root/radiance/ray/src/gen/mkillum.h
Fri Sep 17 21:43:50 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.6: +20 -3 lines
Fri Nov 21 07:15:30 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.5: +5 -3 lines
Sun Nov 16 10:29:38 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.4: +7 -1 lines
Mon Jul 14 22:23:59 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 2.3: +5 -5 lines
Thu Jun 26 00:58:09 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 2.2: +16 -4 lines
Changes since 2.1: +1 -4 lines
Tue Nov 12 17:05:06 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.5 , to selected 2.6
Fri Aug 23 12:30:31 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 2.6
Thu Jul 25 10:59:03 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.3 , to selected 2.6
visual debugging pass
Wed Jul 24 16:48:25 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.2: +7 -7 lines
Diff to previous 1.2 , to selected 2.6
first version of mkillum
Tue Jul 23 16:13:27 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.1: +8 -1 lines
Diff to previous 1.1 , to selected 2.6
*** empty log message ***
Tue Jul 23 13:35:33 1991 UTC (32 years, 9 months ago) by greg
Diff to selected 2.6
