root/Development/ray/src/gen/mkillum.c
Revision: 2.7
Committed: Fri Jan 7 14:51:28 1994 UTC (31 years, 10 months ago) by greg
increased size of urand() table
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 48 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 #define DFLDAT "illum" /* data file name */
22 /* selection options */
23 #define S_NONE 0 /* select none */
24 #define S_ELEM 1 /* select specified element */
25 #define S_COMPL 2 /* select all but element */
26 #define S_ALL 3 /* select all */
27
28 /* rtrace command and defaults */
29 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
30 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
31 int rtargc = 14;
32 /* overriding rtrace options */
33 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", "-y", "0", NULL };
34
35 struct rtproc rt; /* our rtrace process */
36
37 struct illum_args thisillum = { /* our illum and default values */
38 0,
39 DFLMAT,
40 DFLDAT,
41 0,
42 VOIDID,
43 SAMPDENS,
44 NSAMPS,
45 0.,
46 };
47
48 char matcheck[MAXSTR]; /* current material to include or exclude */
49 int matselect = S_ALL; /* selection criterion */
50
51 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
52
53 int gargc; /* global argc */
54 char **gargv; /* global argv */
55 #define progname gargv[0]
56
57 int doneheader = 0; /* printed header yet? */
58 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
59
60 int warnings = 1; /* print warnings? */
61
62 extern char *fgetline(), *fgetword(), *sskip(),
63 *atos(), *iskip(), *fskip(), *strcpy();
64 extern FILE *popen();
65
66
67 main(argc, argv) /* compute illum distributions using rtrace */
68 int argc;
69 char *argv[];
70 {
71 extern char *getenv(), *getpath();
72 char *rtpath;
73 FILE *fp;
74 register int i;
75 /* set global arguments */
76 gargv = argv;
77 /* set up rtrace command */
78 for (i = 1; i < argc; i++) {
79 if (argv[i][0] == '<' && argv[i][1] == '\0')
80 break;
81 rtargv[rtargc++] = argv[i];
82 if (argv[i][0] == '-' && argv[i][1] == 'w')
83 switch (argv[i][2]) {
84 case '\0':
85 warnings = !warnings;
86 break;
87 case '+':
88 case 'T': case 't':
89 case 'Y': case 'y':
90 case '1':
91 warnings = 1;
92 break;
93 case '-':
94 case 'F': case 'f':
95 case 'N': case 'n':
96 case '0':
97 warnings = 0;
98 break;
99 }
100 }
101 gargc = i;
102 rtargc--;
103 for (i = 0; myrtopts[i] != NULL; i++)
104 rtargv[rtargc++] = myrtopts[i];
105 rtargv[rtargc++] = argv[gargc-1];
106 rtargv[rtargc] = NULL;
107 /* just asking for defaults? */
108 if (!strcmp(argv[gargc-1], "-defaults")) {
109 printopts(); fflush(stdout);
110 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
111 if (rtpath == NULL) {
112 eputs(rtargv[0]);
113 eputs(": command not found\n");
114 exit(1);
115 }
116 execv(rtpath, rtargv);
117 perror(rtpath);
118 exit(1);
119 }
120 if (gargc < 2 || argv[gargc-1][0] == '-')
121 error(USER, "missing octree argument");
122 /* else initialize and run our calculation */
123 init();
124 if (gargc+1 < argc)
125 for (i = gargc+1; i < argc; i++) {
126 if ((fp = fopen(argv[i], "r")) == NULL) {
127 sprintf(errmsg,
128 "cannot open scene file \"%s\"", argv[i]);
129 error(SYSTEM, errmsg);
130 }
131 filter(fp, argv[i]);
132 fclose(fp);
133 }
134 else
135 filter(stdin, "standard input");
136 quit(0);
137 }
138
139
140 quit(status) /* exit with status */
141 int status;
142 {
143 int rtstat;
144
145 rtstat = close_process(rt.pd);
146 if (status == 0)
147 if (rtstat < 0)
148 error(WARNING,
149 "unknown return status from rtrace process");
150 else
151 status = rtstat;
152 exit(status);
153 }
154
155
156 init() /* start rtrace and set up buffers */
157 {
158 extern int o_face(), o_sphere(), o_ring();
159 int maxbytes;
160 /* set up object functions */
161 ofun[OBJ_FACE].funp = o_face;
162 ofun[OBJ_SPHERE].funp = o_sphere;
163 ofun[OBJ_RING].funp = o_ring;
164 /* set up signal handling */
165 signal(SIGPIPE, quit);
166 /* start rtrace process */
167 errno = 0;
168 maxbytes = open_process(rt.pd, rtargv);
169 if (maxbytes == 0) {
170 eputs(rtargv[0]);
171 eputs(": command not found\n");
172 exit(1);
173 }
174 if (maxbytes < 0)
