root/radiance/ray/src/gen/mkillum.c
Revision: 2.48
Committed: Tue Jun 3 21:31:51 2025 UTC (3 days, 23 hours ago) by greg
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.48 static const char RCSid[] = "$Id: mkillum.c,v 2.47 2025/04/23 02:35:26 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Make illum sources for optimizing rendering process
6     */
7
8 greg 1.3 #include <signal.h>
9 schorsch 2.13 #include <ctype.h>
10 greg 1.3
11 greg 2.41 #include "paths.h" /* win_popen() */
12 greg 2.15 #include "mkillum.h"
13 greg 2.47 #include "func.h"
14 greg 1.1
15     /* default parameters */
16 greg 1.8 #define SAMPDENS 48 /* points per projected steradian */
17 greg 1.1 #define NSAMPS 32 /* samples per point */
18     #define DFLMAT "illum_mat" /* material name */
19 greg 1.10 #define DFLDAT "illum" /* data file name */
20 greg 1.1 /* selection options */
21     #define S_NONE 0 /* select none */
22     #define S_ELEM 1 /* select specified element */
23     #define S_COMPL 2 /* select all but element */
24     #define S_ALL 3 /* select all */
25
26 greg 1.2 struct illum_args thisillum = { /* our illum and default values */
27     0,
28     DFLMAT,
29 greg 1.10 DFLDAT,
30 greg 1.2 0,
31     VOIDID,
32 greg 1.3 SAMPDENS,
33 greg 1.2 NSAMPS,
34 greg 1.12 0.,
35 greg 1.2 };
36 greg 1.1
37     char matcheck[MAXSTR]; /* current material to include or exclude */
38     int matselect = S_ALL; /* selection criterion */
39
40     int gargc; /* global argc */
41     char **gargv; /* global argv */
42
43     int doneheader = 0; /* printed header yet? */
44 greg 1.2 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
45 greg 1.1
46 greg 1.2 int warnings = 1; /* print warnings? */
47
48 greg 2.28 void init(char *octnm, int np);
49 greg 2.42 void filter(FILE *infp, char *name);
50 schorsch 2.19 void xoptions(char *s, char *nm);
51     void printopts(void);
52 greg 2.42 void printhead(int ac, char **av);
53 schorsch 2.19 void xobject(FILE *fp, char *nm);
54 greg 1.1
55 schorsch 2.19
56     int
57     main( /* compute illum distributions using rtrace */
58     int argc,
59     char *argv[]
60     )
61 greg 1.1 {
62 greg 2.20 int nprocs = 1;
63 greg 1.3 FILE *fp;
64 greg 2.28 int rval;
65 greg 2.42 int i;
66 greg 1.1 /* set global arguments */
67 greg 1.3 gargv = argv;
68 greg 2.48 gargv[0] = fixargv0(argv[0]);
69 greg 2.28 /* set up rendering defaults */
70 greg 2.35 dstrsrc = 0.5;
71 greg 2.28 directrelay = 3;
72     ambounce = 2;
73 greg 2.47 /* initialize calcomp routines */
74     initfunc();
75 greg 2.28 /* get options from command line */
76 greg 2.29 for (i = 1; i < argc; i++) {
77 greg 2.28 while ((rval = expandarg(&argc, &argv, i)) > 0)
78     ;
79     if (rval < 0) {
80     sprintf(errmsg, "cannot expand '%s'", argv[i]);
81     error(SYSTEM, errmsg);
82     }
83     if (argv[i][0] != '-')
84 greg 1.3 break;
85 greg 2.28 if (!strcmp(argv[i], "-w")) {
86     warnings = 0;
87     continue;
88     }
89     if (!strcmp(argv[i], "-n")) {
90     nprocs = atoi(argv[++i]);
91     if (nprocs <= 0)
92     error(USER, "illegal number of processes");
93     continue;
94     }
95     if (!strcmp(argv[i], "-defaults")) {
96     printopts();
97     print_rdefaults();
98     quit(0);
99     }
100     rval = getrenderopt(argc-i, argv+i);
101     if (rval < 0) {
102     sprintf(errmsg, "bad render option at '%s'", argv[i]);
103     error(USER, errmsg);
104 greg 1.1 }
105 greg 2.28 i += rval;
106 greg 1.1 }
107 greg 2.28 gargc = ++i;
