root/radiance/ray/src/gen/mkillum.c
Revision: 2.43
Committed: Mon Jul 20 15:54:29 2020 UTC (4 years, 10 months ago) by greg
Changes since 2.42: +4 -2 lines
fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15
due to broken flockfile() implementation -- workaround is better, anyway
2 static const char RCSid[] = "$Id: mkillum.c,v 2.42 2016/09/15 22:34:41 greg Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "paths.h" /* win_popen() */
12 #include "mkillum.h"
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 struct illum_args thisillum = { /* our illum and default values */
26 0,
27 DFLMAT,
28 DFLDAT,
29 0,
30 VOIDID,
31 SAMPDENS,
32 NSAMPS,
33 0.,
34 };
35
36 char matcheck[MAXSTR]; /* current material to include or exclude */
37 int matselect = S_ALL; /* selection criterion */
38
39 int gargc; /* global argc */
40 char **gargv; /* global argv */
41
42 int doneheader = 0; /* printed header yet? */
43 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
44
45 int warnings = 1; /* print warnings? */
46
47 void init(char *octnm, int np);
48 void filter(FILE *infp, char *name);
49 void xoptions(char *s, char *nm);
50 void printopts(void);
51 void printhead(int ac, char **av);
52 void xobject(FILE *fp, char *nm);
53
54
55 int
56 main( /* compute illum distributions using rtrace */
57 int argc,
58 char *argv[]
59 )
60 {
61 int nprocs = 1;
62 FILE *fp;
63 int rval;
64 int i;
65 /* set global arguments */
66 gargv = argv;
67 progname = gargv[0];
68 /* set up rendering defaults */
69 dstrsrc = 0.5;
70 directrelay = 3;
71 ambounce = 2;
72 /* get options from command line */
73 for (i = 1; i < argc; i++) {
74 while ((rval = expandarg(&argc, &argv, i)) > 0)
75 ;
76 if (rval < 0) {
77 sprintf(errmsg, "cannot expand '%s'", argv[i]);
78 error(SYSTEM, errmsg);
79 }
80 if (argv[i][0] != '-')
81 break;
82 if (!strcmp(argv[i], "-w")) {
83 warnings = 0;
84 continue;
85 }
86 if (!strcmp(argv[i], "-n")) {
87 nprocs = atoi(argv[++i]);
88 if (nprocs <= 0)
89 error(USER, "illegal number of processes");
90 continue;
91 }
92 if (!strcmp(argv[i], "-defaults")) {
93 printopts();
94 print_rdefaults();
95 quit(0);
96 }
97 rval = getrenderopt(argc-i, argv+i);
98 if (rval < 0) {
99 sprintf(errmsg, "bad render option at '%s'", argv[i]);
100 error(USER, errmsg);
101 }
102 i += rval;
103 }
104 gargc = ++i;
105 /* add "mandatory" render options */
106 do_irrad = 0;
107 if (gargc > argc || argv[gargc-1][0] == '-')
108 error(USER, "missing octree argument");
109 /* else initialize and run our calculation */
110 init(argv[gargc-1], nprocs);
111 if (gargc < argc) {
112 if (gargc == argc-1 || argv[gargc][0] != '<' || argv[gargc][1])
113 error(USER, "use '< file1 file2 ..' for multiple inputs");
114 for (i = gargc+1; i < argc; i++) {
115 if ((fp = fopen(argv[i], "r")) == NULL) {
116 sprintf(errmsg,
117 "cannot open scene file \"%s\"", argv[i]);
118 error(SYSTEM, errmsg);
119 }
120 filter(fp, argv[i]);
121 fclose(fp);
122 }
123 } else
124 filter(stdin, "standard input");
125 quit(0);
126 return 0; /* pro forma return */
127 }
128
129
130 void
131 init(char *octnm, int np) /* start rendering process(es) */
132 {
133 /* set up signal handling */
134 signal(SIGINT, quit);
135 #ifdef SIGHUP
136 signal(SIGHUP, quit);
137 #endif
138 #ifdef SIGTERM
139 signal(SIGTERM, quit);
140 #endif
141 #ifdef SIGPIPE
142 signal(SIGPIPE, quit);
143 #endif
144 /* start rendering process(es) */
145 ray_pinit(octnm, np);
146 }
147
148
149 void
150 eputs( /* put string to stderr */
151 char *s
152 )
153 {
154 static int midline = 0;
155
156 if (!*s) return;
157 if (!midline) {
158 fputs(progname, stderr);
159 fputs(": ", stderr);
160 }
161 fputs(s, stderr);
162 midline = s[strlen(s)-1] != '\n';
163 }
164
165
166 void
167 wputs(s) /* print warning if enabled */
168 char *s;
169 {
170 if (warnings)
171 eputs(s);
