329
330 int
331 my_face( /* make an illum face */
332 OBJREC *ob,
333 struct illum_args *il,
334 char *nm
335 )
336 {
337 int dim[2];
338 int n, nalt, nazi, alti;
339 double sp[2], r1, r2;
340 int h;
341 FVECT dn, org, dir;
342 FVECT u, v;
343 double ur[2], vr[2];
344 MAT4 xfm;
345 char xfrot[64];
346 int nallow;
347 FACE *fa;
348 int i, j;
349 /* get/check arguments */
350 fa = getface(ob);
351 if (fa->area == 0.0) {
352 freeface(ob);
353 return(my_default(ob, il, nm));
354 }
355 /* set up sampling */
356 if (il->sd != NULL) {
357 if (!getBSDF_xfm(xfm, fa->norm, il->udir, xfrot)) {
358 objerror(ob, WARNING, "illegal up direction");
359 freeface(ob);
360 return(my_default(ob, il, nm));
361 }
362 n = il->sd->ninc;
363 } else {
364 if (il->sampdens <= 0) {
365 nalt = nazi = 1; /* diffuse assumption */
366 } else {
367 n = PI * il->sampdens;
368 nalt = sqrt(n/PI) + .5;
369 nazi = PI*nalt + .5;
370 }
371 n = nazi*nalt;
372 }
373 newdist(n);
374 /* take first edge >= sqrt(area) */
375 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
376 u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
377 u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
378 u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
379 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
380 break;
381 }
382 if (i < fa->nv) { /* got one! -- let's align our axes */
383 r2 = 1.0/sqrt(r1);
384 u[0] *= r2; u[1] *= r2; u[2] *= r2;
385 fcross(v, fa->norm, u);
386 } else /* oh well, we'll just have to wing it */
387 mkaxes(u, v, fa->norm);
388 /* now, find limits in (u,v) coordinates */
389 ur[0] = vr[0] = FHUGE;
390 ur[1] = vr[1] = -FHUGE;
391 for (i = 0; i < fa->nv; i++) {
392 r1 = DOT(VERTEX(fa,i),u);
393 if (r1 < ur[0]) ur[0] = r1;
394 if (r1 > ur[1]) ur[1] = r1;
395 r2 = DOT(VERTEX(fa,i),v);
396 if (r2 < vr[0]) vr[0] = r2;
397 if (r2 > vr[1]) vr[1] = r2;
398 }
399 /* output detailed geometry? */
400 if (!(il->flags & IL_LIGHT) && il->sd != NULL && il->sd->mgf != NULL &&
401 il->thick <= FTINY) {
402 for (j = 3; j--; )
403 org[j] = .5*(ur[0]+ur[1])*u[j] +
404 .5*(vr[0]+vr[1])*v[j] +
405 fa->offset*fa->norm[j];
406 printgeom(il->sd, xfrot, org, ur[1]-ur[0], vr[1]-vr[0]);
407 }
408 dim[0] = random();
409 /* sample polygon */
410 nallow = 5*n*il->nsamps;
411 for (dim[1] = 0; dim[1] < n; dim[1]++)
412 for (i = 0; i < il->nsamps; i++) {
413 /* randomize direction */
414 h = ilhash(dim, 2) + i;
415 if (il->sd != NULL) {
416 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
417 } else {
418 multisamp(sp, 2, urand(h));
419 alti = dim[1]/nazi;
420 r1 = (alti + sp[0])/nalt;
421 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
422 flatdir(dn, r1, r2);
423 for (j = 0; j < 3; j++)
424 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
425 dn[2]*fa->norm[j];
426 }
427 /* randomize location */
428 do {
429 multisamp(sp, 2, urand(h+4862+nallow));
430 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
431 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
432 for (j = 0; j < 3; j++)
433 org[j] = r1*u[j] + r2*v[j]
434 + fa->offset*fa->norm[j];
435 } while (!inface(org, fa) && nallow-- > 0);
436 if (nallow < 0) {
437 objerror(ob, WARNING, "bad aspect");
438 rayclean();
439 freeface(ob);
440 return(my_default(ob, il, nm));
441 }
442 if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY)
443 r1 = -1.0001*il->thick - 5.*FTINY;
444 else
445 r1 = 5.*FTINY;