108     /* add "mandatory" render options */
109     do_irrad = 0;
110     if (gargc > argc || argv[gargc-1][0] == '-')
111 greg 2.3 error(USER, "missing octree argument");
112 greg 1.1 /* else initialize and run our calculation */
113 greg 2.28 init(argv[gargc-1], nprocs);
114     if (gargc < argc) {
115     if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
116 greg 2.30 error(USER, "use '< file1 file2 ..' for multiple inputs");
117 greg 1.3 for (i = gargc+1; i < argc; i++) {
118 greg 1.5 if ((fp = fopen(argv[i], "r")) == NULL) {
119 greg 1.3 sprintf(errmsg,
120     "cannot open scene file \"%s\"", argv[i]);
121     error(SYSTEM, errmsg);
122     }
123     filter(fp, argv[i]);
124     fclose(fp);
125     }
126 greg 2.28 } else
127 greg 1.3 filter(stdin, "standard input");
128 greg 2.20 quit(0);
129 schorsch 2.27 return 0; /* pro forma return */
130 greg 1.1 }
131
132 schorsch 2.26
133 greg 2.11 void
134 greg 2.28 init(char *octnm, int np) /* start rendering process(es) */
135 greg 1.3 {
136     /* set up signal handling */
137 greg 2.25 signal(SIGINT, quit);
138     #ifdef SIGHUP
139     signal(SIGHUP, quit);
140     #endif
141     #ifdef SIGTERM
142     signal(SIGTERM, quit);
143     #endif
144     #ifdef SIGPIPE
145 greg 1.3 signal(SIGPIPE, quit);
146 schorsch 2.13 #endif
147 greg 2.28 /* start rendering process(es) */
148     ray_pinit(octnm, np);
149 greg 1.1 }
150
151
152 greg 2.11 void
153 schorsch 2.19 eputs( /* put string to stderr */
154 greg 2.44 const char *s
155 schorsch 2.19 )
156 greg 1.1 {
157     static int midline = 0;
158
159     if (!*s) return;
160     if (!midline) {
161     fputs(progname, stderr);
162     fputs(": ", stderr);
163     }
164     fputs(s, stderr);
165     midline = s[strlen(s)-1] != '\n';
166     }
167
168
169 greg 2.11 void
170 greg 2.44 wputs(const char *s) /* print warning if enabled */
171 greg 1.2 {
172     if (warnings)
173     eputs(s);
174     }
175
176
177 schorsch 2.19 void
178 greg 2.44 quit(int ec) /* make sure exit is called */
179 greg 2.36 {
180     if (ray_pnprocs > 0) /* close children if any */
181 greg 2.43 ray_pclose(0);
182     else if (ray_pnprocs < 0)
183     _exit(ec); /* avoid flush() in child */
184 greg 2.36 exit(ec);
185     }
186
187
188     void
189 schorsch 2.19 filter( /* process stream */
190 greg 2.42 FILE *infp,
191 schorsch 2.19 char *name
192     )
193 greg 1.1 {
194     char buf[512];
195     FILE *pfp;
196 greg 2.42 int c;
197 greg 1.1
198     while ((c = getc(infp)) != EOF) {
199     if (isspace(c))
200     continue;
201     if (c == '#') { /* comment/options */
202     buf[0] = c;
203     fgets(buf+1, sizeof(buf)-1, infp);
204 greg 1.2 xoptions(buf, name);
205 greg 1.1 } else if (c == '!') { /* command */
206     buf[0] = c;
207     fgetline(buf+1, sizeof(buf)-1, infp);
208     if ((pfp = popen(buf+1, "r")) == NULL) {
209     sprintf(errmsg, "cannot execute \"%s\"", buf);
210     error(SYSTEM, errmsg);
211     }
212 greg 1.2 filter(pfp, buf);
213 greg 2.45 if (pclose(pfp) != 0) {
214     sprintf(errmsg, "bad status from \"%s\"", buf);
215 greg 2.46 error(WARNING, errmsg);
216 greg 2.45 }
217 greg 1.1 } else { /* object */
218     ungetc(c, infp);
219     xobject(infp, name);
220     }
221     }
222     }
223
224
225 schorsch 2.19 void
226     xoptions( /* process options in string s */
227     char *s,
228     char *nm
229     )
230 greg 1.1 {
231     char buf[64];
232 greg 2.30 int negax;
233 greg 1.1 int nerrs = 0;
