Broke BSDF-handling routines into their own module
Initial implementation of BSDF complete (untested)
Improved BSDF resampling
Made use of COLORV in place of float more consistent
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
visual debugging pass
first version of mkillum
*** empty log message ***
