root/Development/ray/src/gen/mkillum2.c
Revision: 2.25
Committed: Thu Dec 6 19:40:43 2007 UTC (17 years, 10 months ago) by greg
Changes since 2.24: +167 -18 lines
Added light source sampling when l+ and -dv- are set
2 static const char RCSid[] = "$Id: mkillum2.c,v 2.24 2007/12/05 20:07:34 greg Exp $";
5 * Routines to do the actual calculation for mkillum
6 */
7
8 #include <string.h>
9
10 #include "mkillum.h"
11 #include "face.h"
12 #include "cone.h"
13 #include "source.h"
14
15
16 COLORV * distarr = NULL; /* distribution array */
17 int distsiz = 0;
18
19
20 void
21 newdist( /* allocate & clear distribution array */
22 int siz
23 )
24 {
25 if (siz <= 0) {
26 if (distsiz > 0)
27 free((void *)distarr);
28 distarr = NULL;
29 distsiz = 0;
30 return;
31 }
32 if (distsiz < siz) {
33 if (distsiz > 0)
34 free((void *)distarr);
35 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
36 if (distarr == NULL)
37 error(SYSTEM, "out of memory in newdist");
38 distsiz = siz;
39 }
40 memset(distarr, '\0', sizeof(COLOR)*siz);
41 }
42
43
44 int
45 process_ray( /* process a ray result or report error */
46 RAY *r,
47 int rv
48 )
49 {
50 COLORV *colp;
51
52 if (rv == 0) /* no result ready */
53 return(0);
54 if (rv < 0)
55 error(USER, "ray tracing process died");
56 if (r->rno >= distsiz)
57 error(INTERNAL, "bad returned index in process_ray");
58 multcolor(r->rcol, r->rcoef); /* in case it's a source ray */
59 colp = &distarr[r->rno * 3];
60 addcolor(colp, r->rcol);
61 return(1);
62 }
63
64
65 void
66 raysamp( /* queue a ray sample */
67 int ndx,
68 FVECT org,
69 FVECT dir
70 )
71 {
72 RAY myRay;
73 int rv;
74
75 if ((ndx < 0) | (ndx >= distsiz))
76 error(INTERNAL, "bad index in raysamp");
77 VCOPY(myRay.rorg, org);
78 VCOPY(myRay.rdir, dir);
79 myRay.rmax = .0;
80 rayorigin(&myRay, PRIMARY, NULL, NULL);
81 myRay.rno = ndx;
82 /* queue ray, check result */
83 process_ray(&myRay, ray_pqueue(&myRay));
84 }
85
86
87 void
88 srcsamps( /* sample sources from this surface position */
89 struct illum_args *il,
90 FVECT org,
91 FVECT nrm,
92 MAT4 ixfm
93 )
94 {
95 int nalt, nazi;
96 SRCINDEX si;
97 RAY sr;
98 FVECT v;
99 double d;
100 int i, j;
101 /* get sampling density */
102 if (il->sampdens <= 0) {
103 nalt = nazi = 1;
104 } else {
105 i = PI * il->sampdens;
106 nalt = sqrt(i/PI) + .5;
107 nazi = PI*nalt + .5;
108 }
109 initsrcindex(&si); /* loop over (sub)sources */
110 for ( ; ; ) {
111 VCOPY(sr.rorg, org); /* pick side to shoot from */
112 if (il->sd != NULL) {
113 int sn = si.sn;
114 if (si.sp+1 >= si.np) ++sn;
115 if (sn >= nsources) break;
116 if (source[sn].sflags & SDISTANT)
117 d = DOT(source[sn].sloc, nrm);
118 else {
119 VSUB(v, source[sn].sloc, org);
120 d = DOT(v, nrm);
121 }
122 } else
123 d = 1.0; /* only transmission */
124 if (d < 0.0)
125 d = -1.0001*il->thick - 5.*FTINY;
126 else
127 d = 5.*FTINY;
128 for (i = 3; i--; )
129 sr.rorg[i] += d*nrm[i];
130 if (!srcray(&sr, NULL, &si))
131 break; /* end of sources */
132 /* index direction */
133 if (ixfm != NULL)