234 greg 2.42 char *cp;
235 greg 1.1
236 greg 1.2 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
237     fputs(s, stdout); /* not for us */
238 greg 1.1 return;
239 greg 1.2 }
240 greg 1.1 cp = s+10;
241     while (*cp) {
242     switch (*cp) {
243     case ' ':
244     case '\t':
245     case '\n':
246 greg 2.11 case '\r':
247     case '\f':
248 greg 1.1 cp++;
249     continue;
250     case 'm': /* material name */
251 greg 1.2 if (*++cp != '=')
252 greg 1.1 break;
253 greg 2.8 if (!*++cp || isspace(*cp))
254 greg 1.2 break;
255 greg 1.1 atos(thisillum.matname, MAXSTR, cp);
256     cp = sskip(cp);
257     if (!(thisillum.flags & IL_DATCLB)) {
258     strcpy(thisillum.datafile, thisillum.matname);
259     thisillum.dfnum = 0;
260     }
261     continue;
262     case 'f': /* data file name */
263 greg 1.2 if (*++cp != '=')
264 greg 1.1 break;
265 greg 2.8 if (!*++cp || isspace(*cp)) {
266 greg 1.6 strcpy(thisillum.datafile,thisillum.matname);
267 greg 1.10 thisillum.dfnum = 0;
268 greg 1.1 thisillum.flags &= ~IL_DATCLB;
269     continue;
270     }
271     atos(thisillum.datafile, MAXSTR, cp);
272     cp = sskip(cp);
273     thisillum.dfnum = 0;
274     thisillum.flags |= IL_DATCLB;
275     continue;
276     case 'i': /* include material */
277     case 'e': /* exclude material */
278 greg 1.6 if (cp[1] != '=')
279 greg 1.1 break;
280 greg 1.7 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
281     cp += 2;
282     atos(matcheck, MAXSTR, cp);
283 greg 1.1 cp = sskip(cp);
284     continue;
285     case 'a': /* use everything */
286     cp = sskip(cp);
287     matselect = S_ALL;
288     continue;
289     case 'n': /* use nothing (passive) */
290     cp = sskip(cp);
291     matselect = S_NONE;
292     continue;
293     case 'c': /* color calculation */
294 greg 1.2 if (*++cp != '=')
295 greg 1.1 break;
296 greg 1.2 switch (*++cp) {
297 greg 1.1 case 'a': /* average */
298 greg 1.6 thisillum.flags = (thisillum.flags|IL_COLAVG)
299     & ~IL_COLDST;
300 greg 1.1 break;
301     case 'd': /* distribution */
302 greg 1.5 thisillum.flags |= (IL_COLDST|IL_COLAVG);
303 greg 1.1 break;
304     case 'n': /* none */
305     thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
306     break;
307     default:
308     goto opterr;
309     }
310     cp = sskip(cp);
311     continue;
312 greg 2.39 case 'd': /* sample density */
313 greg 1.2 if (*++cp != '=')
314 greg 1.1 break;
315 greg 2.30 if (!*++cp || isspace(*cp))
316     continue;
317 greg 2.33 if (isintd(cp, " \t\n\r")) {
318 greg 2.30 thisillum.sampdens = atoi(cp);
319     } else {
320 greg 2.39 error(WARNING, "direct BSDF input unsupported");
321     goto opterr;
322 greg 2.30 }
323 greg 1.1 cp = sskip(cp);
324     continue;
325 greg 2.30 case 's': /* surface super-samples */
326 greg 1.2 if (*++cp != '=')
327 greg 1.1 break;
328 greg 2.11 if (!isintd(++cp, " \t\n\r"))
329 greg 1.1 break;
330     thisillum.nsamps = atoi(cp);
331     cp = sskip(cp);
332     continue;
333 greg 1.3 case 'l': /* light sources */
334 greg 1.4 cp++;
335     if (*cp == '+')
336 greg 1.3 thisillum.flags |= IL_LIGHT;
337 greg 1.4 else if (*cp == '-')
338     thisillum.flags &= ~IL_LIGHT;
339 greg 1.3 else
340 greg 1.4 break;
341     cp++;
342 greg 1.3 continue;
343 greg 1.12 case 'b': /* brightness */
344     if (*++cp != '=')
345     break;
346 greg 2.11 if (!isfltd(++cp, " \t\n\r"))
347 greg 1.12 break;
348     thisillum.minbrt = atof(cp);
349 greg 1.13 if (thisillum.minbrt < 0.)