446 for (j = 0; j < 3; j++)
447 org[j] += r1*fa->norm[j];
448 /* send sample */
449 raysamp(dim[1], org, dir);
450 }
451 /* add in direct component? */
452 if (il->flags & IL_LIGHT || il->sd != NULL) {
453 MAT4 ixfm;
454 if (il->sd == NULL) {
455 for (i = 3; i--; ) {
456 ixfm[i][0] = u[i];
457 ixfm[i][1] = v[i];
458 ixfm[i][2] = fa->norm[i];
459 ixfm[i][3] = 0.;
460 }
461 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
462 ixfm[3][3] = 1.;
463 } else {
464 if (!invmat4(ixfm, xfm))
465 objerror(ob, INTERNAL,
466 "cannot invert BSDF transform");
467 if (!(il->flags & IL_LIGHT))
468 new_discount();
469 }
470 dim[0] = random();
471 nallow = 10*il->nsamps;
472 for (i = 0; i < il->nsamps; i++) {
473 /* randomize location */
474 h = dim[0] + samplendx++;
475 do {
476 multisamp(sp, 2, urand(h+nallow));
477 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
478 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
479 for (j = 0; j < 3; j++)
480 org[j] = r1*u[j] + r2*v[j]
481 + fa->offset*fa->norm[j];
482 } while (!inface(org, fa) && nallow-- > 0);
483 if (nallow < 0) {
484 objerror(ob, WARNING, "bad aspect");
485 rayclean();
486 freeface(ob);
487 return(my_default(ob, il, nm));
488 }
489 /* sample source rays */
490 srcsamps(il, org, fa->norm, ixfm);
491 }
492 }
493 /* wait for all rays to finish */
494 rayclean();
495 if (il->sd != NULL) { /* run distribution through BSDF */
496 nalt = sqrt(il->sd->nout/PI) + .5;
497 nazi = PI*nalt + .5;
498 redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm);
499 done_discount();
500 if (!il->sampdens)
501 il->sampdens = nalt*nazi/PI + .999;
502 }
503 /* write out the face and its distribution */
504 if (average(il, distarr, n)) {
505 if (il->sampdens > 0)
506 flatout(il, distarr, nalt, nazi, u, v, fa->norm);
507 illumout(il, ob);
508 } else
509 printobj(il->altmat, ob);
510 /* clean up */
511 freeface(ob);
512 return(0);
513 }
514
515
516 int
517 my_sphere( /* make an illum sphere */
518 register OBJREC *ob,
519 struct illum_args *il,
520 char *nm
521 )
522 {
523 int dim[3];
524 int n, nalt, nazi;
525 double sp[4], r1, r2, r3;
526 FVECT org, dir;
527 FVECT u, v;
528 register int i, j;
529 /* check arguments */
530 if (ob->oargs.nfargs != 4)
531 objerror(ob, USER, "bad # of arguments");
532 /* set up sampling */
533 if (il->sampdens <= 0)
534 nalt = nazi = 1;
535 else {
536 n = 4.*PI * il->sampdens;
537 nalt = sqrt(2./PI*n) + .5;
538 nazi = PI/2.*nalt + .5;
539 }
540 if (il->sd != NULL)
541 objerror(ob, WARNING, "BSDF ignored");
542 n = nalt*nazi;
543 newdist(n);
544 dim[0] = random();
545 /* sample sphere */
546 for (dim[1] = 0; dim[1] < nalt; dim[1]++)
547 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
548 for (i = 0; i < il->nsamps; i++) {
549 /* next sample point */
550 multisamp(sp, 4, urand(ilhash(dim,3)+i));
551 /* random direction */
552 r1 = (dim[1] + sp[0])/nalt;
553 r2 = (dim[2] + sp[1] - .5)/nazi;
554 rounddir(dir, r1, r2);
555 /* random location */
556 mkaxes(u, v, dir); /* yuck! */
557 r3 = sqrt(sp[2]);
558 r2 = 2.*PI*sp[3];
559 r1 = r3*ob->oargs.farg[3]*cos(r2);
560 r2 = r3*ob->oargs.farg[3]*sin(r2);
561 r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
562 for (j = 0; j < 3; j++) {
563 org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
564 r3*dir[j];
565 dir[j] = -dir[j];
566 }
567 /* send sample */
568 raysamp(dim[1]*nazi+dim[2], org, dir);
569 }