172 }
173
174
175 void
176 quit(ec) /* make sure exit is called */
177 int ec;
178 {
179 if (ray_pnprocs > 0) /* close children if any */
180 ray_pclose(0);
181 else if (ray_pnprocs < 0)
182 _exit(ec); /* avoid flush() in child */
183 exit(ec);
184 }
185
186
187 void
188 filter( /* process stream */
189 FILE *infp,
190 char *name
191 )
192 {
193 char buf[512];
194 FILE *pfp;
195 int c;
196
197 while ((c = getc(infp)) != EOF) {
198 if (isspace(c))
199 continue;
200 if (c == '#') { /* comment/options */
201 buf[0] = c;
202 fgets(buf+1, sizeof(buf)-1, infp);
203 xoptions(buf, name);
204 } else if (c == '!') { /* command */
205 buf[0] = c;
206 fgetline(buf+1, sizeof(buf)-1, infp);
207 if ((pfp = popen(buf+1, "r")) == NULL) {
208 sprintf(errmsg, "cannot execute \"%s\"", buf);
209 error(SYSTEM, errmsg);
210 }
211 filter(pfp, buf);
212 pclose(pfp);
213 } else { /* object */
214 ungetc(c, infp);
215 xobject(infp, name);
216 }
217 }
218 }
219
220
221 void
222 xoptions( /* process options in string s */
223 char *s,
224 char *nm
225 )
226 {
227 char buf[64];
228 int negax;
229 int nerrs = 0;
230 char *cp;
231
232 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
233 fputs(s, stdout); /* not for us */
234 return;
235 }
236 cp = s+10;
237 while (*cp) {
238 switch (*cp) {
239 case ' ':
240 case '\t':
241 case '\n':
242 case '\r':
243 case '\f':
244 cp++;
245 continue;
246 case 'm': /* material name */
247 if (*++cp != '=')
248 break;
249 if (!*++cp || isspace(*cp))
250 break;
251 atos(thisillum.matname, MAXSTR, cp);
252 cp = sskip(cp);
253 if (!(thisillum.flags & IL_DATCLB)) {
254 strcpy(thisillum.datafile, thisillum.matname);
255 thisillum.dfnum = 0;
256 }
257 continue;
258 case 'f': /* data file name */
259 if (*++cp != '=')
260 break;
261 if (!*++cp || isspace(*cp)) {
262 strcpy(thisillum.datafile,thisillum.matname);
263 thisillum.dfnum = 0;
264 thisillum.flags &= ~IL_DATCLB;
265 continue;
266 }
267 atos(thisillum.datafile, MAXSTR, cp);
268 cp = sskip(cp);
269 thisillum.dfnum = 0;
270 thisillum.flags |= IL_DATCLB;
271 continue;
272 case 'i': /* include material */
273 case 'e': /* exclude material */
274 if (cp[1] != '=')
275 break;
276 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
277 cp += 2;
278 atos(matcheck, MAXSTR, cp);
279 cp = sskip(cp);
280 continue;
281 case 'a': /* use everything */
282 cp = sskip(cp);
283 matselect = S_ALL;
284 continue;
285 case 'n': /* use nothing (passive) */
286 cp = sskip(cp);
287 matselect = S_NONE;
288 continue;
289 case 'c': /* color calculation */
290 if (*++cp != '=')
291 break;
292 switch (*++cp) {
293 case 'a': /* average */
294 thisillum.flags = (thisillum.flags|IL_COLAVG)
295 & ~IL_COLDST;
296 break;
297 case 'd': /* distribution */
298 thisillum.flags |= (IL_COLDST|IL_COLAVG);
299 break;
300 case 'n': /* none */
301 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
302 break;
303 default:
304 goto opterr;
305 }
306 cp = sskip(cp);
307 continue;
308 case 'd': /* sample density */
309 if (*++cp != '=')
310 break;
311 if (!*++cp || isspace(*cp))
312 continue;
313 if (isintd(cp, " \t\n\r")) {
314 thisillum.sampdens = atoi(cp);
315 } else {
316 error(WARNING, "direct BSDF input unsupported");
317 goto opterr;
318 }
319 cp = sskip(cp);
320 continue;
321 case 's': /* surface super-samples */
322 if (*++cp != '=')
323 break;
324 if (!isintd(++cp, " \t\n\r"))
325 break;
326 thisillum.nsamps = atoi(cp);
327 cp = sskip(cp);
328 continue;
329 case 'l': /* light sources */
330 cp++;
331 if (*cp == '+')
332 thisillum.flags |= IL_LIGHT;
333 else if (*cp == '-')
334 thisillum.flags &= ~IL_LIGHT;
335 else
336 break;
337 cp++;
338 continue;
339 case 'b': /* brightness */
340 if (*++cp != '=')
341 break;
342 if (!isfltd(++cp, " \t\n\r"))
343 break;
344 thisillum.minbrt = atof(cp);
345 if (thisillum.minbrt < 0.)
