root/Development/ray/src/gen/mkillum.h
Revision: 2.17
Committed: Fri Jun 12 17:37:37 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.16: +2 -47 lines
Broke BSDF-handling routines into their own module
1 /* RCSid: $Id: mkillum.h,v 2.16 2009/03/04 00:12:25 greg Exp $ */
2 /*
3 * Common definitions for mkillum
4 */
5 #ifndef _RAD_MKILLUM_H_
6 #define _RAD_MKILLUM_H_
7
8 #include "ray.h"
9 #include "otypes.h"
10 #include "bsdf.h"
11 #include "random.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16 /* illum flags */
17 #define IL_LIGHT 0x1 /* light rather than illum */
18 #define IL_COLDST 0x2 /* use color distribution */
19 #define IL_COLAVG 0x4 /* use average color */
20 #define IL_DATCLB 0x8 /* OK to clobber data file */
21
22 struct illum_args {
23 int flags; /* flags from list above */
24 UpDir udir; /* up direction */
25 double thick; /* object thickness */
26 char matname[MAXSTR]; /* illum material name */
27 char datafile[MAXSTR]; /* distribution data file name */
28 int dfnum; /* data file number */
29 char altmat[MAXSTR]; /* alternate material name */
30 int sampdens; /* point sample density */
31 int nsamps; /* # of samples in each direction */
32 struct BSDF_data
33 *sd; /* scattering data (if set) */
34 float minbrt; /* minimum average brightness */
35 COLOR col; /* computed average color */
36 }; /* illum options */
37
38 extern void redistribute(struct BSDF_data *b, int nalt, int nazi,
39 FVECT u, FVECT v, FVECT w, MAT4 xm);
40
41 extern void printobj(char *mod, OBJREC *obj);
42 extern int average(struct illum_args *il, COLORV *da, int n);
43 extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
44 FVECT u, FVECT v, FVECT w);
45 extern void illumout(struct illum_args *il, OBJREC *ob);
46 extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
47
48 extern void newdist(int siz);
49 extern int process_ray(RAY *r, int rv);
50 extern void raysamp(int ndx, FVECT org, FVECT dir);
51 extern void rayclean(void);
52
53 extern void flatdir(FVECT dv, double alt, double azi);
54 extern int flatindex(FVECT dv, int nalt, int nazi);
55
56 extern int my_default(OBJREC *, struct illum_args *, char *);
57 extern int my_face(OBJREC *, struct illum_args *, char *);
58 extern int my_sphere(OBJREC *, struct illum_args *, char *);
59 extern int my_ring(OBJREC *, struct illum_args *, char *);
60
61 extern COLORV * distarr; /* distribution array */
62 extern int distsiz;
63 extern COLORV * direct_discount; /* amount to take off direct */
64
65 extern char *progname;
66
67 #ifdef __cplusplus
68 }
69 #endif
70
71 #endif /* _RAD_MKILLUM_H_ */
72
