--- ray/src/gen/mkillum.h 2007/09/13 06:31:21 2.8 +++ ray/src/gen/mkillum.h 2007/09/13 17:52:35 2.9 @@ -1,4 +1,4 @@ -/* RCSid: $Id: mkillum.h,v 2.8 2007/09/13 06:31:21 greg Exp $ */ +/* RCSid: $Id: mkillum.h,v 2.9 2007/09/13 17:52:35 greg Exp $ */ /* * Common definitions for mkillum */ @@ -26,15 +26,15 @@ struct illum_args { int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ float minbrt; /* minimum average brightness */ - float col[3]; /* computed average color */ + COLOR col; /* computed average color */ }; /* illum options */ -extern void printobj(char *mod, register OBJREC *obj); -extern int average(register struct illum_args *il, float *da, int n); -extern void flatout(struct illum_args *il, float *da, int n, int m, - FVECT u, FVECT v, FVECT w); -extern void illumout(register struct illum_args *il, OBJREC *ob); -extern void roundout(struct illum_args *il, float *da, int n, int m); +extern void printobj(char *mod, register OBJREC *obj); +extern int average(register struct illum_args *il, COLORV *da, int n); +extern void flatout(struct illum_args *il, COLORV *da, int n, int m, + FVECT u, FVECT v, FVECT w); +extern void illumout(register struct illum_args *il, OBJREC *ob); +extern void roundout(struct illum_args *il, COLORV *da, int n, int m); extern int my_default(OBJREC *, struct illum_args *, char *); extern int my_face(OBJREC *, struct illum_args *, char *);