346 thisillum.minbrt = 0.;
347 cp = sskip(cp);
348 continue;
349 case 'o': /* output file */
350 if (*++cp != '=')
351 break;
352 if (!*++cp || isspace(*cp))
353 break;
354 atos(buf, sizeof(buf), cp);
355 cp = sskip(cp);
356 if (freopen(buf, "w", stdout) == NULL) {
357 sprintf(errmsg,
358 "cannot open output file \"%s\"", buf);
359 error(SYSTEM, errmsg);
360 }
361 doneheader = 0;
362 continue;
363 case '!': /* processed file! */
364 sprintf(errmsg, "(%s): already processed!", nm);
365 error(WARNING, errmsg);
366 matselect = S_NONE;
367 return;
368 }
369 opterr: /* skip faulty option */
370 while (*cp && !isspace(*cp))
371 cp++;
372 nerrs++;
373 }
374 /* print header? */
375 checkhead();
376 /* issue warnings? */
377 if (nerrs) {
378 sprintf(errmsg, "(%s): %d error(s) in option line:",
379 nm, nerrs);
380 error(WARNING, errmsg);
381 wputs(s);
382 printf("# %s: the following option line has %d error(s):\n",
383 progname, nerrs);
384 }
385 /* print pure comment */
386 printf("# %s", s+2);
387 }
388
389 void
390 printopts(void) /* print out option default values */
391 {
392 printf("m=%-15s\t\t# material name\n", thisillum.matname);
393 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
394 if (thisillum.flags & IL_COLAVG)
395 if (thisillum.flags & IL_COLDST)
396 printf("c=d\t\t\t\t# color distribution\n");
397 else
398 printf("c=a\t\t\t\t# color average\n");
399 else
400 printf("c=n\t\t\t\t# color none\n");
401 if (thisillum.flags & IL_LIGHT)
402 printf("l+\t\t\t\t# light type on\n");
403 else
404 printf("l-\t\t\t\t# light type off\n");
405 printf("d=%d\t\t\t\t# density of directions\n", thisillum.sampdens);
406 printf("s=%d\t\t\t\t# samples per direction\n", thisillum.nsamps);
407 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
408 }
409
410
411 void
412 printhead( /* print out header */
413 int ac,
414 char **av
415 )
416 {
417 putchar('#');
418 while (ac-- > 0) {
419 putchar(' ');
420 fputs(*av++, stdout);
421 }
422 fputs("\n#@mkillum !\n", stdout);
423 }
424
425
426 void
427 xobject( /* translate an object from fp */
428 FILE *fp,
429 char *nm
430 )
431 {
432 OBJREC thisobj;
433 char str[MAXSTR];
434 int doit;
435 /* read the object */
436 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
437 goto readerr;
438 if (fgetword(str, MAXSTR, fp) == NULL)
439 goto readerr;
440 /* is it an alias? */
441 if (!strcmp(str, ALIASKEY)) {
442 if (fgetword(str, MAXSTR, fp) == NULL)
443 goto readerr;
444 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
445 if (fgetword(str, MAXSTR, fp) == NULL)
446 goto readerr;
447 printf("\t%s\n", str);
448 return;
449 }
450 thisobj.omod = OVOID; /* unused field */
451 if ((thisobj.otype = otype(str)) < 0) {
452 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
453 error(USER, errmsg);
454 }
455 if (fgetword(str, MAXSTR, fp) == NULL)
456 goto readerr;
457 thisobj.oname = str;
458 if (readfargs(&thisobj.oargs, fp) != 1)
459 goto readerr;
460 thisobj.os = NULL;
461 /* check for translation */
462 switch (matselect) {
463 case S_NONE:
464 doit = 0;
465 break;
466 case S_ALL:
467 doit = 1;
468 break;
469 case S_ELEM:
470 doit = !strcmp(thisillum.altmat, matcheck);
471 break;
472 case S_COMPL:
473 doit = strcmp(thisillum.altmat, matcheck);
474 break;
475 }
476 doit = doit && issurface(thisobj.otype);
477 /* print header? */
478 checkhead();
479 /* process object */
480 if (doit)
481 switch (thisobj.otype) {
482 case OBJ_FACE:
483 my_face(&thisobj, &thisillum, nm);
484 break;
485 case OBJ_SPHERE:
486 my_sphere(&thisobj, &thisillum, nm);
487 break;
488 case OBJ_RING:
489 my_ring(&thisobj, &thisillum, nm);
490 break;
491 default:
492 my_default(&thisobj, &thisillum, nm);
493 break;
494 }
495 else
496 printobj(thisillum.altmat, &thisobj);
497 /* free arguments */
498 freefargs(&thisobj.oargs);
499 return;
500 readerr:
501 sprintf(errmsg, "(%s): error reading input", nm);
502 error(USER, errmsg);
503 }
