--- ray/src/gen/mkillum.h 1991/07/23 16:13:27 1.2 +++ ray/src/gen/mkillum.h 2003/07/14 22:23:59 2.4 @@ -1,23 +1,24 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: mkillum.h,v 2.4 2003/07/14 22:23:59 schorsch Exp $ */ /* * Common definitions for mkillum */ +#ifndef _RAD_MKILLUM_H_ +#define _RAD_MKILLUM_H_ #include "standard.h" - #include "object.h" - #include "otypes.h" +#include "rtprocess.h" +#ifdef __cplusplus +extern "C" { +#endif + /* illum flags */ -#define IL_FLAT 0x1 /* flat surface */ -#define IL_LIGHT 0x2 /* light rather than illum */ -#define IL_COLDST 0x4 /* colored distribution */ -#define IL_COLAVG 0x8 /* compute average color */ -#define IL_DATCLB 0x10 /* OK to clobber data file */ +#define IL_LIGHT 0x1 /* light rather than illum */ +#define IL_COLDST 0x2 /* use color distribution */ +#define IL_COLAVG 0x4 /* use average color */ +#define IL_DATCLB 0x8 /* OK to clobber data file */ struct illum_args { int flags; /* flags from list above */ @@ -25,14 +26,23 @@ struct illum_args { char datafile[MAXSTR]; /* distribution data file name */ int dfnum; /* data file number */ char altmat[MAXSTR]; /* alternate material name */ + int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ - int nalt, nazi; /* # of altitude and azimuth angles */ - FVECT orient; /* coordinate system orientation */ + float minbrt; /* minimum average brightness */ + float col[3]; /* computed average color */ }; /* illum options */ struct rtproc { - int pd[3]; /* rtrace pipe descriptors */ + SUBPROC pd; /* rtrace pipe descriptors */ float *buf; /* rtrace i/o buffer */ int bsiz; /* maximum rays for rtrace buffer */ + float **dest; /* destination for each ray result */ int nrays; /* current length of rtrace buffer */ }; /* rtrace process */ + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_MKILLUM_H_ */ +
