| 1 |
/* RCSid: $Id: mkillum.h,v 2.17 2009/06/12 17:37:37 greg Exp $ */
| 2 |
| 3 |
* Common definitions for mkillum
| 4 |
| 5 |
#ifndef _RAD_MKILLUM_H_
| 6 |
#define _RAD_MKILLUM_H_
| 7 |
| 8 |
#include "ray.h"
| 9 |
#include "otypes.h"
| 10 |
#include "bsdf.h"
| 11 |
#include "random.h"
| 12 |
| 13 |
#ifdef __cplusplus
| 14 |
extern "C" {
| 15 |
#endif
| 16 |
/* illum flags */
| 17 |
#define IL_LIGHT 0x1 /* light rather than illum */
| 18 |
#define IL_COLDST 0x2 /* use color distribution */
| 19 |
#define IL_COLAVG 0x4 /* use average color */
| 20 |
#define IL_DATCLB 0x8 /* OK to clobber data file */
| 21 |
| 22 |
struct illum_args {
| 23 |
int flags; /* flags from list above */
| 24 |
UpDir udir; /* up direction */
| 25 |
double thick; /* object thickness */
| 26 |
char matname[MAXSTR]; /* illum material name */
| 27 |
char datafile[MAXSTR]; /* distribution data file name */
| 28 |
int dfnum; /* data file number */
| 29 |
char altmat[MAXSTR]; /* alternate material name */
| 30 |
int sampdens; /* point sample density */
| 31 |
int nsamps; /* # of samples in each direction */
| 32 |
struct BSDF_data
| 33 |
*sd; /* scattering data (if set) */
| 34 |
float minbrt; /* minimum average brightness */
| 35 |
COLOR col; /* computed average color */
| 36 |
}; /* illum options */
| 37 |
| 38 |
extern void redistribute(struct BSDF_data *b, int nalt, int nazi,
| 39 |
FVECT u, FVECT v, FVECT w, MAT4 xm);
| 40 |
| 41 |
extern void printobj(char *mod, OBJREC *obj);
| 42 |
extern int average(struct illum_args *il, COLORV *da, int n);
| 43 |
extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
| 44 |
FVECT u, FVECT v, FVECT w);
| 45 |
extern void illumout(struct illum_args *il, OBJREC *ob);
| 46 |
extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
| 47 |
| 48 |
extern void newdist(int siz);
| 49 |
extern int process_ray(RAY *r, int rv);
| 50 |
extern void raysamp(int ndx, FVECT org, FVECT dir);
| 51 |
extern void rayclean(void);
| 52 |
| 53 |
extern void flatdir(FVECT dv, double alt, double azi);
| 54 |
extern int flatindex(FVECT dv, int nalt, int nazi);
| 55 |
| 56 |
extern int printgeom(struct BSDF_data *sd, char *xfrot,
| 57 |
FVECT ctr, double s1, double s2);
| 58 |
| 59 |
extern int my_default(OBJREC *, struct illum_args *, char *);
| 60 |
extern int my_face(OBJREC *, struct illum_args *, char *);
| 61 |
extern int my_sphere(OBJREC *, struct illum_args *, char *);
| 62 |
extern int my_ring(OBJREC *, struct illum_args *, char *);
| 63 |
| 64 |
extern COLORV * distarr; /* distribution array */
| 65 |
extern int distsiz;
| 66 |
extern COLORV * direct_discount; /* amount to take off direct */
| 67 |
| 68 |
extern char *progname;
| 69 |
| 70 |
#ifdef __cplusplus
| 71 |
| 72 |
#endif
| 73 |
| 74 |
#endif /* _RAD_MKILLUM_H_ */
| 75 |
