root/radiance/ray/src/gen/mkillum.c
Revision: 2.44
Committed: Mon Feb 6 22:40:21 2023 UTC (15 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 2.43: +4 -6 lines
2 static const char RCSid[] = "$Id: mkillum.c,v 2.43 2020/07/20 15:54:29 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "paths.h" /* win_popen() */
12 #include "mkillum.h"
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 struct illum_args thisillum = { /* our illum and default values */
26 0,
27 DFLMAT,
28 DFLDAT,
29 0,
30 VOIDID,
31 SAMPDENS,
32 NSAMPS,
33 0.,
34 };
35
36 char matcheck[MAXSTR]; /* current material to include or exclude */
37 int matselect = S_ALL; /* selection criterion */
38
39 int gargc; /* global argc */
40 char **gargv; /* global argv */
41
42 int doneheader = 0; /* printed header yet? */
43 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
44
45 int warnings = 1; /* print warnings? */
46
47 void init(char *octnm, int np);
48 void filter(FILE *infp, char *name);
49 void xoptions(char *s, char *nm);
50 void printopts(void);
51 void printhead(int ac, char **av);
52 void xobject(FILE *fp, char *nm);
53
54
55 int
56 main( /* compute illum distributions using rtrace */
57 int argc,
58 char *argv[]
59 )
60 {
61 int nprocs = 1;
62 FILE *fp;
63 int rval;
64 int i;
65 /* set global arguments */
66 gargv = argv;
67 progname = gargv[0];
68 /* set up rendering defaults */
69 dstrsrc = 0.5;
70 directrelay = 3;
71 ambounce = 2;
72 /* get options from command line */
73 for (i = 1; i < argc; i++) {
74 while ((rval = expandarg(&argc, &argv, i)) > 0)
75 ;
76 if (rval < 0) {
77 sprintf(errmsg, "cannot expand '%s'", argv[i]);
78 error(SYSTEM, errmsg);
79 }
80 if (argv[i][0] != '-')
81 break;
82 if (!strcmp(argv[i], "-w")) {
83 warnings = 0;
84 continue;
85 }
86 if (!strcmp(argv[i], "-n")) {
87 nprocs = atoi(argv[++i]);
88 if (nprocs <= 0)
89 error(USER, "illegal number of processes");
90 continue;
91 }
92 if (!strcmp(argv[i], "-defaults")) {
93 printopts();
94 print_rdefaults();
95 quit(0);
96 }
97 rval = getrenderopt(argc-i, argv+i);
98 if (rval < 0) {
99 sprintf(errmsg, "bad render option at '%s'", argv[i]);
100 error(USER, errmsg);
101 }
102 i += rval;
103 }
104 gargc = ++i;
105 /* add "mandatory" render options */
106 do_irrad = 0;
107 if (gargc > argc || argv[gargc-1][0] == '-')
108 error(USER, "missing octree argument");
109 /* else initialize and run our calculation */
110 init(argv[gargc-1], nprocs);
111 if (gargc < argc) {
112 if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
113 error(USER, "use '< file1 file2 ..' for multiple inputs");
114 for (i = gargc+1; i < argc; i++) {
115 if ((fp = fopen(argv[i], "r")) == NULL) {
116 sprintf(errmsg,
117 "cannot open scene file \"%s\"", argv[i]);
118 error(SYSTEM, errmsg);
119 }
120 filter(fp, argv[i]);
121 fclose(fp);
122 }
123 } else
124 filter(stdin, "standard input");
125 quit(0);
126 return 0; /* pro forma return */
127 }
128
129
130 void
131 init(char *octnm, int np) /* start rendering process(es) */
132 {
133 /* set up signal handling */
134 signal(SIGINT, quit);
135 #ifdef SIGHUP
136 signal(SIGHUP, quit);
137 #endif
138 #ifdef SIGTERM
139 signal(SIGTERM, quit);
140 #endif
141 #ifdef SIGPIPE
142 signal(SIGPIPE, quit);
143 #endif
144 /* start rendering process(es) */
145 ray_pinit(octnm, np);
146 }
147
148
149 void
150 eputs( /* put string to stderr */
151 const char *s
152 )
153 {
154 static int midline = 0;
155
156 if (!*s) return;
157 if (!midline) {
158 fputs(progname, stderr);
159 fputs(": ", stderr);
160 }
161 fputs(s, stderr);
162 midline = s[strlen(s)-1] != '\n';
163 }
164
165
166 void
167 wputs(const char *s) /* print warning if enabled */
168 {
169 if (warnings)
170 eputs(s);
171 }
172
173
174 void
175 quit(int ec) /* make sure exit is called */