570 /* wait for all rays to finish */
571 rayclean();
572 /* write out the sphere and its distribution */
573 if (average(il, distarr, n)) {
574 if (il->sampdens > 0)
575 roundout(il, distarr, nalt, nazi);
576 else
577 objerror(ob, WARNING, "diffuse distribution");
578 illumout(il, ob);
579 } else
580 printobj(il->altmat, ob);
581 /* clean up */
582 return(1);
583 }
584
585
586 int
587 my_ring( /* make an illum ring */
588 OBJREC *ob,
589 struct illum_args *il,
590 char *nm
591 )
592 {
593 int dim[2];
594 int n, nalt, nazi, alti;
595 double sp[2], r1, r2, r3;
596 int h;
597 FVECT dn, org, dir;
598 FVECT u, v;
599 MAT4 xfm;
600 CONE *co;
601 int i, j;
602 /* get/check arguments */
603 co = getcone(ob, 0);
604 /* set up sampling */
605 if (il->sd != NULL) {
606 if (!getBSDF_xfm(xfm, co->ad, il->udir, NULL)) {
607 objerror(ob, WARNING, "illegal up direction");
608 freecone(ob);
609 return(my_default(ob, il, nm));
610 }
611 n = il->sd->ninc;
612 } else {
613 if (il->sampdens <= 0) {
614 nalt = nazi = 1; /* diffuse assumption */
615 } else {
616 n = PI * il->sampdens;
617 nalt = sqrt(n/PI) + .5;
618 nazi = PI*nalt + .5;
619 }
620 n = nazi*nalt;
621 }
622 newdist(n);
623 mkaxes(u, v, co->ad);
624 dim[0] = random();
625 /* sample disk */
626 for (dim[1] = 0; dim[1] < n; dim[1]++)
627 for (i = 0; i < il->nsamps; i++) {
628 /* next sample point */
629 h = ilhash(dim,2) + i;
630 /* randomize direction */
631 if (il->sd != NULL) {
632 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
633 } else {
634 multisamp(sp, 2, urand(h));
635 alti = dim[1]/nazi;
636 r1 = (alti + sp[0])/nalt;
637 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
638 flatdir(dn, r1, r2);
639 for (j = 0; j < 3; j++)
640 dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
641 }
642 /* randomize location */
643 multisamp(sp, 2, urand(h+8371));
644 r3 = sqrt(CO_R0(co)*CO_R0(co) +
645 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
646 r2 = 2.*PI*sp[1];
647 r1 = r3*cos(r2);
648 r2 = r3*sin(r2);
649 if (il->sd != NULL && DOT(dir, co->ad) < -FTINY)
650 r3 = -1.0001*il->thick - 5.*FTINY;
651 else
652 r3 = 5.*FTINY;
653 for (j = 0; j < 3; j++)
654 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
655 r3*co->ad[j];
656 /* send sample */
657 raysamp(dim[1], org, dir);
658 }
659 /* add in direct component? */
660 if (il->flags & IL_LIGHT || il->sd != NULL) {
661 MAT4 ixfm;
662 if (il->sd == NULL) {
663 for (i = 3; i--; ) {
664 ixfm[i][0] = u[i];
665 ixfm[i][1] = v[i];
666 ixfm[i][2] = co->ad[i];
667 ixfm[i][3] = 0.;
668 }
669 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
670 ixfm[3][3] = 1.;
671 } else {
672 if (!invmat4(ixfm, xfm))
673 objerror(ob, INTERNAL,
674 "cannot invert BSDF transform");
675 if (!(il->flags & IL_LIGHT))
676 new_discount();
677 }
678 dim[0] = random();
679 for (i = 0; i < il->nsamps; i++) {
680 /* randomize location */
681 h = dim[0] + samplendx++;
682 multisamp(sp, 2, urand(h));
683 r3 = sqrt(CO_R0(co)*CO_R0(co) +
684 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
685 r2 = 2.*PI*sp[1];
686 r1 = r3*cos(r2);
687 r2 = r3*sin(r2);
688 for (j = 0; j < 3; j++)
689 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
690 /* sample source rays */
691 srcsamps(il, org, co->ad, ixfm);
692 }
693 }
694 /* wait for all rays to finish */
695 rayclean();
696 if (il->sd != NULL) { /* run distribution through BSDF */
697 nalt = sqrt(il->sd->nout/PI) + .5;
