1 |
/* RCSid: $Id: mkillum.h,v 2.12 2007/11/05 23:40:26 greg Exp $ */ |
2 |
3 |
* Common definitions for mkillum |
4 |
5 |
#ifndef _RAD_MKILLUM_H_ |
6 |
#define _RAD_MKILLUM_H_ |
7 |
8 |
#include "ray.h" |
9 |
#include "otypes.h" |
10 |
11 |
#ifdef __cplusplus |
12 |
extern "C" { |
13 |
#endif |
14 |
/* illum flags */ |
15 |
#define IL_LIGHT 0x1 /* light rather than illum */ |
16 |
#define IL_COLDST 0x2 /* use color distribution */ |
17 |
#define IL_COLAVG 0x4 /* use average color */ |
18 |
#define IL_DATCLB 0x8 /* OK to clobber data file */ |
19 |
20 |
/* up directions */ |
21 |
typedef enum { |
22 |
UDzneg=-3, |
23 |
UDyneg=-2, |
24 |
UDxneg=-1, |
25 |
UDunknown=0, |
26 |
UDxpos=1, |
27 |
UDypos=2, |
28 |
UDzpos=3 |
29 |
} UpDir; |
30 |
/* BSDF coordinate calculation routines */ |
31 |
/* vectors always point away from surface */ |
32 |
typedef int b_vecf(FVECT, int, char *); |
33 |
typedef int b_ndxf(FVECT, char *); |
34 |
typedef double b_radf(int, char *); |
35 |
36 |
/* Bidirectional Scattering Distribution Function */ |
37 |
struct BSDF_data { |
38 |
int ninc; /* number of incoming directions */ |
39 |
int nout; /* number of outgoing directions */ |
40 |
char ib_priv[32]; /* input basis private data */ |
41 |
b_vecf *ib_vec; /* get input vector from index */ |
42 |
b_ndxf *ib_ndx; /* get input index from vector */ |
43 |
b_radf *ib_rad; /* get input radius for index */ |
44 |
char ob_priv[32]; /* output basis private data */ |
45 |
b_vecf *ob_vec; /* get output vector from index */ |
46 |
b_ndxf *ob_ndx; /* get output index from vector */ |
47 |
b_radf *ob_rad; /* get output radius for index */ |
48 |
float *bsdf; /* scattering distribution data */ |
49 |
}; /* bidirectional scattering distrib. func. */ |
50 |
51 |
struct illum_args { |
52 |
int flags; /* flags from list above */ |
53 |
UpDir udir; /* up direction */ |
54 |
double thick; /* object thickness */ |
55 |
char matname[MAXSTR]; /* illum material name */ |
56 |
char datafile[MAXSTR]; /* distribution data file name */ |
57 |
int dfnum; /* data file number */ |
58 |
char altmat[MAXSTR]; /* alternate material name */ |
59 |
int sampdens; /* point sample density */ |
60 |
int nsamps; /* # of samples in each direction */ |
61 |
struct BSDF_data |
62 |
*sd; /* scattering data (if set) */ |
63 |
float minbrt; /* minimum average brightness */ |
64 |
COLOR col; /* computed average color */ |
65 |
}; /* illum options */ |
66 |
67 |
#define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv) |
68 |
#define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv) |
69 |
#define getBSDF_incrad(b,i) (*(b)->ib_rad)(i,(b)->ib_priv) |
70 |
#define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv) |
71 |
#define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv) |
72 |
#define getBSDF_outrad(b,o) (*(b)->ob_rad)(o,(b)->ob_priv) |
73 |
#define BSDF_visible(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)] |
74 |
75 |
extern struct BSDF_data *load_BSDF(char *fname); |
76 |
extern void free_BSDF(struct BSDF_data *b); |
77 |
extern void r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i, |
78 |
double rv, MAT4 xm); |
79 |
extern void r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o, |
80 |
81 |
extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud); |
82 |
extern void redistribute(struct BSDF_data *b, int nalt, int nazi, |
83 |
FVECT u, FVECT v, FVECT w, MAT4 xm); |
84 |
85 |
extern void printobj(char *mod, OBJREC *obj); |
86 |
extern int average(struct illum_args *il, COLORV *da, int n); |
87 |
extern void flatout(struct illum_args *il, COLORV *da, int n, int m, |
88 |
FVECT u, FVECT v, FVECT w); |
89 |
extern void illumout(struct illum_args *il, OBJREC *ob); |
90 |
extern void roundout(struct illum_args *il, COLORV *da, int n, int m); |
91 |
92 |
extern void newdist(int siz); |
93 |
extern int process_ray(RAY *r, int rv); |
94 |
extern void raysamp(int ndx, FVECT org, FVECT dir); |
95 |
extern void rayclean(void); |
96 |
97 |
extern void flatdir(FVECT dv, double alt, double azi); |
98 |
99 |
extern int my_default(OBJREC *, struct illum_args *, char *); |
100 |
extern int my_face(OBJREC *, struct illum_args *, char *); |
101 |
extern int my_sphere(OBJREC *, struct illum_args *, char *); |
102 |
extern int my_ring(OBJREC *, struct illum_args *, char *); |
103 |
104 |
extern COLORV * distarr; /* distribution array */ |
105 |
extern int distsiz; |
106 |
107 |
extern char *progname; |
108 |
109 |
110 |
111 |
#endif |
112 |
113 |
#endif /* _RAD_MKILLUM_H_ */ |
114 |