134 multv3(v, sr.rdir, ixfm);
135 else
136 VCOPY(v, sr.rdir);
137 if (il->sd != NULL) {
138 i = getBSDF_incndx(il->sd, v);
139 if (i < 0)
140 continue; /* must not be important */
141 sr.rno = i;
142 d = getBSDF_incrad(il->sd, i);
143 d = 1.0/(PI*d*d);
144 } else {
145 if (v[2] >= -FTINY)
146 continue; /* only sample transmission */
147 d = 1.0 - v[2]*v[2];
148 i = d*nalt;
149 d = atan2(-v[1], -v[0])/(2.*PI);
150 if (d < 0.0) d += 1.0;
151 j = d*nazi + 0.5;
152 if (j >= nazi) j = 0;
153 sr.rno = i*nazi + j;
154 d = nalt*nazi/PI;
155 }
156 d *= si.dom; /* solid angle correction */
157 scalecolor(sr.rcoef, d);
158 process_ray(&sr, ray_pqueue(&sr));
159 }
160 }
161
162
163 void
164 rayclean() /* finish all pending rays */
165 {
166 RAY myRay;
167
168 while (process_ray(&myRay, ray_presult(&myRay, 0)))
169 ;
170 }
171
172
173 static void
174 mkaxes( /* compute u and v to go with n */
175 FVECT u,
176 FVECT v,
177 FVECT n
178 )
179 {
180 register int i;
181
182 v[0] = v[1] = v[2] = 0.0;
183 for (i = 0; i < 3; i++)
184 if (n[i] < 0.6 && n[i] > -0.6)
185 break;
186 v[i] = 1.0;
187 fcross(u, v, n);
188 normalize(u);
189 fcross(v, n, u);
190 }
191
192
193 static void
194 rounddir( /* compute uniform spherical direction */
195 register FVECT dv,
196 double alt,
197 double azi
198 )
199 {
200 double d1, d2;
201
202 dv[2] = 1. - 2.*alt;
203 d1 = sqrt(1. - dv[2]*dv[2]);
204 d2 = 2.*PI * azi;
205 dv[0] = d1*cos(d2);
206 dv[1] = d1*sin(d2);
207 }
208
209
210 void
211 flatdir( /* compute uniform hemispherical direction */
212 FVECT dv,
213 double alt,
214 double azi
215 )
216 {
217 double d1, d2;
218
219 d1 = sqrt(alt);
220 d2 = 2.*PI * azi;
221 dv[0] = d1*cos(d2);
222 dv[1] = d1*sin(d2);
223 dv[2] = sqrt(1. - alt);
224 }
225
226
227 int
228 my_default( /* default illum action */
229 OBJREC *ob,
230 struct illum_args *il,
231 char *nm
232 )
233 {
234 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
235 nm, ofun[ob->otype].funame, ob->oname);
236 error(WARNING, errmsg);
237 printobj(il->altmat, ob);
238 return(1);
239 }
240
241
242 int
243 my_face( /* make an illum face */
244 OBJREC *ob,
245 struct illum_args *il,
246 char *nm
247 )
248 {
249 int dim[2];
250 int n, nalt, nazi, alti;
251 double sp[2], r1, r2;
252 int h;
253 FVECT dn, org, dir;
254 FVECT u, v;
255 double ur[2], vr[2];
256 MAT4 xfm;
257 int nallow;
258 FACE *fa;
259 int i, j;
260 /* get/check arguments */
261 fa = getface(ob);
262 if (fa->area == 0.0) {
263 freeface(ob);
264 return(my_default(ob, il, nm));
265 }
266 /* set up sampling */
267 if (il->sd != NULL) {
268 if (!getBSDF_xfm(xfm, fa->norm, il->udir)) {
269 objerror(ob, WARNING, "illegal up direction");
270 freeface(ob);
271 return(my_default(ob, il, nm));
272 }
273 n = il->sd->ninc;
274 } else {
275 if (il->sampdens <= 0) {
276 nalt = nazi = 1; /* diffuse assumption */
277 } else {
278 n = PI * il->sampdens;
279 nalt = sqrt(n/PI) + .5;
280 nazi = PI*nalt + .5;
281 }
282 n = nazi*nalt;
283 }
284 newdist(n);
285 /* take first edge >= sqrt(area) */
