| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mkillum.c,v 2.47 2025/04/23 02:35:26 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Make illum sources for optimizing rendering process
| 6 |
| 7 |
| 8 |
#include <signal.h>
| 9 |
#include <ctype.h>
| 10 |
| 11 |
#include "paths.h" /* win_popen() */
| 12 |
#include "mkillum.h"
| 13 |
#include "func.h"
| 14 |
| 15 |
/* default parameters */
| 16 |
#define SAMPDENS 48 /* points per projected steradian */
| 17 |
#define NSAMPS 32 /* samples per point */
| 18 |
#define DFLMAT "illum_mat" /* material name */
| 19 |
#define DFLDAT "illum" /* data file name */
| 20 |
/* selection options */
| 21 |
#define S_NONE 0 /* select none */
| 22 |
#define S_ELEM 1 /* select specified element */
| 23 |
#define S_COMPL 2 /* select all but element */
| 24 |
#define S_ALL 3 /* select all */
| 25 |
| 26 |
struct illum_args thisillum = { /* our illum and default values */
| 27 |
0,
| 28 |
DFLMAT,
| 29 |
DFLDAT,
| 30 |
0,
| 31 |
VOIDID,
| 32 |
SAMPDENS,
| 33 |
NSAMPS,
| 34 |
0.,
| 35 |
| 36 |
| 37 |
char matcheck[MAXSTR]; /* current material to include or exclude */
| 38 |
int matselect = S_ALL; /* selection criterion */
| 39 |
| 40 |
int gargc; /* global argc */
| 41 |
char **gargv; /* global argv */
| 42 |
| 43 |
int doneheader = 0; /* printed header yet? */
| 44 |
#define checkhead() if (!doneheader++) printhead(gargc,gargv)
| 45 |
| 46 |
int warnings = 1; /* print warnings? */
| 47 |
| 48 |
void init(char *octnm, int np);
| 49 |
void filter(FILE *infp, char *name);
| 50 |
void xoptions(char *s, char *nm);
| 51 |
void printopts(void);
| 52 |
void printhead(int ac, char **av);
| 53 |
void xobject(FILE *fp, char *nm);
| 54 |
| 55 |
| 56 |
int
| 57 |
main( /* compute illum distributions using rtrace */
| 58 |
int argc,
| 59 |
char *argv[]
| 60 |
| 61 |
| 62 |
int nprocs = 1;
| 63 |
FILE *fp;
| 64 |
int rval;
| 65 |
int i;
| 66 |
/* set global arguments */
| 67 |
gargv = argv;
| 68 |
gargv[0] = fixargv0(argv[0]);
| 69 |
/* set up rendering defaults */
| 70 |
dstrsrc = 0.5;
| 71 |
directrelay = 3;
| 72 |
ambounce = 2;
| 73 |
/* initialize calcomp routines */
| 74 |
initfunc();
| 75 |
/* get options from command line */
| 76 |
for (i = 1; i < argc; i++) {
| 77 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 78 |
| 79 |
if (rval < 0) {
| 80 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 81 |
error(SYSTEM, errmsg);
| 82 |
| 83 |
if (argv[i][0] != '-')
| 84 |
break;
| 85 |
if (!strcmp(argv[i], "-w")) {
| 86 |
warnings = 0;
| 87 |
continue;
| 88 |
| 89 |
if (!strcmp(argv[i], "-n")) {
| 90 |
nprocs = atoi(argv[++i]);
| 91 |
if (nprocs <= 0)
| 92 |
error(USER, "illegal number of processes");
| 93 |
continue;
| 94 |
| 95 |
if (!strcmp(argv[i], "-defaults")) {
| 96 |
printopts();
| 97 |
print_rdefaults();
| 98 |
quit(0);
| 99 |
| 100 |
rval = getrenderopt(argc-i, argv+i);
| 101 |
if (rval < 0) {
| 102 |
sprintf(errmsg, "bad render option at '%s'", argv[i]);
| 103 |
error(USER, errmsg);
| 104 |
| 105 |
i += rval;
| 106 |
| 107 |
gargc = ++i;
| 108 |
/* add "mandatory" render options */