350     thisillum.minbrt = 0.;
351 greg 1.12 cp = sskip(cp);
352     continue;
353 greg 1.1 case 'o': /* output file */
354 greg 1.2 if (*++cp != '=')
355 greg 1.1 break;
356 greg 2.8 if (!*++cp || isspace(*cp))
357 greg 1.2 break;
358 greg 1.1 atos(buf, sizeof(buf), cp);
359     cp = sskip(cp);
360     if (freopen(buf, "w", stdout) == NULL) {
361     sprintf(errmsg,
362     "cannot open output file \"%s\"", buf);
363     error(SYSTEM, errmsg);
364     }
365     doneheader = 0;
366     continue;
367 greg 1.6 case '!': /* processed file! */
368 greg 1.7 sprintf(errmsg, "(%s): already processed!", nm);
369 greg 1.6 error(WARNING, errmsg);
370 greg 1.7 matselect = S_NONE;
371 greg 1.6 return;
372 greg 1.1 }
373     opterr: /* skip faulty option */
374 greg 2.9 while (*cp && !isspace(*cp))
375     cp++;
376 greg 1.1 nerrs++;
377     }
378 greg 1.2 /* print header? */
379     checkhead();
380     /* issue warnings? */
381 greg 1.1 if (nerrs) {
382     sprintf(errmsg, "(%s): %d error(s) in option line:",
383     nm, nerrs);
384     error(WARNING, errmsg);
385 greg 1.2 wputs(s);
386     printf("# %s: the following option line has %d error(s):\n",
387     progname, nerrs);
388 greg 1.1 }
389 greg 1.2 /* print pure comment */
390 greg 1.4 printf("# %s", s+2);
391 greg 1.9 }
392
393 schorsch 2.19 void
394     printopts(void) /* print out option default values */
395 greg 1.9 {
396 greg 1.11 printf("m=%-15s\t\t# material name\n", thisillum.matname);
397     printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
398 greg 2.2 if (thisillum.flags & IL_COLAVG)
399     if (thisillum.flags & IL_COLDST)
400     printf("c=d\t\t\t\t# color distribution\n");
401     else
402     printf("c=a\t\t\t\t# color average\n");
403     else
404     printf("c=n\t\t\t\t# color none\n");
405     if (thisillum.flags & IL_LIGHT)
406     printf("l+\t\t\t\t# light type on\n");
407     else
408     printf("l-\t\t\t\t# light type off\n");
409 greg 2.34 printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
410     printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
411 greg 1.12 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
412 greg 1.1 }
413 greg 1.2
414
415 schorsch 2.19 void
416     printhead( /* print out header */
417 greg 2.42 int ac,
418     char **av
419 schorsch 2.19 )
420 greg 1.2 {
421     putchar('#');
422     while (ac-- > 0) {
423     putchar(' ');
424     fputs(*av++, stdout);
425     }
426 greg 1.6 fputs("\n#@mkillum !\n", stdout);
427 greg 1.2 }
428
429
430 schorsch 2.19 void
431     xobject( /* translate an object from fp */
432     FILE *fp,
433     char *nm
434     )
435 greg 1.2 {
436     OBJREC thisobj;
437     char str[MAXSTR];
438     int doit;
439     /* read the object */
440     if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
441     goto readerr;
442     if (fgetword(str, MAXSTR, fp) == NULL)
443     goto readerr;
444     /* is it an alias? */
445 greg 2.12 if (!strcmp(str, ALIASKEY)) {
446 greg 1.2 if (fgetword(str, MAXSTR, fp) == NULL)
447     goto readerr;
448 greg 2.12 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
449 greg 1.2 if (fgetword(str, MAXSTR, fp) == NULL)
450     goto readerr;
451 greg 1.4 printf("\t%s\n", str);
452 greg 1.2 return;
453     }
454 greg 1.4 thisobj.omod = OVOID; /* unused field */
455 greg 1.2 if ((thisobj.otype = otype(str)) < 0) {
456     sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
457     error(USER, errmsg);
458     }
459     if (fgetword(str, MAXSTR, fp) == NULL)
460     goto readerr;
461     thisobj.oname = str;
462     if (readfargs(&thisobj.oargs, fp) != 1)
463     goto readerr;
464     thisobj.os = NULL;
465     /* check for translation */
466     switch (matselect) {
467     case S_NONE:
468     doit = 0;
469     break;
470     case S_ALL:
471 greg 1.4 doit = 1;
472 greg 1.2 break;
473     case S_ELEM:
474     doit = !strcmp(thisillum.altmat, matcheck);
475     break;
476     case S_COMPL:
477     doit = strcmp(thisillum.altmat, matcheck);
478     break;
479     }
480 greg 1.4 doit = doit && issurface(thisobj.otype);
481 greg 1.2 /* print header? */
482     checkhead();
483     /* process object */
484     if (doit)
485 greg 2.28 switch (thisobj.otype) {
486     case OBJ_FACE:
487     my_face(&thisobj, &thisillum, nm);
488     break;
489     case OBJ_SPHERE:
490     my_sphere(&thisobj, &thisillum, nm);
491     break;
492     case OBJ_RING:
493     my_ring(&thisobj, &thisillum, nm);
494     break;
495     default:
496     my_default(&thisobj, &thisillum, nm);
497     break;
498     }
499 greg 1.2 else
500     printobj(thisillum.altmat, &thisobj);
501     /* free arguments */
502     freefargs(&thisobj.oargs);
503     return;
504     readerr:
505 greg 2.28 sprintf(errmsg, "(%s): error reading input", nm);
506 greg 1.2 error(USER, errmsg);
507     }