175 error(SYSTEM, "cannot start rtrace process");
176 rt.bsiz = maxbytes/(6*sizeof(float));
177 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
178 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
179 if (rt.buf == NULL || rt.dest == NULL)
180 error(SYSTEM, "out of memory in init");
181 rt.nrays = 0;
182 /* set up urand */
183 initurand(16384);
184 }
185
186
187 eputs(s) /* put string to stderr */
188 register char *s;
189 {
190 static int midline = 0;
191
192 if (!*s) return;
193 if (!midline) {
194 fputs(progname, stderr);
195 fputs(": ", stderr);
196 }
197 fputs(s, stderr);
198 midline = s[strlen(s)-1] != '\n';
199 }
200
201
202 wputs(s) /* print warning if enabled */
203 char *s;
204 {
205 if (warnings)
206 eputs(s);
207 }
208
209
210 filter(infp, name) /* process stream */
211 register FILE *infp;
212 char *name;
213 {
214 char buf[512];
215 FILE *pfp;
216 register int c;
217
218 while ((c = getc(infp)) != EOF) {
219 if (isspace(c))
220 continue;
221 if (c == '#') { /* comment/options */
222 buf[0] = c;
223 fgets(buf+1, sizeof(buf)-1, infp);
224 xoptions(buf, name);
225 } else if (c == '!') { /* command */
226 buf[0] = c;
227 fgetline(buf+1, sizeof(buf)-1, infp);
228 if ((pfp = popen(buf+1, "r")) == NULL) {
229 sprintf(errmsg, "cannot execute \"%s\"", buf);
230 error(SYSTEM, errmsg);
231 }
232 filter(pfp, buf);
233 pclose(pfp);
234 } else { /* object */
235 ungetc(c, infp);
236 xobject(infp, name);
237 }
238 }
239 }
240
241
242 xoptions(s, nm) /* process options in string s */
243 char *s;
244 char *nm;
245 {
246 extern FILE *freopen();
247 char buf[64];
248 int nerrs = 0;
249 register char *cp;
250
251 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
252 fputs(s, stdout); /* not for us */
253 return;
254 }
255 cp = s+10;
256 while (*cp) {
257 switch (*cp) {
258 case ' ':
259 case '\t':
260 case '\n':
261 cp++;
262 continue;
263 case 'm': /* material name */
264 if (*++cp != '=')
265 break;
266 if (!*++cp)
267 break;
268 atos(thisillum.matname, MAXSTR, cp);
269 cp = sskip(cp);
270 if (!(thisillum.flags & IL_DATCLB)) {
271 strcpy(thisillum.datafile, thisillum.matname);
272 thisillum.dfnum = 0;
273 }
274 continue;
275 case 'f': /* data file name */
276 if (*++cp != '=')
277 break;
278 if (!*++cp) {
279 strcpy(thisillum.datafile,thisillum.matname);
280 thisillum.dfnum = 0;
281 thisillum.flags &= ~IL_DATCLB;
282 continue;
283 }
284 atos(thisillum.datafile, MAXSTR, cp);
285 cp = sskip(cp);
286 thisillum.dfnum = 0;
287 thisillum.flags |= IL_DATCLB;
288 continue;
289 case 'i': /* include material */
290 case 'e': /* exclude material */
291 if (cp[1] != '=')
292 break;
293 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
294 cp += 2;
295 atos(matcheck, MAXSTR, cp);
296 cp = sskip(cp);
297 continue;
298 case 'a': /* use everything */
299 cp = sskip(cp);
300 matselect = S_ALL;
301 continue;
302 case 'n': /* use nothing (passive) */
303 cp = sskip(cp);
304 matselect = S_NONE;
305 continue;
306 case 'c': /* color calculation */
307 if (*++cp != '=')
308 break;
309 switch (*++cp) {
310 case 'a': /* average */
311 thisillum.flags = (thisillum.flags|IL_COLAVG)
312 & ~IL_COLDST;
313 break;
314 case 'd': /* distribution */
315 thisillum.flags |= (IL_COLDST|IL_COLAVG);
316 break;
317 case 'n': /* none */
318 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
319 break;
320 default:
321 goto opterr;
322 }
323 cp = sskip(cp);
324 continue;
325 case 'd': /* point sample density */
326 if (*++cp != '=')
327 break;
328 if (!isintd(++cp, " \t\n"))
329 break;
330 thisillum.sampdens = atoi(cp);
331 cp = sskip(cp);
332 continue;
333 case 's': /* point super-samples */
334 if (*++cp != '=')
335 break;
336 if (!isintd(++cp, " \t\n"))
337 break;
338 thisillum.nsamps = atoi(cp);
339 cp = sskip(cp);
340 continue;
341 case 'l': /* light sources */
342 cp++;
343 if (*cp == '+')
344 thisillum.flags |= IL_LIGHT;
345 else if (*cp == '-')
346 thisillum.flags &= ~IL_LIGHT;
347 else
348 break;
349 cp++;
350 continue;
351 case 'b': /* brightness */
352 if (*++cp != '=')
353 break;
354 if (!isfltd(++cp, " \t\n"))
355 break;
356 thisillum.minbrt = atof(cp);
357 if (thisillum.minbrt < 0.)