| 109 |
do_irrad = 0;
| 110 |
if (gargc > argc || argv[gargc-1][0] == '-')
| 111 |
error(USER, "missing octree argument");
| 112 |
/* else initialize and run our calculation */
| 113 |
init(argv[gargc-1], nprocs);
| 114 |
if (gargc < argc) {
| 115 |
if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
| 116 |
error(USER, "use '< file1 file2 ..' for multiple inputs");
| 117 |
for (i = gargc+1; i < argc; i++) {
| 118 |
if ((fp = fopen(argv[i], "r")) == NULL) {
| 119 |
sprintf(errmsg,
| 120 |
"cannot open scene file \"%s\"", argv[i]);
| 121 |
| 122 |
| 123 |
filter(fp, argv[i]);
| 124 |
fclose(fp);
| 125 |
| 126 |
} else
| 127 |
filter(stdin, "standard input");
| 128 |
quit(0);
| 129 |
return 0; /* pro forma return */
| 130 |
| 131 |
| 132 |
| 133 |
void
| 134 |
init(char *octnm, int np) /* start rendering process(es) */
| 135 |
| 136 |
/* set up signal handling */
| 137 |
signal(SIGINT, quit);
| 138 |
#ifdef SIGHUP
| 139 |
signal(SIGHUP, quit);
| 140 |
#endif
| 141 |
#ifdef SIGTERM
| 142 |
signal(SIGTERM, quit);
| 143 |
#endif
| 144 |
#ifdef SIGPIPE
| 145 |
signal(SIGPIPE, quit);
| 146 |
#endif
| 147 |
| 148 |
ray_pinit(octnm, np);
| 149 |
| 150 |
| 151 |
| 152 |
void
| 153 |
eputs( /* put string to stderr */
| 154 |
const char *s
| 155 |
| 156 |
| 157 |
static int midline = 0;
| 158 |
| 159 |
if (!*s) return;
| 160 |
if (!midline) {
| 161 |
fputs(progname, stderr);
| 162 |
fputs(": ", stderr);
| 163 |
| 164 |
fputs(s, stderr);
| 165 |
midline = s[strlen(s)-1] != '\n';
| 166 |
| 167 |
| 168 |
| 169 |
void
| 170 |
wputs(const char *s) /* print warning if enabled */
| 171 |
| 172 |
if (warnings)
| 173 |
eputs(s);
| 174 |
| 175 |
| 176 |
| 177 |
void
| 178 |
quit(int ec) /* make sure exit is called */
| 179 |
| 180 |
if (ray_pnprocs > 0) /* close children if any */
| 181 |
ray_pclose(0);
| 182 |
else if (ray_pnprocs < 0)
| 183 |
_exit(ec); /* avoid flush() in child */
| 184 |
exit(ec);
| 185 |
| 186 |
| 187 |
| 188 |
void
| 189 |
filter( /* process stream */
| 190 |
FILE *infp,
| 191 |
char *name
| 192 |
| 193 |
| 194 |
char buf[512];
| 195 |
FILE *pfp;
| 196 |
int c;
| 197 |
| 198 |
while ((c = getc(infp)) != EOF) {
| 199 |
if (isspace(c))
| 200 |
continue;
| 201 |
if (c == '#') { /* comment/options */
| 202 |
buf[0] = c;
| 203 |
fgets(buf+1, sizeof(buf)-1, infp);
| 204 |
xoptions(buf, name);
| 205 |
} else if (c == '!') { /* command */
| 206 |
buf[0] = c;
| 207 |
fgetline(buf+1, sizeof(buf)-1, infp);
| 208 |
if ((pfp = popen(buf+1, "r")) == NULL) {
| 209 |
sprintf(errmsg, "cannot execute \"%s\"", buf);
| 210 |
| 211 |
| 212 |
filter(pfp, buf);
| 213 |
if (pclose(pfp) != 0) {
| 214 |
sprintf(errmsg, "bad status from \"%s\"", buf);
| 215 |
error(WARNING, errmsg);
| 216 |
| 217 |
} else { /* object */
| 218 |
ungetc(c, infp);
| 219 |
xobject(infp, name);
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
void
| 226 |
xoptions( /* process options in string s */
| 227 |
char *s,
| 228 |
char *nm
| 229 |
| 230 |
| 231 |
char buf[64];
| 232 |
int negax;
| 233 |
int nerrs = 0;
| 234 |
char *cp;
| 235 |
| 236 |
