1 |
/* RCSid: $Id: mkillum.h,v 2.9 2007/09/13 17:52:35 greg Exp $ */ |
2 |
3 |
* Common definitions for mkillum |
4 |
5 |
#ifndef _RAD_MKILLUM_H_ |
6 |
#define _RAD_MKILLUM_H_ |
7 |
8 |
#include "ray.h" |
9 |
#include "otypes.h" |
10 |
11 |
#ifdef __cplusplus |
12 |
extern "C" { |
13 |
#endif |
14 |
/* illum flags */ |
15 |
#define IL_LIGHT 0x1 /* light rather than illum */ |
16 |
#define IL_COLDST 0x2 /* use color distribution */ |
17 |
#define IL_COLAVG 0x4 /* use average color */ |
18 |
#define IL_DATCLB 0x8 /* OK to clobber data file */ |
19 |
20 |
/* up directions */ |
21 |
typedef enum { |
22 |
UDzneg=-3, |
23 |
UDyneg=-2, |
24 |
UDxneg=-1, |
25 |
UDunknown=0, |
26 |
UDxpos=1, |
27 |
UDypos=2, |
28 |
UDzpos=3 |
29 |
} UpDir; |
30 |
31 |
struct BSDF_data { |
32 |
double om_scale; /* maximum solid angle (sr/256) */ |
33 |
int ninc; /* number of incoming directions */ |
34 |
int32 *inc_dir; /* incoming direction codes */ |
35 |
BYTE *inc_rad; /* incoming radians to neighbor */ |
36 |
int nout; /* number of outgoing directions */ |
37 |
int32 *out_dir; /* outgoing direction codes */ |
38 |
BYTE *out_rad; /* outgoing radians to neighbor */ |
39 |
float *bsdf; /* scattering distribution data */ |
40 |
}; /* bidirectional scattering distrib. func. */ |
41 |
42 |
struct illum_args { |
43 |
int flags; /* flags from list above */ |
44 |
UpDir udir; /* up direction */ |
45 |
char matname[MAXSTR]; /* illum material name */ |
46 |
char datafile[MAXSTR]; /* distribution data file name */ |
47 |
int dfnum; /* data file number */ |
48 |
char altmat[MAXSTR]; /* alternate material name */ |
49 |
int sampdens; /* point sample density */ |
50 |
int nsamps; /* # of samples in each direction */ |
51 |
struct BSDF_data |
52 |
*sd; /* scattering data (if set) */ |
53 |
float minbrt; /* minimum average brightness */ |
54 |
COLOR col; /* computed average color */ |
55 |
}; /* illum options */ |
56 |
57 |
#define getBSDF_incvec(v,b,i) decodedir(v, (b)->inc_dir[i]) |
58 |
#define getBSDF_outvec(v,b,o) decodedir(v, (b)->out_dir[o]) |
59 |
#define getBSDF_incrad(b,i) ((b)->om_scale*((b)->inc_rad[i] + .5)); |
60 |
#define getBSDF_outrad(b,o) ((b)->om_scale*((b)->out_rad[o] + .5)); |
61 |
#define BSDF_data(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)] |
62 |
63 |
extern struct BSDF_data *load_BSDF(char *fname); |
64 |
extern void free_BSDF(struct BSDF_data *b); |
65 |
extern void r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i, |
66 |
double rv, MAT4 xm); |
67 |
extern void r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o, |
68 |
69 |
70 |
extern void printobj(char *mod, OBJREC *obj); |
71 |
extern int average(struct illum_args *il, COLORV *da, int n); |
72 |
extern void flatout(struct illum_args *il, COLORV *da, int n, int m, |
73 |
FVECT u, FVECT v, FVECT w); |
74 |
extern void illumout(struct illum_args *il, OBJREC *ob); |
75 |
extern void roundout(struct illum_args *il, COLORV *da, int n, int m); |
76 |
77 |
extern int my_default(OBJREC *, struct illum_args *, char *); |
78 |
extern int my_face(OBJREC *, struct illum_args *, char *); |
79 |
extern int my_sphere(OBJREC *, struct illum_args *, char *); |
80 |
extern int my_ring(OBJREC *, struct illum_args *, char *); |
81 |
82 |
extern char *progname; |
83 |
84 |
85 |
86 |
#endif |
87 |
88 |
#endif /* _RAD_MKILLUM_H_ */ |
89 |
