root/radiance/ray/src/gen/mkillum.h
Revision: 2.7
Committed: Fri Sep 17 21:43:50 2004 UTC (20 years, 8 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 2.6: +20 -3 lines
1 /* RCSid: $Id: mkillum.h,v 2.6 2003/11/21 07:15:30 greg Exp $ */
2 /*
3 * Common definitions for mkillum
4 */
5 #ifndef _RAD_MKILLUM_H_
6 #define _RAD_MKILLUM_H_
7
8 #include "standard.h"
9 #include "object.h"
10 #include "rtprocess.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15 /* illum flags */
16 #define IL_LIGHT 0x1 /* light rather than illum */
17 #define IL_COLDST 0x2 /* use color distribution */
18 #define IL_COLAVG 0x4 /* use average color */
19 #define IL_DATCLB 0x8 /* OK to clobber data file */
20
21 struct illum_args {
22 int flags; /* flags from list above */
23 char matname[MAXSTR]; /* illum material name */
24 char datafile[MAXSTR]; /* distribution data file name */
25 int dfnum; /* data file number */
26 char altmat[MAXSTR]; /* alternate material name */
27 int sampdens; /* point sample density */
28 int nsamps; /* # of samples in each direction */
29 float minbrt; /* minimum average brightness */
30 float col[3]; /* computed average color */
31 }; /* illum options */
32
33 struct rtproc {
34 struct rtproc *next; /* next in list of processes */
35 SUBPROC pd; /* rtrace pipe descriptors */
36 float *buf; /* rtrace i/o buffer */
37 int bsiz; /* maximum rays for rtrace buffer */
38 float **dest; /* destination for each ray result */
39 int nrays; /* current length of rtrace buffer */
40 }; /* rtrace process */
41
42 extern void printobj(char *mod, register OBJREC *obj);
43 extern int average(register struct illum_args *il, float *da, int n);
44 extern void flatout(struct illum_args *il, float *da, int n, int m,
45 FVECT u, FVECT v, FVECT w);
46 extern void illumout(register struct illum_args *il, OBJREC *ob);
47 extern void roundout(struct illum_args *il, float *da, int n, int m);
48
49 /* The header file otypes.h has to follow definition of our struct's */
50 #define FUN_ARGLIST OBJREC *, struct illum_args *, struct rtproc *, char *
51 #ifdef __cplusplus
52 }
53 #include "otypes.h"
54 extern "C" {
55 #else
56 #include "otypes.h"
57 #endif
58
59 extern int o_default(FUN_ARGLIST);
60 extern int o_face(FUN_ARGLIST);
61 extern int o_sphere(FUN_ARGLIST);
62 extern int o_ring(FUN_ARGLIST);
63 extern void raysamp(float res[3], FVECT org, FVECT dir, struct rtproc *rt0);
64 extern void rayflush(struct rtproc *rt, int doall);
65 extern struct rtproc *raywait(struct rtproc *rt0);
66
67
68 #ifdef __cplusplus
69 }
70 #endif
71
72 #endif /* _RAD_MKILLUM_H_ */
73