if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
| 237 |
fputs(s, stdout); /* not for us */
| 238 |
return;
| 239 |
| 240 |
cp = s+10;
| 241 |
while (*cp) {
| 242 |
switch (*cp) {
| 243 |
case ' ':
| 244 |
case '\t':
| 245 |
case '\n':
| 246 |
case '\r':
| 247 |
case '\f':
| 248 |
cp++;
| 249 |
continue;
| 250 |
case 'm': /* material name */
| 251 |
if (*++cp != '=')
| 252 |
break;
| 253 |
if (!*++cp || isspace(*cp))
| 254 |
break;
| 255 |
atos(thisillum.matname, MAXSTR, cp);
| 256 |
cp = sskip(cp);
| 257 |
if (!(thisillum.flags & IL_DATCLB)) {
| 258 |
strcpy(thisillum.datafile, thisillum.matname);
| 259 |
thisillum.dfnum = 0;
| 260 |
| 261 |
continue;
| 262 |
case 'f': /* data file name */
| 263 |
if (*++cp != '=')
| 264 |
break;
| 265 |
if (!*++cp || isspace(*cp)) {
| 266 |
strcpy(thisillum.datafile,thisillum.matname);
| 267 |
| 268 |
thisillum.flags &= ~IL_DATCLB;
| 269 |
continue;
| 270 |
| 271 |
atos(thisillum.datafile, MAXSTR, cp);
| 272 |
cp = sskip(cp);
| 273 |
| 274 |
thisillum.flags |= IL_DATCLB;
| 275 |
continue;
| 276 |
case 'i': /* include material */
| 277 |
case 'e': /* exclude material */
| 278 |
if (cp[1] != '=')
| 279 |
break;
| 280 |
matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
| 281 |
cp += 2;
| 282 |
atos(matcheck, MAXSTR, cp);
| 283 |
cp = sskip(cp);
| 284 |
continue;
| 285 |
case 'a': /* use everything */
| 286 |
cp = sskip(cp);
| 287 |
matselect = S_ALL;
| 288 |
continue;
| 289 |
case 'n': /* use nothing (passive) */
| 290 |
cp = sskip(cp);
| 291 |
matselect = S_NONE;
| 292 |
continue;
| 293 |
case 'c': /* color calculation */
| 294 |
if (*++cp != '=')
| 295 |
break;
| 296 |
switch (*++cp) {
| 297 |
case 'a': /* average */
| 298 |
thisillum.flags = (thisillum.flags|IL_COLAVG)
| 299 |
& ~IL_COLDST;
| 300 |
break;
| 301 |
case 'd': /* distribution */
| 302 |
thisillum.flags |= (IL_COLDST|IL_COLAVG);
| 303 |
break;
| 304 |
case 'n': /* none */
| 305 |
thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
| 306 |
break;
| 307 |
default:
| 308 |
goto opterr;
| 309 |
| 310 |
cp = sskip(cp);
| 311 |
continue;
| 312 |
case 'd': /* sample density */
| 313 |
if (*++cp != '=')
| 314 |
break;
| 315 |
| 316 |
continue;
| 317 |
if (isintd(cp, " \t\n\r")) {
| 318 |
thisillum.sampdens = atoi(cp);
| 319 |
} else {
| 320 |
error(WARNING, "direct BSDF input unsupported");
| 321 |
goto opterr;
| 322 |
| 323 |
cp = sskip(cp);
| 324 |
continue;
| 325 |
case 's': /* surface super-samples */
| 326 |
if (*++cp != '=')
| 327 |
break;
| 328 |
if (!isintd(++cp, " \t\n\r"))
| 329 |
break;
| 330 |
thisillum.nsamps = atoi(cp);
| 331 |
cp = sskip(cp);
| 332 |
continue;
| 333 |
case 'l': /* light sources */
| 334 |
cp++;
| 335 |
if (*cp == '+')
| 336 |
thisillum.flags |= IL_LIGHT;
| 337 |
else if (*cp == '-')
| 338 |
thisillum.flags &= ~IL_LIGHT;
| 339 |
else
| 340 |
break;
| 341 |
cp++;
| 342 |
continue;
| 343 |
case 'b': /* brightness */
| 344 |
if (*++cp != '=')
| 345 |
break;
| 346 |
if (!isfltd(++cp, " \t\n\r"))
| 347 |
break;
| 348 |
thisillum.minbrt = atof(cp);
| 349 |
if (thisillum.minbrt < 0.)
