root/radiance/ray/src/gen/mkillum.h
Revision: 2.19
Committed: Sat Oct 13 20:15:43 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.18: +1 -12 lines
1 /* RCSid: $Id: mkillum.h,v 2.18 2010/09/03 23:53:50 greg Exp $ */
2 /*
3 * Common definitions for mkillum
4 */
5 #ifndef _RAD_MKILLUM_H_
6 #define _RAD_MKILLUM_H_
7
8 #include "ray.h"
9 #include "otypes.h"
10 #include "random.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15 /* illum flags */
16 #define IL_LIGHT 0x1 /* light rather than illum */
17 #define IL_COLDST 0x2 /* use color distribution */
18 #define IL_COLAVG 0x4 /* use average color */
19 #define IL_DATCLB 0x8 /* OK to clobber data file */
20
21 struct illum_args {
22 int flags; /* flags from list above */
23 double thick; /* object thickness */
24 char matname[MAXSTR]; /* illum material name */
25 char datafile[MAXSTR]; /* distribution data file name */
26 int dfnum; /* data file number */
27 char altmat[MAXSTR]; /* alternate material name */
28 int sampdens; /* point sample density */
29 int nsamps; /* # of samples in each direction */
30 float minbrt; /* minimum average brightness */
31 COLOR col; /* computed average color */
32 }; /* illum options */
33
34 extern void printobj(char *mod, OBJREC *obj);
35 extern int average(struct illum_args *il, COLORV *da, int n);
36 extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
37 FVECT u, FVECT v, FVECT w);
38 extern void illumout(struct illum_args *il, OBJREC *ob);
39 extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
40
41 extern void newdist(int siz);
42 extern int process_ray(RAY *r, int rv);
43 extern void raysamp(int ndx, FVECT org, FVECT dir);
44 extern void rayclean(void);
45
46 extern void flatdir(FVECT dv, double alt, double azi);
47 extern int flatindex(FVECT dv, int nalt, int nazi);
48
49 extern int my_default(OBJREC *, struct illum_args *, char *);
50 extern int my_face(OBJREC *, struct illum_args *, char *);
51 extern int my_sphere(OBJREC *, struct illum_args *, char *);
52 extern int my_ring(OBJREC *, struct illum_args *, char *);
53
54 extern COLORV * distarr; /* distribution array */
55 extern int distsiz;
56
57 extern char *progname;
58
59 #ifdef __cplusplus
60 }
61 #endif
62
63 #endif /* _RAD_MKILLUM_H_ */
64
