root/radiance/ray/src/gen/mkillum.h
Wed Dec 12 05:09:58 2007 UTC (16 years, 6 months ago) by greg
Diff to previous 2.14 , to selected 1.1
Initial implementation of BSDF complete (untested)
Sat Dec 8 01:43:09 2007 UTC (16 years, 6 months ago) by greg
Changes since 2.13: +13 -12 lines
Diff to previous 2.13 , to selected 1.1
Wed Dec 5 20:07:34 2007 UTC (16 years, 6 months ago) by greg
Changes since 2.12: +24 -12 lines
Diff to previous 2.12 , to selected 1.1
Improved BSDF resampling
Mon Nov 5 23:40:26 2007 UTC (16 years, 7 months ago) by greg
Diff to previous 2.11 , to selected 1.1
Fri Sep 21 05:53:21 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.10: +13 -1 lines
Diff to previous 2.10 , to selected 1.1
Tue Sep 18 19:51:07 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.9: +42 -4 lines
Diff to previous 2.9 , to selected 1.1
Thu Sep 13 17:52:35 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.8: +8 -8 lines
Diff to previous 2.8 , to selected 1.1
Made use of COLORV in place of float more consistent
Thu Sep 13 06:31:21 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.7: +8 -30 lines
Diff to previous 2.7 , to selected 1.1
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Fri Sep 17 21:43:50 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.6: +20 -3 lines
Diff to previous 2.6 , to selected 1.1
Fri Nov 21 07:15:30 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.5: +5 -3 lines
Diff to previous 2.5 , to selected 1.1
Sun Nov 16 10:29:38 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.4: +7 -1 lines
Diff to previous 2.4 , to selected 1.1
Mon Jul 14 22:23:59 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.3: +5 -5 lines
Diff to previous 2.3 , to selected 1.1
Changes since 2.2: +16 -4 lines
Diff to previous 2.2 , to selected 1.1
Changes since 2.1: +1 -4 lines
Diff to previous 2.1 , to selected 1.1
Tue Nov 12 17:05:06 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 1.1
Fri Aug 23 12:30:31 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 1.1
Thu Jul 25 10:59:03 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.3 , to selected 1.1
visual debugging pass
Wed Jul 24 16:48:25 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.2: +7 -7 lines
Diff to previous 1.2 , to selected 1.1
first version of mkillum
Tue Jul 23 16:13:27 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.1: +8 -1 lines
Diff to previous 1.1
*** empty log message ***
Revision 1.1 - (view) (download) (annotate) - [selected]
Tue Jul 23 13:35:33 1991 UTC (32 years, 11 months ago) by greg