358 thisillum.minbrt = 0.;
359 cp = sskip(cp);
360 continue;
361 case 'o': /* output file */
362 if (*++cp != '=')
363 break;
364 if (!*++cp)
365 break;
366 atos(buf, sizeof(buf), cp);
367 cp = sskip(cp);
368 if (freopen(buf, "w", stdout) == NULL) {
369 sprintf(errmsg,
370 "cannot open output file \"%s\"", buf);
371 error(SYSTEM, errmsg);
372 }
373 doneheader = 0;
374 continue;
375 case '!': /* processed file! */
376 sprintf(errmsg, "(%s): already processed!", nm);
377 error(WARNING, errmsg);
378 matselect = S_NONE;
379 return;
380 }
381 opterr: /* skip faulty option */
382 cp = sskip(cp);
383 nerrs++;
384 }
385 /* print header? */
386 checkhead();
387 /* issue warnings? */
388 if (nerrs) {
389 sprintf(errmsg, "(%s): %d error(s) in option line:",
390 nm, nerrs);
391 error(WARNING, errmsg);
392 wputs(s);
393 printf("# %s: the following option line has %d error(s):\n",
394 progname, nerrs);
395 }
396 /* print pure comment */
397 printf("# %s", s+2);
398 }
399
400
401 printopts() /* print out option default values */
402 {
403 printf("m=%-15s\t\t# material name\n", thisillum.matname);
404 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
405 if (thisillum.flags & IL_COLAVG)
406 if (thisillum.flags & IL_COLDST)
407 printf("c=d\t\t\t\t# color distribution\n");
408 else
409 printf("c=a\t\t\t\t# color average\n");
410 else
411 printf("c=n\t\t\t\t# color none\n");
412 if (thisillum.flags & IL_LIGHT)
413 printf("l+\t\t\t\t# light type on\n");
414 else
415 printf("l-\t\t\t\t# light type off\n");
416 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
417 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
418 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
419 }
420
421
422 printhead(ac, av) /* print out header */
423 register int ac;
424 register char **av;
425 {
426 putchar('#');
427 while (ac-- > 0) {
428 putchar(' ');
429 fputs(*av++, stdout);
430 }
431 fputs("\n#@mkillum !\n", stdout);
432 }
433
434
435 xobject(fp, nm) /* translate an object from fp */
436 FILE *fp;
437 char *nm;
438 {
439 OBJREC thisobj;
440 char str[MAXSTR];
441 int doit;
442 /* read the object */
443 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
444 goto readerr;
445 if (fgetword(str, MAXSTR, fp) == NULL)
446 goto readerr;
447 /* is it an alias? */
448 if (!strcmp(str, ALIASID)) {
449 if (fgetword(str, MAXSTR, fp) == NULL)
450 goto readerr;
451 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
452 if (fgetword(str, MAXSTR, fp) == NULL)
453 goto readerr;
454 printf("\t%s\n", str);
455 return;
456 }
457 thisobj.omod = OVOID; /* unused field */
458 if ((thisobj.otype = otype(str)) < 0) {
459 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
460 error(USER, errmsg);
461 }
462 if (fgetword(str, MAXSTR, fp) == NULL)
463 goto readerr;
464 thisobj.oname = str;
465 if (readfargs(&thisobj.oargs, fp) != 1)
466 goto readerr;
467 thisobj.os = NULL;
468 /* check for translation */
469 switch (matselect) {
470 case S_NONE:
471 doit = 0;
472 break;
473 case S_ALL:
474 doit = 1;
475 break;
476 case S_ELEM:
477 doit = !strcmp(thisillum.altmat, matcheck);
478 break;
479 case S_COMPL:
480 doit = strcmp(thisillum.altmat, matcheck);
481 break;
482 }
483 doit = doit && issurface(thisobj.otype);
484 /* print header? */
485 checkhead();
486 /* process object */
487 if (doit)
488 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
489 else
490 printobj(thisillum.altmat, &thisobj);
491 /* free arguments */
492 freefargs(&thisobj.oargs);
493 return;
494 readerr:
495 sprintf(errmsg, "(%s): error reading scene", nm);
496 error(USER, errmsg);
497 }
