--- ray/src/gen/mkillum.h 1991/07/25 10:59:03 1.4 +++ ray/src/gen/mkillum.h 2007/09/13 06:31:21 2.8 @@ -1,17 +1,16 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: mkillum.h,v 2.8 2007/09/13 06:31:21 greg Exp $ */ /* * Common definitions for mkillum */ +#ifndef _RAD_MKILLUM_H_ +#define _RAD_MKILLUM_H_ -#include "standard.h" - -#include "object.h" - +#include "ray.h" #include "otypes.h" +#ifdef __cplusplus +extern "C" { +#endif /* illum flags */ #define IL_LIGHT 0x1 /* light rather than illum */ #define IL_COLDST 0x2 /* use color distribution */ @@ -26,13 +25,27 @@ struct illum_args { char altmat[MAXSTR]; /* alternate material name */ int sampdens; /* point sample density */ int nsamps; /* # of samples in each direction */ + float minbrt; /* minimum average brightness */ float col[3]; /* computed average color */ }; /* illum options */ -struct rtproc { - int pd[3]; /* rtrace pipe descriptors */ - float *buf; /* rtrace i/o buffer */ - int bsiz; /* maximum rays for rtrace buffer */ - float **dest; /* destination for each ray result */ - int nrays; /* current length of rtrace buffer */ -}; /* rtrace process */ +extern void printobj(char *mod, register OBJREC *obj); +extern int average(register struct illum_args *il, float *da, int n); +extern void flatout(struct illum_args *il, float *da, int n, int m, + FVECT u, FVECT v, FVECT w); +extern void illumout(register struct illum_args *il, OBJREC *ob); +extern void roundout(struct illum_args *il, float *da, int n, int m); + +extern int my_default(OBJREC *, struct illum_args *, char *); +extern int my_face(OBJREC *, struct illum_args *, char *); +extern int my_sphere(OBJREC *, struct illum_args *, char *); +extern int my_ring(OBJREC *, struct illum_args *, char *); + +extern char *progname; + +#ifdef __cplusplus +} +#endif + +#endif /* _RAD_MKILLUM_H_ */ +