286 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
287 u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
288 u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
289 u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
290 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
291 break;
292 }
293 if (i < fa->nv) { /* got one! -- let's align our axes */
294 r2 = 1.0/sqrt(r1);
295 u[0] *= r2; u[1] *= r2; u[2] *= r2;
296 fcross(v, fa->norm, u);
297 } else /* oh well, we'll just have to wing it */
298 mkaxes(u, v, fa->norm);
299 /* now, find limits in (u,v) coordinates */
300 ur[0] = vr[0] = FHUGE;
301 ur[1] = vr[1] = -FHUGE;
302 for (i = 0; i < fa->nv; i++) {
303 r1 = DOT(VERTEX(fa,i),u);
304 if (r1 < ur[0]) ur[0] = r1;
305 if (r1 > ur[1]) ur[1] = r1;
306 r2 = DOT(VERTEX(fa,i),v);
307 if (r2 < vr[0]) vr[0] = r2;
308 if (r2 > vr[1]) vr[1] = r2;
309 }
310 dim[0] = random();
311 /* sample polygon */
312 nallow = 5*n*il->nsamps;
313 for (dim[1] = 0; dim[1] < n; dim[1]++)
314 for (i = 0; i < il->nsamps; i++) {
315 /* randomize direction */
316 h = ilhash(dim, 2) + i;
317 if (il->sd != NULL) {
318 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
319 } else {
320 multisamp(sp, 2, urand(h));
321 alti = dim[1]/nazi;
322 r1 = (alti + sp[0])/nalt;
323 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
324 flatdir(dn, r1, r2);
325 for (j = 0; j < 3; j++)
326 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
327 dn[2]*fa->norm[j];
328 }
329 /* randomize location */
330 do {
331 multisamp(sp, 2, urand(h+4862+nallow));
332 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
333 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
334 for (j = 0; j < 3; j++)
335 org[j] = r1*u[j] + r2*v[j]
336 + fa->offset*fa->norm[j];
337 } while (!inface(org, fa) && nallow-- > 0);
338 if (nallow < 0) {
339 objerror(ob, WARNING, "bad aspect");
340 rayclean();
341 freeface(ob);
342 return(my_default(ob, il, nm));
343 }
344 if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY)
345 r1 = -1.0001*il->thick - 5.*FTINY;
346 else
347 r1 = 5.*FTINY;
348 for (j = 0; j < 3; j++)
349 org[j] += r1*fa->norm[j];
350 /* send sample */
351 raysamp(dim[1], org, dir);
352 }
353 /* add in direct component? */
354 if (!directvis && il->flags & IL_LIGHT) {
355 MAT4 ixfm;
356 if (il->sd == NULL) {
357 for (i = 3; i--; ) {
358 ixfm[i][0] = u[i];
359 ixfm[i][1] = v[i];
360 ixfm[i][2] = fa->norm[i];
361 ixfm[i][3] = 0.;
362 }
363 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
364 ixfm[3][3] = 1.;
365 } else if (!invmat4(ixfm, xfm))
366 objerror(ob, INTERNAL, "cannot invert BSDF transform");
367 dim[0] = random();
368 nallow = 10*il->nsamps;
369 for (i = 0; i < il->nsamps; i++) {
370 /* randomize location */
371 h = dim[0] + samplendx++;
372 do {
373 multisamp(sp, 2, urand(h+nallow));
374 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
375 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
376 for (j = 0; j < 3; j++)
377 org[j] = r1*u[j] + r2*v[j]
