--- ray/src/gen/mkillum.h 1991/07/23 13:35:33 1.1 +++ ray/src/gen/mkillum.h 1991/11/12 17:05:06 2.1 @@ -5,27 +5,35 @@ /* * Common definitions for mkillum */ + +#include "standard.h" + +#include "object.h" + +#include "otypes.h" + /* illum flags */ -#define IL_FLAT 0x1 /* flat surface */ -#define IL_LIGHT 0x2 /* light rather than illum */ -#define IL_COLDST 0x4 /* colored distribution */ -#define IL_COLAVG 0x8 /* compute average color */ -#define IL_DATCLB 0x10 /* OK to clobber data file */ +#define IL_LIGHT 0x1 /* light rather than illum */ +#define IL_COLDST 0x2 /* use color distribution */ +#define IL_COLAVG 0x4 /* use average color */ +#define IL_DATCLB 0x8 /* OK to clobber data file */ struct illum_args { int flags; /* flags from list above */ char matname[MAXSTR]; /* illum material name */ char datafile[MAXSTR]; /* distribution data file name */ int dfnum; /* data file number */ - char altmatname[MAXSTR]; /* alternate material name */ + char altmat[MAXSTR]; /* alternate material name */ + int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ - int nalt, nazi; /* # of altitude and azimuth angles */ - FVECT orient; /* coordinate system orientation */ + float minbrt; /* minimum average brightness */ + float col[3]; /* computed average color */ }; /* illum options */ struct rtproc { int pd[3]; /* rtrace pipe descriptors */ float *buf; /* rtrace i/o buffer */ int bsiz; /* maximum rays for rtrace buffer */ + float **dest; /* destination for each ray result */ int nrays; /* current length of rtrace buffer */ }; /* rtrace process */