698 nazi = PI*nalt + .5;
699 redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm);
700 done_discount();
701 if (!il->sampdens)
702 il->sampdens = nalt*nazi/PI + .999;
703 }
704 /* write out the ring and its distribution */
705 if (average(il, distarr, n)) {
706 if (il->sampdens > 0)
707 flatout(il, distarr, nalt, nazi, u, v, co->ad);
708 illumout(il, ob);
709 } else
710 printobj(il->altmat, ob);
711 /* clean up */
712 freecone(ob);
713 return(1);
714 }
715
716
717 void
718 redistribute( /* pass distarr ray sums through BSDF */
719 struct BSDF_data *b,
720 int nalt,
721 int nazi,
722 FVECT u,
723 FVECT v,
724 FVECT w,
725 MAT4 xm
726 )
727 {
728 int nout = 0;
729 MAT4 mymat, inmat;
730 COLORV *idist;
731 COLORV *cp;
732 FVECT dv;
733 double wt;
734 int i, j, k, c, o;
735 COLOR col, cinc;
736 /* copy incoming distribution */
737 if (b->ninc > distsiz)
738 error(INTERNAL, "error 1 in redistribute");
739 idist = (COLORV *)malloc(sizeof(COLOR)*b->ninc);
740 if (idist == NULL)
741 error(SYSTEM, "out of memory in redistribute");
742 memcpy(idist, distarr, sizeof(COLOR)*b->ninc);
743 /* compose direction transform */
744 for (i = 3; i--; ) {
745 mymat[i][0] = u[i];
746 mymat[i][1] = v[i];
747 mymat[i][2] = w[i];
748 mymat[i][3] = 0.;
749 }
750 mymat[3][0] = mymat[3][1] = mymat[3][2] = 0.;
751 mymat[3][3] = 1.;
752 if (xm != NULL)
753 multmat4(mymat, xm, mymat);
754 for (i = 3; i--; ) { /* make sure it's normalized */
755 wt = 1./sqrt( mymat[0][i]*mymat[0][i] +
756 mymat[1][i]*mymat[1][i] +
757 mymat[2][i]*mymat[2][i] );
758 for (j = 3; j--; )
759 mymat[j][i] *= wt;
760 }
761 if (!invmat4(inmat, mymat)) /* need inverse as well */
762 error(INTERNAL, "cannot invert BSDF transform");
763 newdist(nalt*nazi); /* resample distribution */
764 for (i = b->ninc; i--; ) {
765 int direct_out = -1;
766 COLOR cdir;
767 getBSDF_incvec(dv, b, i); /* compute incident irrad. */
768 multv3(dv, dv, mymat);
769 if (dv[2] < 0.0) {
770 dv[0] = -dv[0]; dv[1] = -dv[1]; dv[2] = -dv[2];
771 direct_out += (direct_discount != NULL);
772 }
773 wt = getBSDF_incohm(b, i);
774 wt *= dv[2]; /* solid_angle*cosine(theta) */
775 cp = &idist[3*i];
776 copycolor(cinc, cp);
777 scalecolor(cinc, wt);
778 if (!direct_out) { /* discount direct contr. */
779 cp = &direct_discount[3*i];
780 copycolor(cdir, cp);
781 scalecolor(cdir, -wt);
782 if (b->nout != b->ninc)
783 direct_out = flatindex(dv, nalt, nazi);
784 else
785 direct_out = i; /* assumes dist. mirroring */
786 }
787 for (k = nalt; k--; ) /* loop over distribution */
788 for (j = nazi; j--; ) {
789 int rstart = random();
790 for (c = NBSDFSAMPS; c--; ) {
791 double sp[2];
792 multisamp(sp, 2, urand(rstart+c));
793 flatdir(dv, (k + sp[0])/nalt,
794 (j + .5 - sp[1])/nazi);
795 multv3(dv, dv, inmat);
796 /* evaluate BSDF @ outgoing */
797 o = getBSDF_outndx(b, dv);
798 if (o < 0) {
799 nout++;
800 continue;
801 }
802 wt = BSDF_value(b, i, o) * (1./NBSDFSAMPS);
803 copycolor(col, cinc);
804 if (b->nout != b->ninc)
805 o = k*nazi + j;
806 if (o == direct_out)
807 addcolor(col, cdir); /* minus direct */
808 scalecolor(col, wt);
809 cp = &distarr[3*(k*nazi + j)];
810 addcolor(cp, col); /* sum into distribution */
811 }
812 }
813 }
814 free(idist); /* free temp space */
815 if (nout) {
816 sprintf(errmsg, "missing %.1f%% of BSDF directions",
817 100.*nout/(b->ninc*nalt*nazi*NBSDFSAMPS));
818 error(WARNING, errmsg);
819 }
820 }