378 + fa->offset*fa->norm[j];
379 } while (!inface(org, fa) && nallow-- > 0);
380 if (nallow < 0) {
381 objerror(ob, WARNING, "bad aspect");
382 rayclean();
383 freeface(ob);
384 return(my_default(ob, il, nm));
385 }
386 /* sample source rays */
387 srcsamps(il, org, fa->norm, ixfm);
388 }
389 }
390 /* wait for all rays to finish */
391 rayclean();
392 if (il->sd != NULL) { /* run distribution through BSDF */
393 nalt = sqrt(il->sd->nout/PI) + .5;
394 nazi = PI*nalt + .5;
395 redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm);
396 }
397 /* write out the face and its distribution */
398 if (average(il, distarr, n)) {
399 if (il->sampdens > 0)
400 flatout(il, distarr, nalt, nazi, u, v, fa->norm);
401 illumout(il, ob);
402 } else
403 printobj(il->altmat, ob);
404 /* clean up */
405 freeface(ob);
406 return(0);
407 }
408
409
410 int
411 my_sphere( /* make an illum sphere */
412 register OBJREC *ob,
413 struct illum_args *il,
414 char *nm
415 )
416 {
417 int dim[3];
418 int n, nalt, nazi;
419 double sp[4], r1, r2, r3;
420 FVECT org, dir;
421 FVECT u, v;
422 register int i, j;
423 /* check arguments */
424 if (ob->oargs.nfargs != 4)
425 objerror(ob, USER, "bad # of arguments");
426 /* set up sampling */
427 if (il->sampdens <= 0)
428 nalt = nazi = 1;
429 else {
430 n = 4.*PI * il->sampdens;
431 nalt = sqrt(2./PI*n) + .5;
432 nazi = PI/2.*nalt + .5;
433 }
434 if (il->sd != NULL)
435 objerror(ob, WARNING, "BSDF ignored");
436 n = nalt*nazi;
437 newdist(n);
438 dim[0] = random();
439 /* sample sphere */
440 for (dim[1] = 0; dim[1] < nalt; dim[1]++)
441 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
442 for (i = 0; i < il->nsamps; i++) {
443 /* next sample point */
444 multisamp(sp, 4, urand(ilhash(dim,3)+i));
445 /* random direction */
446 r1 = (dim[1] + sp[0])/nalt;
447 r2 = (dim[2] + sp[1] - .5)/nazi;
448 rounddir(dir, r1, r2);
449 /* random location */
450 mkaxes(u, v, dir); /* yuck! */
451 r3 = sqrt(sp[2]);
452 r2 = 2.*PI*sp[3];
453 r1 = r3*ob->oargs.farg[3]*cos(r2);
454 r2 = r3*ob->oargs.farg[3]*sin(r2);
455 r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
456 for (j = 0; j < 3; j++) {
457 org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
458 r3*dir[j];
459 dir[j] = -dir[j];
460 }
461 /* send sample */
462 raysamp(dim[1]*nazi+dim[2], org, dir);
463 }
464 /* wait for all rays to finish */
465 rayclean();
466 /* write out the sphere and its distribution */
467 if (average(il, distarr, n)) {
468 if (il->sampdens > 0)
469 roundout(il, distarr, nalt, nazi);
470 else
471 objerror(ob, WARNING, "diffuse distribution");
472 illumout(il, ob);
473 } else
474 printobj(il->altmat, ob);
475 /* clean up */
476 return(1);
477 }
478
479
480 int
481 my_ring( /* make an illum ring */
482 OBJREC *ob,
483 struct illum_args *il,
484 char *nm
485 )
486 {
487 int dim[2];
488 int n, nalt, nazi, alti;
489 double sp[2], r1, r2, r3;
490 int h;
491 FVECT dn, org, dir;
492 FVECT u, v;
493 MAT4 xfm;
494 CONE *co;
495 int i, j;
496 /* get/check arguments */
497 co = getcone(ob, 0);
