| 1 |
/* RCSid: $Id: mkillum.h,v 2.14 2007/12/08 01:43:09 greg Exp $ */
| 2 |
| 3 |
* Common definitions for mkillum
| 4 |
| 5 |
#ifndef _RAD_MKILLUM_H_
| 6 |
#define _RAD_MKILLUM_H_
| 7 |
| 8 |
#include "ray.h"
| 9 |
#include "otypes.h"
| 10 |
#include "random.h"
| 11 |
| 12 |
#ifdef __cplusplus
| 13 |
extern "C" {
| 14 |
#endif
| 15 |
/* illum flags */
| 16 |
#define IL_LIGHT 0x1 /* light rather than illum */
| 17 |
#define IL_COLDST 0x2 /* use color distribution */
| 18 |
#define IL_COLAVG 0x4 /* use average color */
| 19 |
#define IL_DATCLB 0x8 /* OK to clobber data file */
| 20 |
| 21 |
/* up directions */
| 22 |
typedef enum {
| 23 |
UDzneg=-3,
| 24 |
UDyneg=-2,
| 25 |
UDxneg=-1,
| 26 |
UDunknown=0,
| 27 |
UDxpos=1,
| 28 |
UDypos=2,
| 29 |
UDzpos=3
| 30 |
} UpDir;
| 31 |
/* BSDF coordinate calculation routines */
| 32 |
/* vectors always point away from surface */
| 33 |
typedef int b_vecf(FVECT, int, void *);
| 34 |
typedef int b_ndxf(FVECT, void *);
| 35 |
typedef double b_radf(int, void *);
| 36 |
| 37 |
/* Bidirectional Scattering Distribution Function */
| 38 |
struct BSDF_data {
| 39 |
int ninc; /* number of incoming directions */
| 40 |
int nout; /* number of outgoing directions */
| 41 |
void *ib_priv; /* input basis private data */
| 42 |
b_vecf *ib_vec; /* get input vector from index */
| 43 |
b_ndxf *ib_ndx; /* get input index from vector */
| 44 |
b_radf *ib_ohm; /* get input radius for index */
| 45 |
void *ob_priv; /* output basis private data */
| 46 |
b_vecf *ob_vec; /* get output vector from index */
| 47 |
b_ndxf *ob_ndx; /* get output index from vector */
| 48 |
b_radf *ob_ohm; /* get output radius for index */
| 49 |
float *bsdf; /* scattering distribution data */
| 50 |
}; /* bidirectional scattering distrib. func. */
| 51 |
| 52 |
struct illum_args {
| 53 |
int flags; /* flags from list above */
| 54 |
UpDir udir; /* up direction */
| 55 |
double thick; /* object thickness */
| 56 |
char matname[MAXSTR]; /* illum material name */
| 57 |
char datafile[MAXSTR]; /* distribution data file name */
| 58 |
int dfnum; /* data file number */
| 59 |
char altmat[MAXSTR]; /* alternate material name */
| 60 |
int sampdens; /* point sample density */
| 61 |
int nsamps; /* # of samples in each direction */
| 62 |
struct BSDF_data
| 63 |
*sd; /* scattering data (if set) */
| 64 |
float minbrt; /* minimum average brightness */
| 65 |
COLOR col; /* computed average color */
| 66 |
}; /* illum options */
| 67 |
| 68 |
#define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
| 69 |
#define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
| 70 |
#define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
| 71 |
#define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
| 72 |
#define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
| 73 |
#define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
| 74 |
#define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
| 75 |
| 76 |
extern struct BSDF_data *load_BSDF(char *fname);
| 77 |
extern void free_BSDF(struct BSDF_data *b);
| 78 |
extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
| 79 |
double rv, MAT4 xm);
| 80 |
extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
| 81 |
| 82 |
extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud);
| 83 |
extern void redistribute(struct BSDF_data *b, int nalt, int nazi,
| 84 |
FVECT u, FVECT v, FVECT w, MAT4 xm);
| 85 |
| 86 |
extern void printobj(char *mod, OBJREC *obj);
| 87 |
extern int average(struct illum_args *il, COLORV *da, int n);
| 88 |
extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
| 89 |
FVECT u, FVECT v, FVECT w);
| 90 |
extern void illumout(struct illum_args *il, OBJREC *ob);
| 91 |
extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
| 92 |
| 93 |
extern void newdist(int siz);
| 94 |
extern int process_ray(RAY *r, int rv);
| 95 |
extern void raysamp(int ndx, FVECT org, FVECT dir);
| 96 |
extern void rayclean(void);
| 97 |
| 98 |
extern void flatdir(FVECT dv, double alt, double azi);
| 99 |
| 100 |
extern int my_default(OBJREC *, struct illum_args *, char *);
| 101 |
extern int my_face(OBJREC *, struct illum_args *, char *);
| 102 |
extern int my_sphere(OBJREC *, struct illum_args *, char *);
| 103 |
extern int my_ring(OBJREC *, struct illum_args *, char *);
| 104 |
| 105 |
extern COLORV * distarr; /* distribution array */
| 106 |
extern int distsiz;
| 107 |
| 108 |
extern char *progname;
| 109 |
| 110 |
#ifdef __cplusplus
| 111 |
| 112 |
#endif
| 113 |
| 114 |
#endif /* _RAD_MKILLUM_H_ */
| 115 |