176 {
177 if (ray_pnprocs > 0) /* close children if any */
178 ray_pclose(0);
179 else if (ray_pnprocs < 0)
180 _exit(ec); /* avoid flush() in child */
181 exit(ec);
182 }
183
184
185 void
186 filter( /* process stream */
187 FILE *infp,
188 char *name
189 )
190 {
191 char buf[512];
192 FILE *pfp;
193 int c;
194
195 while ((c = getc(infp)) != EOF) {
196 if (isspace(c))
197 continue;
198 if (c == '#') { /* comment/options */
199 buf[0] = c;
200 fgets(buf+1, sizeof(buf)-1, infp);
201 xoptions(buf, name);
202 } else if (c == '!') { /* command */
203 buf[0] = c;
204 fgetline(buf+1, sizeof(buf)-1, infp);
205 if ((pfp = popen(buf+1, "r")) == NULL) {
206 sprintf(errmsg, "cannot execute \"%s\"", buf);
207 error(SYSTEM, errmsg);
208 }
209 filter(pfp, buf);
210 pclose(pfp);
211 } else { /* object */
212 ungetc(c, infp);
213 xobject(infp, name);
214 }
215 }
216 }
217
218
219 void
220 xoptions( /* process options in string s */
221 char *s,
222 char *nm
223 )
224 {
225 char buf[64];
226 int negax;
227 int nerrs = 0;
228 char *cp;
229
230 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
231 fputs(s, stdout); /* not for us */
232 return;
233 }
234 cp = s+10;
235 while (*cp) {
236 switch (*cp) {
237 case ' ':
238 case '\t':
239 case '\n':
240 case '\r':
241 case '\f':
242 cp++;
243 continue;
244 case 'm': /* material name */
245 if (*++cp != '=')
246 break;
247 if (!*++cp || isspace(*cp))
248 break;
249 atos(thisillum.matname, MAXSTR, cp);
250 cp = sskip(cp);
251 if (!(thisillum.flags & IL_DATCLB)) {
252 strcpy(thisillum.datafile, thisillum.matname);
253 thisillum.dfnum = 0;
254 }
255 continue;
256 case 'f': /* data file name */
257 if (*++cp != '=')
258 break;
259 if (!*++cp || isspace(*cp)) {
260 strcpy(thisillum.datafile,thisillum.matname);
261 thisillum.dfnum = 0;
262 thisillum.flags &= ~IL_DATCLB;
263 continue;
264 }
265 atos(thisillum.datafile, MAXSTR, cp);
266 cp = sskip(cp);
267 thisillum.dfnum = 0;
268 thisillum.flags |= IL_DATCLB;
269 continue;
270 case 'i': /* include material */
271 case 'e': /* exclude material */
272 if (cp[1] != '=')
273 break;
274 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
275 cp += 2;
276 atos(matcheck, MAXSTR, cp);
277 cp = sskip(cp);
278 continue;
279 case 'a': /* use everything */
280 cp = sskip(cp);
281 matselect = S_ALL;
282 continue;
283 case 'n': /* use nothing (passive) */
284 cp = sskip(cp);
285 matselect = S_NONE;
286 continue;
287 case 'c': /* color calculation */
288 if (*++cp != '=')
289 break;
290 switch (*++cp) {
291 case 'a': /* average */
292 thisillum.flags = (thisillum.flags|IL_COLAVG)
293 & ~IL_COLDST;
294 break;
295 case 'd': /* distribution */
296 thisillum.flags |= (IL_COLDST|IL_COLAVG);
297 break;
298 case 'n': /* none */
299 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
300 break;
301 default:
302 goto opterr;
303 }
304 cp = sskip(cp);
305 continue;
306 case 'd': /* sample density */
307 if (*++cp != '=')
308 break;
309 if (!*++cp || isspace(*cp))
310 continue;
311 if (isintd(cp, " \t\n\r")) {
312 thisillum.sampdens = atoi(cp);
313 } else {
314 error(WARNING, "direct BSDF input unsupported");
315 goto opterr;
316 }
317 cp = sskip(cp);
318 continue;
319 case 's': /* surface super-samples */
320 if (*++cp != '=')
321 break;
322 if (!isintd(++cp, " \t\n\r"))
323 break;
324 thisillum.nsamps = atoi(cp);
325 cp = sskip(cp);
326 continue;
327 case 'l': /* light sources */
328 cp++;
329 if (*cp == '+')
330 thisillum.flags |= IL_LIGHT;
331 else if (*cp == '-')
332 thisillum.flags &= ~IL_LIGHT;
333 else
334 break;
335 cp++;
336 continue;
337 case 'b': /* brightness */
338 if (*++cp != '=')
339 break;
340 if (!isfltd(++cp, " \t\n\r"))
341 break;
342 thisillum.minbrt = atof(cp);
343 if (thisillum.minbrt < 0.)