498 /* set up sampling */
499 if (il->sd != NULL) {
500 if (!getBSDF_xfm(xfm, co->ad, il->udir)) {
501 objerror(ob, WARNING, "illegal up direction");
502 freecone(ob);
503 return(my_default(ob, il, nm));
504 }
505 n = il->sd->ninc;
506 } else {
507 if (il->sampdens <= 0) {
508 nalt = nazi = 1; /* diffuse assumption */
509 } else {
510 n = PI * il->sampdens;
511 nalt = sqrt(n/PI) + .5;
512 nazi = PI*nalt + .5;
513 }
514 n = nazi*nalt;
515 }
516 newdist(n);
517 mkaxes(u, v, co->ad);
518 dim[0] = random();
519 /* sample disk */
520 for (dim[1] = 0; dim[1] < n; dim[1]++)
521 for (i = 0; i < il->nsamps; i++) {
522 /* next sample point */
523 h = ilhash(dim,2) + i;
524 /* randomize direction */
525 if (il->sd != NULL) {
526 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
527 } else {
528 multisamp(sp, 2, urand(h));
529 alti = dim[1]/nazi;
530 r1 = (alti + sp[0])/nalt;
531 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
532 flatdir(dn, r1, r2);
533 for (j = 0; j < 3; j++)
534 dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
535 }
536 /* randomize location */
537 multisamp(sp, 2, urand(h+8371));
538 r3 = sqrt(CO_R0(co)*CO_R0(co) +
539 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
540 r2 = 2.*PI*sp[1];
541 r1 = r3*cos(r2);
542 r2 = r3*sin(r2);
543 if (il->sd != NULL && DOT(dir, co->ad) < -FTINY)
544 r3 = -1.0001*il->thick - 5.*FTINY;
545 else
546 r3 = 5.*FTINY;
547 for (j = 0; j < 3; j++)
548 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
549 r3*co->ad[j];
550 /* send sample */
551 raysamp(dim[1], org, dir);
552 }
553 /* add in direct component? */
554 if (!directvis && il->flags & IL_LIGHT) {
555 MAT4 ixfm;
556 if (il->sd == NULL) {
557 for (i = 3; i--; ) {
558 ixfm[i][0] = u[i];
559 ixfm[i][1] = v[i];
560 ixfm[i][2] = co->ad[i];
561 ixfm[i][3] = 0.;
562 }
563 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
564 ixfm[3][3] = 1.;
565 } else if (!invmat4(ixfm, xfm))
566 objerror(ob, INTERNAL, "cannot invert BSDF transform");
567 dim[0] = random();
568 for (i = 0; i < il->nsamps; i++) {
569 /* randomize location */
570 h = dim[0] + samplendx++;
571 multisamp(sp, 2, urand(h));
572 r3 = sqrt(CO_R0(co)*CO_R0(co) +
573 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
574 r2 = 2.*PI*sp[1];
575 r1 = r3*cos(r2);
576 r2 = r3*sin(r2);
577 for (j = 0; j < 3; j++)
578 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
579 /* sample source rays */
580 srcsamps(il, org, co->ad, ixfm);
581 }
582 }
583 /* wait for all rays to finish */
584 rayclean();
585 if (il->sd != NULL) { /* run distribution through BSDF */
586 nalt = sqrt(il->sd->nout/PI) + .5;
587 nazi = PI*nalt + .5;
588 redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm);
589 }
590 /* write out the ring and its distribution */
591 if (average(il, distarr, n)) {
592 if (il->sampdens > 0)
593 flatout(il, distarr, nalt, nazi, u, v, co->ad);
594 illumout(il, ob);
595 } else
596 printobj(il->altmat, ob);
597 /* clean up */
598 freecone(ob);
599 return(1);
600 }
