--- ray/src/gen/mkillum.h 1991/07/24 16:48:25 1.3 +++ ray/src/gen/mkillum.h 2004/09/17 21:43:50 2.7 @@ -1,17 +1,17 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: mkillum.h,v 2.7 2004/09/17 21:43:50 greg Exp $ */ /* * Common definitions for mkillum */ +#ifndef _RAD_MKILLUM_H_ +#define _RAD_MKILLUM_H_ #include "standard.h" - #include "object.h" +#include "rtprocess.h" -#include "otypes.h" - +#ifdef __cplusplus +extern "C" { +#endif /* illum flags */ #define IL_LIGHT 0x1 /* light rather than illum */ #define IL_COLDST 0x2 /* use color distribution */ @@ -26,13 +26,48 @@ struct illum_args { char altmat[MAXSTR]; /* alternate material name */ int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ - float col[3]; /* average color */ + float minbrt; /* minimum average brightness */ + float col[3]; /* computed average color */ }; /* illum options */ struct rtproc { - int pd[3]; /* rtrace pipe descriptors */ + struct rtproc *next; /* next in list of processes */ + SUBPROC pd; /* rtrace pipe descriptors */ float *buf; /* rtrace i/o buffer */ int bsiz; /* maximum rays for rtrace buffer */ float **dest; /* destination for each ray result */ int nrays; /* current length of rtrace buffer */ }; /* rtrace process */ + +extern void printobj(char *mod, register OBJREC *obj); +extern int average(register struct illum_args *il, float *da, int n); +extern void flatout(struct illum_args *il, float *da, int n, int m, + FVECT u, FVECT v, FVECT w); +extern void illumout(register struct illum_args *il, OBJREC *ob); +extern void roundout(struct illum_args *il, float *da, int n, int m); + +/* The header file otypes.h has to follow definition of our struct's */ +#define FUN_ARGLIST OBJREC *, struct illum_args *, struct rtproc *, char * +#ifdef __cplusplus +} +#include "otypes.h" +extern "C" { +#else +#include "otypes.h" +#endif + +extern int o_default(FUN_ARGLIST); +extern int o_face(FUN_ARGLIST); +extern int o_sphere(FUN_ARGLIST); +extern int o_ring(FUN_ARGLIST); +extern void raysamp(float res[3], FVECT org, FVECT dir, struct rtproc *rt0); +extern void rayflush(struct rtproc *rt, int doall); +extern struct rtproc *raywait(struct rtproc *rt0); + + +#ifdef __cplusplus +} +#endif + +#endif /* _RAD_MKILLUM_H_ */ +