344 thisillum.minbrt = 0.;
345 cp = sskip(cp);
346 continue;
347 case 'o': /* output file */
348 if (*++cp != '=')
349 break;
350 if (!*++cp || isspace(*cp))
351 break;
352 atos(buf, sizeof(buf), cp);
353 cp = sskip(cp);
354 if (freopen(buf, "w", stdout) == NULL) {
355 sprintf(errmsg,
356 "cannot open output file \"%s\"", buf);
357 error(SYSTEM, errmsg);
358 }
359 doneheader = 0;
360 continue;
361 case '!': /* processed file! */
362 sprintf(errmsg, "(%s): already processed!", nm);
363 error(WARNING, errmsg);
364 matselect = S_NONE;
365 return;
366 }
367 opterr: /* skip faulty option */
368 while (*cp && !isspace(*cp))
369 cp++;
370 nerrs++;
371 }
372 /* print header? */
373 checkhead();
374 /* issue warnings? */
375 if (nerrs) {
376 sprintf(errmsg, "(%s): %d error(s) in option line:",
377 nm, nerrs);
378 error(WARNING, errmsg);
379 wputs(s);
380 printf("# %s: the following option line has %d error(s):\n",
381 progname, nerrs);
382 }
383 /* print pure comment */
384 printf("# %s", s+2);
385 }
386
387 void
388 printopts(void) /* print out option default values */
389 {
390 printf("m=%-15s\t\t# material name\n", thisillum.matname);
391 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
392 if (thisillum.flags & IL_COLAVG)
393 if (thisillum.flags & IL_COLDST)
394 printf("c=d\t\t\t\t# color distribution\n");
395 else
396 printf("c=a\t\t\t\t# color average\n");
397 else
398 printf("c=n\t\t\t\t# color none\n");
399 if (thisillum.flags & IL_LIGHT)
400 printf("l+\t\t\t\t# light type on\n");
401 else
402 printf("l-\t\t\t\t# light type off\n");
403 printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
404 printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
405 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
406 }
407
408
409 void
410 printhead( /* print out header */
411 int ac,
412 char **av
413 )
414 {
415 putchar('#');
416 while (ac-- > 0) {
417 putchar(' ');
418 fputs(*av++, stdout);
419 }
420 fputs("\n#@mkillum !\n", stdout);
421 }
422
423
424 void
425 xobject( /* translate an object from fp */
426 FILE *fp,
427 char *nm
428 )
429 {
430 OBJREC thisobj;
431 char str[MAXSTR];
432 int doit;
433 /* read the object */
434 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
435 goto readerr;
436 if (fgetword(str, MAXSTR, fp) == NULL)
437 goto readerr;
438 /* is it an alias? */
439 if (!strcmp(str, ALIASKEY)) {
440 if (fgetword(str, MAXSTR, fp) == NULL)
441 goto readerr;
442 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
443 if (fgetword(str, MAXSTR, fp) == NULL)
444 goto readerr;
445 printf("\t%s\n", str);
446 return;
447 }
448 thisobj.omod = OVOID; /* unused field */
449 if ((thisobj.otype = otype(str)) < 0) {
450 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
451 error(USER, errmsg);
452 }
453 if (fgetword(str, MAXSTR, fp) == NULL)
454 goto readerr;
455 thisobj.oname = str;
456 if (readfargs(&thisobj.oargs, fp) != 1)
457 goto readerr;
458 thisobj.os = NULL;
459 /* check for translation */
460 switch (matselect) {
461 case S_NONE:
462 doit = 0;
463 break;
464 case S_ALL:
465 doit = 1;
466 break;
467 case S_ELEM:
468 doit = !strcmp(thisillum.altmat, matcheck);
469 break;
470 case S_COMPL:
471 doit = strcmp(thisillum.altmat, matcheck);
472 break;
473 }
474 doit = doit && issurface(thisobj.otype);
475 /* print header? */
476 checkhead();
477 /* process object */
478 if (doit)
479 switch (thisobj.otype) {
480 case OBJ_FACE:
481 my_face(&thisobj, &thisillum, nm);
482 break;
483 case OBJ_SPHERE:
484 my_sphere(&thisobj, &thisillum, nm);
485 break;
486 case OBJ_RING:
487 my_ring(&thisobj, &thisillum, nm);
488 break;
489 default:
490 my_default(&thisobj, &thisillum, nm);
491 break;
492 }
493 else
494 printobj(thisillum.altmat, &thisobj);
495 /* free arguments */
496 freefargs(&thisobj.oargs);
497 return;
498 readerr:
499 sprintf(errmsg, "(%s): error reading input", nm);
500 error(USER, errmsg);
501 }
