--- ray/src/gen/mkillum.h 1991/11/12 17:05:06 2.1 +++ ray/src/gen/mkillum.h 2007/09/18 19:51:07 2.10 @@ -1,39 +1,89 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: mkillum.h,v 2.10 2007/09/18 19:51:07 greg Exp $ */ /* * Common definitions for mkillum */ +#ifndef _RAD_MKILLUM_H_ +#define _RAD_MKILLUM_H_ -#include "standard.h" - -#include "object.h" - +#include "ray.h" #include "otypes.h" +#ifdef __cplusplus +extern "C" { +#endif /* illum flags */ #define IL_LIGHT 0x1 /* light rather than illum */ #define IL_COLDST 0x2 /* use color distribution */ #define IL_COLAVG 0x4 /* use average color */ #define IL_DATCLB 0x8 /* OK to clobber data file */ + /* up directions */ +typedef enum { + UDzneg=-3, + UDyneg=-2, + UDxneg=-1, + UDunknown=0, + UDxpos=1, + UDypos=2, + UDzpos=3 +} UpDir; + +struct BSDF_data { + double om_scale; /* maximum solid angle (sr/256) */ + int ninc; /* number of incoming directions */ + int32 *inc_dir; /* incoming direction codes */ + BYTE *inc_rad; /* incoming radians to neighbor */ + int nout; /* number of outgoing directions */ + int32 *out_dir; /* outgoing direction codes */ + BYTE *out_rad; /* outgoing radians to neighbor */ + float *bsdf; /* scattering distribution data */ +}; /* bidirectional scattering distrib. func. */ + struct illum_args { int flags; /* flags from list above */ + UpDir udir; /* up direction */ char matname[MAXSTR]; /* illum material name */ char datafile[MAXSTR]; /* distribution data file name */ int dfnum; /* data file number */ char altmat[MAXSTR]; /* alternate material name */ int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ + struct BSDF_data + *sd; /* scattering data (if set) */ float minbrt; /* minimum average brightness */ - float col[3]; /* computed average color */ + COLOR col; /* computed average color */ }; /* illum options */ -struct rtproc { - int pd[3]; /* rtrace pipe descriptors */ - float *buf; /* rtrace i/o buffer */ - int bsiz; /* maximum rays for rtrace buffer */ - float **dest; /* destination for each ray result */ - int nrays; /* current length of rtrace buffer */ -}; /* rtrace process */ +#define getBSDF_incvec(v,b,i) decodedir(v, (b)->inc_dir[i]) +#define getBSDF_outvec(v,b,o) decodedir(v, (b)->out_dir[o]) +#define getBSDF_incrad(b,i) ((b)->om_scale*((b)->inc_rad[i] + .5)); +#define getBSDF_outrad(b,o) ((b)->om_scale*((b)->out_rad[o] + .5)); +#define BSDF_data(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)] + +extern struct BSDF_data *load_BSDF(char *fname); +extern void free_BSDF(struct BSDF_data *b); +extern void r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i, + double rv, MAT4 xm); +extern void r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o, + double rv, MAT4 xm); + +extern void printobj(char *mod, OBJREC *obj); +extern int average(struct illum_args *il, COLORV *da, int n); +extern void flatout(struct illum_args *il, COLORV *da, int n, int m, + FVECT u, FVECT v, FVECT w); +extern void illumout(struct illum_args *il, OBJREC *ob); +extern void roundout(struct illum_args *il, COLORV *da, int n, int m); + +extern int my_default(OBJREC *, struct illum_args *, char *); +extern int my_face(OBJREC *, struct illum_args *, char *); +extern int my_sphere(OBJREC *, struct illum_args *, char *); +extern int my_ring(OBJREC *, struct illum_args *, char *); + +extern char *progname; + +#ifdef __cplusplus +} +#endif + +#endif /* _RAD_MKILLUM_H_ */ +