| 350 |
thisillum.minbrt = 0.;
| 351 |
cp = sskip(cp);
| 352 |
continue;
| 353 |
case 'o': /* output file */
| 354 |
if (*++cp != '=')
| 355 |
break;
| 356 |
| 357 |
break;
| 358 |
atos(buf, sizeof(buf), cp);
| 359 |
cp = sskip(cp);
| 360 |
if (freopen(buf, "w", stdout) == NULL) {
| 361 |
sprintf(errmsg,
| 362 |
"cannot open output file \"%s\"", buf);
| 363 |
| 364 |
| 365 |
doneheader = 0;
| 366 |
continue;
| 367 |
case '!': /* processed file! */
| 368 |
sprintf(errmsg, "(%s): already processed!", nm);
| 369 |
| 370 |
matselect = S_NONE;
| 371 |
return;
| 372 |
| 373 |
opterr: /* skip faulty option */
| 374 |
while (*cp && !isspace(*cp))
| 375 |
cp++;
| 376 |
nerrs++;
| 377 |
| 378 |
/* print header? */
| 379 |
checkhead();
| 380 |
/* issue warnings? */
| 381 |
if (nerrs) {
| 382 |
sprintf(errmsg, "(%s): %d error(s) in option line:",
| 383 |
nm, nerrs);
| 384 |
| 385 |
wputs(s);
| 386 |
printf("# %s: the following option line has %d error(s):\n",
| 387 |
progname, nerrs);
| 388 |
| 389 |
/* print pure comment */
| 390 |
printf("# %s", s+2);
| 391 |
| 392 |
| 393 |
void
| 394 |
printopts(void) /* print out option default values */
| 395 |
| 396 |
printf("m=%-15s\t\t# material name\n", thisillum.matname);
| 397 |
printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
| 398 |
if (thisillum.flags & IL_COLAVG)
| 399 |
if (thisillum.flags & IL_COLDST)
| 400 |
printf("c=d\t\t\t\t# color distribution\n");
| 401 |
else
| 402 |
printf("c=a\t\t\t\t# color average\n");
| 403 |
else
| 404 |
printf("c=n\t\t\t\t# color none\n");
| 405 |
if (thisillum.flags & IL_LIGHT)
| 406 |
printf("l+\t\t\t\t# light type on\n");
| 407 |
else
| 408 |
printf("l-\t\t\t\t# light type off\n");
| 409 |
printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
| 410 |
printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
| 411 |
printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
| 412 |
| 413 |
| 414 |
| 415 |
void
| 416 |
printhead( /* print out header */
| 417 |
int ac,
| 418 |
char **av
| 419 |
| 420 |
| 421 |
putchar('#');
| 422 |
while (ac-- > 0) {
| 423 |
putchar(' ');
| 424 |
fputs(*av++, stdout);
| 425 |
| 426 |
fputs("\n#@mkillum !\n", stdout);
| 427 |
| 428 |
| 429 |
| 430 |
void
| 431 |
xobject( /* translate an object from fp */
| 432 |
FILE *fp,
| 433 |
char *nm
| 434 |
| 435 |
| 436 |
OBJREC thisobj;
| 437 |
char str[MAXSTR];
| 438 |
int doit;
| 439 |
/* read the object */
| 440 |
if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
| 441 |
goto readerr;
| 442 |
if (fgetword(str, MAXSTR, fp) == NULL)
| 443 |
goto readerr;
| 444 |
/* is it an alias? */
| 445 |
if (!strcmp(str, ALIASKEY)) {
| 446 |
| 447 |
goto readerr;
| 448 |
printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
| 449 |
| 450 |
goto readerr;
| 451 |
printf("\t%s\n", str);
| 452 |
return;
| 453 |
| 454 |
thisobj.omod = OVOID; /* unused field */
| 455 |
if ((thisobj.otype = otype(str)) < 0) {
| 456 |
sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
| 457 |
| 458 |
| 459 |
| 460 |
goto readerr;
| 461 |
thisobj.oname = str;
| 462 |
if (readfargs(&thisobj.oargs, fp) != 1)
| 463 |
goto readerr;
| 464 |
thisobj.os = NULL;
| 465 |
/* check for translation */
| 466 |
switch (matselect) {
| 467 |
case S_NONE:
| 468 |
doit = 0;
| 469 |
break;
| 470 |
case S_ALL:
| 471 |
doit = 1;
| 472 |
break;
| 473 |
case S_ELEM:
| 474 |
doit = !strcmp(thisillum.altmat, matcheck);
| 475 |
break;
| 476 |
case S_COMPL:
| 477 |
doit = strcmp(thisillum.altmat, matcheck);
| 478 |
break;
| 479 |
| 480 |
doit = doit && issurface(thisobj.otype);
| 481 |
/* print header? */
| 482 |
checkhead();
| 483 |
/* process object */
| 484 |
if (doit)
| 485 |
switch (thisobj.otype) {
| 486 |
case OBJ_FACE:
| 487 |
my_face(&thisobj, &thisillum, nm);
| 488 |
break;
| 489 |
case OBJ_SPHERE:
| 490 |
my_sphere(&thisobj, &thisillum, nm);
| 491 |
break;
| 492 |
case OBJ_RING:
| 493 |
my_ring(&thisobj, &thisillum, nm);
| 494 |
break;
| 495 |
default:
| 496 |
my_default(&thisobj, &thisillum, nm);
| 497 |
break;
| 498 |
| 499 |
else
| 500 |
printobj(thisillum.altmat, &thisobj);
| 501 |
/* free arguments */
| 502 |
freefargs(&thisobj.oargs);
| 503 |
return;
| 504 |
readerr:
| 505 |
sprintf(errmsg, "(%s): error reading input", nm);
| 506 |
| 507 |
